vrm_portal:change_log
Previous revision | |||
— | vrm_portal:change_log [2025-08-11 13:42] (current) – aleximb | ||
+ | ====== VRM Portal Changelog ====== | ||
+ | === 2025-08-11 === | ||
+ | * Dynamic ESS: Fix " | ||
+ | === 2025-08-06 === | ||
+ | * Fleet Monitor: Add icons to each widget, so they are easier to identify. | ||
+ | * Preferences: | ||
+ | * API: Fix `users/ | ||
+ | * Advanced: Fall back to regular datapoints when user selects `show min/max values` when that data is not available. | ||
+ | * User groups: Ensure user group page doesn' | ||
+ | * Login: Added user feedback after opening a wrong invite. | ||
+ | === 2025-07-31 === | ||
+ | * Device list: Fix showing the VRM Portal Model row in the table even if no value is reported. | ||
+ | === 2025-07-30 === | ||
+ | * Command K: Show enhanced search in all the pages that are not part of an installation. | ||
+ | * Economic Results: Fix alignment of buttons in economic report results. | ||
+ | * Advanced Widgets: Make the solar irradiance widget take the date picker values into account. | ||
+ | * Installation overview: Show favorite installations in the installation overview on mobile. | ||
+ | * Settings: Show the Replace GX device section faster and consistently. | ||
+ | * Controls: Use 1% increments for the Mininum SOC. | ||
+ | * AI Assistant: Allow users to directly edit the widget manually, without needing to go to the edit custom widget menu first. | ||
+ | * AI Assistant: Allow users to delete a chat. | ||
+ | * AI Assistant: Allow users to rename a chat, so it is more clear what the chat is about. | ||
+ | * API: Include access level in the response of the `/users/me` endpoint. | ||
+ | === 2025-07-25 === | ||
+ | * Languages: Add support for Romanian. | ||
+ | === 2025-07-23 === | ||
+ | * Advanced: Search mode is considered active only when search query is entered. | ||
+ | * Device List: Fix bug when loading remote support details without relevant data. | ||
+ | * Invites: Improve validation when inviting users to installations and fix setting the locale of the invited user. | ||
+ | * Remote console in VictronConnect: | ||
+ | * Date picker: Fix date picker ignoring URL parameters when going to Advanced from an Alarm. | ||
+ | * Installation data: Add widget for the Grid meter to Installation data section of the Dashboard for specific systems with a Grid meter (i.e. with Grid Meter, no Inverter/ | ||
+ | * Advanced: Added scrollbar when there are too many custom widgets. | ||
+ | * Advanced: Enabled scrolling on the advanced page for newly added custom widgets. | ||
+ | * Teams: Allow only the invited user to accept the invite link. | ||
+ | * Teams & Installation groups: Set page title for single team and installation group pages. | ||
+ | * Fleet monitor: Added ' | ||
+ | * Add installation: | ||
+ | * Enhanced search: Fix error caused by by using quotation marks in the search query. | ||
+ | * AI Assistant: Change the internal architecture and introduce the suggestions and feedback capabilities. | ||
+ | === 2025-07-17 === | ||
+ | * Dashboard: Fix Sync with OS display preference not working as intended on the Dashboard. | ||
+ | * Firmware file upload: Improve file extension validation and filtering for .vup, .dup, and .xup. | ||
+ | * Fleet monitor: Fixed a bug that prevented fleet-monitor from fetching data in parallel on production. | ||
+ | === 2025-07-16 === | ||
+ | * Alarm rules: Allow adding alarm rules for multiple installation, | ||
+ | * Teams/ | ||
+ | * Login: Added a ' | ||
+ | * Login: Added an ' | ||
+ | * Dashboard: Added translation to " | ||
+ | * Fleet monitor: Improve the page load time by fetching data in parallel more. | ||
+ | * Venus OS Large: The links to external services like Node-RED and Signal K now open in a new browser tab. | ||
+ | * Dashboard: Fix " | ||
+ | === 2025-07-10 === | ||
+ | * Fleet monitor: Significantly improve page responsiveness after a lot of data is loaded. | ||
+ | * Venus OS Large: Explain that 'VRM Portal Mode' should be set to ' | ||
+ | === 2025-07-09 === | ||
+ | * General: Added a backup font in case the browser cannot render special characters (Russian, Ukrainian, etc). | ||
+ | * General: The default time that notifications are shown was increased to 20 seconds. | ||
+ | * Advanced: Fixed a bug that allowed editing multiple widgets via ' | ||
+ | * Advanced: Added a ' | ||
+ | * Fleet monitor: Decrease the time it takes for the page to load with data. | ||
+ | === 2025-07-04 === | ||
+ | * Validation: Fix TypeError in validators | ||
+ | * Dynamic ESS Report: Improve code quality & make sure the report is generated in the user's preferred language. | ||
+ | === 2025-07-03 === | ||
+ | * Infrastructure: | ||
+ | * Site groups: Make the alarm toggle changeable for your own account even if you are not group owner/ | ||
+ | === 2025-07-02 === | ||
+ | * Users: Add mailto link to teams, groups & installation user management pages to simplify contacting users in case of issues. | ||
+ | * Installation overview: Your favourite installations will now show on top of your installation overview. | ||
+ | * Device List: Show local IP address again. | ||
+ | * Reporting: Fix Dynamic ESS report not showing at all if DESS was off for a portion of the selected period. | ||
+ | === 2025-07-01 === | ||
+ | * Navbar: Fix `Dynamic ESS` settings not being shown in the navbar on pages in the new frontend framework. | ||
+ | * VictronConnect: | ||
+ | * Groups: Fix bug where a team as site-group administrators are not able to add a site they have full access to. | ||
+ | === 2025-06-25 === | ||
+ | * Dashboard: Show different banner for opportunistic battery balancing. | ||
+ | * Settings: Allow user to reset his consumption forecast. | ||
+ | * General: Animate VRM AI Assistant button icon. | ||
+ | === 2025-06-24 === | ||
+ | * Login: Remove `*******` placeholder from the password field to prevent confusion. | ||
+ | === 2025-06-18 === | ||
+ | * Installation overview: Make all filters apply immediately for consistent behaviour. | ||
+ | * Installation group: Fix styling of 'Link user' modal inputs on smaller devices. | ||
+ | * Fleet monitor: Added relative difference column to the solar widget. | ||
+ | === 2025-06-17 === | ||
+ | * Dashboard: Fix Demo mode banner not showing for certain modes. | ||
+ | === 2025-06-12 === | ||
+ | * Dashboard: Fix turning DESS off in the controls also causing DESS to be turned off in the site's settings. | ||
+ | === 2025-06-11 === | ||
+ | * Device Overview: Add icon for Energy Solutions Smart Switch | ||
+ | * Dashboard: Add new data attribute ' | ||
+ | * Alarms: Fix error caused by missing data attribute for Tank and Temperature Sensor alarms | ||
+ | === 2025-06-06 === | ||
+ | * Firmware update: Updating a GX device now properly waits with rescanning until the GX device is done rebooting | ||
+ | === 2025-06-05 === | ||
+ | * Diagnostics: | ||
+ | === 2025-06-04 === | ||
+ | * Fleet Monitor: Add enhanced search functionality triggered by the Command/ | ||
+ | * Venus OS Large: Add support for connecting to Node-Red/ | ||
+ | === 2025-06-03 === | ||
+ | * Device Registration: | ||
+ | === 2025-05-28 === | ||
+ | * Add Installations: | ||
+ | * Teams: Add the permission for admins/ | ||
+ | * Dashboard: Display AC Meter cards per instance for installations with energy meters and without certain devices | ||
+ | * VRM AI Assistant: Introducing the AI Assistant, which is capable of helping users with adding custom widgets to the Advanced page | ||
+ | === 2025-05-26 === | ||
+ | * Device list: Add GX IO Extender support | ||
+ | * Dashboard: Display PV inverter cards per instance when using dashboard layout for installations with energy meters and without certain devices | ||
+ | === 2025-05-21 === | ||
+ | * Navigation: Implement ' | ||
+ | * Dashboard: Add new layout for installations with energy meters and without certain devices | ||
+ | * Dashboard : Add EV card on dashboard to view EV information. | ||
+ | * Register: Dealers can now share a link to new users to automatically link them to their dealer account after registering. | ||
+ | * Register: Make go to login button smaller. | ||
+ | === 2025-05-17 === | ||
+ | * Controls: Fix ESS controls not working for users with a non-Enligh language. | ||
+ | === 2025-05-15 === | ||
+ | * Controls: Fix EVCS manual charge toggle on mobile. | ||
+ | * General: Fix a language issue when entering demo mode | ||
+ | * Installation data: Improve the logic for showing and hiding the dropdown items Solar and EV Charger. | ||
+ | * Login: Fix redirecting users with one installation to their dashboard. | ||
+ | * Controls: Fix unable to change EVCS mode | ||
+ | === 2025-05-14 === | ||
+ | * Dashboard: New UI for the controls section on mobile to prevent accidental changes. | ||
+ | * Dashboard: Fix VRM freezing under specific conditions when DESS is enabled. | ||
+ | * Admin Device search: Allow searching by VE.Bus serial number. | ||
+ | * Login: Improve performance & prevent showing the login page when already logged in. | ||
+ | === 2025-05-13 === | ||
+ | * Login: Fix incorrect language being set when initially visiting the login page | ||
+ | === 2025-05-12 === | ||
+ | * Login: Fix account language being overwritten by login | ||
+ | === 2025-05-10 === | ||
+ | * Login/ | ||
+ | === 2025-05-08 === | ||
+ | * Login/ | ||
+ | === 2025-05-07 === | ||
+ | * Navbar: Fixed background not staying blurry when navigating between sites on a mobile device | ||
+ | * Login/ | ||
+ | === 2025-05-06 === | ||
+ | * Advanced: Added new widgets: EV Location, EV SOC, EV State | ||
+ | === 2025-05-02 === | ||
+ | * Alarm Rules: Fixed issue where Automatic Alarm Monitoring would not update properly when moving to a different page | ||
+ | === 2025-05-01 === | ||
+ | * DESS: fixed the DESS configuration page sometimes not loading | ||
+ | === 2025-04-30 === | ||
+ | * Site Unlinking: Improve UX of API when unlinking a user from a site that wasn't bound in the first place | ||
+ | * Alarms: Allow filling in decimals and negative numbers on mobile devices | ||
+ | * DESS: Add support for ENTSOE multiple pricing options | ||
+ | === 2025-04-24 === | ||
+ | * Dashboard: Fix incorrect magnitudes for large numbers, e.g. 20560W should be 20,56kW | ||
+ | === 2025-04-19 === | ||
+ | * Recurring Reports: Make sure users get their report & let them know that their report template may need a correction (e.g. missing kWh sell price) | ||
+ | === 2025-04-18 === | ||
+ | * Data Download: Fix corrupt Excel file when the selected timerange does not data available | ||
+ | * Alarms: Validate basic info when adding or editing alarm rules | ||
+ | * Widgets: Fix issue where timeseries could not be properly merged together | ||
+ | === 2025-04-17 === | ||
+ | * Device list: Add icon for Motor drive. | ||
+ | === 2025-04-16 === | ||
+ | * Teams: Fixed an issue where buttons in some modals couldn' | ||
+ | * Device list: Add event log when a user opens Victron Connect | ||
+ | * Command K: Add CommandK modal functionality in the context of an installation to navigate between installation pages | ||
+ | * Mail Templates: Fix a couple missing variables & add monitoring | ||
+ | * DESS: Remove `error_codes` for a successful DELETE call | ||
+ | * Fleet Monitor: Fixed widgets sometimes not loading for users with >1500 sites | ||
+ | === 2025-04-09 === | ||
+ | * Fleet Monitor: Removed the " | ||
+ | * Dashboard: Added support for new attributes to control tracker availability and conditionally hide trackers based on their values | ||
+ | * Avatar: Added role-specific icons to user avatars for admins and technicians | ||
+ | * Installation Overview: Remove unnecessary loop, slightly increasing performance when getting the minigraphs | ||
+ | * Global Banner: Reduce the amount of times the banner is fetched to once per minute | ||
+ | * Device list: Added "Open in Victron Connect" | ||
+ | === 2025-04-07 === | ||
+ | * Dashboard: Fix DESS cost and savings graph to show correct savings | ||
+ | * Notifications: | ||
+ | === 2025-04-04 === | ||
+ | * Advanced: Fix .xlsx downloads to not have corrupt headers | ||
+ | * Event logs: Fix bug where event logs timestamps were shown based on location timezone instead of timezone set in GX device | ||
+ | * Menu: Fixed bug where the Admin section was not visible in the menu on the Event Logs and Fleet Monitor pages. | ||
+ | === 2025-04-03 === | ||
+ | * Alarm notifications: | ||
+ | === 2025-04-02 === | ||
+ | * Fleet monitor: Introduce fleet monitor page with alarms overview chart and stats widgets | ||
+ | === 2025-03-29 === | ||
+ | * Alarms: Stop showing an error after an alarm was successfully deleted. | ||
+ | * Dynamic ESS: Fix energy prices graph when a site is in an earlier timezone than the user. | ||
+ | === 2025-03-28 === | ||
+ | * Invite Emails: Fix templating mistake in invite e-mails where personal message sender was not properly filled. | ||
+ | * Two-factor Authentication: | ||
+ | === 2025-03-27 === | ||
+ | * Eventlogs: First page to have been rebuilt in a new frontend framework, functionality stays the same. | ||
+ | === 2025-03-26 === | ||
+ | * Installation dashboard: Fix the "DESS prices missing" | ||
+ | * Installation dashboard: Show forecasts as a range. | ||
+ | * Installation groups: Display admins of installation groups. | ||
+ | * Reporting: Improve UX/UI of sliders when inserting values manually. | ||
+ | === 2025-03-21 === | ||
+ | * Dynamic ESS: Remove unnecessary labels for math tokens in the formula builder. | ||
+ | === 2025-03-19 === | ||
+ | * Dashboard: Fixed an issue where the "This week" date range would select the incorrect start date. | ||
+ | * Profile: When changing your account email, also send an email to the old email address to notify of this change. | ||
+ | * General: Created a new banner which is displayed on all pages to urge non admin users to turn on two factor authentication. | ||
+ | * Enhanced search: Improved navigation and search consistency, | ||
+ | === 2025-03-12 === | ||
+ | * Internal: Only save images in S3 and remove image from S3 on delete. | ||
+ | * API: Fix users being able to set any minute value in price schedule | ||
+ | === 2025-03-05 === | ||
+ | * Installation overview: Allow users to filter installations using alarm tags | ||
+ | === 2025-03-04 === | ||
+ | * General settings: Redirect users to the `add-installation` page when transferring a GX device. | ||
+ | === 2025-03-03 === | ||
+ | * DESS: Always write the DESS settings to Venus, even when DESS is turned off. | ||
+ | === 2025-02-26 === | ||
+ | * Users: enable linking user to a site individually, | ||
+ | * Advanced: Added a " | ||
+ | === 2025-02-21 === | ||
+ | * Location: Fix timezone not updating when changing the location. | ||
+ | === 2025-02-19 === | ||
+ | * Advanced: Save the latest 5 widget searches. | ||
+ | * Event logs: Do not show consecutive advanced page changes. | ||
+ | * Internal: retry transactions 3 times in case of deadlock. | ||
+ | * Advanced: Fix issue with chart where certain data points were filtered out when the value was zero | ||
+ | === 2025-02-12 === | ||
+ | * Site share: Hide the exact location by default (Dashboard: Weather card, Advanced: GPS widget) | ||
+ | * Remote Console: Update the proxy URL for custom gui-v2 WASM binaries to non-deprecated /gui-v2 | ||
+ | * Enhanced search: Show Command+K icon on the text input of the Enhanced Search and update the modal design | ||
+ | * Dashboard: Restructure the formatting of the generator runtime to make it more readable and fix the alignments of the piecharts | ||
+ | === 2025-02-05 === | ||
+ | * Victron Connect: Improve performance of retrieving installations when using replica database | ||
+ | * Dynamic ESS: Synchronise configuration with Venus OS | ||
+ | * Add Installation: | ||
+ | === 2025-02-04 === | ||
+ | * Site permissions: | ||
+ | === 2025-02-01 === | ||
+ | * Recurring Reports: Fix recurring reports not being sent due to an error | ||
+ | === 2025-01-29 === | ||
+ | * Advanced: Connect the data points of custom graphs that display prices or total energy | ||
+ | * Device List: Remove ' | ||
+ | * Installation users: Add modal confirmation before deleting user, team or installation group | ||
+ | * Installation overview: Fix installation name overflowing its container | ||
+ | === 2025-01-23 === | ||
+ | * Navbar: For users with more than 10 sites, make the 'All installations' | ||
+ | * Installation graph: Show installation data for the last year in the installation graph on the dashboard | ||
+ | === 2025-01-18 === | ||
+ | * General Settings: Fix GX replacement error caused by database changes | ||
+ | * Alarms: Add proper validation on ' | ||
+ | === 2025-01-16 === | ||
+ | * API: Return the id of the Access Token used in the `/me` endpoint. | ||
+ | === 2025-01-15 === | ||
+ | * Event Log: Display the name of the user that changed the general settings of the site | ||
+ | * Event Log: Display the name of the user that added / removed a tag and display the tag name | ||
+ | * Event Log: Add new event descriptions when installation settings are updated to be more descriptive | ||
+ | * Device List: Add reboot button for GX device | ||
+ | * Remote VEConfigure: | ||
+ | * Teams: Improved management of team member roles and updated UI | ||
+ | * Devices: Added icon for heatpump | ||
+ | * Navbar: Clicking on an installation on the navbar while holding the command (on Mac) button or control (on Windows) will open the site in a new tab | ||
+ | * Installation Overview: In the grid view, now you can see the battery to grid and the PV to grid values | ||
+ | * Installation Overview: On mobile, made the 'add installation' | ||
+ | * Installation Overview: Fix incorrect columns on the ' | ||
+ | === 2025-01-13 === | ||
+ | * Navigation Bar: Fix showing "Teams & Groups" | ||
+ | === 2025-01-10 === | ||
+ | * Dashboard: Fix tank sensor values being displayed as " | ||
+ | === 2025-01-08 === | ||
+ | * Advanced: Display the custom name of the MPPT tracker for that tracker' | ||
+ | * Dashboard: Allow users to set site avatar in a popup window. | ||
+ | * Dynamic ESS Report: Dynamic ESS Report provides insight of energy bought, sold, and prices over a selected period. | ||
+ | * Enhanced search: Add support for partial search for the names of the sites. | ||
+ | * Installation overview: Allow a user to include all their sites in the production report if they have filters enabled. | ||
+ | * General: Improve message formatting for api request validation errors. | ||
+ | * Reporting: Fix reports not downloading for larger timeranges. | ||
+ | * Installation overview: Add monitoring to minigraphs to investigate potential empty graphs. | ||
+ | * Dynamic ESS: Quickly go back to overview after changing one step. | ||
+ | * Dashboard: While on a day view, using the arrows now always takes you to the following day. | ||
+ | * Installation overview: Added a battery icon to display battery percentages similar to how it is done for tanks. | ||
+ | === 2025-01-06 === | ||
+ | * Admin: Store data attribute filters in the URL | ||
+ | === 2025-01-02 === | ||
+ | * Advanced: Fix Generator State widget not showing values. | ||
+ | For earlier changelogs, see https:// | ||
vrm_portal/change_log.1586349535.txt.gz · Last modified: (external edit)
