victronconnect:beta
victronconnect:beta [2026-09-11 19:32] – mpalavecinovictronconnect:beta [2026-11-10 13:33] (current) – [v6.43 (Released officially)] jperez
Line 12: Line 12:
-==== v6.50beta6 ==== +==== v6.50beta13 ====
-** 2026-09-11 **+** 2026-10-27 **
 __Download links:__ __Download links:__
Line 22: Line 22:
     * [[https://groups.google.com/g/victronconnect-beta-testing|1. Join beta testing group on this link ]]     * [[https://groups.google.com/g/victronconnect-beta-testing|1. Join beta testing group on this link ]]
     * [[https://play.google.com/apps/testing/com.victronenergy.victronconnect|2. Join VictronConnect beta on Google Play Store ]]     * [[https://play.google.com/apps/testing/com.victronenergy.victronconnect|2. Join VictronConnect beta on Google Play Store ]]
-  * [[https://www.dropbox.com/scl/fi/pmrn18tj05qsjd1ljfrjj/VictronConnectInstaller.exe?rlkey=b5y427eqgyetn6e51b3nh2oee&st=nm2mq0la&dl=1|Windows 10 and higher]] +  * [[https://www.dropbox.com/scl/fi/1q981eh043zau6ukrh4ut/VictronConnectInstaller.exe?rlkey=ttps7xwplgejaddlgr0k5ygqk&st=j2zmb7jl&dl=1|Windows 10 and higher]]
-  * [[https://www.dropbox.com/scl/fi/00rgykchjmcdykfvk63r3/VictronConnect.dmg?rlkey=jxtjzxmaycehrx4dwns3vjqfr&st=wrg4b2rf&dl=1|macOS 11 (Big Sur) and higher]] +  * [[https://www.dropbox.com/scl/fi/58qj08qhtfq75sssbixoa/VictronConnect.dmg?rlkey=jjx9v78er5knhm5fdi2gc3ruh&st=gpx29fms&dl=1|macOS 11 (Big Sur) and higher]]
-  * [[https://www.dropbox.com/scl/fi/dsepmz2z71oe433enmjz7/VictronConnect-x86_64.AppImage?rlkey=gj2vo8ommyxy4qj9mlchjxvzv&st=0b2pd1hc&dl=1|Linux AppImage]]+  * [[https://www.dropbox.com/scl/fi/w49stgb7jvat9cmomgak9/VictronConnect-x86_64.AppImage?rlkey=06p7loww4ygio9h71zzohkir5&st=zsibjkkv&dl=1|Linux AppImage]]
 Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue.
 +__Changes__
 +Remote Console
 +  * Added a "No internet connection" message with a Retry button when the phone is offline
 +  * The remote console now always loads the version that matches the GX, including after firmware updates or downgrades
 +  * Fixed a verification issue after signing in to a password-protected GX device
 +  * Fixed an occasional crash while synchronizing product PINs with VRM
 +Android
 +  * In full-screen mode, system bars no longer reappear with every touch on older Android versions
 +  * Improved use of the display area around the front camera on older Android versions
 +Apple CarPlay
 +  * Products are now displayed even when the phone is locked or when the app is started from the car
 +  * Each product now shows its two most important values without rotating between values
 +  * Removed the "Unlock your phone" message
 +  * Fixed crashes that could occur when unlocking the phone while CarPlay is active
 +  * Improved stability with fewer unnecessary screen refreshes and no more stuck alerts
 +==== v6.50beta12 ====
 +** 2026-10-23 **
 +__Changes__
 +VRM
 +  * Android: VRM sign-in now supports passkeys
 +  * macOS: Signing in to VRM no longer uses a previous session
 +  * Improved VRM loading and error screens
 +  * Improved reliability when loading VRM pages after signing in
 +Remote Connection
 +  * Improved remote reconnection behavior when returning to the app
 +  * Opening the app without an internet connection no longer shows a connection error; installations appear automatically once connectivity is restored
 +GlobalLink & P1 Link
 +  * GlobalLink: Mobile operator information is shown again
 +  * GlobalLink: Renamed "Smart Devices" to "External Devices"
 +  * P1 Link: "Last seen" now shows "a few seconds ago" for recent updates
 +  * Removed the energy counter reset option from P1 Link
 +  * Removed the VRM information pop-up from GlobalLink and P1 Link settings
 +EV Charging Station
 +  * Added firmware v1.02 for V2 models
 +Other
 +  * Fixed overlapping text in value rows
 +  * Improved firmware release checking
 +  * Fixed EVCS demo issues introduced in v6.50beta11
 +==== v6.50beta11 ====
 +** 2026-10-16 **
 +__Changes__
 +General
 +  * Added support for future products
 +SuperPack NG
 +  * Added "Always Off" heater mode setting (requires an upcoming firmware release)
 +  * Added a new "External Feedback Signal" setting that allows the external signal to be used as an alarm (requires an upcoming firmware release)
 +  * Added charge/discharge off reasons #14 "Cell Measurement Fault" and #15 "Long Charging Protection" (requires an upcoming firmware release)
 +EVCS
 +  * Added support for "Control Charging by Tag" (EVCS V2 only — requires an upcoming firmware release)
 +  * Added support for new first-setup configurations (requires an upcoming firmware release)
 +  * Fixed several issues with scheduler settings
 +  * Various other fixes and improvements
 +==== v6.50beta10 ====
 +** 2026-10-06 **
 +__Changes__
 +General
 +GX Remote Console
 +  * Various improvements
 +SmartShunt
 +  * Added firmware v4.20
 +BMV 712
 +==== v6.50beta9 ====
 +** 2026-09-30 **
 +__Changes__
 +Installation page (VRM)
 +  * Reduced dashboard loading time
 +  * Improved loading state UI
 +  * Improved retry mechanism in case of network failure
 +GX Remote Console
 +  * Fix a bug that makes it not loading after resuming the app
 +MPPT RS
 +  * Added error #41, "PV isolation failure" (requires an upcoming firmware release)
 +SuperPack NG
 +  * Fixed Min/Max Temperature values not being displayed properly
 +EVCS
 +  * Added firmware v2.09
 +OrionXS
 +  * Added firmware v1.15
 +SolarSense
 +  * Fixed an issue when setting the device RTC under certain conditions
 +==== v6.50beta8 ====
 + 2026-09-18
 +__Changes__
 +iOS
 +  * Add Apple CarPlay support. (Bluetooth)
 +Android
 +  * Improve Bluetooth device scanning
 +  * Notify when Bluetooth scanning cannot be initiated
 +GX Remote Console
 +  * Significantly improve loading time
 +EVCS
 +  * Add new errors and warnings
 +  * Add local firmware updates via Ethernet (EVCS V2 only — requires a future firmware release)
 +  * Add Instant Readout support for remote connections
 +MultiHS
 +  * Fix Grid Feed-In settings visibility
 + ==== v6.50beta7 ====
 + 2026-09-14
 +__Changes__
 +EVCS
 +  * Add firmware v2.08
 +OrionXS
 +  * Further improvements to the Emergency Charge feature (requires a future firmware release)
 +==== v6.50beta6 ====
 +** 2026-09-11 **
 __Changes__ __Changes__
Line 138: Line 294:
   * Added support for PV Tracker enabling settings   * Added support for PV Tracker enabling settings
-==== v6.42 (Released officially) ==== +
-** 2026-09-09 **+==== v6.43.1 (Released officially) ====
 +** 2026-11-10 **
 +This version is only available for Windows, macOS, Android and Linux.
-  * iOS: [[https://itunes.apple.com/app/victronconnect/id943840744?mt=8|App Store]]
   * [[https://play.google.com/store/apps/details?id=com.victronenergy.victronconnect|Android]]   * [[https://play.google.com/store/apps/details?id=com.victronenergy.victronconnect|Android]]
   * [[https://updates.victronenergy.com/feeds/VictronConnect/windows/w10/VictronConnectInstaller.exe|Windows 10 and higher]]   * [[https://updates.victronenergy.com/feeds/VictronConnect/windows/w10/VictronConnectInstaller.exe|Windows 10 and higher]]
-  * macOS [[https://itunes.apple.com/app/victronconnect/id1084677271?mt=12|11 (macOS Big Sur) and higher|App Store]] +  * macOS [[https://itunes.apple.com/app/victronconnect/id1084677271?mt=12|13 (macOS Ventura) and higher|App Store]]
-  * [[https://updates.victronenergy.com/feeds/VictronConnect/linux/VictronConnect-x86_64_v6.42.AppImage|Linux AppImage]]+  * [[https://updates.victronenergy.com/feeds/VictronConnect/linux/VictronConnect-x86_64_v6.43.1.AppImage|Linux AppImage]]
 Firmware updates: For more details, check release notes on Victron Professional. Firmware updates: For more details, check release notes on Victron Professional.
Line 153: Line 311:
 +VE.Bus Inverter/Chargers
 +  * Improved VE.Bus Inverter/Charger firmware updates
 +  * Added firmware v568 and v570
 +==== v6.43 (Released officially) ====
 +** 2026-09-23 **
 +__Changes__
 +OrionXS
 +  - Added firmware v1.15
 +  - Added the new "Emergency Charge" feature
 +==== v6.42 (Released officially) ====
 +** 2026-09-09 **
 +__Changes__
 Lynx Smart BMS Lynx Smart BMS
victronconnect/beta.1789155158.txt.gz · Last modified: by mpalavecino
