vrm_portal:change_log
vrm_portal:change_log [2025-04-30 14:14] – aleximb | vrm_portal:change_log [2025-07-10 17:11] (current) – aleximb | ||
+ | === 2025-07-10 === | ||
+ | * Fleet monitor: Significantly improve page responsiveness after a lot of data is loaded. | ||
+ | * Venus OS Large: Explain that 'VRM Portal Mode' should be set to ' | ||
+ | === 2025-07-09 === | ||
+ | * General: Added a backup font in case the browser cannot render special characters (Russian, Ukrainian, etc). | ||
+ | * General: The default time that notifications are shown was increased to 20 seconds. | ||
+ | * Advanced: Fixed a bug that allowed editing multiple widgets via ' | ||
+ | * Advanced: Added a ' | ||
+ | * Fleet monitor: Decrease the time it takes for the page to load with data. | ||
+ | === 2025-07-04 === | ||
+ | * Validation: Fix TypeError in validators | ||
+ | * Dynamic ESS Report: Improve code quality & make sure the report is generated in the user's preferred language. | ||
+ | === 2025-07-03 === | ||
+ | * Infrastructure: | ||
+ | * Site groups: Make the alarm toggle changeable for your own account even if you are not group owner/ | ||
+ | === 2025-07-02 === | ||
+ | * Users: Add mailto link to teams, groups & installation user management pages to simplify contacting users in case of issues. | ||
+ | * Installation overview: Your favourite installations will now show on top of your installation overview. | ||
+ | * Device List: Show local IP address again. | ||
+ | * Reporting: Fix Dynamic ESS report not showing at all if DESS was off for a portion of the selected period. | ||
+ | * Preferences: | ||
+ | === 2025-07-01 === | ||
+ | * Navbar: Fix `Dynamic ESS` settings not being shown in the navbar on pages in the new frontend framework. | ||
+ | * VictronConnect: | ||
+ | * Groups: Fix bug where a team as site-group administrators are not able to add a site they have full access to. | ||
+ | === 2025-06-25 === | ||
+ | * Dashboard: Show different banner for opportunistic battery balancing. | ||
+ | * Settings: Allow user to reset his consumption forecast. | ||
+ | * General: Animate VRM AI Assistant button icon. | ||
+ | === 2025-06-24 === | ||
+ | * Login: Remove `*******` placeholder from the password field to prevent confusion. | ||
+ | === 2025-06-18 === | ||
+ | * Installation overview: Make all filters apply immediately for consistent behaviour. | ||
+ | * Installation group: Fix styling of 'Link user' modal inputs on smaller devices. | ||
+ | * Fleet monitor: Added relative difference column to the solar widget. | ||
+ | === 2025-06-17 === | ||
+ | * Dashboard: Fix Demo mode banner not showing for certain modes. | ||
+ | === 2025-06-12 === | ||
+ | * Dashboard: Fix turning DESS off in the controls also causing DESS to be turned off in the site's settings. | ||
+ | === 2025-06-11 === | ||
+ | * Device Overview: Add icon for Energy Solutions Smart Switch | ||
+ | * Dashboard: Add new data attribute ' | ||
+ | * Alarms: Fix error caused by missing data attribute for Tank and Temperature Sensor alarms | ||
+ | === 2025-06-06 === | ||
+ | * Firmware update: Updating a GX device now properly waits with rescanning until the GX device is done rebooting | ||
+ | === 2025-06-05 === | ||
+ | * Diagnostics: | ||
+ | === 2025-06-04 === | ||
+ | * Fleet Monitor: Add enhanced search functionality triggered by the Command/ | ||
+ | * Venus OS Large: Add support for connecting to Node-Red/ | ||
+ | === 2025-06-03 === | ||
+ | * Device Registration: | ||
+ | === 2025-05-28 === | ||
+ | * Add Installations: | ||
+ | * Teams: Add the permission for admins/ | ||
+ | * Dashboard: Display AC Meter cards per instance for installations with energy meters and without certain devices | ||
+ | * VRM AI Assistant: Introducing the AI Assistant, which is capable of helping users with adding custom widgets to the Advanced page | ||
+ | === 2025-05-26 === | ||
+ | * Device list: Add GX IO Extender support | ||
+ | * Dashboard: Display PV inverter cards per instance when using dashboard layout for installations with energy meters and without certain devices | ||
+ | === 2025-05-21 === | ||
+ | * Navigation: Implement ' | ||
+ | * Dashboard: Add new layout for installations with energy meters and without certain devices | ||
+ | * Dashboard : Add EV card on dashboard to view EV information. | ||
+ | * Register: Dealers can now share a link to new users to automatically link them to their dealer account after registering. | ||
+ | * Register: Make go to login button smaller. | ||
+ | === 2025-05-17 === | ||
+ | * Controls: Fix ESS controls not working for users with a non-Enligh language. | ||
+ | === 2025-05-15 === | ||
+ | * Controls: Fix EVCS manual charge toggle on mobile. | ||
+ | * General: Fix a language issue when entering demo mode | ||
+ | * Installation data: Improve the logic for showing and hiding the dropdown items Solar and EV Charger. | ||
+ | * Login: Fix redirecting users with one installation to their dashboard. | ||
+ | * Controls: Fix unable to change EVCS mode | ||
+ | === 2025-05-14 === | ||
+ | * Dashboard: New UI for the controls section on mobile to prevent accidental changes. | ||
+ | * Dashboard: Fix VRM freezing under specific conditions when DESS is enabled. | ||
+ | * Admin Device search: Allow searching by VE.Bus serial number. | ||
+ | * Login: Improve performance & prevent showing the login page when already logged in. | ||
+ | === 2025-05-13 === | ||
+ | * Login: Fix incorrect language being set when initially visiting the login page | ||
+ | === 2025-05-12 === | ||
+ | * Login: Fix account language being overwritten by login | ||
+ | === 2025-05-10 === | ||
+ | * Login/ | ||
+ | === 2025-05-08 === | ||
+ | * Login/ | ||
+ | === 2025-05-07 === | ||
+ | * Navbar: Fixed background not staying blurry when navigating between sites on a mobile device | ||
+ | * Login/ | ||
+ | === 2025-05-06 === | ||
+ | * Advanced: Added new widgets: EV Location, EV SOC, EV State | ||
+ | === 2025-05-02 === | ||
+ | * Alarm Rules: Fixed issue where Automatic Alarm Monitoring would not update properly when moving to a different page | ||
+ | === 2025-05-01 === | ||
+ | * DESS: fixed the DESS configuration page sometimes not loading | ||
=== 2025-04-30 === | === 2025-04-30 === | ||
* Site Unlinking: Improve UX of API when unlinking a user from a site that wasn't bound in the first place | * Site Unlinking: Improve UX of API when unlinking a user from a site that wasn't bound in the first place |
vrm_portal/change_log.1746015268.txt.gz · Last modified: by aleximb
