vrm_portal:change_log
vrm_portal:change_log [2024-04-04 13:28] – aleximb | vrm_portal:change_log [2024-05-03 14:32] (current) – aleximb | ||
+ | === 2024-05-03 === | ||
+ | === 2024-05-02 === | ||
+ | === 2024-04-25 === | ||
+ | === 2024-04-11 === | ||
+ | === 2024-04-09 === | ||
=== 2024-04-04 === | === 2024-04-04 === | ||
- | * Dashboard: Fix, show distinct graphs for EVCS(s) on input and output side of multi - #1736 | + | * Dashboard: Fix, show distinct graphs for EVCS(s) on input and output side of multi |
* Alarms: Change communication monitoring alarm to be more descriptive (vrm stopped logging) | * Alarms: Change communication monitoring alarm to be more descriptive (vrm stopped logging) | ||
* Data Download: Improve the speed of data export feature | * Data Download: Improve the speed of data export feature | ||
=== 2024-04-03 === | === 2024-04-03 === | ||
* Installation overview: Fix map info window bug on cluster click | * Installation overview: Fix map info window bug on cluster click |
vrm_portal/change_log.1712230094.txt.gz · Last modified: 2024-04-04 13:28 by aleximb
