vrm_portal:change_log
VRM Portal Changelog
2026-10-19
- Dashboard controls: Fix grid current limit controls not showing up for inverters
- Preferences: Fix the Save button's loading state after a successful save.
2026-10-15
- Device list: Fix remote support port overflow.
2026-10-14 (1.129.0)
- VRM Light: Load the Consumption and Solar sheets in parallel so they appear after one round trip instead of several, which cuts the wait noticeably on mobile connections.
- Event log: Show who wrote a note and its text, for installation notes and, for admins, admin notes.
- Event log: Include the actor name in more events.
- Event log: Add an entry when someone generates or downloads a site report.
- Firmware update: Block updating VE.Bus (Multi/Quattro) devices to firmware 565 or newer when the GX device runs a Venus OS version older than v3.70, and ask to update Venus OS first.
- Firmware update: Reinstall the firmware version a device already runs, without changing the version.
- Dynamic ESS: Show the settings to users with read-only access without letting them change anything; the wizard steps and the on/off switch stay closed to them.
- Dashboard: Hide the “Battery Balancing is scheduled for this day” message when Dynamic ESS is off.
- Dashboard: Show the AI assistant button for every user, and hide it while scrolling on mobile.
- AI Assistant: Open with the current site and page already known.
- AI Assistant: Replace the starter questions on the AI assistant page.
- AI Assistant: Show a deprecation banner on the single-site AI assistant.
- VRM Light: Add a “Learn more” page to the Energy tab of the Dynamic ESS sheet.
- Installation groups: Allow adding a user to a group directly when they are already linked through a team.
- Installation groups: Show a clear message instead of an error when opening an invite link for a team or group you already belong to.
- Notification preferences: Allow users to turn alarm emails back on after unsubscribing.
- Switches: Widen the controls and switches panel on desktop and wrap long switch names.
- Device list: Show the EV charger's own last contact time, matching the dashboard.
- Device list: Show the correct gateway icon for GlobalLink connections.
- EV charging: Allow the paid EV features for users whose vehicles are connected through Node-RED (Enode/Tesla).
- VRM UI: Use the shared dialog component for temporary and custom dialogs (clear alarm, access tokens and others), with the same keyboard and focus behaviour everywhere.
- VRM UI: Support keyboard navigation in select fields with the arrow keys and Enter.
- API: Speed up permission checks on every request.
2026-10-13
2026-10-07 (1.128.0)
- Update colours for success, error and warning texts.
- System Optimisation: Fix blank Chrome print preview.
- System Optimisation: Add economic feasibility disclaimer.
- Dashboard: Fix the dashboard date picker on mobile being silently replaced by a quick range.
2026-10-02
- Advanced: Fix larger CSV exports failing
2026-09-30 (1.127.0)
- Fleet dashboard: Added support for downloading the alarm reports from the VRM fleet monitor over a selected time range.
- VRM in VC: Remove Overview dropdown from the DESS tab in the Data tab.
- VRM in VC: Fix and adjust rule to show Solar card in Dashboard tab.
- Preferences: Fix Turkish language name.
- VRM in VC: Fix the missing legend items under the graphs in the Data sheets.
- DESS: Fix untranslated Dynamic ESS config title.
- Profile: Remove the language setting from the profile page.
- Navbar: Show the Access management item to all users, also when they are not in a team or installation group.
- Event Log: Show which type of device was deleted.
- VRM in VC: Replace the arrow icons on the Grid and Solar bottom sheets with battery, sun and grid icons.
- VRM in VC: Show a fade, a cut-off card and a scrollbar when a bottom sheet has more to scroll.
- Teams and Installation Groups: Hide the access level controls from users who are not allowed to change access levels.
- Notes: YouTube and Vimeo videos embedded in installation notes show and play again in the notes view; Vimeo videos are embedded too.
2026-09-28
- Advanced: Fix error messages when trying to download an invalid report
2026-09-23 (1.126.0)
- iOS: Fix the main graph jumping on the dashboard.
- VRM in VictronConnect: Fix the Tanks, Irradiance and Temperature bottom sheets closing when a new option is selected.
- VRM in VictronConnect: Fix the DESS “Energy” and “Costs and earnings” charts in the Data tab not showing the entire day.
- VRM in VictronConnect: Fix a single battery appearing twice in the battery bottom sheet when the GX device reports the same service more than once.
2026-09-21 (1.125.0)
- VRM in VictronConnect: Restyle and expand the UI with new elements and interactions.
- Installation Groups: Allow appointing teams as group managers.
- Installation Groups: The “Edit group” and “Edit team” buttons are renamed to “Group settings” and “Team settings”.
- Session: Added support for logging out of all other devices to prevent unauthorised access.
- Dashboard: AC loads are hidden on the input side.
- Dashboard: Read-only users no longer see the photo and note action buttons, since they cannot use them.
- Dynamic ESS: The energy graph now draws a zero line for hours without energy bars, so those hours read as zero instead of empty space.
- Photos: HEIC and HEIF photos, the iPhone default format, are now accepted when uploading installation photos in the portal or through the API.
- Event log: Every alarm rule change is now recorded in detail: the metric and device, the thresholds, whether the rule is enabled and the notification delay, for created, edited and deleted rules.
- Access requests: Users who ask for access to an installation or a team are now told by email when the request is declined, and the decision is recorded in the event log.
- Access requests: Admin email addresses are no longer listed in the notification email.
- Switches: Added support for generic inputs.
- Preferences: Replace the remaining native select elements with the shared select components.
- iOS: Add support for password manager autofill for VRM login.
- iOS: Fix the remote console closing element.
- Site share: Fix changing settings permissions.
2026-09-10
- Dashboard: Fix Dynamic ESS chart x-axis misalignment.
- Access Management: Fix access level change confirmation dialog button size.
- Garmin: Improved switch discoverability to match VRM Portal.
- Garmin: Improved rendering of long values above slider switches to avoid overlap with the name.
2026-09-09 (1.124.0)
- Dashboard: Show DC sources (alternator, fuel cell, DC generator) as cards with history and power flow, like the GX GUI v2.
- Dashboard: Show the DC Power / DC Loads card in the parallel (ESS) layout too, placed beside the battery when there is room and below it otherwise.
- Dashboard: Update the weather and card icons in VRM and VRM Light to the new design.
- Dynamic ESS Settings: Allow different price formulas for Saturday and Sunday.
- Dynamic ESS Settings: Add the option to disable solar production at low buy prices.
- Dynamic ESS Settings: New configurations now have “My prices can be negative” enabled by default.
- Installation settings: Allow admins to unlink any installation group.
- Access management: Remove an individual user's access to an installation even when they are also linked through a team or installation group; the team or group keeps its access.
- Installation Notes: Fix notes not being editable immediately after adding them.
- Fleet monitor: Add a widget listing sites with zero consumption for some time.
- Multi-site AI assistant: Add widget creation to the multi-site assistant.
- System optimisation: Include the site name in the page title.
- Installation groups: Allow user teams to be assigned as group managers.
2026-09-02 (1.123.0)
- User Teams & Installation Groups: Complete redesign and rehaul of the Teams and Groups (Access Management) pages.
- User Teams & Installation Groups: Allow adding a new site to a user team or installation group when creating it.
- User Teams & Installation Groups: Add bulk removal of sites and groups from a user team, with a confirmation step.
- Preferences: Add a troubleshooting guide for when notifications are enabled but not arriving, with the community forum as fallback.
- Dashboard: Fix the chart loading state for future ranges.
- Dashboard: Fix sell & buy prices interval if they mismatch in timeframes (15 min vs 1 hour intervals).
- Geofence: Improve user experience by updating the “Save” button disabled state and Mapbox shape drawer.
- Android App: Fix the photo picker router for uploading.
2026-08-31
- Android and iOS: Add Switches widget
2026-08-26
2026-08-19 (1.122.0)
- Dashboard: Replace the DESS card icons.
- Dashboard: Fix “Part of X groups” on the installation dashboard to show the site's groups, not the viewer's.
- Invitations: Fix invite links losing the + in email addresses.
- Installation Notes: Keep multiple notes per installation, with author and date.
- Improve the Add installation and Replace GX device flow so device data is only requested when it is needed.
- Improve VRM API response times across all requests through faster token validation and request routing.
- Improve the processing speed of solar forecast imports and EV trip detection.
- Settings: Prompt to delete the replaced GX's site after a GX swap.
- Settings and Events: Hide admin, technician and support staff events from read-only users.
2026-08-14
- Navigation (Language selector): Fix Turkish language name.
2026-08-12 (1.121.0)
- Advanced: Show a single reset zoom button at the top of the page when zoomed in.
- Preferences: Fix account deletion flow for users migrated to Victron OneID.
- Dashboard: Time picker update for hourly based intervals.
- Watch: iOS watch app Switches control.
- Mobile: Show the SoC forecast in the widgets widgets.
- Event log: Switch control changes (toggles, dimming, mode changes) are now recorded in the event log, showing who made the change, when, and the new state.
- Reports: The EVCS report PDF export now includes all pages instead of only the currently viewed page.
- Tags: Add tags to multiple installations in bulk.
- Installation general settings: The installation general settings page has been migrated to Vue 3.
2026-08-07
- Diagnostics: Add values for for ns{0 ..11} for easier troubleshooting.
2026-08-05 (1.120.0)
- Tags: No longer automatically create a tag for the team or installation group a site belongs to.
- Access management: Show “Victron Support Staff” instead of the employee's personal name in e-mails that are sent when Victron staff manages access to your installation or team.
- Installation groups: Improve the response time of updating installation groups that contain many installations.
- Dashboard: Fix the forecasted total sometimes showing a lower bound below the already measured total.
- Navigation: Add a multi-site AI assistant to the primary navbar for users with 10 or more sites.
- Advanced: A “Loading widgets…” text is shown while widgets are loading.
2026-08-04
- Dashboard: Fix installation data not updating every minute anymore.
2026-07-30
- Fix Safari zooming in the page on inputs and text areas.
2026-07-29 (1.119.0)
- Dashboard: Fixed showing the custom name of the 4th MultiRS tracker.
- VictronConnect: Added a VRM registration flow within VictronConnect.
- VictronConnect: Added a switches button and corresponding panel.
- Teams/Groups: Installations can now be middle-/Cmd-clicked to open in a new tab.
- Group dashboard: Improved visibility of site names in the bar chart.
- Notifications: Fixed invite emails not being sent due to an incorrect default setting.
2026-07-23
- Switches: Fix dropdown values being hidden in the card.
- Navigation (Notifications): Fix the Preferences button tooltip getting stuck on iOS after tapping it.
2026-07-22 (1.118.0)
- Dashboard: Improve dashboard cards wrapping.
- Advanced: Restrict quick ranges to at most 6 months.
- Dashboard: Show Dynamic ESS charts display at 15 minute intervals for 15 minute price users.
- Teams: Update the design of the “Linked installations and groups” table for mobile.
- Dashboard: Fix slow EV tile map loading.
- Dashboard: Update SolarSense tile layout for configured and unconfigured sensors.
- Switches: Change the style of the switches to match the Venus OS design.
- Switches: Fix the custom naming of GX relays.
2026-07-17
- Fix timezone mapping for 3 segment timezones such as America/Kentucky/Louisville.
2026-07-15 (1.117.0)
- Notifications: Added a conditional reminder to charge your EV.
- Mobile dashboard: Moved the “show details” icon to its permanent spot higher up on the card.
- API: Configuration values are now cached to slightly improve performance across all requests.
- EV: Installation admins can now unlink any linked EV from a site, with a confirmation step.
- Dashboard: Grid and AC-load widgets now refresh after VE.Bus communication recovers.
- Account: MFA verification is now required when deleting a VRM account.
- Dashboard: Non-VE.Bus systems now show a dedicated passthrough modal.
- EV: Linking an EV service now correctly redirects back to the mobile app.
- Add installation: A new installation can now be assigned to a team.
- Installation settings: The page header now updates with the new installation name on save.
- Remote console: Added portrait mode support.
- Units: Added miles support for distance across VRM.
- Installation dashboard: The “Last updated” timestamp now updates live from MQTT instead of the database log interval.
- Teams: Access request notifications now show the requester's email so owners can verify identity.
- Alarm rules: The permissions table now shows each user's email and push notification status.
- Notifications: Added an expand-all/collapse-all control for bulk alarm rule configuration.
- Notifications: Redesigned the Preferences page with a per-site/per-group alarm status overview.
- Installation groups: Group dashboards now appear on the homepage and site dashboard for better visibility.
- API Login: Return deprecation message when user and password are used to authenticate against Victron OneID.
2026-07-09
- Device list: Fix Unlink vehicle button placement.
2026-07-08 (1.116.0)
- iOS Watch App: Redesign complications.
- Advanced: Give options in filter bars a distinctive background colour.
- Device List: Don't show remote support IP when remote support is disabled.
- Microgrid dashboard: Add a per-installation table showing battery SoC, AC power, voltage, frequency, per-phase power and tank levels.
- Microgrid dashboard: Stream per-installation data in near real time over MQTT.
- Microgrid dashboard: Update the site metrics live, refreshing values automatically without reloading the page.
- Group dashboards: Add an “Open installation” tooltip on installation names in charts and tables.
- Advanced: Skip EV GPS requests that would return a 403 based on the vehicle's privacy settings.
- Teams: Fix a team still appearing in the list after you remove yourself and refresh the page.
- Group dashboards: Show a window icon next to installation names on mobile so it's clear they're tappable to open the installation.
- Integrations: Remove an EV's historical locations once location storage is turned off.
2026-07-03
- Dashboard: Update icon for the switches panel to the one used by the GUI v2.
2026-07-01 (1.115.0)
- Vehicle integration: make linked vehicles more prominent on the page for users with linked vehicles.
- iOS: version 3.035 watch app complications and adjustment.
- Advanced AI assistant: fix viewport height issue causing the input to be hidden on iOS.
- Devices: Add support for the Cerbo GX Mk3 (product ID 0xC016), shown with the Cerbo GX icon across the portal.
- Devices: Add support for the Nucleo GX (product ID 0xC015), shown with a dedicated Nucleo GX icon and selectable in Add Installation.
- Fleet monitor: Add a report download (csv, xlsx) option for alarms.
- Installation group (dashboard): Show calendar dates in group dashboard event logs that have events.
- Dashboard API: Fix EVCS total calculation of non-grouped multiple instances.
- Vehicle integration: Scroll to and highlight vehicle permissions after linking a vehicle.
- Vehicle integration: Filter vehicle list by selected brand card on the “Link your vehicle” page.
- Event log: Show which user updated dynamic ESS settings.
- Multi-site AI assistant: Replace the AI assistant's in-chat icon.
- Installation groups: Fix close button position in the 'Add new members' modal.
- Dynamic ESS: Change the style of links.
2026-06-30
- Dashboard: Fixed an issue where EVCS data wouldn't show up correctly in specific cases with multiple EVCS's
2026-06-24
- Installation group dashboard: Remove breadcrumbs and add back button.
2026-06-17
- Advanced: Align state-type widget x-axis with other widget types.
- Dashboard: Support multiple grid meters in the system sizing layout.
- Event log: Add events related to payments for paid features.
- Installation group: Order installations in the Installation Group page alphabetically.
- Teams: Allow all team members to view installations within their team.
2026-06-14
- Advanced: Fix the fit of the widgets in fullscreen mode.
2026-06-10
- Event log: Add the event log entries for the AC system controls.
- System optimisation: Add warning for misconfigured sites and additional information on the “Optimising…” modal.
- System optimisation: Set default timezone to installation timezone instead of browser.
- Devices: Show the Multi RS icon for Multi RS devices even when they act as a PV Inverter, while third-party PV Inverters keep the generic PV Inverter icon.
- Dashboard: Fix EV status and power flow on mobile devices.
2026-06-09
- Dashboard: Fix “Total” series not toggling on the dashboard Grid Meter Combined widget (System sizing layout).
- Teams: Fix text misalignment in “Add members” modal
2026-06-08
- Installation group dashboard: Fix cards not displaying total values and chart displaying incorrect production and consumption values for “Today”.
2026-06-05
- Reports: Add visual progress bars to the new Hybrid Genset report.
- Reports: Fix missing currency validation, making recurring reporting fail.
2026-06-04
- Navigation: Show alarms in the notifications panel.
- Teams and installation groups: Fix toast error in teams details and installation groups details page.
- Event log: Make the search work more consistently and for all languages.
2026-06-03 (1.112.0)
- Advanced: Adjusted tooltip approach for the advanced page to improve visibility of the charts.
- Event log: Group event log filter entries to make them more valuable and easier to understand.
- Devices: Allow installation admins to unlink any linked EV from the device list, with a confirmation step and an event log entry on each unlink.
- Installations: Add an admin-only internal notes tab visible to Victron admin users only, with create, edit and delete actions plus author and timestamp on every note.
Devices: Show the Multi RS icon for Multi RS devices even when they act as a PV Inverter, while third-party PV Inverters keep the generic PV Inverter icon. - #3894
2026-05-28
- Device replacement: Fix the GX device select dropdown and its search keyboard not opening/sizing correctly on iOS Safari and mobile.
- Event logs: Add search across all events and event-type filtering, and synced the datepicker to the timeline for faster navigation.
- Dashboard: Fix certain iOS devices not being able to drag the sliders used in switches.
- Dashboard: Fix the color wheel on switches being slightly clipped on certain iOS devices.
2026-05-27
- Installation groups: Allow site admins to add their site to an installation group via a shareable link.
- Reports: Replace PDF rendering library for Generator reports.
2026-05-20
- Firmware updates: Show firmware release notes and option to download firmware
- Tags: Bring back tags dropdown to show tags from other sites.
- Alarms: Add notification settings link in the user permissions table
- Dashboard: Fix consumption forecasts toggle triggering a full graph refresh.
- Date picker: Adjust date range selection for mobile devices
- Alarm logs: Add link for navigation to alarm rules page
- Alarms: Show the current user at the top of the table with their identifier
- Teams: Allow site admins to grant team access via a shareable link
- Reports: Add EV charging reports
- Reports: Add EV trip reports
- Dashboard: Add note for clamped negative prices
- Installation group dashboard: Added a basic dashboard for regular installation groups
- Device list: Moved the page to Vue 3
- Device list: Make use of the VregLink attribute to determine if a device can be opened in VictronConnect.
- Dashboard: Add panel to remotely control switches via VRM.
2026-05-19
- Diagnostics: Add “Last EV Contact”, “Last EV Charging Update”, and “Last EV Location Update”.
2026-05-13
- Color scheme: Make color scheme more consistent
- Dashboard: Display generator runtime in hours
- Advanced: Update EV location chart
2026-05-04
- Set Alarms: Wrap long usernames to prevent table layout breaking.
- Command K: Fix issue with scroll on mobile.
- DESS: Adding Sell & Buy price for energy graph.
- Reporting: The reporting pages have been migrated to Vue 3 (excluding EVCS).
- Advanced: Use the zoom range for data exports while zoomed in on charts.
- Advanced: Add calculated parameters from 'standard widgets' in custom widgets.
- Advanced: Add Power widgets per tracker for Multi RS.
2026-05-04
- Event log: Fix severity icon now showing in light mode.
2026-04-28
- Dashboard: Cache OpenWeather calls for 15 minutes to reduce usage.
- Dashboard: Cache MapBox Geocoding based on coordinated to reduce usage.
- Dashboard: Always start with the map boxes collapsed.
2026-04-24
- Preferences: Fix an issue where SMS tokens were being sent when visiting the profile page
2026-04-22
- Dashboard: Show how different energy sources contributing to my consumption.
- Navigation (Notifications): Decrease size of text shown after accepting/declining a team invite
- AI Agent: A multi-site agent page has been added
- Dashboard: Improved the UI of the Show details element
- Installation groups: Allow users to create microgrid installation groups
- Forecasts & DESS: Allow users to adjust their consumption forecast on the live-feed chart
- Advanced: Add Voltage and Current widgets per tracker for the Multi RS devices.
- Remote console: Fix the keyboard not showing in Safari for iOS 26.4.1 or newer.
2026-04-16
- Dashboard: Count Generator-coupled PV in Total solar
- Dashboard & Advanced: Show Virtual EVs created from Node-RED
2026-04-14
- Mobile: Fix graphs not loading for older iOS devices.
2026-04-11
- Advanced: Add L2 & L3 data to 'System - Critical Loads' widget.
2026-04-08
- Navigation: Fix notifications badge positioning.
- Dashboard: Fix Solar Forecast tollorence + Display of it.
- Dashboard: Add logic that prevents unnecessary chart data queries on mobile dashboard and VC embed pages.
- Advanced: Add cell difference line in tooltip for BMS Min/Max Cell Voltage widgets.
- Firmware updates: Bring back 'waiting for reconfiguration' success message after VE.bus firmware update.
- Firmware updates: Remove rounding from progress.
2026-04-07
- Advanced: Fix 'apparent power' not showing range values while the slider is enabled.
2026-04-02
- Graphs: Fix issue where pre-Summer-Time ranges had wrong hours in graphs on dashboard and in the widgets
2026-04-01
- Dashboard: Fix Solar Forecast tolerance + Display of it
- Firmware updates: Round progress percentage to full number
2026-03-31
- Add Installation: Redirect to the user's site when it's already connected.
2026-03-27
- Firmware update: Added a missing translation to the Firmware update page.
- Preferences: Fixed an incorrect validation error in the MFA setup for SMS verification.
2026-03-20
- Garmin Watch APP: New release featuring switch controls, a new view with today's totals for a site, using totals for complications, as well as adding favorite site settings and complication site choosing to the APP settings menu
2026-03-19
- Changing Passwords: Change to realtime password validation & fix issue where missing a special character would not show a clear error.
2026-03-18
- Dashboard: system sizing installations now display separate energy meter cards in the VC embedded view instead of the legacy dashboard layout.
- Dashboard: all widgets now follow a consistent expandable behaviour and visual hierarchy to ensure key information is presented uniformly.
- Dashboard: users can now choose which temperature sensor or tank is displayed in the VC embedded dashboard view.
- Dashboard: EV card now shows the vehicle’s current street and city when location sharing is enabled, including a home indicator when at the installation location.
- Dashboard: air quality metrics such as CO2 and PM2.5 are now shown more prominently within the temperature card.
- Installation: unlink action is now disabled for installations managed via installation groups or teams, with clear guidance shown to the user.
- Teams: team details page has been migrated to newer framework.
- Teams: team overview page has been migrated to newer framework.
- Dashboard: add “Total energy” to the EVCS card in the alternative dashboard layout.
- OneID: Fix migrating account when a OneID account already exists, and the VRM account has a too weak password
2026-03-13
- Dynamic ESS Settings: Fix loop where configuration form goes back to the first step after completing the second step.
- Login: Fix Garmin watch login when logging in through OneID.
2026-03-10
- Login: Fix logins through OneID in the VRM app when on an ipad.
2026-03-04
- Version detection: Improve automatic version detection and reloading for the Vue 3 pages.
- Alarm log: Improve performance of sites with many alarms.
2026-03-03
- Venus OS Large: Remove unnecessary “Missing NodeRed” toaster when not running NodeRed
2026-02-28
- Notifications: Allow users to (re)subscribe to alarm notifications, e.g. after clicking the unsubscribe email in alarm emails.
2026-02-25
- Date Picker: Add `Recent and Upcoming` quickrange.
- Data Download: Deprecate old vrm-api based `/data-download` endpoint & direct users to use the new vrm-reports-api.
- Alarm Logs: Don't show an error toaster on empty alarmlog page.
- API Docs: Document installation-user management endpoints.
- API: Add attribute-exists validation to `/installation-data-attributes` endpoint.
- Tags API: Group tags by source & allow filtering on a specific tag source.
- Timezones: Synchronise VRM's timezone with the GX's timezone.
- Advanced: Add location history to GPS widget.
2026-02-20
- Fix issue on safari causing blank space when window width was right on the edge of mobile and desktop width
2026-02-12
- Dashboard: Change number formatting for Meterological sensor.
- Dashboard: Use Temperature sensor type for the name of the card if no custom name is set.
- Profile: Replace all phone inputs with the new phone input component.
- Notifications: Allow users to see, accept and reject installation access requests in the notifications popup.
- Data Download: Fix issues with partially filled columns.
2026-02-05
- Dashboard: Fix “This year” time range start date.
2026-02-04
- Home page: Added shortcut buttons to favorite installations for easy access to the Advanced and Device List pages.
- Advanced: In custom widgets with individual PV trackers, we now also show the custom name per tracker.
- Datepicker: Fixed an issue where you could not select custom dates in German.
2026-02-02
- [Admin] Firmware release: Fixed a Safari-specific layout issue in the Markdown editor.
2026-01-29
- Event Log: Show VRM Plus changes in the event log.
- VRM Warning: Improved the VRM warning design and added a new warning for users who reset their location while DESS is enabled.
- Datepicker: Fixed editing custom dates by typing in the textfield.
- Reports: New EVCS reports to track charging history and charging sessions.
2026-01-26
- Advanced: Added 'PV Yield Overview' widgets for Inverter, Inverter/Charger and Solar Charger
- Advanced: Fix the NOx axis going negative for the 'Air Quality` widget.
- Advanced: Fix `hours of AC in` on the VE.Bus Summary widget OOM error for large datasets.
2026-01-22
- Production Reports: Fix identifier sometimes being returned as int, breaking report generation.
- API: Clean up & improve performance for the `/installations` endpoint.
- API: Fix `/overallstats` endpoint sometimes timing out.
- Advanced: Fix x-axis disappearing after zooming.
2026-01-21
- Installation DESS settings: fix 500 error for some sites when calling the settings endpoint
- Invites: Improved invite acceptance errors by showing the specific failure reason from the API instead of a static error message
- Installation: Keep site location when replacing GX device
- Advanced: Add 'Battery Balancing Status' & 'Battery Smart Lithium Errors' widgets
- Remote Console: Fix missing close console button on small screens
2026-01-20
- Advanced: Fix AC Energy Summary not showing L3 power.
2026-01-15
- Navigation: Fix an issue causing middle mouse clicks to open duplicate tabs in some browsers.
2026-01-14
- Dashboard: Fixed an issue where AC Load details would not show up.
- General: Update the favicons to the new version.
- Navigation: Fix an issue where submenu would not update correctly on page change.
- Dashboard: Fix bug where live feed graph was missing Y-axis for future ranges, and “Last year” range was missing the “next” range.
- Command K: Allow users to switch between navigation and search mode in installation context.
- Remote Console: Fix bug where modal title was too dark in dark mode.
2026-01-09
- Device list: Show EV model and VIN in the details of the EV device.
2026-01-07
- Login: Improve user feedback when encountering issues during login
- Advanced: Move reset zoom button out of the active chart area and into the header
2026-01-05
- Advanced: Fix heat pump L3 power and frequency not showing.
2025-12-24
- Data Downloads: Only allow one generating one datadownload at a time.
- Advanced: Fix header padding bug on screen resize.
- Advanced: Add Heatpump widgets: voltage, current, and energy.
2025-12-23
- API: Cache devicetypes to reduce database load.
- API: Remove queries for non-existent attributes.
- API: Upgrade database abstraction layer.
- Reports: Improve generation time of data download export (advanced) & production report (installation overview).
2025-12-22
- Device List: Fix DC Generator not showing in the Device List.
2025-12-17
- Remote Console: Fix close button styling.
- Victron Connect: Fix authorising VictronConnect returning a URL-encoded email, leading to authentication issues.
2025-12-10
- Fleet Monitor: Hide offline sites from disconnected devices.
- Fleet Monitor: Add widget for offline sites.
2025-12-09
- Advanced: Add state widgets for MultiRS in general and for the individual trackers.
- Device list: Fix VRM reboot timeout not showing when reported as 0.
2025-12-03
- Dashboard: Add Apparent power to the Grid Meter Combined chart for system sizing layouts.
- Advanced: Add Apparent power tab for the Grid Meter Combined widget.
- Dashboard: Hide the minus sign when the temperature is 0 degrees.
- Dashboard: Reduce the size of the weather icons.
- Navigation: Auto hide the navigation bar, allow users to always hide it from Preferences, and various other UX improvements.
- Teams and Installation Groups: Fix to ensure the Members dropdown inside the “Link users” modal closes when users click outside the dropdown.
- API: Add an endpoint to show total usage of VRM
2025-12-02
- Recurring Reports: Fix error causing recurring reports to not generate.
2025-11-26
- API: Add `/v2/installation-data-attributes` endpoint to allow users & tools to query their sites by (multiple) data attributes.
- Remote Console: Improve fetching logic of the `New UI` to prevent unnecessary re-downloads.
2025-11-20
- Device list: Rename Motor Drive to E-drive and adjust icons.
- Dashboard: Various fixes of the EV card data formatting and display conditions.
2025-11-20
- API: Revert the changes done to the `live_feed` type on the `/stats` endpoint.
2025-11-19
- Widget AI: Allow adding the same widget to multiple sites.
- Remote Console: Add a new progress bar.
- Remote Console: Allow users to open NodeRED and SignalK from the remote console via VRM.
2025-11-14
2025-11-13
2025-11-12
2025-11-11
2025-11-06
2025-11-05
2025-10-30
2025-10-29
2025-10-23
2025-10-22
2025-10-20
2025-10-16
2025-10-09
2025-10-07
2025-10-06
2025-10-02
2025-10-01
2025-09-29
2025-09-25
2025-09-17
2025-09-12
2025-09-11
2025-09-10
2025-09-04
2025-09-03
2025-09-02
2025-08-28
2025-08-27
2025-08-22
2025-08-20
2025-08-18
2025-08-14
2025-08-13
2025-08-11
2025-08-06
2025-07-31
2025-07-30
2025-07-25
2025-07-23
2025-07-17
2025-07-16
2025-07-10
2025-07-09
2025-07-04
2025-07-03
2025-07-02
2025-07-01
2025-06-25
2025-06-24
- Login: Remove `*******` placeholder from the password field to prevent confusion.
2025-06-18
2025-06-17
2025-06-12
2025-06-11
2025-06-06
2025-06-05
2025-06-04
2025-06-03
2025-05-28
2025-05-26
2025-05-21
2025-05-17
2025-05-15
2025-05-14
2025-05-13
2025-05-12
2025-05-10
2025-05-08
2025-05-07
2025-05-06
2025-05-02
2025-05-01
2025-04-30
2025-04-24
2025-04-19
2025-04-18
2025-04-17
2025-04-16
2025-04-09
2025-04-07
2025-04-04
2025-04-03
2025-04-02
2025-03-29
2025-03-28
2025-03-27
2025-03-26
2025-03-21
2025-03-19
2025-03-12
2025-03-05
2025-03-04
2025-03-03
2025-02-26
2025-02-21
2025-02-19
2025-02-12
2025-02-05
2025-02-04
2025-02-01
2025-01-29
2025-01-23
2025-01-18
2025-01-16
2025-01-15
2025-01-13
2025-01-10
2025-01-08
2025-01-06
2025-01-02
vrm_portal/change_log.1792399474.txt.gz · Last modified: by aleximb
Add this page to your book
Manage book (
Help
