vrm_portal:change_log
| vrm_portal:change_log [2026-10-19 07:36] – aleximb | vrm_portal:change_log [2026-11-04 12:29] (current) – aleximb | ||
| Line 1: | Line 1: | ||
| ====== VRM Portal Changelog ====== | ====== VRM Portal Changelog ====== | ||
| + | === 2026-11-04 (1.132.0) === | ||
| + | * Dashboard: Lazy load the Dynamic ESS chart. | ||
| + | * Dashboard: Adjust the Dynamic ESS chart axis intervals for mobile devices. | ||
| + | * AI assistant: Stop the chat from jumping to the bottom while an answer is written. | ||
| + | * Access Management: Keep the Access Management menu item highlighted on team and group pages. | ||
| + | * Device list: Show the EVCS control panel button for all EVCS-v2 models. | ||
| + | * Alarms: Allow saving an alarm rule after switching every alarm state back on. | ||
| + | * API: Document the Replace GX (transfer-site) endpoint in the public API docs. | ||
| + | === 2026-10-28 (1.131.0) === | ||
| + | * Installation Users Settings: Show a message when removing a user from an installation if they are linked through a User Team or Installation Group. | ||
| + | * System optimisation: | ||
| + | * Advanced: Show generator run time in hours instead of seconds. | ||
| + | * Fix several translation bugs. | ||
| + | * VRM Light: Add an "Open in Maps" button to the weather bottom sheet. | ||
| + | === 2026-10-27 === | ||
| + | * Dashboard controls: Fixed an issue where inverter controls did not load correctly | ||
| + | === 2026-10-21 (1.130.0) === | ||
| + | * Dashboard: Add an "Air quality" | ||
| + | * Dashboard: Refresh minigraphs and Dynamic ESS graphs automatically when the dashboard stays open for a long time or the device wakes from sleep. | ||
| + | * DESS Settings: Preview today' | ||
| + | * EVCS report Excel export: Fix column order and split value/ | ||
| + | * Advanced: Fix the hover state of the Reset zoom button. | ||
| + | * Device list: Fix the hover state of device details. | ||
| === 2026-10-19 === | === 2026-10-19 === | ||
| * Dashboard controls: Fix grid current limit controls not showing up for inverters | * Dashboard controls: Fix grid current limit controls not showing up for inverters | ||
| + | * Preferences: | ||
| === 2026-10-15 === | === 2026-10-15 === | ||
vrm_portal/change_log.1792395361.txt.gz · Last modified: by aleximb
