vrm_portal:change_log
VRM Portal Changelog
2025-12-03
- Dashboard: Add Apparent power to the Grid Meter Combined chart for system sizing layouts.
- Advanced: Add Apparent power tab for the Grid Meter Combined widget.
- Dashboard: Hide the minus sign when the temperature is 0 degrees.
- Dashboard: Reduce the size of the weather icons.
- Navigation: Auto hide the navigation bar, allow users to always hide it from Preferences, and various other UX improvements.
- Teams and Installation Groups: Fix to ensure the Members dropdown inside the “Link users” modal closes when users click outside the dropdown.
2025-12-02
- Recurring Reports: Fix error causing recurring reports to not generate.
2025-11-26
- API: Add `/v2/installation-data-attributes` endpoint to allow users & tools to query their sites by (multiple) data attributes.
- Remote Console: Improve fetching logic of the `New UI` to prevent unnecessary re-downloads.
2025-11-20
- Device list: Rename Motor Drive to E-drive and adjust icons.
- Dashboard: Various fixes of the EV card data formatting and display conditions.
2025-11-20
- API: Revert the changes done to the `live_feed` type on the `/stats` endpoint.
2025-11-19
- Widget AI: Allow adding the same widget to multiple sites.
- Remote Console: Add a new progress bar.
- Remote Console: Allow users to open NodeRED and SignalK from the remote console via VRM.
2025-11-14
2025-11-13
2025-11-12
2025-11-11
2025-11-06
2025-11-05
2025-10-30
2025-10-29
2025-10-23
2025-10-22
2025-10-20
2025-10-16
2025-10-09
2025-10-07
2025-10-06
2025-10-02
2025-10-01
2025-09-29
2025-09-25
2025-09-17
2025-09-12
2025-09-11
2025-09-10
2025-09-04
2025-09-03
2025-09-02
2025-08-28
2025-08-27
2025-08-22
2025-08-20
2025-08-18
2025-08-14
2025-08-13
2025-08-11
2025-08-06
2025-07-31
2025-07-30
2025-07-25
2025-07-23
2025-07-17
2025-07-16
2025-07-10
2025-07-09
2025-07-04
2025-07-03
2025-07-02
2025-07-01
2025-06-25
2025-06-24
2025-06-18
2025-06-17
2025-06-12
2025-06-11
2025-06-06
2025-06-05
2025-06-04
2025-06-03
2025-05-28
2025-05-26
2025-05-21
2025-05-17
2025-05-15
2025-05-14
2025-05-13
2025-05-12
2025-05-10
2025-05-08
2025-05-07
2025-05-06
2025-05-02
2025-05-01
2025-04-30
2025-04-24
2025-04-19
2025-04-18
2025-04-17
2025-04-16
2025-04-09
2025-04-07
2025-04-04
2025-04-03
2025-04-02
2025-03-29
2025-03-28
2025-03-27
2025-03-26
2025-03-21
2025-03-19
2025-03-12
2025-03-05
2025-03-04
2025-03-03
2025-02-26
2025-02-21
2025-02-19
2025-02-12
2025-02-05
2025-02-04
2025-02-01
2025-01-29
2025-01-23
2025-01-18
2025-01-16
2025-01-15
2025-01-13
2025-01-10
2025-01-08
2025-01-06
2025-01-02
vrm_portal/change_log.1764765710.txt.gz · Last modified: by aleximb
Add this page to your book
Manage book (
Help
