vrm_portal:dashboard
| vrm_portal:dashboard [2020-09-29 06:51] – mvader | vrm_portal:dashboard [2023-10-10 09:50] (current) – [1.5. Details per section] sloges | ||
| Line 18: | Line 18: | ||
| - | ==== 1.4. Details per section ==== | + | ==== 1.5. Details per section ==== |
| - | === 1.4.1 Schematic visualisation === | + | === 1.5.1 Schematic visualisation === |
| Line 26: | Line 26: | ||
| The information shown adapts itself to the system installed. For systems without an inverter/ | The information shown adapts itself to the system installed. For systems without an inverter/ | ||
| - | === 1.4.2 Battery block === | + | === 1.5.2 Battery block === |
| - | Intended | + | The purpose of this part of the dashboard is to show all available batteries, |
| - | To see this information, the following must be done: | + | For each of the configured battery, the VRM Portal will show its name, the voltage, current, and state of charge. |
| - | | + | Configuration: |
| - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | ||
| - Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | - Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | ||
| - | The settings in the GX Device allow configuration | + | This is the main configuration |
| - | - to hide or show it | + | {{ : |
| - | - to name it | + | |
| - | The menu will list all available battery measurements: from all connected | + | It lists all available battery measurements. Including |
| - | Here is a screen shot main menu: | + | The GX Device allows configuration of each of the available battery measurements: |
| - | {{ : | + | - to hide or show it |
| + | - to name it | ||
| - | And here is how to configure an entry: | + | Screenshot of detailed menu: |
| - | === 1.4.3 Historical data === | + | === 1.5.3 Historical data === |
| Depending on available information, | Depending on available information, | ||
| Line 62: | Line 64: | ||
| * Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access | * Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access | ||
| - | * Phoenix | + | * Inverter: Output power on the left axis, Battery voltage on the right axis |
| * Solar Charger: Output power on the left axis, Battery voltage on the right axis. | * Solar Charger: Output power on the left axis, Battery voltage on the right axis. | ||
| Requirements for the kWh production and consumption data are explained [[vrm_portal: | Requirements for the kWh production and consumption data are explained [[vrm_portal: | ||
| - | Screenshot of an installation with only a Phoenix | + | Screenshot of an installation with only an Inverter, thus showing the line diagram: |
| Line 86: | Line 88: | ||
| ==== 2.2 Disabling the realtime data feature ==== | ==== 2.2 Disabling the realtime data feature ==== | ||
| - | Within a few weeks, a switch will be added to the Settings | + | It is possible |
| + | Examples of when you want to disable real time data are: | ||
| * To keep data usage to a minimum, while keeping the VRM Two way communication setting enabled to be able to remotely configure & firmware update | * To keep data usage to a minimum, while keeping the VRM Two way communication setting enabled to be able to remotely configure & firmware update | ||
| Line 95: | Line 99: | ||
| * A GX Device, with Venus OS v2.60 or later | * A GX Device, with Venus OS v2.60 or later | ||
| * Good internet connection | * Good internet connection | ||
| - | * Settings -> VRM Portal -> Two way communication must be enabled | ||
| * Sufficient CPU resources (see below) | * Sufficient CPU resources (see below) | ||
| + | * Settings -> VRM Portal -> Two way communication must be enabled | ||
| ==== 2.4 GX Device CPU Load ==== | ==== 2.4 GX Device CPU Load ==== | ||
| Line 105: | Line 112: | ||
| + | ===== 3. Control your devices in VRM ===== | ||
| + | VRM offers control over some of your Victron devices, straight from the VRM dashboard. With this feature, you can quickly adjust the settings ESS or relay switches, without needing to open the remote console. | ||
| + | To access it, head to your VRM dashboard. | ||
| + | In the top right of your installation' | ||
| + | Note: Access to controls requires the 'real time data' connection to your installation. | ||
| + | ==== 3.1 Inverter controls in VRM ==== | ||
| + | VE.Bus Inverter controls can be made available on the VRM Dashboard, but require an additional step to enable in the Settings for that specific VRM Installation. This is to prevent accidentally switching off the system. | ||
| + | It is ONLY recommended to enable this easy system shutdown control for small systems in non-critical environments. It is STRONGLY recommended to leave this feature disabled for large mission critical systems, or where there are multiple users with access to the Admin controls. | ||
| + | Once enabled, you can access the settings via the control button. | ||
| + | Note - This feature is only available for VE.Bus models, is not available for VE.Direct, or VE.Can inverters. Also, there is a limitation where these controls are not available when using a Digital Multi Control, or VE.Bus BMS v1 in the system. | ||
| + | ==== 3.2 ESS controls in VRM ==== | ||
| + | For your ESS system, you can switch your settings between ESS modes ' | ||
| + | As with the inverter settings, you will have 5 seconds to cancel any change in settings before it is sent to the device. | ||
| + | You will also be able to adjust the minimum state of charge. | ||
| + | Note that setting the minimum state of charge will not be possible when the ESS is set to 'keep batteries charged' | ||
| + | ==== 3.3 Manual relay controls in VRM ==== | ||
| + | **This functionality is not yet available.** | ||
| + | We are currently working on enabling toggling manual relays on and off from the controls panel in VRM. We plan to release this in Q3 of 2022. | ||
| + | ==== 3.4 Generator controls in VRM ==== | ||
| + | We are currently working on enabling you to also control your generator from your VRM dashboard. You would then be able to start or stop the generator, or start a timed run for it. We plan to release this in Q3 of 2022. | ||
vrm_portal/dashboard.1601362273.txt.gz · Last modified: by mvader
