vrm_portal:change_log
| vrm_portal:change_log [2026-09-10 10:26] – aleximb | vrm_portal:change_log [2026-11-04 12:29] (current) – aleximb | ||
| Line 1: | Line 1: | ||
| ====== VRM Portal Changelog ====== | ====== VRM Portal Changelog ====== | ||
| - | ===== 2026-09-10 ===== | + | === 2026-11-04 (1.132.0) === |
| + | * Dashboard: Lazy load the Dynamic ESS chart. | ||
| + | * Dashboard: Adjust the Dynamic ESS chart axis intervals for mobile devices. | ||
| + | * AI assistant: Stop the chat from jumping to the bottom while an answer is written. | ||
| + | * Access Management: Keep the Access Management menu item highlighted on team and group pages. | ||
| + | * Device list: Show the EVCS control panel button for all EVCS-v2 models. | ||
| + | * Alarms: Allow saving an alarm rule after switching every alarm state back on. | ||
| + | * API: Document the Replace GX (transfer-site) endpoint in the public API docs. | ||
| + | === 2026-10-28 (1.131.0) === | ||
| + | * Installation Users Settings: Show a message when removing a user from an installation if they are linked through a User Team or Installation Group. | ||
| + | * System optimisation: | ||
| + | * Advanced: Show generator run time in hours instead of seconds. | ||
| + | * Fix several translation bugs. | ||
| + | * VRM Light: Add an "Open in Maps" button to the weather bottom sheet. | ||
| + | === 2026-10-27 === | ||
| + | * Dashboard controls: Fixed an issue where inverter controls did not load correctly | ||
| + | === 2026-10-21 (1.130.0) === | ||
| + | * Dashboard: Add an "Air quality" | ||
| + | * Dashboard: Refresh minigraphs and Dynamic ESS graphs automatically when the dashboard stays open for a long time or the device wakes from sleep. | ||
| + | * DESS Settings: Preview today' | ||
| + | * EVCS report Excel export: Fix column order and split value/ | ||
| + | * Advanced: Fix the hover state of the Reset zoom button. | ||
| + | * Device list: Fix the hover state of device details. | ||
| + | === 2026-10-19 === | ||
| + | * Dashboard controls: Fix grid current limit controls not showing up for inverters | ||
| + | * Preferences: | ||
| + | === 2026-10-15 === | ||
| + | * Device list: Fix remote support port overflow. | ||
| + | === 2026-10-14 (1.129.0) === | ||
| + | * VRM Light: Load the Consumption and Solar sheets in parallel so they appear after one round trip instead of several, which cuts the wait noticeably on mobile connections. | ||
| + | * Event log: Show who wrote a note and its text, for installation notes and, for admins, admin notes. | ||
| + | * Event log: Include the actor name in more events. | ||
| + | * Event log: Add an entry when someone generates or downloads a site report. | ||
| + | * Firmware update: Block updating VE.Bus (Multi/ | ||
| + | * Firmware update: Reinstall the firmware version a device already runs, without changing the version. | ||
| + | * Dynamic ESS: Show the settings to users with read-only access without letting them change anything; the wizard steps and the on/off switch stay closed to them. | ||
| + | * Dashboard: Hide the " | ||
| + | * Dashboard: Show the AI assistant button for every user, and hide it while scrolling on mobile. | ||
| + | * AI Assistant: Open with the current site and page already known. | ||
| + | * AI Assistant: Replace the starter questions on the AI assistant page. | ||
| + | * AI Assistant: Show a deprecation banner on the single-site AI assistant. | ||
| + | * VRM Light: Add a "Learn more" page to the Energy tab of the Dynamic ESS sheet. | ||
| + | * Installation groups: Allow adding a user to a group directly when they are already linked through a team. | ||
| + | * Installation groups: Show a clear message instead of an error when opening an invite link for a team or group you already belong to. | ||
| + | * Notification preferences: | ||
| + | * Switches: Widen the controls and switches panel on desktop and wrap long switch names. | ||
| + | * Device list: Show the EV charger' | ||
| + | * Device list: Show the correct gateway icon for GlobalLink connections. | ||
| + | * EV charging: Allow the paid EV features for users whose vehicles are connected through Node-RED (Enode/ | ||
| + | * VRM UI: Use the shared dialog component for temporary and custom dialogs (clear alarm, access tokens and others), with the same keyboard and focus behaviour everywhere. | ||
| + | * VRM UI: Support keyboard navigation in select fields with the arrow keys and Enter. | ||
| + | * API: Speed up permission checks on every request. | ||
| + | === 2026-10-13 === | ||
| + | === 2026-10-07 (1.128.0) === | ||
| + | * Update colours for success, error and warning texts. | ||
| + | * System Optimisation: | ||
| + | * Dashboard: Fix the dashboard date picker on mobile being silently replaced by a quick range. | ||
| + | === 2026-10-02 === | ||
| + | * Advanced: Fix larger CSV exports failing | ||
| + | === 2026-09-30 (1.127.0) === | ||
| + | * Fleet dashboard: Added support for downloading the alarm reports from the VRM fleet monitor over a selected time range. | ||
| + | * VRM in VC: Remove Overview dropdown from the DESS tab in the Data tab. | ||
| + | * VRM in VC: Fix and adjust rule to show Solar card in Dashboard tab. | ||
| + | * VRM in VC: Fix the missing legend items under the graphs in the Data sheets. | ||
| + | * DESS: Fix untranslated Dynamic ESS config title. | ||
| + | * Profile: Remove the language setting from the profile page. | ||
| + | * Navbar: Show the Access management item to all users, also when they are not in a team or installation group. | ||
| + | * Event Log: Show which type of device was deleted. | ||
| + | * VRM in VC: Replace the arrow icons on the Grid and Solar bottom sheets with battery, sun and grid icons. | ||
| + | * VRM in VC: Show a fade, a cut-off card and a scrollbar when a bottom sheet has more to scroll. | ||
| + | * Teams and Installation Groups: Hide the access level controls from users who are not allowed to change access levels. | ||
| + | * Notes: YouTube and Vimeo videos embedded in installation notes show and play again in the notes view; Vimeo videos are embedded too. | ||
| + | === 2026-09-28 === | ||
| + | * Advanced: Fix error messages when trying to download an invalid report | ||
| + | === 2026-09-23 (1.126.0) === | ||
| + | * iOS: Fix the main graph jumping on the dashboard. | ||
| + | * VRM in VictronConnect: | ||
| + | === 2026-09-21 (1.125.0) === | ||
| + | * Installation Groups: Allow appointing teams as group managers. | ||
| + | * Installation Groups: The "Edit group" and "Edit team" buttons are renamed to "Group settings" | ||
| + | * Session: Added support for logging out of all other devices to prevent unauthorised access. | ||
| + | * Dashboard: AC loads are hidden on the input side. | ||
| + | * Dashboard: Read-only users no longer see the photo and note action buttons, since they cannot use them. | ||
| + | * Dynamic ESS: The energy graph now draws a zero line for hours without energy bars, so those hours read as zero instead of empty space. | ||
| + | * Photos: HEIC and HEIF photos, the iPhone default format, are now accepted when uploading installation photos in the portal or through the API. | ||
| + | * Event log: Every alarm rule change is now recorded in detail: the metric and device, the thresholds, whether the rule is enabled and the notification delay, for created, edited and deleted rules. | ||
| + | * Access requests: Users who ask for access to an installation or a team are now told by email when the request is declined, and the decision is recorded in the event log. | ||
| + | * Access requests: Admin email addresses are no longer listed in the notification email. | ||
| + | * Switches: Added support for generic inputs. | ||
| + | * iOS: Add support for password manager autofill for VRM login. | ||
| + | * iOS: Fix the remote console closing element. | ||
| + | * Site share: Fix changing settings permissions. | ||
| + | === 2026-09-10 | ||
| * Dashboard: Fix Dynamic ESS chart x-axis misalignment. | * Dashboard: Fix Dynamic ESS chart x-axis misalignment. | ||
| * Access Management: Fix access level change confirmation dialog button size. | * Access Management: Fix access level change confirmation dialog button size. | ||
| - | ===== 2026-09-09 (1.124.0) | + | * Garmin: Improved switch discoverability to match VRM Portal. |
| + | * Garmin: Improved rendering of long values above slider switches to avoid overlap with the name. | ||
| + | === 2026-09-09 (1.124.0) === | ||
| * Dashboard: Show DC sources (alternator, | * Dashboard: Show DC sources (alternator, | ||
| * Dashboard: Show the DC Power / DC Loads card in the parallel (ESS) layout too, placed beside the battery when there is room and below it otherwise. | * Dashboard: Show the DC Power / DC Loads card in the parallel (ESS) layout too, placed beside the battery when there is room and below it otherwise. | ||
vrm_portal/change_log.1789036017.txt.gz · Last modified: by aleximb
