vrm_portal:change_log
vrm_portal:change_log [2022-05-11 14:05] aleximbvrm_portal:change_log [2022-07-01 11:35] aleximb
 ====== VRM Portal changelog ====== ====== VRM Portal changelog ======
 +=== 2022-07-01===
 +  * Dashboard: Add expandable ESS states to the Battery tile.
 +=== 2022-06-29===
 +  * ESS Controls: Design improvements.
 +=== 2022-06-28===
 +  * Device List: Show L2 and L3 PV Inverter devices.
 +=== 2022-06-21===
 +  * Advanced: Fix voltage unit for energy meters in graph legends.
 +  * Advanced: Fix synchronised zooming for the Solar Charger Current widget.
 +=== 2022-06-20===
 +  * Dashboard controls: Add control for EV Charging Station.
 +  * Dashboard controls: Add generator control (requires Venus v2.90).
 +  * Dashboard controls: Allow user to enable Inverter/Charger control from general settings.
 +  * Dashboard controls: Display loading state of the controls.
 +  * Advanced: Switch around Humidity and Pressure series to ensure color consistency.
 +=== 2022-06-15===
 +  * Advanced: Fix calculated Solar Charger PV Current not being displayed sometimes.
 +  * Advanced: Fix graphs showing "No data available" instead of rendering the actual data.
 +  * Translations: Fix reloading english translations upon failure.
 +=== 2022-06-13===
 +  * Dashboard: Improve battery temperature readings. Now the temperature is displayed for more system types that use different methods of reading temperatures.
 +=== 2022-06-09===
 +  * Advanced: Add the ability to edit custom widgets.
 +  * Advanced: Show device names in the custom widget legend.
 +=== 2022-05-24===
 +  * Alarm log: Fix selecting the time range of an alarm when navigating to the Advanced page.
 +=== 2022-05-23===
 +  * Activate Hotjar for web and mobile.
 +=== 2022-05-17===
 +  * Controls: Change ESS translations keys.
 +=== 2022-05-16===
 +  * Advanced: Add icon to custom widgets.
 +  * Dashboard: Improve input limit tile styling.
 +=== 2022-05-12===
 +  * Installation overview: Add a Total row to sum up the power from all installations in the overview.
 === 2022-05-11=== === 2022-05-11===
-  * Firmware Update: Change the firmware file format for EV Charging Stationfrom .bin to .evcsup.+  * Firmware Update: Change the firmware file format for EV Charging Station from .bin to .evcsup.
   * Dashboard: Improve the update frequency of the values from the EV Charging Station tile.   * Dashboard: Improve the update frequency of the values from the EV Charging Station tile.
   * Improve overall buttons styling and consistency.   * Improve overall buttons styling and consistency.
vrm_portal/change_log.txt · Last modified: 2022-08-04 14:01 by aleximb
