vrm_portal:change_log
vrm_portal:change_log [2024-04-08 21:48] – aleximb | vrm_portal:change_log [2024-05-16 20:04] – Correct some notes from 16th of May release aleximb | ||
+ | === 2024-05-16 === | ||
+ | * Navbar: Update the link to the Manual | ||
+ | * What's New: minor styling changes | ||
+ | * DESS formula: Now possible to copy and paste pricing formula. Also possible to use ctrl+v | ||
+ | * Installation Overview Data XLSX Download: Add generator runtime till service | ||
+ | === 2024-05-14 === | ||
+ | * Settings: Location; added ' | ||
+ | === 2024-05-10 === | ||
+ | * Advanced: (Restricted) admins can create custom widgets to troubleshoot problems | ||
+ | * Alarms: Fix ' | ||
+ | === 2024-05-07 === | ||
+ | * Firmware upgrade: Adjusted the table styling for updatable devices | ||
+ | * E-Mails: Don't show a " | ||
+ | * DESS Settings: Add Green Mode | ||
+ | * DESS Prices: Monitor missing price data + increase timeouts | ||
+ | * DESS: Turn off and don't schedule DESS for sites that are not DESS capable | ||
+ | * DESS: On mobile, when selecting an hour from the static price ranges for sell and buy prices, the hour picker stays inside of screen | ||
+ | * Alarms page: Fix PUT updates (except ' | ||
+ | === 2024-05-03 === | ||
+ | === 2024-05-02 === | ||
+ | === 2024-04-25 === | ||
+ | === 2024-04-11 === | ||
+ | === 2024-04-09 === | ||
=== 2024-04-04 === | === 2024-04-04 === | ||
- | * Dashboard: Fix, show distinct graphs for EVCS(s) on input and output side of multi - #1736 | + | * Dashboard: Fix, show distinct graphs for EVCS(s) on input and output side of multi |
* Alarms: Change communication monitoring alarm to be more descriptive (vrm stopped logging) | * Alarms: Change communication monitoring alarm to be more descriptive (vrm stopped logging) | ||
* Data Download: Improve the speed of data export feature | * Data Download: Improve the speed of data export feature |
vrm_portal/change_log.txt · Last modified: 2024-05-31 21:23 by aleximb
