vrm_portal:change_log
vrm_portal:change_log [2025-05-08 14:56] aleximbvrm_portal:change_log [2025-12-10 11:13] (current) aleximb
 ====== VRM Portal Changelog ====== ====== VRM Portal Changelog ======
 +=== 2025-12-10 ===
 +   * Fleet Monitor: Hide offline sites from disconnected devices.
 +   * Fleet Monitor: Add widget for offline sites.
 +=== 2025-12-09 ===
 +   * Advanced: Add state widgets for MultiRS in general and for the individual trackers.
 +   * Device list: Fix VRM reboot timeout not showing when reported as 0.
 +=== 2025-12-03 ===
 +   * Dashboard: Add Apparent power to the Grid Meter Combined chart for system sizing layouts.
 +   * Advanced: Add Apparent power tab for the Grid Meter Combined widget.
 +   * Dashboard: Hide the minus sign when the temperature is 0 degrees.
 +   * Dashboard: Reduce the size of the weather icons.
 +   * Navigation: Auto hide the navigation bar, allow users to always hide it from Preferences, and various other UX improvements.
 +   * Teams and Installation Groups: Fix to ensure the Members dropdown inside the “Link users” modal closes when users click outside the dropdown.
 +   * API: Add an endpoint to show total usage of VRM
 +=== 2025-12-02 ===
 +   * Recurring Reports: Fix error causing recurring reports to not generate.
 +=== 2025-11-26 ===
 +   * API: Add `/v2/installation-data-attributes` endpoint to allow users & tools to query their sites by (multiple) data attributes.
 +   * Remote Console: Improve fetching logic of the `New UI` to prevent unnecessary re-downloads.
 +=== 2025-11-20 ===
 +   * Device list: Rename Motor Drive to E-drive and adjust icons.
 +   * Dashboard: Various fixes of the EV card data formatting and display conditions.
 +=== 2025-11-20 ===
 +   * API: Revert the changes done to the `live_feed` type on the `/stats` endpoint.
 +=== 2025-11-19 ===
 +   * Advanced: Improve header and calendar behaviour on mobile (portrait and landscape mode).
 +   * Navigation: Add language selector to the navigation bar.
 +   * Installation data: Load data from different data sources independently.
 +   * Widget AI: Allow adding the same widget to multiple sites.
 +   * Remote Console: Add a new progress bar.
 +   * Remote Console: Allow users to open NodeRED and SignalK from the remote console via VRM.
 +=== 2025-11-14 ===
 +   * Allow choosing which Remote console version to show in full screen with a URL parameter.
 +   * Dashboard: Show session and total energy for EVCS.
 +   * Dashboard: Fix charging time for EVCS connected over MQTT.
 +=== 2025-11-13 ===
 +   * Installation Groups: Increase maximum amount of sites that can be added in bulk to 250.
 +   * Enhanced Search: Allow searching for sites with a specific product (by name).
 +=== 2025-11-12 ===
 +   * Dynamic ESS: Added support to specify different pricing formulas for DESS that vary throughout the day.
 +   * Accesstokens: Add endpoint to get a regular JWT from the access token (VictronConnect integration).
 +   * Search: Fix not finding exact site match with special characters.
 +   * Remote console: Fix remote console not opening automatically when ?openRemoteConsole is in the url.
 +   * Demo mode: Fix not being able to visit other demo sites when visiting a ?demoShare url while not logged in.
 +=== 2025-11-11 ===
 +   * Dashboard: Fix EVCS, PV Inverter and Grid Meter tiles missing for the layout without a inverter/charger.
 +=== 2025-11-06 ===
 +   * Remote console: Fix remote console choice title color not visible in dark mode.
 +=== 2025-11-05 ===
 +   * Dashboard: Add dedicated card for Heatpump type in the alternative dashboard.
 +   * Advanced: Add Air Quality widget for Ruuvi Air.
 +   * Dashboard: Add support for Ruuvi Air by showing air quality measurements in the temperature tile.
 +   * Navbar: Fixed missing “Open in new tab” option in the new navbar.
 +=== 2025-10-30 ===
 +   * Reports: Use old logic of calculating generator runtimes for "Hybrid genset" and "Economic" reports
 +   * Installation data: Switch around the Grid meter combined widget and the kWh tiles.
 +=== 2025-10-29 ===
 +   * Installations overview: Added search bars to the 'Alarm', 'User teams', 'Installation groups' and 'Tags' filters (only visible when there are more than 5 options present)
 +   * Email change: Slightly adjusted email notification text
 +   * Global banner: Improved global banner for maintenance news, etc in vue 3 pages
 +   * Generator Reports: Fix incorrect report for sites not reporting `Tga` attribute
 +=== 2025-10-23 ===
 +   * Alarms: Fix not being able to change an alarm as Fahrenheit user if low or high value is not set.
 +=== 2025-10-22 ===
 +   * Installations/Users: When user requests access to a site they have a valid invite for, automatically add them with the right access level.
 +   * Dashboard: Fix value alignment issues with PV charger card.
 +   * Navbar: Replace `<` icon on bottom nav, as it doesn't always go back.
 +   * Log out: add confirmation dialog to make sure user wants to log out.
 +   * Home: remove 'Add installation' button.
 +   * Installation overview: fix filters not being cleared on the first press of 'Clear button'.
 +   * Home: Fix news title overlapping and scrollbar issues in some devices.
 +   * Device list: Fix EVCS Control Panel IP when the device is connected over MQTT.
 +=== 2025-10-20 ===
 +   * Advanced: Add "Total" series for Power and Current in the Grid combined widget.
 +=== 2025-10-16 ===
 +   * Installation/Users: Add button for getting an invitation link for the installation, to share with other users so they can be added to the installation.
 +   * DESS Settings: Improve UX, change stepsize for prices & costs to cents instead of full euros.
 +   * Home: Add favorite installations, recently viewed and Victron news to home page.
 +   * Navbar: Make bottom bar take up less space on mobile landscape view.
 +   * Modals: Fix pressing x not closing the modal.
 +   * Fleet Widget: Add D-Bus round trip widget.
 +   * Admin: Enable the on-hover tooltip showing the data label per data point.
 +=== 2025-10-09 ===
 +   * Advanced: Reduce the padding of the fixed bar to save vertical space.
 +   * Remote console: Fix the touch event on the checkbox to "Remember this choice".
 +   * Tags: Apply the DESS tag to sites running Dynamic ESS.
 +=== 2025-10-07 ===
 +   * Share Site: fix embedding iframe empty state for 5 minutes.
 +=== 2025-10-06 ===
 +   * DESS wizard : Null battery costs will now be correctly considered as 0.01 as the default value
 +=== 2025-10-02 ===
 +   * Dashboard: Show Power for EMs with the EVCS role and hide the unavailable details.
 +   * Controls: Hide the EVCS Control card for EMs with the EVCS role.
 +=== 2025-10-01 ===
 +   * Alarms: Remove instance number from alarm groups title.
 +   * Recaptcha: Improve error handling.
 +=== 2025-09-29 ===
 +   * Preferences: Fixed an issue where the display preference options would always be empty.
 +   * Preferences: Fixed broken navigation links to specific preference pages.
 +   * Dashboard: Fixed date picker going off screen on desktop
 +=== 2025-09-25 ===
 +   * Dashboard: Fix solar irradiance unit.
 +   * Navbar: Implement new navbar.
 +   * Navbar (Notifications): Add notifications section to the navbar, allowing users to accept/reject invites to teams or installation groups.
 +   * Navbar (Notifications): Integrate changelog into the new notifications section.
 +   * Navbar (Notifications): Add a notification when a user requests to join a team.
 +   * Teams and Installation groups: Allow fleet owners to link multiple users to an installation group or team in one go.
 +   * Date Picker: Implemented the calendar to show the days where battery balancing has happened.
 +   * Dynamic ESS wizard: Redesigned the Dynamic ESS setup form.
 +   * Dashboard: Changed the banner to promote the navbar.
 +   * Groups: Fix users not having profile icon compared to the rest of VRM.
 +   * AI Agent: Redesign the "Search chats" button so it visually resembles a search input field while keeping button functionality.
 +   * Background: Updated background colour across all VRM pages.
 +=== 2025-09-17 ===
 +   * Dashboard: Display card for meteorological sensors.
 +   * Advanced: Change the name of the widget "Meteorological Sensor" to "Meteorological Sensor Overview" and add 4 new widgets for this device.
 +   * Installation Overview: Fix some minor styling issues related with the Search Tour.
 +   * Access Tokens: Limit the amount of active access tokens a user can have.
 +   * Device List & General Settings: Improve readability of serial numbers & identifiers.
 +   * Reports: Use new data attribute for generator runtime for "Hybrid Genset" and "Economic" reports.
 +   * Installation Data: Display data even if some data sources are not available. For example, solar and consumption but no SOC.
 +   * Alarm logs: Move to the new framework.
 +   * Controls: Fix bug which made it impossible to set a custom Inverter current limit
 +=== 2025-09-12 ===
 +   * iOS: Loading screen is no longer always white, it is now dependent on the device's dark mode setting.
 +   * Add Installation: Revert back to sending an email to linked admins when requesting access to a pre-existing installation.
 +=== 2025-09-11 ===
 +   * Event log: Show log entries coming from Venus OS.
 +   * Mobile: Fix issue where leftover overlay causes VRM to be unusable.
 +   * Dashboard: Fix bug causing an error notification when switching to site without remote console access.
 +=== 2025-09-10 ===
 +   * Advanced: Renamed 'Critical loads' to 'Essential loads' in GUI to be consistent with GUI v2
 +   * Installation Dashboard: Replaced 'Last 90 days' quick range option with 'Last 12 week', added 'Last 48 hours' option
 +   * Batch alarms: Fix issue where an installation belonging to two groups was removed from the list when one group was deselected.
 +   * Dashboard: Fix installation charts displaying "No data to display" instead of "Loading" on date range change
 +   * Installation overview: Add a visual hint for the Command-K shortcut that disappears after dismissal and is stored in user preferences
 +   * VRM: reduce network and memory usage for users with many sites, reducing iOS and Android crash risk
 +   * Remote Console: add option to use a 'popup' version of the console where it can be moved and resized as a small overlay while using VRM
 +=== 2025-09-04 ===
 +  * Dynamic Ess: Fixed no providers being displayed for Spain
 +=== 2025-09-03 ===
 +    * Dashboard: Fixed controls on mobile not working for AC System
 +    * Email fields: Added validation to check if email address is correct (Login, Register, Installation > Share, Profile Preferences)
 +    * AI Chat: Internally store which task agent was chosen
 +    * Advanced: Add DESS Error State Widget
 +    * Dashboard: Fixed grey line appearing sometimes in the DESS charts on 'now' indicator
 +=== 2025-09-02 ===
 +    * Advanced: Fixed bug on mobile when a widget is fullscreen; removed big gray box when tooltip is showing.
 +=== 2025-08-28 ===
 +    * Enhanced Search: Upgrade underlying infrastructure for improved maintainability & performance.
 +=== 2025-08-27 ===
 +    * Batch alarms: Fix not all eligible installations being shown
 +    * Alarms: Fix empty fields displaying very high values
 +    * Preferences: Prevent the text in the sidebar from overflowing
 +    * Share: Remove tokens of shared sessions after sharing is disabled
 +    * Teams: Unify Grafana and "Edit" buttons alignment for mid-sized viewports
 +=== 2025-08-22 ===
 +    * Dashboard: Fix power flow between AC Loads and AC Input for sites with AC System.
 +=== 2025-08-20 ===
 +    * Installations Overview: when "Detailed mode" is enabled, values between -0.5 and 0 are now shown as 0, not as -0.
 +    * Preferences: Fixed an issue where e-mail address could not be changed.
 +    * Teams: Add invitation link to the team.
 +=== 2025-08-18 ===
 +    * General: Fixed an issue where the 2FA banner linked to an incorrect URL for the Security settings.
 +=== 2025-08-14 ===
 +    * Replace GX: Fix allowing to select an installation already added to VRM.
 +    * Dashboard: Fix incorrect forecast values.
 +=== 2025-08-13 ===
 +    * Homepage: Introducing a new homepage for VRM for users with more than 10 installations.
 +    * Replace GX: Reboot GX devices and clear old data after replacing GX device.
 +    * Settings: 'Replace GX Device' and 'Reset Tokens' buttons now follow the same style as other action buttons.
 +    * Alarm Rules: Alarms are now sorted by the type of device to more easily find alarm rules.
 +    * Alarm Rules: You can now set only a high or only a low alarm without needing to fill all four alarm fields.
 +    * Advanced: Fix graphs using UTC instead of local time.
 +    * Advanced: 'Widget settings' are now displayed in a modal.
 +    * Report Templates: When creating a new template, added error if name is shorter than 2 characters.
 +=== 2025-08-11 ===
 +    * Dynamic ESS: Fix "Leave" button not working when prompted on unsaved changes in the Dynamic ESS settings
 +=== 2025-08-06 ===
 +    * Fleet Monitor: Add icons to each widget, so they are easier to identify.
 +    * Preferences: Sort languages alphabetically.
 +    * API: Fix `users/{id}/diagnostics` endpoint.
 +    * Advanced: Fall back to regular datapoints when user selects `show min/max values` when that data is not available.
 +    * User groups: Ensure user group page doesn't allow site permission changes if user doesn't have the right privileges.
 +    * Login: Added user feedback after opening a wrong invite.
 +=== 2025-07-31 ===
 +    * Device list: Fix showing the VRM Portal Model row in the table even if no value is reported.
 +=== 2025-07-30 ===
 +    * Command K: Show enhanced search in all the pages that are not part of an installation.
 +    * Economic Results: Fix alignment of buttons in economic report results.
 +    * Advanced Widgets: Make the solar irradiance widget take the date picker values into account.
 +    * Installation overview: Show favorite installations in the installation overview on mobile.
 +    * Settings: Show the Replace GX device section faster and consistently.
 +    * Controls: Use 1% increments for the Mininum SOC.
 +    * AI Assistant: Allow users to directly edit the widget manually, without needing to go to the edit custom widget menu first.
 +    * AI Assistant: Allow users to delete a chat.
 +    * AI Assistant: Allow users to rename a chat, so it is more clear what the chat is about.
 +    * API: Include access level in the response of the `/users/me` endpoint.
 +=== 2025-07-25 ===
 +    * Languages: Add support for Romanian.
 +=== 2025-07-23 ===
 +    * Advanced: Search mode is considered active only when search query is entered.
 +    * Device List: Fix bug when loading remote support details without relevant data.
 +    * Invites: Improve validation when inviting users to installations and fix setting the locale of the invited user.
 +    * Remote console in VictronConnect: Allow users to see remote console in full screen.
 +    * Remote console in VictronConnect: Allow users to choose which version of the remote console to see in full screen.
 +    * Date picker: Fix date picker ignoring URL parameters when going to Advanced from an Alarm.
 +    * Installation data: Add widget for the Grid meter to Installation data section of the Dashboard for specific systems with a Grid meter (i.e. with Grid Meter, no Inverter/Charger/Inverter+Charger).
 +    * Advanced: Added scrollbar when there are too many custom widgets.
 +    * Advanced: Enabled scrolling on the advanced page for newly added custom widgets.
 +    * Teams: Allow only the invited user to accept the invite link.
 +    * Teams & Installation groups: Set page title for single team and installation group pages.
 +    * Fleet monitor: Added 'Command+K' search bar to to the page.
 +    * Add installation: Show a message if the user already has an existing invite for the site.
 +    * Enhanced search: Fix error caused by by using quotation marks in the search query.
 +    * AI Assistant: Change the internal architecture and introduce the suggestions and feedback capabilities.
 +=== 2025-07-17 ===
 +    * Dashboard: Fix Sync with OS display preference not working as intended on the Dashboard.
 +    * Firmware file upload: Improve file extension validation and filtering for .vup, .dup, and .xup.
 +    * Fleet monitor: Fixed a bug that prevented fleet-monitor from fetching data in parallel on production.
 +=== 2025-07-16 ===
 +    * Alarm rules: Allow adding alarm rules for multiple installation, in batch.
 +    * Teams/Installation groups: Redirect user to team/installation group page after they accept an invite.
 +    * Login: Added a 'x' icon to the email and password fields to allow users to reset the inputs with a single click.
 +    * Login: Added an 'eye' icon to the password field to hide/show it.
 +    * Dashboard: Added translation to "Now" label.
 +    * Add installation: Made 'Replace GX Device' button translatable.
 +    * Fleet monitor: Improve the page load time by fetching data in parallel more.
 +    * Venus OS Large: The links to external services like Node-RED and Signal K now open in a new browser tab.
 +    * Dashboard: Fix "Now" indicator not updating when the hour changes.
 +=== 2025-07-10 ===
 +    * Fleet monitor: Significantly improve page responsiveness after a lot of data is loaded.
 +    * Venus OS Large: Explain that 'VRM Portal Mode' should be set to 'Full' to access Node-RED and Signal-K.
 +=== 2025-07-09 ===
 +    * General: Added a backup font in case the browser cannot render special characters (Russian, Ukrainian, etc).
 +    * General: The default time that notifications are shown was increased to 20 seconds.
 +    * Advanced: Fixed a bug that allowed editing multiple widgets via 'Enable/Disable All Widgets' even when widgets were locked.
 +    * Advanced: Added a 'Create with AI' button next to the 'Create Custom Widget' button to highlight the possibility of creating a custom widget using AI.
 +    * Fleet monitor: Decrease the time it takes for the page to load with data.
 +=== 2025-07-04 ===
 +    * Validation: Fix TypeError in validators
 +    * Dynamic ESS Report: Improve code quality & make sure the report is generated in the user's preferred language.
 +=== 2025-07-03 ===
 +    * Infrastructure: Upgrade backend API framework to newer version
 +    * Site groups: Make the alarm toggle changeable for your own account even if you are not group owner/admin.
 +=== 2025-07-02 ===
 +    * Users: Add mailto link to teams, groups & installation user management pages to simplify contacting users in case of issues.
 +    * Installation overview: Your favourite installations will now show on top of your installation overview.
 +    * Device List: Show local IP address again.
 +    * Reporting: Fix Dynamic ESS report not showing at all if DESS was off for a portion of the selected period.
 +    * Preferences: Redesigned the preferences pages.
 +=== 2025-07-01 ===
 +    * Navbar: Fix `Dynamic ESS` settings not being shown in the navbar on pages in the new frontend framework.
 +    * VictronConnect: Add route to support future remote console feature.
 +    * Groups: Fix bug where a team as site-group administrators are not able to add a site they have full access to.
 +=== 2025-06-25 ===
 +    * Dashboard: Show different banner for opportunistic battery balancing.
 +    * Settings: Allow user to reset his consumption forecast.
 +    * General: Animate VRM AI Assistant button icon.
 +=== 2025-06-24 ===
 +    * Login: Remove `*******` placeholder from the password field to prevent confusion.
 +=== 2025-06-18 ===
 +    * Installation overview: Make all filters apply immediately for consistent behaviour.
 +    * Installation group: Fix styling of 'Link user' modal inputs on smaller devices.
 +    * Fleet monitor: Added relative difference column to the solar widget.
 +=== 2025-06-17 ===
 +    * Dashboard: Fix Demo mode banner not showing for certain modes.
 +=== 2025-06-12 ===
 +    * Dashboard: Fix turning DESS off in the controls also causing DESS to be turned off in the site's settings.
 +=== 2025-06-11 ===
 +    * Device Overview: Add icon for Energy Solutions Smart Switch
 +    * Dashboard: Add new data attribute 'apt' and hide Passthrough from Controls based on it
 +    * Alarms: Fix error caused by missing data attribute for Tank and Temperature Sensor alarms
 +=== 2025-06-06 ===
 +    * Firmware update: Updating a GX device now properly waits with rescanning until the GX device is done rebooting
 +=== 2025-06-05 ===
 +    * Diagnostics: Migrate page to new frontend framework
 +=== 2025-06-04 ===
 +    * Fleet Monitor: Add enhanced search functionality triggered by the Command/Ctrl + K shortcut
 +    * Venus OS Large: Add support for connecting to Node-Red/Signal-K over IPv6
 +=== 2025-06-03 ===
 +    * Device Registration: Added spinner to login page when you open it after clicking device registration from remote console
 +=== 2025-05-28 ===
 +    * Add Installations: Add new page where sites can be added in bulk with the option of giving a name to the site and tags
 +    * Teams: Add the permission for admins/owner of the team to unlink it from a site to which the team has read-only right
 +    * Dashboard: Display AC Meter cards per instance for installations with energy meters and without certain devices
 +    * VRM AI Assistant: Introducing the AI Assistant, which is capable of helping users with adding custom widgets to the Advanced page
 +=== 2025-05-26 ===
 +    * Device list: Add GX IO Extender support
 +    * Dashboard: Display PV inverter cards per instance when using dashboard layout for installations with energy meters and without certain devices
 +=== 2025-05-21 ===
 +    * Navigation: Implement 'identifier search' in the new navigation bar.
 +    * Dashboard: Add new layout for installations with energy meters and without certain devices
 +    * Dashboard : Add EV card on dashboard to view EV information.
 +    * Register: Dealers can now share a link to new users to automatically link them to their dealer account after registering.
 +    * Register: Make go to login button smaller.
 +=== 2025-05-17 ===
 +    * Controls: Fix ESS controls not working for users with a non-Enligh language.
 +=== 2025-05-15 ===
 +    * Controls: Fix EVCS manual charge toggle on mobile.
 +    * General: Fix a language issue when entering demo mode
 +    * Installation data: Improve the logic for showing and hiding the dropdown items Solar and EV Charger.
 +    * Login: Fix redirecting users with one installation to their dashboard.
 +    * Controls: Fix unable to change EVCS mode
 +=== 2025-05-14 ===
 +    * Dashboard: New UI for the controls section on mobile to prevent accidental changes.
 +    * Dashboard: Fix VRM freezing under specific conditions when DESS is enabled.
 +    * Admin Device search: Allow searching by VE.Bus serial number.
 +    * Login: Improve performance & prevent showing the login page when already logged in.
 +=== 2025-05-13 ===
 +    * Login: Fix incorrect language being set when initially visiting the login page
 +=== 2025-05-12 ===
 +    * Login: Fix account language being overwritten by login
 +=== 2025-05-10 ===
 +    * Login/Register: Polyfill the new form items to work on iOS 15, until we stop support it completely.
 === 2025-05-08 === === 2025-05-08 ===
     * Login/Register: Decrease image size to improve page loading time     * Login/Register: Decrease image size to improve page loading time
vrm_portal/change_log.1746708982.txt.gz · Last modified: by aleximb
