vrm_portal:change_log
| vrm_portal:change_log [2026-01-07 11:30] – aleximb | vrm_portal:change_log [2026-02-05 14:34] (current) – aleximb | ||
| Line 1: | Line 1: | ||
| ====== VRM Portal Changelog ====== | ====== VRM Portal Changelog ====== | ||
| + | === 2026-02-05 === | ||
| + | * Dashboard: Fix “This year” time range start date. | ||
| + | === 2026-02-04 === | ||
| + | * Home page: Added shortcut buttons to favorite installations for easy access to the Advanced and Device List pages. | ||
| + | * Advanced: In custom widgets with individual PV trackers, we now also show the custom name per tracker. | ||
| + | * Datepicker: Fixed an issue where you could not select custom dates in German. | ||
| + | === 2026-02-02 === | ||
| + | * [Admin] Firmware release: Fixed a Safari-specific layout issue in the Markdown editor. | ||
| + | === 2026-01-29 === | ||
| + | * Event Log: Show VRM Plus changes in the event log. | ||
| + | * VRM Warning: Improved the VRM warning design and added a new warning for users who reset their location while DESS is enabled. | ||
| + | * Datepicker: Fixed editing custom dates by typing in the textfield. | ||
| + | * Reports: New EVCS reports to track charging history and charging sessions. | ||
| + | === 2026-01-26 === | ||
| + | * Advanced: Added 'PV Yield Overview' | ||
| + | * Advanced: Fix the NOx axis going negative for the 'Air Quality` widget. | ||
| + | * Advanced: Fix `hours of AC in` on the VE.Bus Summary widget OOM error for large datasets. | ||
| + | === 2026-01-22 === | ||
| + | * Production Reports: Fix identifier sometimes being returned as int, breaking report generation. | ||
| + | * API: Clean up & improve performance for the `/ | ||
| + | * API: Fix `/ | ||
| + | * Advanced: Fix x-axis disappearing after zooming. | ||
| + | === 2026-01-21 === | ||
| + | * Installation DESS settings: fix 500 error for some sites when calling the settings endpoint | ||
| + | * Invites: Improved invite acceptance errors by showing the specific failure reason from the API instead of a static error message | ||
| + | * Installation: | ||
| + | * Advanced: Add ' | ||
| + | * Remote Console: Fix missing close console button on small screens | ||
| + | === 2026-01-20 === | ||
| + | * Advanced: Fix AC Energy Summary not showing L3 power. | ||
| + | === 2026-01-15 === | ||
| + | * Navigation: Fix an issue causing middle mouse clicks to open duplicate tabs in some browsers. | ||
| + | === 2026-01-14 === | ||
| + | * Dashboard: Fixed an issue where AC Load details would not show up. | ||
| + | * General: Update the favicons to the new version. | ||
| + | * Navigation: Fix an issue where submenu would not update correctly on page change. | ||
| + | * Dashboard: Fix bug where live feed graph was missing Y-axis for future ranges, and "Last year" range was missing the " | ||
| + | * Command K: Allow users to switch between navigation and search mode in installation context. | ||
| + | * Remote Console: Fix bug where modal title was too dark in dark mode. | ||
| + | === 2026-01-09 === | ||
| + | * Device list: Show EV model and VIN in the details of the EV device. | ||
| === 2026-01-07 === | === 2026-01-07 === | ||
| * Login: Improve user feedback when encountering issues during login | * Login: Improve user feedback when encountering issues during login | ||
vrm_portal/change_log.1767781834.txt.gz · Last modified: by aleximb
