vrm_portal:change_log
vrm_portal:change_log [2026-01-29 14:49] aleximbvrm_portal:change_log [2026-03-20 15:10] (current) aleximb
 ====== VRM Portal Changelog ====== ====== VRM Portal Changelog ======
 +=== 2026-03-20 ===
 +   * Garmin Watch APP: New release featuring switch controls, a new view with today's totals for a site, using totals for complications, as well as adding favorite site settings and complication site choosing to the APP settings menu
 +=== 2026-03-19 ===
 +   * Changing Passwords: Change to realtime password validation & fix issue where missing a special character would not show a clear error.
 +=== 2026-03-18 ===
 +   * Dashboard: system sizing installations now display separate energy meter cards in the VC embedded view instead of the legacy dashboard layout.
 +   * Dashboard: all widgets now follow a consistent expandable behaviour and visual hierarchy to ensure key information is presented uniformly.
 +   * Dashboard: users can now choose which temperature sensor or tank is displayed in the VC embedded dashboard view.
 +   * Dashboard: EV card now shows the vehicle’s current street and city when location sharing is enabled, including a home indicator when at the installation location.
 +   * Dashboard: air quality metrics such as CO2 and PM2.5 are now shown more prominently within the temperature card.
 +   * Installation: unlink action is now disabled for installations managed via installation groups or teams, with clear guidance shown to the user.
 +   * Teams: team details page has been migrated to newer framework.
 +   * Teams: team overview page has been migrated to newer framework.
 +   * Dashboard: add “Total energy” to the EVCS card in the alternative dashboard layout.
 +   * OneID: Fix migrating account when a OneID account already exists, and the VRM account has a too weak password
 +=== 2026-03-13 ===
 +   * Dynamic ESS Settings: Fix loop where configuration form goes back to the first step after completing the second step.
 +   * Login: Fix Garmin watch login when logging in through OneID.
 +=== 2026-03-10 ===
 +   * Login: Fix logins through OneID in the VRM app when on an ipad.
 +=== 2026-03-04 ===
 +   * Version detection: Improve automatic version detection and reloading for the Vue 3 pages.
 +   * Alarm log: Improve performance of sites with many alarms.
 +=== 2026-03-03 ===
 +   * Venus OS Large: Remove unnecessary "Missing NodeRed" toaster when not running NodeRed
 +=== 2026-02-28 ===
 +   * Notifications: Allow users to (re)subscribe to alarm notifications, e.g. after clicking the unsubscribe email in alarm emails.
 +=== 2026-02-25 ===
 +   * Date Picker: Add `Recent and Upcoming` quickrange.
 +   * Data Download: Deprecate old vrm-api based `/data-download` endpoint & direct users to use the new vrm-reports-api.
 +   * Alarm Logs: Don't show an error toaster on empty alarmlog page.
 +   * API Docs: Document installation-user management endpoints.
 +   * API: Add attribute-exists validation to `/installation-data-attributes` endpoint.
 +   * Tags API: Group tags by source & allow filtering on a specific tag source.
 +   * Timezones: Synchronise VRM's timezone with the GX's timezone.
 +   * Advanced: Add location history to GPS widget.
 +=== 2026-02-20 ===
 +   * Fix issue on safari causing blank space when window width was right on the edge of mobile and desktop width
 +=== 2026-02-12 ===
 +   * Dashboard: Change number formatting for Meterological sensor.
 +   * Dashboard: Use Temperature sensor type for the name of the card if no custom name is set.
 +   * Profile: Replace all phone inputs with the new phone input component.
 +   * Notifications: Allow users to see, accept and reject installation access requests in the notifications popup.
 +   * Data Download: Fix issues with partially filled columns.
 +=== 2026-02-05 ===
 +   * Dashboard: Fix “This year” time range start date.
 +=== 2026-02-04 ===
 +   * Home page: Added shortcut buttons to favorite installations for easy access to the Advanced and Device List pages.
 +   * Advanced: In custom widgets with individual PV trackers, we now also show the custom name per tracker.
 +   * Datepicker: Fixed an issue where you could not select custom dates in German.
 +=== 2026-02-02 ===
 +  * [Admin] Firmware release: Fixed a Safari-specific layout issue in the Markdown editor.
 === 2026-01-29 === === 2026-01-29 ===
   * Event Log: Show VRM Plus changes in the event log.   * Event Log: Show VRM Plus changes in the event log.
vrm_portal/change_log.1769694544.txt.gz · Last modified: by aleximb
