vrm_portal:change_log
| vrm_portal:change_log [2025-05-14 18:26] – aleximb | vrm_portal:change_log [2025-12-10 11:13] (current) – aleximb | ||
| Line 1: | Line 1: | ||
| ====== VRM Portal Changelog ====== | ====== VRM Portal Changelog ====== | ||
| + | === 2025-12-10 === | ||
| + | * Fleet Monitor: Hide offline sites from disconnected devices. | ||
| + | * Fleet Monitor: Add widget for offline sites. | ||
| + | === 2025-12-09 === | ||
| + | * Advanced: Add state widgets for MultiRS in general and for the individual trackers. | ||
| + | * Device list: Fix VRM reboot timeout not showing when reported as 0. | ||
| + | === 2025-12-03 === | ||
| + | * Dashboard: Add Apparent power to the Grid Meter Combined chart for system sizing layouts. | ||
| + | * Advanced: Add Apparent power tab for the Grid Meter Combined widget. | ||
| + | * Dashboard: Hide the minus sign when the temperature is 0 degrees. | ||
| + | * Dashboard: Reduce the size of the weather icons. | ||
| + | * Navigation: Auto hide the navigation bar, allow users to always hide it from Preferences, | ||
| + | * Teams and Installation Groups: Fix to ensure the Members dropdown inside the “Link users” modal closes when users click outside the dropdown. | ||
| + | * API: Add an endpoint to show total usage of VRM | ||
| + | === 2025-12-02 === | ||
| + | * Recurring Reports: Fix error causing recurring reports to not generate. | ||
| + | === 2025-11-26 === | ||
| + | * API: Add `/ | ||
| + | * Remote Console: Improve fetching logic of the `New UI` to prevent unnecessary re-downloads. | ||
| + | === 2025-11-20 === | ||
| + | * Device list: Rename Motor Drive to E-drive and adjust icons. | ||
| + | * Dashboard: Various fixes of the EV card data formatting and display conditions. | ||
| + | * API: Revert the changes done to the `live_feed` type on the `/stats` endpoint. | ||
| + | === 2025-11-19 === | ||
| + | * Advanced: Improve header and calendar behaviour on mobile (portrait and landscape mode). | ||
| + | * Navigation: Add language selector to the navigation bar. | ||
| + | * Installation data: Load data from different data sources independently. | ||
| + | * Widget AI: Allow adding the same widget to multiple sites. | ||
| + | * Remote Console: Add a new progress bar. | ||
| + | * Remote Console: Allow users to open NodeRED and SignalK from the remote console via VRM. | ||
| + | === 2025-11-14 === | ||
| + | * Allow choosing which Remote console version to show in full screen with a URL parameter. | ||
| + | * Dashboard: Show session and total energy for EVCS. | ||
| + | * Dashboard: Fix charging time for EVCS connected over MQTT. | ||
| + | === 2025-11-13 === | ||
| + | * Installation Groups: Increase maximum amount of sites that can be added in bulk to 250. | ||
| + | * Enhanced Search: Allow searching for sites with a specific product (by name). | ||
| + | === 2025-11-12 === | ||
| + | * Dynamic ESS: Added support to specify different pricing formulas for DESS that vary throughout the day. | ||
| + | * Accesstokens: | ||
| + | * Search: Fix not finding exact site match with special characters. | ||
| + | * Remote console: Fix remote console not opening automatically when ? | ||
| + | * Demo mode: Fix not being able to visit other demo sites when visiting a ?demoShare url while not logged in. | ||
| + | === 2025-11-11 === | ||
| + | * Dashboard: Fix EVCS, PV Inverter and Grid Meter tiles missing for the layout without a inverter/ | ||
| + | === 2025-11-06 === | ||
| + | * Remote console: Fix remote console choice title color not visible in dark mode. | ||
| + | === 2025-11-05 === | ||
| + | * Dashboard: Add dedicated card for Heatpump type in the alternative dashboard. | ||
| + | * Advanced: Add Air Quality widget for Ruuvi Air. | ||
| + | * Dashboard: Add support for Ruuvi Air by showing air quality measurements in the temperature tile. | ||
| + | * Navbar: Fixed missing “Open in new tab” option in the new navbar. | ||
| + | === 2025-10-30 === | ||
| + | * Reports: Use old logic of calculating generator runtimes for " | ||
| + | * Installation data: Switch around the Grid meter combined widget and the kWh tiles. | ||
| + | === 2025-10-29 === | ||
| + | * Installations overview: Added search bars to the ' | ||
| + | * Email change: Slightly adjusted email notification text | ||
| + | * Global banner: Improved global banner for maintenance news, etc in vue 3 pages | ||
| + | * Generator Reports: Fix incorrect report for sites not reporting `Tga` attribute | ||
| + | === 2025-10-23 === | ||
| + | * Alarms: Fix not being able to change an alarm as Fahrenheit user if low or high value is not set. | ||
| + | === 2025-10-22 === | ||
| + | * Installations/ | ||
| + | * Dashboard: Fix value alignment issues with PV charger card. | ||
| + | * Navbar: Replace `<` icon on bottom nav, as it doesn' | ||
| + | * Log out: add confirmation dialog to make sure user wants to log out. | ||
| + | * Home: remove 'Add installation' | ||
| + | * Installation overview: fix filters not being cleared on the first press of 'Clear button' | ||
| + | * Home: Fix news title overlapping and scrollbar issues in some devices. | ||
| + | * Device list: Fix EVCS Control Panel IP when the device is connected over MQTT. | ||
| + | === 2025-10-20 === | ||
| + | * Advanced: Add " | ||
| + | === 2025-10-16 === | ||
| + | * Installation/ | ||
| + | * DESS Settings: Improve UX, change stepsize for prices & costs to cents instead of full euros. | ||
| + | * Home: Add favorite installations, | ||
| + | * Navbar: Make bottom bar take up less space on mobile landscape view. | ||
| + | * Modals: Fix pressing x not closing the modal. | ||
| + | * Fleet Widget: Add D-Bus round trip widget. | ||
| + | * Admin: Enable the on-hover tooltip showing the data label per data point. | ||
| + | === 2025-10-09 === | ||
| + | * Advanced: Reduce the padding of the fixed bar to save vertical space. | ||
| + | * Remote console: Fix the touch event on the checkbox to " | ||
| + | * Tags: Apply the DESS tag to sites running Dynamic ESS. | ||
| + | === 2025-10-07 === | ||
| + | * Share Site: fix embedding iframe empty state for 5 minutes. | ||
| + | === 2025-10-06 === | ||
| + | * DESS wizard : Null battery costs will now be correctly considered as 0.01 as the default value | ||
| + | === 2025-10-02 === | ||
| + | * Dashboard: Show Power for EMs with the EVCS role and hide the unavailable details. | ||
| + | * Controls: Hide the EVCS Control card for EMs with the EVCS role. | ||
| + | === 2025-10-01 === | ||
| + | * Alarms: Remove instance number from alarm groups title. | ||
| + | * Recaptcha: Improve error handling. | ||
| + | === 2025-09-29 === | ||
| + | * Preferences: | ||
| + | * Dashboard: Fixed date picker going off screen on desktop | ||
| + | === 2025-09-25 === | ||
| + | * Dashboard: Fix solar irradiance unit. | ||
| + | * Navbar: Implement new navbar. | ||
| + | * Navbar (Notifications): | ||
| + | * Teams and Installation groups: Allow fleet owners to link multiple users to an installation group or team in one go. | ||
| + | * Date Picker: Implemented the calendar to show the days where battery balancing has happened. | ||
| + | * Dynamic ESS wizard: Redesigned the Dynamic ESS setup form. | ||
| + | * Dashboard: Changed the banner to promote the navbar. | ||
| + | * Groups: Fix users not having profile icon compared to the rest of VRM. | ||
| + | * AI Agent: Redesign the " | ||
| + | * Background: Updated background colour across all VRM pages. | ||
| + | === 2025-09-17 === | ||
| + | * Dashboard: Display card for meteorological sensors. | ||
| + | * Advanced: Change the name of the widget " | ||
| + | * Installation Overview: Fix some minor styling issues related with the Search Tour. | ||
| + | * Access Tokens: Limit the amount of active access tokens a user can have. | ||
| + | * Device List & General Settings: Improve readability of serial numbers & identifiers. | ||
| + | * Reports: Use new data attribute for generator runtime for " | ||
| + | * Installation Data: Display data even if some data sources are not available. For example, solar and consumption but no SOC. | ||
| + | * Alarm logs: Move to the new framework. | ||
| + | * Controls: Fix bug which made it impossible to set a custom Inverter current limit | ||
| + | === 2025-09-12 === | ||
| + | * iOS: Loading screen is no longer always white, it is now dependent on the device' | ||
| + | * Add Installation: | ||
| + | === 2025-09-11 === | ||
| + | * Event log: Show log entries coming from Venus OS. | ||
| + | * Mobile: Fix issue where leftover overlay causes VRM to be unusable. | ||
| + | * Dashboard: Fix bug causing an error notification when switching to site without remote console access. | ||
| + | === 2025-09-10 === | ||
| + | * Advanced: Renamed ' | ||
| + | * Installation Dashboard: Replaced 'Last 90 days' quick range option with 'Last 12 week', added 'Last 48 hours' option | ||
| + | * Batch alarms: Fix issue where an installation belonging to two groups was removed from the list when one group was deselected. | ||
| + | * Dashboard: Fix installation charts displaying "No data to display" | ||
| + | * Installation overview: Add a visual hint for the Command-K shortcut that disappears after dismissal and is stored in user preferences | ||
| + | * VRM: reduce network and memory usage for users with many sites, reducing iOS and Android crash risk | ||
| + | * Remote Console: add option to use a ' | ||
| + | === 2025-09-04 === | ||
| + | * Dynamic Ess: Fixed no providers being displayed for Spain | ||
| + | === 2025-09-03 === | ||
| + | * Dashboard: Fixed controls on mobile not working for AC System | ||
| + | * Email fields: Added validation to check if email address is correct (Login, Register, Installation > Share, Profile Preferences) | ||
| + | * AI Chat: Internally store which task agent was chosen | ||
| + | * Advanced: Add DESS Error State Widget | ||
| + | * Dashboard: Fixed grey line appearing sometimes in the DESS charts on ' | ||
| + | === 2025-09-02 === | ||
| + | * Advanced: Fixed bug on mobile when a widget is fullscreen; removed big gray box when tooltip is showing. | ||
| + | === 2025-08-28 === | ||
| + | * Enhanced Search: Upgrade underlying infrastructure for improved maintainability & performance. | ||
| + | === 2025-08-27 === | ||
| + | * Batch alarms: Fix not all eligible installations being shown | ||
| + | * Alarms: Fix empty fields displaying very high values | ||
| + | * Share: Remove tokens of shared sessions after sharing is disabled | ||
| + | * Teams: Unify Grafana and " | ||
| + | === 2025-08-22 === | ||
| + | * Dashboard: Fix power flow between AC Loads and AC Input for sites with AC System. | ||
| + | === 2025-08-20 === | ||
| + | * Installations Overview: when " | ||
| + | * Teams: Add invitation link to the team. | ||
| + | === 2025-08-18 === | ||
| + | * General: Fixed an issue where the 2FA banner linked to an incorrect URL for the Security settings. | ||
| + | === 2025-08-14 === | ||
| + | * Replace GX: Fix allowing to select an installation already added to VRM. | ||
| + | * Dashboard: Fix incorrect forecast values. | ||
| + | === 2025-08-13 === | ||
| + | * Homepage: Introducing a new homepage for VRM for users with more than 10 installations. | ||
| + | * Replace GX: Reboot GX devices and clear old data after replacing GX device. | ||
| + | * Settings: ' | ||
| + | * Alarm Rules: Alarms are now sorted by the type of device to more easily find alarm rules. | ||
| + | * Alarm Rules: You can now set only a high or only a low alarm without needing to fill all four alarm fields. | ||
| + | * Advanced: Fix graphs using UTC instead of local time. | ||
| + | * Advanced: ' | ||
| + | * Report Templates: When creating a new template, added error if name is shorter than 2 characters. | ||
| + | === 2025-08-11 === | ||
| + | * Dynamic ESS: Fix " | ||
| + | === 2025-08-06 === | ||
| + | * Fleet Monitor: Add icons to each widget, so they are easier to identify. | ||
| + | * API: Fix `users/ | ||
| + | * Advanced: Fall back to regular datapoints when user selects `show min/max values` when that data is not available. | ||
| + | * User groups: Ensure user group page doesn' | ||
| + | * Login: Added user feedback after opening a wrong invite. | ||
| + | === 2025-07-31 === | ||
| + | * Device list: Fix showing the VRM Portal Model row in the table even if no value is reported. | ||
| + | === 2025-07-30 === | ||
| + | * Command K: Show enhanced search in all the pages that are not part of an installation. | ||
| + | * Economic Results: Fix alignment of buttons in economic report results. | ||
| + | * Advanced Widgets: Make the solar irradiance widget take the date picker values into account. | ||
| + | * Installation overview: Show favorite installations in the installation overview on mobile. | ||
| + | * Settings: Show the Replace GX device section faster and consistently. | ||
| + | * Controls: Use 1% increments for the Mininum SOC. | ||
| + | * AI Assistant: Allow users to directly edit the widget manually, without needing to go to the edit custom widget menu first. | ||
| + | * AI Assistant: Allow users to delete a chat. | ||
| + | * AI Assistant: Allow users to rename a chat, so it is more clear what the chat is about. | ||
| + | * API: Include access level in the response of the `/users/me` endpoint. | ||
| + | === 2025-07-25 === | ||
| + | * Languages: Add support for Romanian. | ||
| + | === 2025-07-23 === | ||
| + | * Advanced: Search mode is considered active only when search query is entered. | ||
| + | * Device List: Fix bug when loading remote support details without relevant data. | ||
| + | * Invites: Improve validation when inviting users to installations and fix setting the locale of the invited user. | ||
| + | * Remote console in VictronConnect: | ||
| + | * Date picker: Fix date picker ignoring URL parameters when going to Advanced from an Alarm. | ||
| + | * Installation data: Add widget for the Grid meter to Installation data section of the Dashboard for specific systems with a Grid meter (i.e. with Grid Meter, no Inverter/ | ||
| + | * Advanced: Added scrollbar when there are too many custom widgets. | ||
| + | * Advanced: Enabled scrolling on the advanced page for newly added custom widgets. | ||
| + | * Teams: Allow only the invited user to accept the invite link. | ||
| + | * Teams & Installation groups: Set page title for single team and installation group pages. | ||
| + | * Fleet monitor: Added ' | ||
| + | * Add installation: | ||
| + | * Enhanced search: Fix error caused by by using quotation marks in the search query. | ||
| + | * AI Assistant: Change the internal architecture and introduce the suggestions and feedback capabilities. | ||
| + | === 2025-07-17 === | ||
| + | * Dashboard: Fix Sync with OS display preference not working as intended on the Dashboard. | ||
| + | * Firmware file upload: Improve file extension validation and filtering for .vup, .dup, and .xup. | ||
| + | * Fleet monitor: Fixed a bug that prevented fleet-monitor from fetching data in parallel on production. | ||
| + | === 2025-07-16 === | ||
| + | * Alarm rules: Allow adding alarm rules for multiple installation, | ||
| + | * Teams/ | ||
| + | * Login: Added a ' | ||
| + | * Login: Added an ' | ||
| + | * Dashboard: Added translation to " | ||
| + | * Fleet monitor: Improve the page load time by fetching data in parallel more. | ||
| + | * Venus OS Large: The links to external services like Node-RED and Signal K now open in a new browser tab. | ||
| + | * Dashboard: Fix " | ||
| + | === 2025-07-10 === | ||
| + | * Fleet monitor: Significantly improve page responsiveness after a lot of data is loaded. | ||
| + | * Venus OS Large: Explain that 'VRM Portal Mode' should be set to ' | ||
| + | === 2025-07-09 === | ||
| + | * General: Added a backup font in case the browser cannot render special characters (Russian, Ukrainian, etc). | ||
| + | * General: The default time that notifications are shown was increased to 20 seconds. | ||
| + | * Advanced: Fixed a bug that allowed editing multiple widgets via ' | ||
| + | * Advanced: Added a ' | ||
| + | * Fleet monitor: Decrease the time it takes for the page to load with data. | ||
| + | === 2025-07-04 === | ||
| + | * Validation: Fix TypeError in validators | ||
| + | * Dynamic ESS Report: Improve code quality & make sure the report is generated in the user's preferred language. | ||
| + | === 2025-07-03 === | ||
| + | * Infrastructure: | ||
| + | * Site groups: Make the alarm toggle changeable for your own account even if you are not group owner/ | ||
| + | === 2025-07-02 === | ||
| + | * Users: Add mailto link to teams, groups & installation user management pages to simplify contacting users in case of issues. | ||
| + | * Installation overview: Your favourite installations will now show on top of your installation overview. | ||
| + | * Device List: Show local IP address again. | ||
| + | * Reporting: Fix Dynamic ESS report not showing at all if DESS was off for a portion of the selected period. | ||
| + | === 2025-07-01 === | ||
| + | * Navbar: Fix `Dynamic ESS` settings not being shown in the navbar on pages in the new frontend framework. | ||
| + | * VictronConnect: | ||
| + | * Groups: Fix bug where a team as site-group administrators are not able to add a site they have full access to. | ||
| + | === 2025-06-25 === | ||
| + | * Dashboard: Show different banner for opportunistic battery balancing. | ||
| + | * Settings: Allow user to reset his consumption forecast. | ||
| + | * General: Animate VRM AI Assistant button icon. | ||
| + | === 2025-06-24 === | ||
| + | * Login: Remove `*******` placeholder from the password field to prevent confusion. | ||
| + | === 2025-06-18 === | ||
| + | * Installation overview: Make all filters apply immediately for consistent behaviour. | ||
| + | * Installation group: Fix styling of 'Link user' modal inputs on smaller devices. | ||
| + | * Fleet monitor: Added relative difference column to the solar widget. | ||
| + | === 2025-06-17 === | ||
| + | * Dashboard: Fix Demo mode banner not showing for certain modes. | ||
| + | === 2025-06-12 === | ||
| + | * Dashboard: Fix turning DESS off in the controls also causing DESS to be turned off in the site's settings. | ||
| + | === 2025-06-11 === | ||
| + | * Device Overview: Add icon for Energy Solutions Smart Switch | ||
| + | * Dashboard: Add new data attribute ' | ||
| + | * Alarms: Fix error caused by missing data attribute for Tank and Temperature Sensor alarms | ||
| + | === 2025-06-06 === | ||
| + | * Firmware update: Updating a GX device now properly waits with rescanning until the GX device is done rebooting | ||
| + | === 2025-06-05 === | ||
| + | * Diagnostics: | ||
| + | === 2025-06-04 === | ||
| + | * Fleet Monitor: Add enhanced search functionality triggered by the Command/ | ||
| + | * Venus OS Large: Add support for connecting to Node-Red/ | ||
| + | === 2025-06-03 === | ||
| + | * Device Registration: | ||
| + | === 2025-05-28 === | ||
| + | * Add Installations: | ||
| + | * Teams: Add the permission for admins/ | ||
| + | * Dashboard: Display AC Meter cards per instance for installations with energy meters and without certain devices | ||
| + | * VRM AI Assistant: Introducing the AI Assistant, which is capable of helping users with adding custom widgets to the Advanced page | ||
| + | === 2025-05-26 === | ||
| + | * Device list: Add GX IO Extender support | ||
| + | * Dashboard: Display PV inverter cards per instance when using dashboard layout for installations with energy meters and without certain devices | ||
| + | === 2025-05-21 === | ||
| + | * Navigation: Implement ' | ||
| + | * Dashboard: Add new layout for installations with energy meters and without certain devices | ||
| + | * Dashboard : Add EV card on dashboard to view EV information. | ||
| + | * Register: Dealers can now share a link to new users to automatically link them to their dealer account after registering. | ||
| + | * Register: Make go to login button smaller. | ||
| + | === 2025-05-17 === | ||
| + | * Controls: Fix ESS controls not working for users with a non-Enligh language. | ||
| + | === 2025-05-15 === | ||
| + | * Controls: Fix EVCS manual charge toggle on mobile. | ||
| + | * General: Fix a language issue when entering demo mode | ||
| + | * Installation data: Improve the logic for showing and hiding the dropdown items Solar and EV Charger. | ||
| + | * Login: Fix redirecting users with one installation to their dashboard. | ||
| + | * Controls: Fix unable to change EVCS mode | ||
| === 2025-05-14 === | === 2025-05-14 === | ||
| * Dashboard: New UI for the controls section on mobile to prevent accidental changes. | * Dashboard: New UI for the controls section on mobile to prevent accidental changes. | ||
vrm_portal/change_log.1747239965.txt.gz · Last modified: by aleximb
