vrm_portal:change_log
vrm_portal:change_log [2024-03-27 15:08] – aleximb | vrm_portal:change_log [2024-05-03 14:32] – aleximb | ||
+ | === 2024-05-03 === | ||
+ | === 2024-05-02 === | ||
+ | === 2024-04-25 === | ||
+ | === 2024-04-11 === | ||
+ | === 2024-04-09 === | ||
+ | === 2024-04-04 === | ||
+ | === 2024-04-03 === | ||
+ | === 2024-03-28 === | ||
+ | * Translations: | ||
=== 2024-03-27 === | === 2024-03-27 === | ||
* Android and iOS: there is now a new status widget with chart ranges and the old version as an alternative | * Android and iOS: there is now a new status widget with chart ranges and the old version as an alternative | ||
* iOS: inform the user when the widget cannot be edited if there is no internet or the user is logged out | * iOS: inform the user when the widget cannot be edited if there is no internet or the user is logged out | ||
- | === 2024-03-20 === | + | * DESS: Show negative value for energy price when below 0 in the Schedule -> Energy prices graph |
+ | === 2024-03-21 === | ||
* DESS: Set battery capacity before turning DESS On | * DESS: Set battery capacity before turning DESS On | ||
=== 2024-03-20 === | === 2024-03-20 === |
vrm_portal/change_log.txt · Last modified: 2024-06-06 13:30 by aleximb
