vrm_portal:change_log
vrm_portal:change_log [2024-05-02 14:48] – aleximb | vrm_portal:change_log [2024-05-03 14:32] (current) – aleximb | ||
+ | === 2024-05-03 === | ||
=== 2024-05-02 === | === 2024-05-02 === | ||
* Dashboard: Fetch latest widget data when tab becomes active after more than 30 minutes of inactivity. | * Dashboard: Fetch latest widget data when tab becomes active after more than 30 minutes of inactivity. |
vrm_portal/change_log.txt · Last modified: 2024-05-03 14:32 by aleximb
