vrm_portal:change_log
VRM Portal Changelog
2026-01-21
  • Installation DESS settings: fix 500 error for some sites when calling the settings endpoint
  • Invites: Improved invite acceptance errors by showing the specific failure reason from the API instead of a static error message
  • Installation: Keep site location when replacing GX device
  • Advanced: Add 'Battery Balancing Status' & 'Battery Smart Lithium Errors' widgets
  • Remote Console: Fix missing close console button on small screens
2026-01-20
  • Advanced: Fix AC Energy Summary not showing L3 power.
2026-01-15
  • Navigation: Fix an issue causing middle mouse clicks to open duplicate tabs in some browsers.
2026-01-14
  • Dashboard: Fixed an issue where AC Load details would not show up.
  • General: Update the favicons to the new version.
  • Navigation: Fix an issue where submenu would not update correctly on page change.
  • Dashboard: Fix bug where live feed graph was missing Y-axis for future ranges, and “Last year” range was missing the “next” range.
  • Command K: Allow users to switch between navigation and search mode in installation context.
  • Remote Console: Fix bug where modal title was too dark in dark mode.
2026-01-09
  • Device list: Show EV model and VIN in the details of the EV device.
2026-01-07
  • Login: Improve user feedback when encountering issues during login
  • Advanced: Move reset zoom button out of the active chart area and into the header
2026-01-05
  • Advanced: Fix heat pump L3 power and frequency not showing.
2025-12-24
  • Data Downloads: Only allow one generating one datadownload at a time.
  • Advanced: Fix header padding bug on screen resize.
  • Advanced: Add Heatpump widgets: voltage, current, and energy.
2025-12-23
  • API: Cache devicetypes to reduce database load.
  • API: Remove queries for non-existent attributes.
  • API: Upgrade database abstraction layer.
  • Reports: Improve generation time of data download export (advanced) & production report (installation overview).
2025-12-22
  • Device List: Fix DC Generator not showing in the Device List.
2025-12-17
  • Remote Console: Fix close button styling.
  • Victron Connect: Fix authorising VictronConnect returning a URL-encoded email, leading to authentication issues.
2025-12-10
  • Fleet Monitor: Hide offline sites from disconnected devices.
  • Fleet Monitor: Add widget for offline sites.
2025-12-09
  • Advanced: Add state widgets for MultiRS in general and for the individual trackers.
  • Device list: Fix VRM reboot timeout not showing when reported as 0.
2025-12-03
  • Dashboard: Add Apparent power to the Grid Meter Combined chart for system sizing layouts.
  • Advanced: Add Apparent power tab for the Grid Meter Combined widget.
  • Dashboard: Hide the minus sign when the temperature is 0 degrees.
  • Dashboard: Reduce the size of the weather icons.
  • Navigation: Auto hide the navigation bar, allow users to always hide it from Preferences, and various other UX improvements.
  • Teams and Installation Groups: Fix to ensure the Members dropdown inside the “Link users” modal closes when users click outside the dropdown.
  • API: Add an endpoint to show total usage of VRM
2025-12-02
  • Recurring Reports: Fix error causing recurring reports to not generate.
2025-11-26
  • API: Add `/v2/installation-data-attributes` endpoint to allow users & tools to query their sites by (multiple) data attributes.
  • Remote Console: Improve fetching logic of the `New UI` to prevent unnecessary re-downloads.
2025-11-20
  • Device list: Rename Motor Drive to E-drive and adjust icons.
  • Dashboard: Various fixes of the EV card data formatting and display conditions.
2025-11-20
  • API: Revert the changes done to the `live_feed` type on the `/stats` endpoint.
2025-11-19
  • Advanced: Improve header and calendar behaviour on mobile (portrait and landscape mode).
  • Navigation: Add language selector to the navigation bar.
  • Installation data: Load data from different data sources independently.
  • Widget AI: Allow adding the same widget to multiple sites.
  • Remote Console: Add a new progress bar.
  • Remote Console: Allow users to open NodeRED and SignalK from the remote console via VRM.
2025-11-14
  • Allow choosing which Remote console version to show in full screen with a URL parameter.
  • Dashboard: Show session and total energy for EVCS.
  • Dashboard: Fix charging time for EVCS connected over MQTT.
2025-11-13
  • Installation Groups: Increase maximum amount of sites that can be added in bulk to 250.
  • Enhanced Search: Allow searching for sites with a specific product (by name).
2025-11-12
  • Dynamic ESS: Added support to specify different pricing formulas for DESS that vary throughout the day.
  • Accesstokens: Add endpoint to get a regular JWT from the access token (VictronConnect integration).
  • Search: Fix not finding exact site match with special characters.
  • Remote console: Fix remote console not opening automatically when ?openRemoteConsole is in the url.
  • Demo mode: Fix not being able to visit other demo sites when visiting a ?demoShare url while not logged in.
2025-11-11
  • Dashboard: Fix EVCS, PV Inverter and Grid Meter tiles missing for the layout without a inverter/charger.
2025-11-06
  • Remote console: Fix remote console choice title color not visible in dark mode.
2025-11-05
  • Dashboard: Add dedicated card for Heatpump type in the alternative dashboard.
  • Advanced: Add Air Quality widget for Ruuvi Air.
  • Dashboard: Add support for Ruuvi Air by showing air quality measurements in the temperature tile.
  • Navbar: Fixed missing “Open in new tab” option in the new navbar.
2025-10-30
  • Installation data: Switch around the Grid meter combined widget and the kWh tiles.
2025-10-29
2025-10-23
2025-10-22
2025-10-20
2025-10-16
2025-10-09
2025-10-07
2025-10-06
2025-10-02
2025-10-01
2025-09-29
2025-09-25
2025-09-17
2025-09-12
2025-09-11
2025-09-10
2025-09-04
2025-09-03
2025-09-02
2025-08-28
2025-08-27
2025-08-22
2025-08-20
2025-08-18
2025-08-14
2025-08-13
2025-08-11
2025-08-06
2025-07-31
2025-07-30
2025-07-25
2025-07-23
2025-07-17
2025-07-16
2025-07-10
2025-07-09
2025-07-04
2025-07-03
2025-07-02
2025-07-01
2025-06-25
2025-06-24
2025-06-18
2025-06-17
2025-06-12
2025-06-11
2025-06-06
2025-06-05
2025-06-04
2025-06-03
2025-05-28
2025-05-26
2025-05-21
2025-05-17
2025-05-15
2025-05-14
2025-05-13
2025-05-12
2025-05-10
2025-05-08
2025-05-07
2025-05-06
2025-05-02
2025-05-01
2025-04-30
2025-04-24
2025-04-19
2025-04-18
2025-04-17
2025-04-16
2025-04-09
2025-04-07
2025-04-04
2025-04-03
2025-04-02
2025-03-29
2025-03-28
2025-03-27
2025-03-26
2025-03-21
2025-03-19
2025-03-12
2025-03-05
2025-03-04
2025-03-03
2025-02-26
2025-02-21
2025-02-19
2025-02-12
2025-02-05
2025-02-04
2025-02-01
2025-01-29
2025-01-23
2025-01-18
2025-01-16
2025-01-15
2025-01-13
2025-01-10
2025-01-08
2025-01-06
2025-01-02
vrm_portal/change_log.1769010901.txt.gz · Last modified: by aleximb
