vrm_portal:change_log
vrm_portal:change_log [2025-11-05 13:35] aleximbvrm_portal:change_log [2025-12-03 15:47] (current) aleximb
 ====== VRM Portal Changelog ====== ====== VRM Portal Changelog ======
 +=== 2025-12-03 ===
 +   * Dashboard: Add Apparent power to the Grid Meter Combined chart for system sizing layouts.
 +   * Advanced: Add Apparent power tab for the Grid Meter Combined widget.
 +   * Dashboard: Hide the minus sign when the temperature is 0 degrees.
 +   * Dashboard: Reduce the size of the weather icons.
 +   * Navigation: Auto hide the navigation bar, allow users to always hide it from Preferences, and various other UX improvements.
 +   * Teams and Installation Groups: Fix to ensure the Members dropdown inside the “Link users” modal closes when users click outside the dropdown.
 +   * API: Add an endpoint to show total usage of VRM
 +=== 2025-12-02 ===
 +   * Recurring Reports: Fix error causing recurring reports to not generate.
 +=== 2025-11-26 ===
 +   * API: Add `/v2/installation-data-attributes` endpoint to allow users & tools to query their sites by (multiple) data attributes.
 +   * Remote Console: Improve fetching logic of the `New UI` to prevent unnecessary re-downloads.
 +=== 2025-11-20 ===
 +   * Device list: Rename Motor Drive to E-drive and adjust icons.
 +   * Dashboard: Various fixes of the EV card data formatting and display conditions.
 +=== 2025-11-20 ===
 +   * API: Revert the changes done to the `live_feed` type on the `/stats` endpoint.
 +=== 2025-11-19 ===
 +   * Advanced: Improve header and calendar behaviour on mobile (portrait and landscape mode).
 +   * Navigation: Add language selector to the navigation bar.
 +   * Installation data: Load data from different data sources independently.
 +   * Widget AI: Allow adding the same widget to multiple sites.
 +   * Remote Console: Add a new progress bar.
 +   * Remote Console: Allow users to open NodeRED and SignalK from the remote console via VRM.
 +=== 2025-11-14 ===
 +   * Allow choosing which Remote console version to show in full screen with a URL parameter.
 +   * Dashboard: Show session and total energy for EVCS.
 +   * Dashboard: Fix charging time for EVCS connected over MQTT.
 +=== 2025-11-13 ===
 +   * Installation Groups: Increase maximum amount of sites that can be added in bulk to 250.
 +   * Enhanced Search: Allow searching for sites with a specific product (by name).
 +=== 2025-11-12 ===
 +   * Dynamic ESS: Added support to specify different pricing formulas for DESS that vary throughout the day.
 +   * Accesstokens: Add endpoint to get a regular JWT from the access token (VictronConnect integration).
 +   * Search: Fix not finding exact site match with special characters.
 +   * Remote console: Fix remote console not opening automatically when ?openRemoteConsole is in the url.
 +   * Demo mode: Fix not being able to visit other demo sites when visiting a ?demoShare url while not logged in.
 +=== 2025-11-11 ===
 +   * Dashboard: Fix EVCS, PV Inverter and Grid Meter tiles missing for the layout without a inverter/charger.
 +=== 2025-11-06 ===
 +   * Remote console: Fix remote console choice title color not visible in dark mode.
 === 2025-11-05 === === 2025-11-05 ===
    * Dashboard: Add dedicated card for Heatpump type in the alternative dashboard.    * Dashboard: Add dedicated card for Heatpump type in the alternative dashboard.
Line 7: Line 49:
 === 2025-10-30 === === 2025-10-30 ===
    * Reports: Use old logic of calculating generator runtimes for "Hybrid genset" and "Economic" reports    * Reports: Use old logic of calculating generator runtimes for "Hybrid genset" and "Economic" reports
 +   * Installation data: Switch around the Grid meter combined widget and the kWh tiles.
 === 2025-10-29 === === 2025-10-29 ===
    * Installations overview: Added search bars to the 'Alarm', 'User teams', 'Installation groups' and 'Tags' filters (only visible when there are more than 5 options present)    * Installations overview: Added search bars to the 'Alarm', 'User teams', 'Installation groups' and 'Tags' filters (only visible when there are more than 5 options present)
vrm_portal/change_log.1762346106.txt.gz · Last modified: by aleximb
