vrm_portal:change_log
vrm_portal:change_log [2025-06-03 12:28] aleximbvrm_portal:change_log [2025-07-10 17:11] (current) aleximb
 ====== VRM Portal Changelog ====== ====== VRM Portal Changelog ======
 +=== 2025-07-10 ===
 +    * Fleet monitor: Significantly improve page responsiveness after a lot of data is loaded.
 +    * Venus OS Large: Explain that 'VRM Portal Mode' should be set to 'Full' to access Node-RED and Signal-K.
 +=== 2025-07-09 ===
 +    * General: Added a backup font in case the browser cannot render special characters (Russian, Ukrainian, etc).
 +    * General: The default time that notifications are shown was increased to 20 seconds.
 +    * Advanced: Fixed a bug that allowed editing multiple widgets via 'Enable/Disable All Widgets' even when widgets were locked.
 +    * Advanced: Added a 'Create with AI' button next to the 'Create Custom Widget' button to highlight the possibility of creating a custom widget using AI.
 +    * Fleet monitor: Decrease the time it takes for the page to load with data.
 +=== 2025-07-04 ===
 +    * Validation: Fix TypeError in validators
 +    * Dynamic ESS Report: Improve code quality & make sure the report is generated in the user's preferred language.
 +=== 2025-07-03 ===
 +    * Infrastructure: Upgrade backend API framework to newer version
 +    * Site groups: Make the alarm toggle changeable for your own account even if you are not group owner/admin.
 +=== 2025-07-02 ===
 +    * Users: Add mailto link to teams, groups & installation user management pages to simplify contacting users in case of issues.
 +    * Installation overview: Your favourite installations will now show on top of your installation overview.
 +    * Device List: Show local IP address again.
 +    * Reporting: Fix Dynamic ESS report not showing at all if DESS was off for a portion of the selected period.
 +    * Preferences: Redesigned the preferences pages.
 +=== 2025-07-01 ===
 +    * Navbar: Fix `Dynamic ESS` settings not being shown in the navbar on pages in the new frontend framework.
 +    * VictronConnect: Add route to support future remote console feature.
 +    * Groups: Fix bug where a team as site-group administrators are not able to add a site they have full access to.
 +=== 2025-06-25 ===
 +    * Dashboard: Show different banner for opportunistic battery balancing.
 +    * Settings: Allow user to reset his consumption forecast.
 +    * General: Animate VRM AI Assistant button icon.
 +=== 2025-06-24 ===
 +    * Login: Remove `*******` placeholder from the password field to prevent confusion.
 +=== 2025-06-18 ===
 +    * Installation overview: Make all filters apply immediately for consistent behaviour.
 +    * Installation group: Fix styling of 'Link user' modal inputs on smaller devices.
 +    * Fleet monitor: Added relative difference column to the solar widget.
 +=== 2025-06-17 ===
 +    * Dashboard: Fix Demo mode banner not showing for certain modes.
 +=== 2025-06-12 ===
 +    * Dashboard: Fix turning DESS off in the controls also causing DESS to be turned off in the site's settings.
 +=== 2025-06-11 ===
 +    * Device Overview: Add icon for Energy Solutions Smart Switch
 +    * Dashboard: Add new data attribute 'apt' and hide Passthrough from Controls based on it
 +    * Alarms: Fix error caused by missing data attribute for Tank and Temperature Sensor alarms
 +=== 2025-06-06 ===
 +    * Firmware update: Updating a GX device now properly waits with rescanning until the GX device is done rebooting
 +=== 2025-06-05 ===
 +    * Diagnostics: Migrate page to new frontend framework
 +=== 2025-06-04 ===
 +    * Fleet Monitor: Add enhanced search functionality triggered by the Command/Ctrl + K shortcut
 +    * Venus OS Large: Add support for connecting to Node-Red/Signal-K over IPv6
 === 2025-06-03 === === 2025-06-03 ===
     * Device Registration: Added spinner to login page when you open it after clicking device registration from remote console     * Device Registration: Added spinner to login page when you open it after clicking device registration from remote console
vrm_portal/change_log.1748946502.txt.gz · Last modified: by aleximb
