vrm_portal:change_log
vrm_portal:change_log [2025-08-11 13:42] (current) aleximb
 +====== VRM Portal Changelog ======
 +=== 2025-08-11 ===
 +    * Dynamic ESS: Fix "Leave" button not working when prompted on unsaved changes in the Dynamic ESS settings
 +=== 2025-08-06 ===
 +    * Fleet Monitor: Add icons to each widget, so they are easier to identify.
 +    * Preferences: Sort languages alphabetically.
 +    * API: Fix `users/{id}/diagnostics` endpoint.
 +    * Advanced: Fall back to regular datapoints when user selects `show min/max values` when that data is not available.
 +    * User groups: Ensure user group page doesn't allow site permission changes if user doesn't have the right privileges.
 +    * Login: Added user feedback after opening a wrong invite.
 +=== 2025-07-31 ===
 +    * Device list: Fix showing the VRM Portal Model row in the table even if no value is reported.
 +=== 2025-07-30 ===
 +    * Command K: Show enhanced search in all the pages that are not part of an installation.
 +    * Economic Results: Fix alignment of buttons in economic report results.
 +    * Advanced Widgets: Make the solar irradiance widget take the date picker values into account.
 +    * Installation overview: Show favorite installations in the installation overview on mobile.
 +    * Settings: Show the Replace GX device section faster and consistently.
 +    * Controls: Use 1% increments for the Mininum SOC.
 +    * AI Assistant: Allow users to directly edit the widget manually, without needing to go to the edit custom widget menu first.
 +    * AI Assistant: Allow users to delete a chat.
 +    * AI Assistant: Allow users to rename a chat, so it is more clear what the chat is about.
 +    * API: Include access level in the response of the `/users/me` endpoint.
 +=== 2025-07-25 ===
 +    * Languages: Add support for Romanian.
 +=== 2025-07-23 ===
 +    * Advanced: Search mode is considered active only when search query is entered.
 +    * Device List: Fix bug when loading remote support details without relevant data.
 +    * Invites: Improve validation when inviting users to installations and fix setting the locale of the invited user.
 +    * Remote console in VictronConnect: Allow users to see remote console in full screen.
 +    * Remote console in VictronConnect: Allow users to choose which version of the remote console to see in full screen.
 +    * Date picker: Fix date picker ignoring URL parameters when going to Advanced from an Alarm.
 +    * Installation data: Add widget for the Grid meter to Installation data section of the Dashboard for specific systems with a Grid meter (i.e. with Grid Meter, no Inverter/Charger/Inverter+Charger).
 +    * Advanced: Added scrollbar when there are too many custom widgets.
 +    * Advanced: Enabled scrolling on the advanced page for newly added custom widgets.
 +    * Teams: Allow only the invited user to accept the invite link.
 +    * Teams & Installation groups: Set page title for single team and installation group pages.
 +    * Fleet monitor: Added 'Command+K' search bar to to the page.
 +    * Add installation: Show a message if the user already has an existing invite for the site.
 +    * Enhanced search: Fix error caused by by using quotation marks in the search query.
 +    * AI Assistant: Change the internal architecture and introduce the suggestions and feedback capabilities.
 +=== 2025-07-17 ===
 +    * Dashboard: Fix Sync with OS display preference not working as intended on the Dashboard.
 +    * Firmware file upload: Improve file extension validation and filtering for .vup, .dup, and .xup.
 +    * Fleet monitor: Fixed a bug that prevented fleet-monitor from fetching data in parallel on production.
 +=== 2025-07-16 ===
 +    * Alarm rules: Allow adding alarm rules for multiple installation, in batch.
 +    * Teams/Installation groups: Redirect user to team/installation group page after they accept an invite.
 +    * Login: Added a 'x' icon to the email and password fields to allow users to reset the inputs with a single click.
 +    * Login: Added an 'eye' icon to the password field to hide/show it.
 +    * Dashboard: Added translation to "Now" label.
 +    * Add installation: Made 'Replace GX Device' button translatable.
 +    * Fleet monitor: Improve the page load time by fetching data in parallel more.
 +    * Venus OS Large: The links to external services like Node-RED and Signal K now open in a new browser tab.
 +    * Dashboard: Fix "Now" indicator not updating when the hour changes.
 +=== 2025-07-10 ===
 +    * Fleet monitor: Significantly improve page responsiveness after a lot of data is loaded.
 +    * Venus OS Large: Explain that 'VRM Portal Mode' should be set to 'Full' to access Node-RED and Signal-K.
 +=== 2025-07-09 ===
 +    * General: Added a backup font in case the browser cannot render special characters (Russian, Ukrainian, etc).
 +    * General: The default time that notifications are shown was increased to 20 seconds.
 +    * Advanced: Fixed a bug that allowed editing multiple widgets via 'Enable/Disable All Widgets' even when widgets were locked.
 +    * Advanced: Added a 'Create with AI' button next to the 'Create Custom Widget' button to highlight the possibility of creating a custom widget using AI.
 +    * Fleet monitor: Decrease the time it takes for the page to load with data.
 +=== 2025-07-04 ===
 +    * Validation: Fix TypeError in validators
 +    * Dynamic ESS Report: Improve code quality & make sure the report is generated in the user's preferred language.
 +=== 2025-07-03 ===
 +    * Infrastructure: Upgrade backend API framework to newer version
 +    * Site groups: Make the alarm toggle changeable for your own account even if you are not group owner/admin.
 +=== 2025-07-02 ===
 +    * Users: Add mailto link to teams, groups & installation user management pages to simplify contacting users in case of issues.
 +    * Installation overview: Your favourite installations will now show on top of your installation overview.
 +    * Device List: Show local IP address again.
 +    * Reporting: Fix Dynamic ESS report not showing at all if DESS was off for a portion of the selected period.
 +    * Preferences: Redesigned the preferences pages.
 +=== 2025-07-01 ===
 +    * Navbar: Fix `Dynamic ESS` settings not being shown in the navbar on pages in the new frontend framework.
 +    * VictronConnect: Add route to support future remote console feature.
 +    * Groups: Fix bug where a team as site-group administrators are not able to add a site they have full access to.
 +=== 2025-06-25 ===
 +    * Dashboard: Show different banner for opportunistic battery balancing.
 +    * Settings: Allow user to reset his consumption forecast.
 +    * General: Animate VRM AI Assistant button icon.
 +=== 2025-06-24 ===
 +    * Login: Remove `*******` placeholder from the password field to prevent confusion.
 +=== 2025-06-18 ===
 +    * Installation overview: Make all filters apply immediately for consistent behaviour.
 +    * Installation group: Fix styling of 'Link user' modal inputs on smaller devices.
 +    * Fleet monitor: Added relative difference column to the solar widget.
 +=== 2025-06-17 ===
 +    * Dashboard: Fix Demo mode banner not showing for certain modes.
 +=== 2025-06-12 ===
 +    * Dashboard: Fix turning DESS off in the controls also causing DESS to be turned off in the site's settings.
 +=== 2025-06-11 ===
 +    * Device Overview: Add icon for Energy Solutions Smart Switch
 +    * Dashboard: Add new data attribute 'apt' and hide Passthrough from Controls based on it
 +    * Alarms: Fix error caused by missing data attribute for Tank and Temperature Sensor alarms
 +=== 2025-06-06 ===
 +    * Firmware update: Updating a GX device now properly waits with rescanning until the GX device is done rebooting
 +=== 2025-06-05 ===
 +    * Diagnostics: Migrate page to new frontend framework
 +=== 2025-06-04 ===
 +    * Fleet Monitor: Add enhanced search functionality triggered by the Command/Ctrl + K shortcut
 +    * Venus OS Large: Add support for connecting to Node-Red/Signal-K over IPv6
 +=== 2025-06-03 ===
 +    * Device Registration: Added spinner to login page when you open it after clicking device registration from remote console
 +=== 2025-05-28 ===
 +    * Add Installations: Add new page where sites can be added in bulk with the option of giving a name to the site and tags
 +    * Teams: Add the permission for admins/owner of the team to unlink it from a site to which the team has read-only right
 +    * Dashboard: Display AC Meter cards per instance for installations with energy meters and without certain devices
 +    * VRM AI Assistant: Introducing the AI Assistant, which is capable of helping users with adding custom widgets to the Advanced page
 +=== 2025-05-26 ===
 +    * Device list: Add GX IO Extender support
 +    * Dashboard: Display PV inverter cards per instance when using dashboard layout for installations with energy meters and without certain devices
 +=== 2025-05-21 ===
 +    * Navigation: Implement 'identifier search' in the new navigation bar.
 +    * Dashboard: Add new layout for installations with energy meters and without certain devices
 +    * Dashboard : Add EV card on dashboard to view EV information.
 +    * Register: Dealers can now share a link to new users to automatically link them to their dealer account after registering.
 +    * Register: Make go to login button smaller.
 +=== 2025-05-17 ===
 +    * Controls: Fix ESS controls not working for users with a non-Enligh language.
 +=== 2025-05-15 ===
 +    * Controls: Fix EVCS manual charge toggle on mobile.
 +    * General: Fix a language issue when entering demo mode
 +    * Installation data: Improve the logic for showing and hiding the dropdown items Solar and EV Charger.
 +    * Login: Fix redirecting users with one installation to their dashboard.
 +    * Controls: Fix unable to change EVCS mode
 +=== 2025-05-14 ===
 +    * Dashboard: New UI for the controls section on mobile to prevent accidental changes.
 +    * Dashboard: Fix VRM freezing under specific conditions when DESS is enabled.
 +    * Admin Device search: Allow searching by VE.Bus serial number.
 +    * Login: Improve performance & prevent showing the login page when already logged in.
 +=== 2025-05-13 ===
 +    * Login: Fix incorrect language being set when initially visiting the login page
 +=== 2025-05-12 ===
 +    * Login: Fix account language being overwritten by login
 +=== 2025-05-10 ===
 +    * Login/Register: Polyfill the new form items to work on iOS 15, until we stop support it completely.
 +=== 2025-05-08 ===
 +    * Login/Register: Decrease image size to improve page loading time
 +=== 2025-05-07 ===
 +    * Navbar: Fixed background not staying blurry when navigating between sites on a mobile device
 +    * Login/Register: Improve design for the login and register page
 +=== 2025-05-06 ===
 +    * Advanced: Added new widgets: EV Location, EV SOC, EV State
 +=== 2025-05-02 ===
 +    * Alarm Rules: Fixed issue where Automatic Alarm Monitoring would not update properly when moving to a different page
 +=== 2025-05-01 ===
 +    * DESS: fixed the DESS configuration page sometimes not loading
 +=== 2025-04-30 ===
 +    * Site Unlinking: Improve UX of API when unlinking a user from a site that wasn't bound in the first place
 +    * Alarms: Allow filling in decimals and negative numbers on mobile devices
 +    * DESS: Add support for ENTSOE multiple pricing options
 +=== 2025-04-24 ===
 +    * Dashboard: Fix incorrect magnitudes for large numbers, e.g. 20560W should be 20,56kW
 +=== 2025-04-19 ===
 +    * Recurring Reports: Make sure users get their report & let them know that their report template may need a correction (e.g. missing kWh sell price)
 +=== 2025-04-18 ===
 +    * Data Download: Fix corrupt Excel file when the selected timerange does not data available
 +    * Alarms: Validate basic info when adding or editing alarm rules
 +    * Widgets: Fix issue where timeseries could not be properly merged together
 +=== 2025-04-17 ===
 +    * Device list: Add icon for Motor drive.
 +=== 2025-04-16 ===
 +    * Teams: Fixed an issue where buttons in some modals couldn't be clicked on mobile
 +    * Device list: Add event log when a user opens Victron Connect
 +    * Command K: Add CommandK modal functionality in the context of an installation to navigate between installation pages
 +    * Mail Templates: Fix a couple missing variables & add monitoring
 +    * DESS: Remove `error_codes` for a successful DELETE call
 +    * Fleet Monitor: Fixed widgets sometimes not loading for users with >1500 sites
 +=== 2025-04-09 ===
 +    * Fleet Monitor: Removed the "Today's Alarms" card from the page to avoid confusion
 +    * Dashboard: Added support for new attributes to control tracker availability and conditionally hide trackers based on their values
 +    * Avatar: Added role-specific icons to user avatars for admins and technicians
 +    * Installation Overview: Remove unnecessary loop, slightly increasing performance when getting the minigraphs
 +    * Global Banner: Reduce the amount of times the banner is fetched to once per minute
 +    * Device list: Added "Open in Victron Connect" buttons
 +=== 2025-04-07 ===
 +    * Dashboard: Fix DESS cost and savings graph to show correct savings
 +    * Notifications: Fix email notifications toggle bug
 +=== 2025-04-04 ===
 +    * Advanced: Fix .xlsx downloads to not have corrupt headers
 +    * Event logs: Fix bug where event logs timestamps were shown based on location timezone instead of timezone set in GX device
 +    * Menu: Fixed bug where the Admin section was not visible in the menu on the Event Logs and Fleet Monitor pages.
 +=== 2025-04-03 ===
 +    * Alarm notifications: Fix bug where users would get their alarm notifications randomly muted
 +=== 2025-04-02 ===
 +    * Fleet monitor: Introduce fleet monitor page with alarms overview chart and stats widgets
 +=== 2025-03-29 ===
 +    * Alarms: Stop showing an error after an alarm was successfully deleted.
 +    * Dynamic ESS: Fix energy prices graph when a site is in an earlier timezone than the user.
 +=== 2025-03-28 ===
 +    * Invite Emails: Fix templating mistake in invite e-mails where personal message sender was not properly filled.
 +    * Two-factor Authentication: Add a `Recommended` badge on the more secure Authenticator App option to decrease reliance on vulnerable SMS 2FA.
 +=== 2025-03-27 ===
 +    * Eventlogs: First page to have been rebuilt in a new frontend framework, functionality stays the same.
 +=== 2025-03-26 ===
 +    * Installation dashboard: Fix the "DESS prices missing" alert banner showing when prices are not missing.
 +    * Installation dashboard: Show forecasts as a range.
 +    * Installation groups: Display admins of installation groups.
 +    * Reporting: Improve UX/UI of sliders when inserting values manually.
 +=== 2025-03-21 ===
 +    * Infrastructure: Upgrade PHP & improve server performance.
 +    * Dynamic ESS: Remove unnecessary labels for math tokens in the formula builder.
 +=== 2025-03-19 ===
 +    * Dashboard: Fixed an issue where the "This week" date range would select the incorrect start date.
 +    * Profile: When changing your account email, also send an email to the old email address to notify of this change.
 +    * General: Created a new banner which is displayed on all pages to urge non admin users to turn on two factor authentication.
 +    * Add installation: Adjusted GX device replacement dropdown height to keep search bar visible.
 +    * Enhanced search: Improved navigation and search consistency, keeping the input focused while navigating.
 +=== 2025-03-12 ===
 +    * Internal: Only save images in S3 and remove image from S3 on delete.
 +    * API: Fix users being able to set any minute value in price schedule
 +=== 2025-03-05 ===
 +    * Installation overview: Allow users to filter installations using alarm tags
 +=== 2025-03-04 ===
 +    * General settings: Redirect users to the `add-installation` page when transferring a GX device.
 +=== 2025-03-03 ===
 +    * DESS: Always write the DESS settings to Venus, even when DESS is turned off.
 +=== 2025-02-26 ===
 +    * Users: enable linking user to a site individually, even though they are already linked through a team or a group
 +    * Advanced: Added a "scroll to top" button to make it easier to navigate the advanced page
 +    * Advanced: Added a "scroll to widget" button allowing users to easily scroll to a specific widget
 +=== 2025-02-21 ===
 +   * Location: Fix timezone not updating when changing the location.
 +=== 2025-02-19 ===
 +   * Advanced: Save the latest 5 widget searches.
 +   * Event logs: Do not show consecutive advanced page changes.
 +   * Internal: retry transactions 3 times in case of deadlock.
 +   * Advanced: Fix issue with chart where certain data points were filtered out when the value was zero
 +=== 2025-02-12 ===
 +   * Site share: Hide the exact location by default (Dashboard: Weather card, Advanced: GPS widget)
 +   * Remote Console: Update the proxy URL for custom gui-v2 WASM binaries to non-deprecated /gui-v2
 +   * Enhanced search: Show Command+K icon on the text input of the Enhanced Search and update the modal design
 +   * Dashboard: Restructure the formatting of the generator runtime to make it more readable and fix the alignments of the piecharts
 +=== 2025-02-05 ===
 +    * Victron Connect: Improve performance of retrieving installations when using replica database
 +    * Dynamic ESS: Synchronise configuration with Venus OS
 +    * Add Installation: Allow selecting the correct device type of the form using a productId URL parameter instead of the device type
 +=== 2025-02-04 ===
 +    * Site permissions: Fix losing access to site when deleting team regardless of site membership
 +=== 2025-02-01 ===
 +    * Recurring Reports: Fix recurring reports not being sent due to an error
 +=== 2025-01-29 ===
 +    *  Advanced: Connect the data points of custom graphs that display prices or total energy
 +    *  Add Installation: Improve GX device replacement flow
 +    *  Device List: Remove 'unlink sites' button from a site's device list
 +    *  Installation users: Add modal confirmation before deleting user, team or installation group
 +    *  Installation overview: Fix installation name overflowing its container
 +=== 2025-01-23 ===
 +    * Navbar: For users with more than 10 sites, make the 'All installations' button show in the navbar on site-level
 +    * Installation graph: Show installation data for the last year in the installation graph on the dashboard
 +=== 2025-01-18 ===
 +    * General Settings: Fix GX replacement error caused by database changes
 +    * Alarms: Add proper validation on 'noDataAlarmTimeout' after seeing errors
 +=== 2025-01-16 ===
 +    * API: Return the id of the Access Token used in the `/me` endpoint.
 +=== 2025-01-15 ===
 +    * Event Log: Display the name of the user that changed the general settings of the site
 +    * Event Log: Display the name of the user that added / removed a tag and display the tag name
 +    * Event Log: Add new event descriptions when installation settings are updated to be more descriptive
 +    * Device List: Add reboot button for GX device
 +    * Remote VEConfigure: Add site name to VE.config download file
 +    * Teams: Improved management of team member roles and updated UI
 +    * Devices: Added icon for heatpump
 +    * Navbar: Clicking on an installation on the navbar while holding the command (on Mac) button or control (on Windows) will open the site in a new tab
 +    * Installation Overview: In the grid view, now you can see the battery to grid and the PV to grid values
 +    * Installation Overview: On mobile, made the 'add installation' button less prominent, as it isn't a typical mobile user flow
 +    * Installation Overview: Fix incorrect columns on the 'Active Alarms' pane
 +=== 2025-01-13 ===
 +    * Navigation Bar: Fix showing "Teams & Groups" for users with more than 1 installation
 +=== 2025-01-10 ===
 +    * Dashboard: Fix tank sensor values being displayed as "-" even though they are not outdated
 +=== 2025-01-08 ===
 +    * Advanced: Display the custom name of the MPPT tracker for that tracker's widget.
 +    * Dashboard: Allow users to set site avatar in a popup window.
 +    * Dynamic ESS Report: Dynamic ESS Report provides insight of energy bought, sold, and prices over a selected period.
 +    * Enhanced search: Add support for partial search for the names of the sites.
 +    * Installation overview: Allow a user to include all their sites in the production report if they have filters enabled.
 +    * General: Improve message formatting for api request validation errors.
 +    * Reporting: Fix reports not downloading for larger timeranges.
 +    * Installation overview: Add monitoring to minigraphs to investigate potential empty graphs.
 +    * Dynamic ESS: Quickly go back to overview after changing one step.
 +    * Dashboard: While on a day view, using the arrows now always takes you to the following day.
 +    * Installation overview: Added a battery icon to display battery percentages similar to how it is done for tanks.
 +=== 2025-01-06 ===
 +    * Admin: Store data attribute filters in the URL
 +=== 2025-01-02 ===
 +    * Advanced: Fix Generator State widget not showing values.
 +For earlier changelogs, see https://www.victronenergy.com/live/vrm_portal:change_log_2015-2024.
vrm_portal/change_log.1573036895.txt.gz · Last modified: (external edit)
