vrm_portal:change_log
| vrm_portal:change_log [2025-11-26 10:58] – aleximb | vrm_portal:change_log [2025-12-03 15:47] (current) – aleximb | ||
| Line 1: | Line 1: | ||
| ====== VRM Portal Changelog ====== | ====== VRM Portal Changelog ====== | ||
| + | === 2025-12-03 === | ||
| + | * Dashboard: Add Apparent power to the Grid Meter Combined chart for system sizing layouts. | ||
| + | * Advanced: Add Apparent power tab for the Grid Meter Combined widget. | ||
| + | * Dashboard: Hide the minus sign when the temperature is 0 degrees. | ||
| + | * Dashboard: Reduce the size of the weather icons. | ||
| + | * Navigation: Auto hide the navigation bar, allow users to always hide it from Preferences, | ||
| + | * Teams and Installation Groups: Fix to ensure the Members dropdown inside the “Link users” modal closes when users click outside the dropdown. | ||
| + | * API: Add an endpoint to show total usage of VRM | ||
| + | === 2025-12-02 === | ||
| + | * Recurring Reports: Fix error causing recurring reports to not generate. | ||
| === 2025-11-26 === | === 2025-11-26 === | ||
| * API: Add `/ | * API: Add `/ | ||
vrm_portal/change_log.1764151111.txt.gz · Last modified: by aleximb
