vrm_portal:dashboard
vrm_portal:dashboard [2022-04-14 04:09] – [3.1 Inverter controls in VRM] guystewartvrm_portal:dashboard [2023-10-10 09:50] (current) – [1.5. Details per section] sloges
Line 64: Line 64:
   * Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access   * Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access
-  * Phoenix Inverter: Output power on the left axis, Battery voltage on the right axis+  * Inverter: Output power on the left axis, Battery voltage on the right axis
   * Solar Charger: Output power on the left axis, Battery voltage on the right axis.   * Solar Charger: Output power on the left axis, Battery voltage on the right axis.
 Requirements for the kWh production and consumption data are explained [[vrm_portal:faq|]]. Requirements for the kWh production and consumption data are explained [[vrm_portal:faq|]].
-Screenshot of an installation with only a Phoenix Inverter, and thus showing the line diagram:+Screenshot of an installation with only an Inverter, thus showing the line diagram:
 {{ :vrm_portal:line_diagram.png?direct |}} {{ :vrm_portal:line_diagram.png?direct |}}
Line 116: Line 116:
 ===== 3. Control your devices in VRM ===== ===== 3. Control your devices in VRM =====
-VRM offers control over some of your Victron devices, straight from the VRM dashboard. With this feature, you can quickly adjust the settings of your inverter, ESS or relay switches, without needing to open the remote console. +VRM offers control over some of your Victron devices, straight from the VRM dashboard. With this feature, you can quickly adjust the settings ESS or relay switches, without needing to open the remote console.
 To access it, head to your VRM dashboard. To access it, head to your VRM dashboard.
Line 126: Line 126:
 {{:vrm_portal:vrm-controls-1.jpg?800|}} {{:vrm_portal:vrm-controls-1.jpg?800|}}
-{{:vrm_portal:vrm-controls-2.jpg?800|}}+{{:vrm_portal:vrm-controls-2-revised.jpg?800|}}
 ==== 3.1 Inverter controls in VRM ==== ==== 3.1 Inverter controls in VRM ====
-Note - while initially available, inverter controls have since been removed and are not currently accessible via the controls feature. +VE.Bus Inverter controls can be made available on the VRM Dashboard, but require an additional step to enable in the Settings for that specific VRM Installation. This is to prevent accidentally switching off the system.
 +{{:vrm_portal:victron_enable_inverter_control.jpg?800|}}
 +It is ONLY recommended to enable this easy system shutdown control for small systems in non-critical environments. It is STRONGLY recommended to leave this feature disabled for large mission critical systems, or where there are multiple users with access to the Admin controls.
 +Once enabled, you can access the settings via the control button.
 +{{:vrm_portal:inverter_control_step_1.jpg?800|}}
 +{{:vrm_portal:inverter_control_step_2.jpg?800|}}
 +Note - This feature is only available for VE.Bus models, is not available for VE.Direct, or VE.Can inverters. Also, there is a limitation where these controls are not available when using a Digital Multi Control, or VE.Bus BMS v1 in the system.
 ==== 3.2 ESS controls in VRM ==== ==== 3.2 ESS controls in VRM ====
vrm_portal/dashboard.1649909347.txt.gz · Last modified: by guystewart
