vrm_portal:change_log
| vrm_portal:change_log [2025-11-12 11:53] – aleximb | vrm_portal:change_log [2025-12-03 15:47] (current) – aleximb | ||
| Line 1: | Line 1: | ||
| ====== VRM Portal Changelog ====== | ====== VRM Portal Changelog ====== | ||
| + | === 2025-12-03 === | ||
| + | * Dashboard: Add Apparent power to the Grid Meter Combined chart for system sizing layouts. | ||
| + | * Advanced: Add Apparent power tab for the Grid Meter Combined widget. | ||
| + | * Dashboard: Hide the minus sign when the temperature is 0 degrees. | ||
| + | * Dashboard: Reduce the size of the weather icons. | ||
| + | * Navigation: Auto hide the navigation bar, allow users to always hide it from Preferences, | ||
| + | * Teams and Installation Groups: Fix to ensure the Members dropdown inside the “Link users” modal closes when users click outside the dropdown. | ||
| + | * API: Add an endpoint to show total usage of VRM | ||
| + | === 2025-12-02 === | ||
| + | * Recurring Reports: Fix error causing recurring reports to not generate. | ||
| + | === 2025-11-26 === | ||
| + | * API: Add `/ | ||
| + | * Remote Console: Improve fetching logic of the `New UI` to prevent unnecessary re-downloads. | ||
| + | === 2025-11-20 === | ||
| + | * Device list: Rename Motor Drive to E-drive and adjust icons. | ||
| + | * Dashboard: Various fixes of the EV card data formatting and display conditions. | ||
| + | * API: Revert the changes done to the `live_feed` type on the `/stats` endpoint. | ||
| + | === 2025-11-19 === | ||
| + | * Advanced: Improve header and calendar behaviour on mobile (portrait and landscape mode). | ||
| + | * Navigation: Add language selector to the navigation bar. | ||
| + | * Installation data: Load data from different data sources independently. | ||
| + | * Widget AI: Allow adding the same widget to multiple sites. | ||
| + | * Remote Console: Add a new progress bar. | ||
| + | * Remote Console: Allow users to open NodeRED and SignalK from the remote console via VRM. | ||
| + | === 2025-11-14 === | ||
| + | * Allow choosing which Remote console version to show in full screen with a URL parameter. | ||
| + | * Dashboard: Show session and total energy for EVCS. | ||
| + | * Dashboard: Fix charging time for EVCS connected over MQTT. | ||
| + | === 2025-11-13 === | ||
| + | * Installation Groups: Increase maximum amount of sites that can be added in bulk to 250. | ||
| + | * Enhanced Search: Allow searching for sites with a specific product (by name). | ||
| === 2025-11-12 === | === 2025-11-12 === | ||
| - | * Accesstokens: | + | * Dynamic ESS: Added support to specify different pricing formulas for DESS that vary throughout the day. |
| - | * Search: Fix not finding exact site match with special characters | + | * Accesstokens: |
| + | * Search: Fix not finding exact site match with special characters. | ||
| + | * Remote console: Fix remote console not opening automatically when ? | ||
| + | * Demo mode: Fix not being able to visit other demo sites when visiting a ?demoShare url while not logged in. | ||
| === 2025-11-11 === | === 2025-11-11 === | ||
| * Dashboard: Fix EVCS, PV Inverter and Grid Meter tiles missing for the layout without a inverter/ | * Dashboard: Fix EVCS, PV Inverter and Grid Meter tiles missing for the layout without a inverter/ | ||
vrm_portal/change_log.1762944826.txt.gz · Last modified: by aleximb
