vrm_portal:change_log
vrm_portal:change_log [2025-10-02 12:49] – aleximb | vrm_portal:change_log [2025-10-16 12:18] (current) – aleximb | ||
+ | === 2025-10-16 === | ||
+ | * Installation/ | ||
+ | * DESS Settings: Improve UX, change stepsize for prices & costs to cents instead of full euros. | ||
+ | * Home: Add favorite installations, | ||
+ | * Navbar: Make bottom bar take up less space on mobile landscape view. | ||
+ | * Modals: Fix pressing x not closing the modal. | ||
+ | * Fleet Widget: Add D-Bus round trip widget. | ||
+ | * Admin: Enable the on-hover tooltip showing the data label per data point. | ||
+ | === 2025-10-09 === | ||
+ | * Advanced: Reduce the padding of the fixed bar to save vertical space. | ||
+ | * Remote console: Fix the touch event on the checkbox to " | ||
+ | * Tags: Apply the DESS tag to sites running Dynamic ESS. | ||
+ | === 2025-10-07 === | ||
+ | * Share Site: fix embedding iframe empty state for 5 minutes. | ||
+ | === 2025-10-06 === | ||
+ | * DESS wizard : Null battery costs will now be correctly considered as 0.01 as the default value | ||
=== 2025-10-02 === | === 2025-10-02 === | ||
- | * Dashboard: Show Power for EMs with the EVCS role. | + | * Dashboard: Show Power for EMs with the EVCS role and hide the unavailable details. |
+ | * Controls: Hide the EVCS Control card for EMs with the EVCS role. | ||
=== 2025-10-01 === | === 2025-10-01 === | ||
* Alarms: Remove instance number from alarm groups title. | * Alarms: Remove instance number from alarm groups title. |
vrm_portal/change_log.1759402152.txt.gz · Last modified: by aleximb
