vrm_portal:change_log
vrm_portal:change_log [2025-05-13 11:49] aleximbvrm_portal:change_log [2025-07-10 17:11] (current) aleximb
 ====== VRM Portal Changelog ====== ====== VRM Portal Changelog ======
 +=== 2025-07-10 ===
 +    * Fleet monitor: Significantly improve page responsiveness after a lot of data is loaded.
 +    * Venus OS Large: Explain that 'VRM Portal Mode' should be set to 'Full' to access Node-RED and Signal-K.
 +=== 2025-07-09 ===
 +    * General: Added a backup font in case the browser cannot render special characters (Russian, Ukrainian, etc).
 +    * General: The default time that notifications are shown was increased to 20 seconds.
 +    * Advanced: Fixed a bug that allowed editing multiple widgets via 'Enable/Disable All Widgets' even when widgets were locked.
 +    * Advanced: Added a 'Create with AI' button next to the 'Create Custom Widget' button to highlight the possibility of creating a custom widget using AI.
 +    * Fleet monitor: Decrease the time it takes for the page to load with data.
 +=== 2025-07-04 ===
 +    * Validation: Fix TypeError in validators
 +    * Dynamic ESS Report: Improve code quality & make sure the report is generated in the user's preferred language.
 +=== 2025-07-03 ===
 +    * Infrastructure: Upgrade backend API framework to newer version
 +    * Site groups: Make the alarm toggle changeable for your own account even if you are not group owner/admin.
 +=== 2025-07-02 ===
 +    * Users: Add mailto link to teams, groups & installation user management pages to simplify contacting users in case of issues.
 +    * Installation overview: Your favourite installations will now show on top of your installation overview.
 +    * Device List: Show local IP address again.
 +    * Reporting: Fix Dynamic ESS report not showing at all if DESS was off for a portion of the selected period.
 +    * Preferences: Redesigned the preferences pages.
 +=== 2025-07-01 ===
 +    * Navbar: Fix `Dynamic ESS` settings not being shown in the navbar on pages in the new frontend framework.
 +    * VictronConnect: Add route to support future remote console feature.
 +    * Groups: Fix bug where a team as site-group administrators are not able to add a site they have full access to.
 +=== 2025-06-25 ===
 +    * Dashboard: Show different banner for opportunistic battery balancing.
 +    * Settings: Allow user to reset his consumption forecast.
 +    * General: Animate VRM AI Assistant button icon.
 +=== 2025-06-24 ===
 +    * Login: Remove `*******` placeholder from the password field to prevent confusion.
 +=== 2025-06-18 ===
 +    * Installation overview: Make all filters apply immediately for consistent behaviour.
 +    * Installation group: Fix styling of 'Link user' modal inputs on smaller devices.
 +    * Fleet monitor: Added relative difference column to the solar widget.
 +=== 2025-06-17 ===
 +    * Dashboard: Fix Demo mode banner not showing for certain modes.
 +=== 2025-06-12 ===
 +    * Dashboard: Fix turning DESS off in the controls also causing DESS to be turned off in the site's settings.
 +=== 2025-06-11 ===
 +    * Device Overview: Add icon for Energy Solutions Smart Switch
 +    * Dashboard: Add new data attribute 'apt' and hide Passthrough from Controls based on it
 +    * Alarms: Fix error caused by missing data attribute for Tank and Temperature Sensor alarms
 +=== 2025-06-06 ===
 +    * Firmware update: Updating a GX device now properly waits with rescanning until the GX device is done rebooting
 +=== 2025-06-05 ===
 +    * Diagnostics: Migrate page to new frontend framework
 +=== 2025-06-04 ===
 +    * Fleet Monitor: Add enhanced search functionality triggered by the Command/Ctrl + K shortcut
 +    * Venus OS Large: Add support for connecting to Node-Red/Signal-K over IPv6
 +=== 2025-06-03 ===
 +    * Device Registration: Added spinner to login page when you open it after clicking device registration from remote console
 +=== 2025-05-28 ===
 +    * Add Installations: Add new page where sites can be added in bulk with the option of giving a name to the site and tags
 +    * Teams: Add the permission for admins/owner of the team to unlink it from a site to which the team has read-only right
 +    * Dashboard: Display AC Meter cards per instance for installations with energy meters and without certain devices
 +    * VRM AI Assistant: Introducing the AI Assistant, which is capable of helping users with adding custom widgets to the Advanced page
 +=== 2025-05-26 ===
 +    * Device list: Add GX IO Extender support
 +    * Dashboard: Display PV inverter cards per instance when using dashboard layout for installations with energy meters and without certain devices
 +=== 2025-05-21 ===
 +    * Navigation: Implement 'identifier search' in the new navigation bar.
 +    * Dashboard: Add new layout for installations with energy meters and without certain devices
 +    * Dashboard : Add EV card on dashboard to view EV information.
 +    * Register: Dealers can now share a link to new users to automatically link them to their dealer account after registering.
 +    * Register: Make go to login button smaller.
 +=== 2025-05-17 ===
 +    * Controls: Fix ESS controls not working for users with a non-Enligh language.
 +=== 2025-05-15 ===
 +    * Controls: Fix EVCS manual charge toggle on mobile.
 +    * General: Fix a language issue when entering demo mode
 +    * Installation data: Improve the logic for showing and hiding the dropdown items Solar and EV Charger.
 +    * Login: Fix redirecting users with one installation to their dashboard.
 +    * Controls: Fix unable to change EVCS mode
 +=== 2025-05-14 ===
 +    * Dashboard: New UI for the controls section on mobile to prevent accidental changes.
 +    * Dashboard: Fix VRM freezing under specific conditions when DESS is enabled.
 +    * Admin Device search: Allow searching by VE.Bus serial number.
 +    * Login: Improve performance & prevent showing the login page when already logged in.
 === 2025-05-13 === === 2025-05-13 ===
     * Login: Fix incorrect language being set when initially visiting the login page     * Login: Fix incorrect language being set when initially visiting the login page
vrm_portal/change_log.1747129757.txt.gz · Last modified: by aleximb
