vrm_portal:change_log
| vrm_portal:change_log [2026-07-29 13:46] – aleximb | vrm_portal:change_log [2026-09-10 15:31] (current) – aleximb | ||
| Line 1: | Line 1: | ||
| ====== VRM Portal Changelog ====== | ====== VRM Portal Changelog ====== | ||
| + | ===== 2026-09-10 ===== | ||
| + | * Dashboard: Fix Dynamic ESS chart x-axis misalignment. | ||
| + | * Access Management: Fix access level change confirmation dialog button size. | ||
| + | * Garmin: Improved switch discoverability to match VRM Portal. | ||
| + | * Garmin: Improved rendering of long values above slider switches to avoid overlap with the name. | ||
| + | ===== 2026-09-09 (1.124.0) ===== | ||
| + | * Dashboard: Show DC sources (alternator, | ||
| + | * Dashboard: Show the DC Power / DC Loads card in the parallel (ESS) layout too, placed beside the battery when there is room and below it otherwise. | ||
| + | * Dashboard: Update the weather and card icons in VRM and VRM Light to the new design. | ||
| + | * Dynamic ESS Settings: Allow different price formulas for Saturday and Sunday. | ||
| + | * Dynamic ESS Settings: Add the option to disable solar production at low buy prices. | ||
| + | * Dynamic ESS Settings: New configurations now have “My prices can be negative” enabled by default. | ||
| + | * Installation settings: Allow admins to unlink any installation group. | ||
| + | * Access management: Remove an individual user's access to an installation even when they are also linked through a team or installation group; the team or group keeps its access. | ||
| + | * Installation Notes: Fix notes not being editable immediately after adding them. | ||
| + | * Fleet monitor: Add a widget listing sites with zero consumption for some time. | ||
| + | * Multi-site AI assistant: Add widget creation to the multi-site assistant. | ||
| + | * System optimisation: | ||
| + | * Installation groups: Allow user teams to be assigned as group managers. | ||
| + | === 2026-09-02 (1.123.0) === | ||
| + | * User Teams & Installation Groups: Complete redesign and rehaul of the Teams and Groups (Access Management) pages. | ||
| + | * User Teams & Installation Groups: Allow adding a new site to a user team or installation group when creating it. | ||
| + | * User Teams & Installation Groups: Add bulk removal of sites and groups from a user team, with a confirmation step. | ||
| + | * Preferences: | ||
| + | * Dashboard: Fix the chart loading state for future ranges. | ||
| + | * Dashboard: Fix sell & buy prices interval if they mismatch in timeframes (15 min vs 1 hour intervals). | ||
| + | * Geofence: Improve user experience by updating the " | ||
| + | * Android App: Fix the photo picker router for uploading. | ||
| + | === 2026-08-31 === | ||
| + | * Android and iOS: Add Switches widget | ||
| + | === 2026-08-26 === | ||
| + | * Dashboard: Fix the chart loading state for future ranges | ||
| + | === 2026-08-19 (1.122.0) === | ||
| + | * Dashboard: Replace the DESS card icons. | ||
| + | * Dashboard: Fix "Part of X groups" | ||
| + | * Invitations: | ||
| + | * Installation Notes: Keep multiple notes per installation, | ||
| + | * Improve the Add installation and Replace GX device flow so device data is only requested when it is needed. | ||
| + | * Improve VRM API response times across all requests through faster token validation and request routing. | ||
| + | * Improve the processing speed of solar forecast imports and EV trip detection. | ||
| + | * Settings: Prompt to delete the replaced GX's site after a GX swap. | ||
| + | * Settings and Events: Hide admin, technician and support staff events from read-only users. | ||
| + | === 2026-08-14 === | ||
| + | * Navigation (Language selector): Fix Turkish language name. | ||
| + | === 2026-08-12 (1.121.0) === | ||
| + | * Advanced: Show a single reset zoom button at the top of the page when zoomed in. | ||
| + | * Dashboard: Time picker update for hourly based intervals. | ||
| + | * Watch: iOS watch app Switches control. | ||
| + | * Mobile: Show the SoC forecast in the widgets widgets. | ||
| + | * Event log: Switch control changes (toggles, dimming, mode changes) are now recorded in the event log, showing who made the change, when, and the new state. | ||
| + | * Reports: The EVCS report PDF export now includes all pages instead of only the currently viewed page. | ||
| + | * Tags: Add tags to multiple installations in bulk. | ||
| + | * Installation general settings: The installation general settings page has been migrated to Vue 3. | ||
| + | === 2026-08-07 === | ||
| + | * Diagnostics: | ||
| + | === 2026-08-05 (1.120.0) === | ||
| + | * Tags: No longer automatically create a tag for the team or installation group a site belongs to. | ||
| + | * Access management: Show " | ||
| + | * Installation groups: Improve the response time of updating installation groups that contain many installations. | ||
| + | * Dashboard: Fix the forecasted total sometimes showing a lower bound below the already measured total. | ||
| + | * Navigation: Add a multi-site AI assistant to the primary navbar for users with 10 or more sites. | ||
| + | * Advanced: A " | ||
| + | === 2026-08-04 === | ||
| + | * Dashboard: Fix installation data not updating every minute anymore. | ||
| + | === 2026-07-30 === | ||
| + | * Fix Safari zooming in the page on inputs and text areas. | ||
| === 2026-07-29 (1.119.0) === | === 2026-07-29 (1.119.0) === | ||
| * Dashboard: Fixed showing the custom name of the 4th MultiRS tracker. | * Dashboard: Fixed showing the custom name of the 4th MultiRS tracker. | ||
vrm_portal/change_log.1785325579.txt.gz · Last modified: by aleximb
