VictronConnect changelog and beta releases
During beta-testing of a new VictronConnect release, its details will be listed at the top of this page. Once released officially, all beta release notes are condensed into one full release note.
More information about VictronConnect, including manuals, is here: https://www.victronenergy.com/panel-systems-remote-monitoring/victronconnect.
Please report bugs and give feedback to these betas via the Disqus comments below. Note that comments are not public by default, and first go to a moderation queue.
Changelog
(Currently available betas are on top. See further below for official releases.)
v5.70beta3
2022-05-21
Download links:
* Android: If you can't open the downloaded file from the downloads list try using a file browser.
Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue.
Mandatory vs optional firmware updates: Please note that all the updates included in beta releases are always mandatory upon connection. The information in the changelog that indicates whether the update is mandatory or optional refers to the upcoming official release, not while installed as a beta.
Changes
Add Danish & Russian trasnlations
Allow VE.Can firmware updates via VC-remote connection. Requires Venus beta firmware v2.90.
Fix Android 12 Bluetooth products scan. Location permission were checked as a condition to start the scan although are not necessary anymore.
New broadcast data functionality:
VictronConnect can now show the most relevant data of Smart products in the product list page without having to stablish connection with the product.
Currently only SmartLithium v1.27 which is included in this VictronConnect release supports this new feature. Other products will be added soon.
Broadcast data is disabled by default, can be enabled in product info page.
Broadcast data is encrypted.
Broadcast data has better range than regular connection.
VE.Direct and VRM remote connected devices does also benefit of this new feature; no new firmware is needed.
SmartLithium:
Add firmware v1.27: (optional update)
Support for runtime data advertisement. Disabled by default, to enable it go to Settings → Product Info and enable “Bluetooth live data advertisement”
VE.Bus Smart dongle:
Add firmware v1.12:
Add support for VE.Bus BMS V2 (enables on/off/charger-only selection in combination with VE.Bus BMS V2)
Add “External control” status when BOL frames are being detected,
v5.70beta2
2022-05-03
Changes
Support Android 12 new Bluetooth permissions this allows VictronConnect to no longer need to request location permissions to scan nearby Victron Bluetooth products.
Fix PIN code change option is not visible. Issue was introduced in 5.70beta1
Improve Venus to xlsx converter: Conversion can now cope with partially corrupted VRM log files
Internal improvements
Orion Smart:
Add firmware v1.09:
Fix float disabling bug. It was possible to “disable” the float stage of the charging cycle, what is actually not supported by the charger. When float was “disabled”, the charger went into an “unknown” mode, instead of going to float, reporting as being in “Storage”, with the absorption voltage as voltage setpoint. Float is always present on the * * Orion Smart chargers.
Reduce minimum absorption time from 1h to 0h when fixed absorption time is selected and from 1h to 30min when adaptive absorption time is selected. This allows the support of * batteries that required less than 1h of absorption time
Add BLE Mode feature that allows user to fully disable/enable the BLE, or enable it for only 30s after power-up.
BLE improvements.
For models with 24V output: fix bug when changing from PSU to charger mode, or the other way around, that changes the input lock-out default values to a wrong, and out of range, value.
GlobalLink:
SmartShunt & BMV-712:
v5.70beta1
2022-04-11
Changes
VE.Can products:
Lynx Smart BMS:
VE.Can MPPT Solar Chargers:
Smart Battery Sense:
SmartSolar, BMV-712 & SmartShunt:
Orion Smart:
Add firmware v1.08:
Reduce minimum absorption time from 1h to 0h when fixed absorption time is selected and from 1h to 30min when adaptive absorption time is selected. This allows the support of batteries that required less than 1h of absorption time
BLE improvements.
Phoenix Smart Charger (120-240V models) :
Add warning 31 (input voltage out of range)
Add option to disable repeated absorption
Add manual recondition button
v5.59 (Released officially)
2022-04-04
Changes
RS Inverters and Solar chargers:
Orion Smart:
BMV & SmartShunt:
v5.58 (Released officially)
2022-03-16
Download links:
Changes
VE.Bus Inverter/Chargers:
Phoenix Inverter:
v5.57 (Released officially)
2022-03-04
Changes
SmartLithium:
SmartShunt:
Phoenix Inverter:
v5.56 (Released officially)
2022-02-08
Changes
MPPT RS:
Inverter RS:
Multi RS:
Lynx Smart BMS:
v5.55 (Released officially)
2022-02-01
v5.55 was released for macOS only, other platforms remain on v5.54.
v5.54 (Released officially)
2022-01-31
Download links:
Changes
Known issues
v5.53 (Released officially)
2022-01-24
Changes
General:
Multi RS:
Add firmware version v1.07 for Multi RS as a mandatory update.
Add an option to synchronise the battery SOC to 100%
Add Shutdown on SOC setting
Add setting to spefify the source of AC Input
Add setting to enable/disble the motoring of PE to Neutral voltage
Add Aux input settings
MPPT RS:
v5.52 (Released officially)
2022-01-03
Changes
Multi RS:
Lynx Smart BMS:
Known issues:
Bluetooth pairing is broken in macOS Monterey: connection can only be stablished with products that were already paired before updating the Apple device to Monterey. We're working on that, with Apple, but there is no solution on the horizon yet.
v5.51 (Released officially)
2021-11-23
Changes
Lynx Smart BMS:
Phoenix Smart IP43 Charger 120-240V:
v5.50 (Released officially)
2021-11-17
Download links:
Changes
Add firmware v490:
Add option to remove VE.Bus BMS configuration
Add low battery temperature cut-off setting for Lithium batteries
Improve the settings write and read progress notification
MultiRS:
Smart Battery Protect:
v5.49 (Released officially)
2021-10-29
Download links:
Changes
v5.48 (Released officially)
2021-10-07
Changes
Fix demo products show “This is latest version!” although version number is not shown
Hide status in the VE.Smart networking page during the setup process, it can be confusing.
Fix crash when a GX device on local lan is detected multiple times. This can happen when a GX device is connected to
LAN via ethernet and Wi-Fi simultaniously.
Blue Smart Charger:
MPPT RS:
Add firmware v1.05: (optional update)
Add TEXT protocol on the ve.direct interface (Inverter RS).
Add internal DC voltage measurement safeguard. In case the measurement is not ok the unit stops working, showing error code 201. This prevents over-charging a battery or damage to the internal circuitry.
Fix MPPT start-up sequence: bench testing the MPPT using a power supply could damage the internal circuitry (using firmware v1.04).
Fix 30-day MPPT history readout.
Fix bug when disabling temperature compensation. It was not fully disabled when battery temperature was above 50°C.
Fix bug for DVCC’s limit charge current when having only one charger connected on the VE.CAN bus.
Improve control loop stability of the built-in MPPT.
Add DC input resistance readout
Rename imput mode from BMS to 2-Wire BMS
Do not not warn about remote mode not in set to 2-Wire BMS when selecting Lithium. A VE.Can BMS can be used instead.
Do not automatically switch remote imput mode to 2-Wire BMS when Lithium preset is selected from VictronConnect presets library. Remote mode will change if the MPPT built-in “Lithium 2-Wire BMS” is selected.
Inverter RS:
MPPT Control:
VE.Bus Inverter/Charger:
v5.47 (Released officially)
2021-08-13
Changes
v5.46 (Released officially)
v5.45 (Released officially)
2021-07-19
Changes
Fix GX products
LAN/WiFi discovery on iOS and improve it on rest of platforms
Lynx Smart BMS:
VE.Bus Smart Dongle:
SmartLithium:
MultiPlus-II GX:
v5.44 (Released officially)
2021-07-01
Changes
VE.Bus Inverter/Charger (connected with MK3-USB):
v5.43 (Released officially)
2021-06-24
v5.43 was released for Android only, other platforms remain on v5.42.
v5.42 (Released officially)
2021-06-23
Changes
Various internal VRM improvements
Add Turkish language
Improve translations
Stop animations while not visible. This has an impact on Inverter RS firmware updating time on Windows which is now improved.
Open links to manuals in VC selected language whenever available.
Fix an issue on Android phones that makes that the toolbar is not properly drawn on Android phones. This issue is caused because Android provides wrong display metrics. So far, this issue has only been observer on phones with a 21:9 aspect ratio screen.
Fix some Android system configuration changes can make VictronConnect crash and show a white screen.
Blue Smart Charger:
Add firmware for future IP65 6V/12V model (mandatory installation upon connection):
Add re-bulk method setting (IP22 REV2 only)
Allow full current range on IP22 REV2 models (IP22 REV2 only)
Fixed demo mode for build-in battery types
Added explanation to recondition voltage setting
Fix bulk time unit in CSV history export
Add firmware v3.40 for rev2 models: (Optional update)
Update for Blue Smart IP22 Chargers REV2 only; starting production date week 24 of 2020 (serial number HQ2024nnnnn and newer). The hardware revision printed on the the product label should be “hw rev 02” or higher.
Support for VE.Smart networking
Blink status LEDs briefly once every 4 seconds to indicate VE.Smart networking is active
Added support for synchronized charging, allowing to parallel multiple chargers and synchronize their charge algorithms. Compatible with SmartSolar chargers, where the Blue Smart charger will become the charge master.
The PV power of all solar chargers is totalized by the charge master and broadcasted into the network to be displayed in VictronConnect when connected to a solar charger.
The battery idle voltage at sunrise, needed for aborption time calculation, is taken from the solar charge master upon master take-over. This value is continued to be broadcasted into the network for the solar chargers, to be able to continue charging if the Blue Smart Chargers are disconnected from the network.
Manual equalisation from the solar charger settings menu in VictronConnect will be delegated to all devices in the network by the charge master.
Enforce re-bulk voltage method, to prevent premature re-bulking when only the charge master is providing the full current. This setting is only enforced when the charge master has detected other chargers in the network and will continue to use the user selected method is case of stand-alone mode. The enforced setting is volatile, meaning that when the charger is restarted it will revert back to the last value the user has selected.
Added support for VSense; to be used for cable loss compsensation for individual network nodes
Added support for TSense; to be used for temperature compensation and low battery temperature cut*off, required for lithium batteries.
Added support for ICharge; when available, the total charge current of all chargers on the network will be used for the tail current.
Added support for ISense; when available, the battery current will be used for the tail current. This value is prioritized over the ICharge value. Requires a BMV or SmartShunt.
VE.Smart networking settings will be reset upon a “Reset to defaults” in VictronConnect.
Added low battery temperature cut-off
Requires VE.Smart networking temperature sensor, e.g. Smart Battery Sense or SmartShunt
When pressing the `Why is my charger off?` button in VictronConnect it will state that the charger is off due to a low battery temperature.
Because the charger cannot be totally switched off, the setpoints are set to lowest value possible, i.e. 12.8V and 25% * Inominal for a 12V unit.
Note for Victron Smart Lithium batteries, above feature is not relevant. Since then the BMS will disable the charge when the batteries are below 5°C, and also in case of cell over voltage. More clearly: its not necessary to buy a Smart Battery Sense to make sure a Phoenix Smart Charger stops charging a Victron Smart Lithium Battery below 5°C.
Add tail current functionality
Add re-bulk method based on voltage; this method can be selected using the “Re-bulk method” setting in VictronConnect
When the charge current is below the threshold for 1 minute, the absorption stage is ended and the charger will switch to float/storage. Note that the re-bulk current setting is ignored when this method is selected.
The default re-bulk behavior remains unchanged, to be able to use the product as mobile charger.
Allow 0% recondition current
This fixes an issue with the VictronConnect lithium preset
Setting it to 0% skips the recondition stage, if enabled
The charge current is now adjustable over the full range, from 25*100% * Inominal
The recondition current is now configurable from 0-50% (0=disabled)
Improved temperature compensation
Compensate down to -20°C for bulk and absorption, instead of only 6°C. During float and storage, the compensation is only down to 6°C, as per best practises: to charge a very cold battery, increase the charge voltage; but not to “float” a battery. With this change the temperature compensation works the same as our Solar Chargers as well as Multi and Quattro inverter/chargers.
Add hardware check for internal temperature sensor
In case malfunction, the temperature derating and compensation works incorrectly
An error 23 will be issued in case of sensor malfunction; this is not auto-recoverable and requires a power cycle of the unit. If the error persists, the unit is broken.
Allow absorption time less than 1 hour (community request)
Improve bluetooth connectability with VictronConnect
Show hardware revision for IP22 demo products:
Phoenix Smart Charger:
SmartLithium:
Add support for MultiPlus-II 2x120V split phase models
Show L2 information for MultiPlus-II 2x120V split phase models
Fix values can freeze when swithing between apps while connected to a Multi. (Android only)
Add latest firmware v482, v484 for MultiPlus-II 2x120V:
VE.Bus Smart Dongle
Solar Chargers:
Multi RS Solar:
Inverter RS & MPPT RS:
Phoenix Inverter:
Add firmware v1.25 for Smart Phoenix Inverters 1600/2000/3000VA - 230Vac: (Optional update)
Reduced power when AC output is off and device is in hibernation mode
Fix for saved history data issue
Lynx Smart BMS:
* Add number of parallel batteries setting
* Correct some of displayed error numbers
Add monitor mode setting available in Misc settings page.
Limit low SOC relay clear setting to a max value of 99%, 100% is not allowed by firmware.
Fix low SOC relay setting range slider is partially hidden when Dutch and French languages are selected.
v5.41 (Released officially)
2021-04-26
Changes
SmartShunt & BMV battery monitors:
Fix zero current calibration data is copied across settings files. This prevents copying incorrect calibration data to other units, for example when using a master setting file to batch configure multiple units.
Improve the warning text shown when triggering a zero current calibration
GlobaLink 520:
v5.40 (Released officially)
2021-04-20
Changes
* Fix SmartLithium and Orion Smart demo products doesn't open.
v5.39 (Released officially)
2021-04-12
Smart BMS 12/200:
Add support for the new Smart BMS
Add firmware v1.06 (mandatory installation upon connection)
Fix fuse type is not selected warning is shown while in the firmware update page
Smart BMS CL 12-100:
Blue Smart Charger:
Add firmware v3.25 for some of the IP22, IP65 & IP67 models (mandatory installation upon connection)
Add support for future models
IMPULSE-II:
v5.38 (Released officially)
2021-02-10
Changes:
SmartLithium:
Inverter RS:
v5.37 (Released officially)
2021-02-02
Fixes Bluetooth issue on Android. v5.37 was released for Android only, other platforms remain on v5.36.
Note that a Google SDK update forced us to change the required type of location permissions to “fine”. As explained in the manual, and in response to various feedback, we are not happy about this at all - its a result of how Google and Android works in combination with Bluetooth Low Energy. Note that VictronConnect is not sending any data to Victron, and for sure its not sending any location data.
v5.36 (Released officially)
2021-02-02
Changes:
General:
Added continuous BLE scan: instead of only scanning once when opening VictronConnect, and thereafter only when the scan button was pressed, it will now keep scanning as long as the Device list page is open. Products will appear in the list as soon as they are in range. A note on power consumption and this change: Continuous scanning has no impact on the power consumption of the Victron product. For phones, tablets and laptops, it will of course will have an impact on battery consumption, but that will be rather minimal if even measurable at all. The continuous scan is only active when the app is in the foreground and on the devices list page. When the app is sent to the background or connected to a product, the scanning stops. The refresh buttons remains, pushing it will make VictronConnect scan for VE.Direct devices, refresh the VRM installations list, and restart the Bluetooth scanning just in case it is needed.
Added Bluetooth signal strength indicator to the Device list page.
Increase Bluetooth connection timeout. Prevents the retry mechanism to be triggered too early in some old devices.
Fix custom name length limit when pasting non-
ASCII texts
Show badge on top of the settings icon when a firmware update is available
iOS: Fix Google Drive and probably other apps doesn't show the option to open firmware files with VictronConnect
Fix crash reported when closing VictronConnect on macOS Big Sur and iOS 14
Fix crashes on iOS when bringing back the app from background
Added the Lynx Smart BMS to the demo list (note that this product is not available for sale yet)
VE.Bus inverter/charger:
Include firmware v478
Add VE.Bus system configuration:
Guided Parallel, three phase and split phase systems setup
Guided standalone mode reset when only one unit is detected
Max of three units can be configured, for larger systems, use VE.Bus System Configurator.
Detects outdated firmware and version mismatch between units and offers the option to update them during the guided setup when setting up a new system.
AC switch over info:
Show the reason why the grid is rejected
Once grid is available again, the remaining time for AC input activation is shown
Show when AC input is ignored
Add detection of wrong phase rotation on AC in
Fix absorption time and interval can't be modified in demos
Inverter RS:
Add inverter ground relay enable/disable setting
Add AC frequency readout
Add “#14 battery temperature too low” error
Warn about 8:1 ratio when setting float voltage, including the calculation of max PV voltage for the given float voltage value
MPPT RS:
VRM:
Add installation filtering by tag
Fix VRM login on Android 5 phones, this issue was present since first release of the VRM functionality
Cerbo GX:
BMV & SmartShunt:
Orion Smart:
IMPULSE-II:
SmartBMS CL:
BlueSolar & SmartSolar MPPT:
v5.35 (Released officially)
2020-11-04
Changes
Fix freeze on Windows at startup and/or when scanning
Improve VRM connection by retrying to connect before showing a timeout error.
Fix VRM sign in button doesn't open the browser on iOS 14 when Safari is not the default browser. This issue also affects other links in VictronConnect.
Add support for the upcoming Lynx Smart BMS
Improve Venus backlog to xlsx converter:
Smart Chargers:
BMS-CL:
Inverter RS:
MPPT RS:
v5.34 (Released officially)
2020-10-21
Changes
Sort VRM installations by name
Add timeout when connecting to a Bluetooth product to prevent connection getting stuck and ensure that the retry mechanism is triggered.
Fix some texts do not update when switching language until the application is restarted
Improve VE.Smart networking on demo products
Solar Chargers:
SmartLithium:
VE.Smart Bluetooth Dongle:
MPPT Control:
MPPT RS:
Inverter RS:
VE.Bus inverter/chargers:
Battery monitors:
v5.33 (Released officially)
2020-09-30
Changes
Orion Smart:
v5.32 (Released officially)
2020-09-23
Changes
Fix “Fetching data” message is shown on the background when the alert notification drawer is open.
Fix connection process gets stuck at 20% when the bonding information is not valid, e.g., after changing the PIN code from a different phone.
Fix default PIN code warning “Do not warn me again for this product” option sometimes is not applied until the app is restarted.
Improve behavior when a scan is started before the previously product was actually disconnected
Changes to Trends UI and zoom functionality
Show short note when firmware library is empty
Fix Lithium Iron Phosphate (LiFePo4) preset for non-MPPT products with equalization auto stop mode setting support.
Orion Smart:
Add firmware v1.05:
Add input voltage modulation when input voltage gets below the engine shutdown detection level (Vshutdown) to avoid depleting the starter battery.
Add new engine shutdown detection strategy to include a delayed start level to allow the starter battery to recharge for some time after turning on the engine.
Add different default input voltage lock-out values for when the charger is at charger mode (12.5V and 12.8V) or at PSU mode (10.5V and 11V).
Add remark “History data is for the total of all outputs” to history page (history is only available in beta firmware)
Improve charge current setting adding minimum, low, and max current presets. Low current preset matches the charger low current mode so the charger LEDs behavior is the same than when enabling by pressing the physical button.
Solar Chargers:
Smart Chargers:
Add support for VE.Smart networking (only Phoenix Smart Charger, by using a beta firmware)
Layout fixes and improvements
Fix reported power supply state
Fix absorption time description
Change the way the adaptive absorption time is displayed, make it similar to the MPPT for more consistency.
Enabled more battery preset capabilities
Improve re-bulk voltage offset setting
Add “Why is the charger off?” functionality
Add low temperature cut-off settings (only supported by beta firmware)
Add IMPULSE-II Smart IP65 firmware v3.17
Add Blue Smart IP65 Charger 12/5 firmware v3.22 update
v5.31 (Released officially)
2020-09-01
Changes
BMV & SmartShunt:
Smart Phoenix Inverter:
v5.30 (Released officially)
v5.29 (Released officially)
v5.28 (Released officially)
2020-08-03
Changes
Add the date to history CSV exports
Add a setting to keep screen on while using VictronConnect
Improve Bluetooth connection
Allow commas and dots as decimal separator. This is useful on phones/computers with non-matching locale and keyboard layout configuration.
Fix default battery monitor values when creating a new battery preset
Unified MQTT and VRM error codes
Added acknowledgment checkbox on the disable Bluetooth dialog.
Fix duplicated disable Bluetooth switch/button
Keep the connecting blur until all the live values are fetched.
Show battery monitor settings in battery presets only if supported by the product
Improve error message shown when opening a settings file created with an older VictronConnect version.
Solar Chargers:
Add firmware v475
Fix when updating the dongle firmware, a wrong warning that corresponds to Multi/Quattro firmware update is displayed.
Fix VE.Bus product is not recognized after a firmware update requiring to press the scan button.
Orion Smart:
Smart Chargers:
Collapse status widget when scrolling
Add support for future Phoenix Smart IP43 Charger revision 2 models
Fix “User defined” is shown when selecting Lithium preset from VictronConnect presets library
Fix vertical scroll bar in live data page is not shown on desktops and tablets when in landscape mode
Lynx BMS:
Battery monitor:
v5.27 (Released officially)
2020-07-06
Changes
Improve the warning and information messages in the firmware update page
Improve troubleshooting information
Show default PIN code to the connection progress pop-up
Advice to check the notifications bar when the pairing request doesn't appear on Android
Only advice to remove the product from the Bluetooth paired devices list when that could be the issue.
Disconnect every Bluetooth product before starting a new scan. This prevents the state where a product could remain connected after an interrupted firmware update.
Increase the number of lines logged into the service report.
Fix *.xup update fails when triggered within a few seconds after VictronConnect start up.
SmartLithium:
v5.26 (Released officially)
2020-06-19
Download links:
Changes
Fix freezes for a small amount of time while retrieving installations from the VRM server
Fix possible crashes after re-scan
Fix Android crashes and synchronization problems
Fix devices in range list doesn't refresh when joining an existing VE.Smart network
Fix settings save/load buttons sometimes remain disabled having to reconnect to activate them
Fix the PIN dialog keeps the input of the first PIN change when changing the PIN twice on same session
Remove duplicated demo products
Do not show the default PIN code warning if there is a mandatory firmware update available
Improve PIN code reset via PUK error handling
Fix PIN code reset via PUK on Linux
New “charger off reason” feature: Display the actual off reason reported by the charger and offers guidance for troubleshooting possible installation problems. This feature is not available for the following solar charger models:
BlueSolar 70/15
BlueSolar 75/10
BlueSolar 75/15
BlueSolar 100/15
BlueSolar 100/30 rev1
BlueSolar 150/35 rev1
BlueSolar 75/50
BlueSolar 100/50 rev1
Disable equalization voltage setting when Lithium preset is selected
Rename “ESS” state by “External control”
SmartLihium:
Orion Smart:
InverterRS:
Smart Chargers:
v5.25 (Released officially)
2020-05-25
Changes
Mark the VE.Direct Smart Dongle (Rev1) firmware v2.23 as a mandatory update. When a dongle running firmware v2.10 is connected to a BMV-70x the battery reading current is read only once and doesn't update when the value changes.
Fix an issue that makes firmware updates via VE.Direct cable will not use higher baud rates than 19k2 making the firmware update slower than it should be.
v5.24 (Released officially)
2020-05-22
Changes
Smart Chargers:
v5.23 (Released officially)
2020-05-22
Changes:
Fix history CSV export (Solar Chargers & Blue Smart Chargers)
Fix Multi/Quattro AC Input control battery low voltage condition
Fix battery settings voltages on Orion Smart demos
Fix updater issues when the update button is pressed while the connection is not ready
v5.22 (Released officially)
v5.21 (Released officially)
2020-05-18
Changes:
Improved Bluetooth stability on Android
Fix crash on Android when removing the USB serial port
Performance improvements, mostly noticeable during connection time.
Do not show the disable Bluetooth warnings when connected via VE.Direct cable
VE.Smart network UI/UX improvements
Fix battery presets edition
Improve
URL scheme registration on Linux
Fix freezes on macOS where there are Bluetooth devices providing a serial port interface
Solar Chargers:
Add Bluetooth firmware v2.25
Add firmware v1.50
Improve PV Short Protection detection for 250V models when on ESS
Add timeout to join a synchronised charging network
Remove error 68. Now, the error will be no longer triggered when the same information comes from BLE and VE.Direct. A decision method based on priority is applied, where VE.Direct has a higher priority when compared to BLE. For more information, see MPPT Error Codes.
Fix spurious charge algorithm reset after overshoot/zero current event.
Add firmware v1.06 (VE.Can models)
Update error 68 trigger conditions. Now, the error will be no longer triggered when the same information comes from BLE and VE.Direct/VE.Can. A decision method based on priority is applied, where VE.Direct/VE.Can have a higher priority when compared to BLE. Error will still be triggered if same data is received from VE.Direct and VE.Can. For more information, see MPPT Error Codes.
Improved error 38/39 detection when charger is externally controlled (i.e. ESS mode).
Fixed issue that could lead the MPPT to trigger error 67 (BMS missing) even when the BMS was present at the network. Also, the error could not be cleared properly.
Change error 67 behavior by turning it into a warning, not error. Output voltage drops to the battery base voltage.
Fix the reception of the charge current limit. That was a combined issue with Venus
OS. The fix for the Venus is available on Venus
OS v2.53 or higher.
Fix NMEA device instance change when done over complex commands on VE.Can.
Show PV power of all the synchronised charging MPPT's in the VE.Smart network
Blue Smart Chargers:
VRM:
Fix app crash can happen on Android on reconnection when bringing back the app from background
Fix error “-100” on poor network connections or Venus devices with high CPU loads, now connection is retried and the error is better handled.
Do not try to get a list of devices when the user has no full control access to the installation.
InverterRS:
BMV & SmartShunt:
Smart Chargers:
v5.20 (Released officially)
2020-04-06
Changes:
Include Linux build as part of the releases
Fix iOS video playback
Make connection retry mechanism stop after three attempts
Fix app can freeze when changing layout by resizing the window
Speed up firmware updates for *.dup firmware based products
Improve alarm notifications panel
Add connection keep alive mechanism:
Fix that on Android, in certain situations the Bluetooth connection remains active when it should be closed.
Needs to be supported by the device firmware, at this moment only supported by Smart Battery Protect firmware v2.04.
(New)VRM feature:
Android:
SmartShunt:
SmartCharger:
Improve night mode handling
Make re-bulk current a battery parameter
Fix update notification doesn't update when error changes
Add invalid history data error, including advice of how to recover
Make changes to charge cycles history in preparation to upcoming new firmware version
InverterRS:
VE.Direct Phoenix Inverter:
Solar Chargers:
SmartBMS CL:
GX devices:
Solar Chargers:
Add MultiPlus-II firmware v471
Fix AC low voltage connect value in demos
Add demo for MultiPlus-II 5000
v5.19 (Released officially)
2020-02-20
Changes:
v5.18 (Released officially)
2020-02-13
Changes:
Performance improvements on iOS and at first run for rest of platforms.
Fix notifications drawer don't update the alarm/warning/error description is some cases
Order demo groups alphabetically
SmartSolar VE.Can:
GX devices:
Improve Venus network settings layout
Add new icons for Cerbo GX, Maxi GX, Octo GX and MultiPlus-II GX
Solar Chargers:
Smart Chargers:
BMV:
SmartShunt:
SmartLithium:
v5.17 (Released officially)
2020-02-03
Changes:
General performance improvements
Do not show default PIN code warning when there is a mandatory update available
Fix missing decimal digits and units for trends
Show a warning when trying to use an invalid firmware file
GX devices:
Solar Chargers:
Improve StreetLight settings UX
Improve TX port and Load output settings UX
Add support for new models
Phoenix Inverter:
BMV-712
Smart Chargers:
v5.16 (Released officially)
v5.15 (Released officially)
v5.14 (Released officially)
2019-12-10
Changes:
Guide the user when a product is not found:
Make it clear that product is using latest firmware
Show built-in firmware if there is a firmware update available
Advice to remove bond when resetting PIN code by using PUK code; Otherwise, if using an invalid bond the puk reset process will fail
Add SOC to battery settings so now it is possible to manually set it.
Add storage settings to battery presets
Check device
OS and warn if it is not supported by VictronConnect
Do not show default PIN code warning if there is a mandatory update available
Fix trends sometimes don't restore the stored trend views
Do not show the default PIN security warning when there is a mandatory update available
Show devices in the devices list even when connection is not possible because are already connected to another phone/computer. Compatible devices:
VE.Direct dongles - released in v2.17 for SmartBMV, VE.Direct SmartSolar, PhoenixInverterSmart and VE.Direct external dongle; released in v2.18 for VE.Can SmartSolar.
SmartLithium batteries - released in v1.17
Smart Battery Sense - released in v1.04
IMPULSE-II Smart chargers - since v3.09
Phoenix Smart Charger - since v3.08
Add a text to advice to remove the jumper in VE.Direct port when changing load output operation mode.
Fix available options on RX Functions for MPPTs. Small models have all 4 options, bigger models do not have a load output.
Smart Chargers:
Phoenix VE.Direct Inverters:
VE.Direct Bluetooth Smart Dongle:
IMPULSE-II Smart IP65 Chargers:
Add firmware v3.15:
Limit charging below 17.4V:
Trigger a low battery voltage error
Open the output relay
Set the charge voltage to 24V
Limit the charge current to 1A
v5.13 (Released officially)
2019-10-28
Changes:
v5.12 (Released officially)
2019-10-28
Changes:
Fix firmware version is not shown in all the cases when the update is completed
Fix “update succeeded” message is wrongly displayed when trying to update using an invalid file
Various user interface fixes and improvements
VE.Smart network:
Bluetooth internal and external dongles:
MPPT SolarChargers:
Add MPPT Solar Chargers firmware v1.46:
Update marked mandatory only for SmartSolar as these models are affected by the bug described below.
Fix bug on the internal temperature measurement that lead to not being able to de-rate the output current due to a high temperature nor triggering the over temperature protection. (Bug introduced on v1.30). This bug is only present in SmartSolar.
Make 30 day history in demos more accurate
Add VE.Can MPPT SmartSolar firmware v1.03
BMV-712:
SmartLithium:
Blue Smart chargers:
v5.11 (Released officially)
2019-09-18
Blog post: VictronConnect 5.9 – Solar Charger improvements and much more
Changes:
Fix VictronConnect could not recover properly after an interrupted bluetooth update of the bluetooth microcontroller/dongles in our products.
Known issues:
On macOS, a firmware update of Multis, Quattros or other devices with a VE.Bus port may fail. This issue was introduced in VictronConnect v5.9. A new VictronConnect version fixing this is expected in the near future. Meanwhile, there is a workaround.
v5.10 (Released officially)
2019-09-13
Changes:
- Fix an issue with the MPPT battery presets created with VictronConnect v5.8 and older. Those old presets don’t include values for the new settings introduced in MPPT firmware v1.42. Because of that, when the user selected and re-applied such “old” preset using VictronConnect 5.9, settings like Adaptive absorption were disabled, while they should be enabled by default.
v5.9 (Released officially)
2019-09-11
Download links:
iOS:
App Store (Pending of App Store approval)
Changes:
General:
Trends tab remembers last selected graphs for certain product family
Improve PIN code change process
Improve information shown when unable to connect to a product
Fix PIN code reset via PUK code interface issues
Fix settings files buttons could not appear when VE.Direct connected
Fix overlapped text in the Inverter/Charger details page on Windows 10
Show a warning when using Default PIN via BLE
Firmware updates are no longer mandatory for basic monitoring:
Live data page: This page can be accessed without updating the firmware unless the update is highly recommended and marked as mandatory.
Setting pages: To view and modify settings it is always necessary to update the product to the latest version included in VictronConnect.
Do not allow change PIN code to same code
Update the framework on top of which VictronConnect is built, required to comply with Google Play Store requirements. This will improve the application performance but adds a drawback: We have to drop support for old
OS versions, see below.
Android:
Add ARM64bit build: Takes advantage of all the power of modern CPUs. This is also required by Google Play Store.
Drop support for Android versions older than 5.0(Lollipop).
Remove unintentional Android “microphone” and “camera” permissions, they are actually never user by VictronConnect.
iOS:
MPPT Chargers:
SmartShunt:
BMV:
Orion Smart:
BlueSmart Chargers IP65:
Bluetooth:
Add firmware v1.17
Add “ECO search time” setting
Add option to disable Bluetooth on Smart models
Fix wrong AC output voltage being shown in in some cases
IMPULSE-II chargers:
v5.8 (Released officially)
2019-07-18
Notes:
When viewing the permissions of the Android version of VictronConnect, it shows “microphone” and “camera”. This is unintentional and they are actually never user by VictronConnect. On Android versions >= 6, the individual permissions can be enabled/disabled and the “microphone” an “camera” permissions can stay disabled. These permissions are removed in version 5.9beta2.
Changes:
Inveter/Chargers:
Orion Smart:
GX devices:
Bluetooth products:
Add Bluetooth disable option for products that supports it, available in the product info page
Add instructional videos of how to remove the device pairing, required after a PIN code change
VE.Can MPPT:
SmartSolar chargers, Smart BMV, Smart Phoenix Inverters & VE.Direct Smart Bluetooth dongle:
Settings now scale accordingly to the selected battery voltage
Fix presets can be created with incorrect values from a demo product and therefore when loading it on a real product makes the charger enter in error mode having to restore settings and power cycle it.
General:
v5.7 (Released officially)
2019-05-08
Changes:
v5.6 (Released officially)
2019-05-07
Notes:
Changes:
Fix firmware update retry is not triggered when reconnecting after an unsuccessful firmware update.
Fix disable Bluetooth toggle is shown twice for some products
Make trends use user selected temperature unit
Fix typos in Dutch and German translations
GX devices:
v5.5 (Released officially)
2019-05-02
Download links:
Changes:
Add support for Phoenix Smart Chargers
Add new features highlight on home screen
Add onboarding, shows to the user a brief description of the available options
Add a button to disable Bluetooth; currently available for:
Smart BMV-712
SmartSolar Chargers (only when updated to v1.40 or newer, which is not publicly available yet at this moment)
Phoenix Smart Charger IP43
Improve reset pin code by PUK handling
Fix the “user defined” is shown when certain battery presets are selected
Android: Fix crash on devices without Bluetooth
Small
GUI fixes and improvements
Fix GX log converter day light saving issues.
Add trend graphics for BMV, MPPT and Smart Battery Sense
BMV: voltage, current, power, consumed amp hours, state of charge, starter battery voltage, temperature, mid voltage deviation
Smart Battery Sense: voltage, temperature (those two are all this device measures)
MPPT: solar voltage, current & power. Battery voltage & current & temperature. Load current (for models that have a load output)
It records for max 2 hours; and stops/discards as soon as you disconnect from a device.
Fix typos and improve wording on various pages
Set MPPT low-temp cut-off setting resolution to one degree; the previous higher resolution was pointless.
Add an option to select Fahrenheit as the unit for temperature. To enable, open the main VictronConnect menu, click settings. Here you’ll see the version of VictronConnect as well as the option to change language and temperature unit.
Fix EasySolar-II GX, MultiPlus-II GX and Generic Venus devices are shown as Unknown devices when discovered over UPnP
v5.4 (Released officially)
2019-03-08
Changes:
Smart Lithium Batteries:
Venus devices:
Android:
v5.3 (Released officially)
2019-02-10
Changes:
BMV Battery monitor:
Fix “Battery starts synchronized” setting. This is a recently introduced feature in the BMVs; Configuring that feature, #70 START SYNCHRONIZED, on the unit itself worked fine. But in VictronConnect it was not possible to change that setting. Now it works as it should.
Peak Power Pack:
v5.2 (Released officially)
2019-01-09
Changes:
New products support:
BMV Battery Monitor:
BMV 712 Bluetooth firmware update v2.14
BMV Battery monitor firmware v3.10(BMV 70x) and v4.01(Smart BMV) update
Add “Battery starts synchronized” setting
Add scrollbar to presets list
Fix history totals text overlap
SmartSolar Bluetooth firmware v2.14 update:
iOS:
v5.1 (Released officially)
2018-11-23
SmartLithium
MPPT solar chargers:
Phoenix Inverter:
macOS:
Android:
v5.0 (Released officially)
2018-10-09
Changes:
Firmware updating:
BMV battery monitor:
v4.9 (Released officially)
2018-08-23
Changes:
VE.Bus Smart Bluetooth Dongle:
Added firmware v1.07 update
Hide SOC items when battery monitor is disabled
Added missing Multi's model names
Fix issues when connected Multi/Quattro firmware version is lower than 415.
Warn about minimum firmware version
Added power value reading to the main page
Fix time to go reported as “Infinite” instead of “0h” when discharge floor SOC level is reached
Fix high voltage relay setting reports wrong values when editing for a first time in the session
Blue Smart Charger:
v4.8 (Released officially)
2018-07-05
Changes:
Mac:
VE.Bus smart dongle:
v4.7 (Released officially)
2018-06-09
Changes:
iOS:
v4.6 (Released officially)
2018-05-29
Changes:
MPPT:
macOS:
v4.5 (Released officially)
2018-04-25
Changes:
Solar Chargers:
v4.4 (Released officially)
2018-03-16
Changes:
Fix custom name max length for non
ASCII characters
Add VE.Smart networking settings to demo products
Update translations
Fix hardware failure alarm icon
Fix live data relay icon
Small user interface corrections and improvements
Solar Chargers:
Added internal bluetooth firmware v2.12 update
Add low temp cut-off setting, prevents damage in lithium batteries by disabling the charge during low temperature conditions.
Show battery temperature when available.
Make auto equalization interval the only charge setting that can be modified when a factory default battery is selected
Send local time to the MPPT: Helps streetlights functionality to synchronize.
Fix a bug that keeps streetlights on after sunrise
Fix mid-point deviation unit, it was “V” when it should be “%”
SmartLithium:
Added firmware v1.12 update
Add “Allowed-To-Discharge cell voltage” setting
Fix low cell voltage alarm
VE.Smart dongle:
SmartBatterySense:
PeakPowerPack:
v4.3 (Released officially)
2018-02-08
Download links:
Changes:
SmartLithium:
MPPT Solar chargers:
Fix save/load settings functionality on BlueSolar 150/100 model
Add relay state to live data page
Add an error in one of the history records of the demo products
Rename load output to virtual load output on devices without load output
Add description to day/night detection settings
History graphs:
Hide Bluk, Absorption or Float segments when the state was not reached
Improve bar length on days without production
Add scrollbars
Add mouseover to bars and buttons
Fix daily records values are partially hidden on some small screens, for example iPhone 5 & iPhone SE
Fix text overlapping due to translations
Phoenix Inverters:
Fix save and load settings icons are disabled when using VE.Direct cable
Add mode setting, mode now can be switched between on, off and ECO
Add firmware v1.14 update for 800VA models
Windows & Mac:
Add scroll bars to device list and settings pages
Add mouseover effect to the refresh button in the device list page
Rename “CCGX log converter” to “Venus log converter”
v4.2 (Released officially)
2018-01-07
Download links:
Changes:
Note that in v4.0 and v4.1 the auto-update was not working in Windows hence fixed in v4.2, so Windows users will need to manually download and install this new version. There is no need to first uninstall it; simply download the new version and install it. This will automatically replace any existing install.
v4.1 (Released officially)
2018-01-07
Changes:
MPPT Solar Charger history page:
Fix on historical graph, PMax is displayed in 'kWh' instead of 'W'
Fix yield counter reset button missing
BMV
iOS only: fix pressing the plus and minus symbols on the clear value also changed the set value at times when it shouldn't.
Fix Tail current is shown as if its in Amps (current), while actually it is in percentage.
Fix discharged & charged Energy units mix up
Fix Missing “Sync to 100%” and “Zero current calibration” buttons
Windows & macOS:
Fix device settings windows for the BMV are all blank.
Fix saving mppt 30 day history to csv doesn’t work.
And our thanks to Damon, Claudio, Justin, Rob, Andre, and others that helped find those bugs so quickly after the release.
v4.0 (Released officially)
2018-01-05
Changes:
Added translations: Dutch, French, German, Italian and Spanish. By default the system language is chosen
SmartLithium:
Improved history page with graphs
Added user battery presets library
Included firmware v1.29 update
Show the actual state when performing an automatic equalization
Android:
Minimum required version is Android 4.1
Dropped support for Android ARMv5
Notify that the location services are disabled when needed (Bluetooth & Android > 5) and guide the user to the Android location settings page.
Improved USB OTG connection, fixes firmware update failures and random crashes.
Fix first connection attempt after introducing the PIN code fails
Windows:
Dropped Windows XP & Vista support, minimum required version is now Windows 7. The previous version, which can be used on XP, will remain available on our software downloads page.
macOS:
v3.3 (Windows only)
2018-01-05
Changes:
No changes added, this is a transition version to prevent VictronConnect being updated to v4.0 on Windows XP / Vista.
Windows XP / Vista:
This is the latest version as support for XP / Vista is dropped in v4.0.
Windows 7 and higher:
When updating from v3.2 this version will be installed and v4.0 update will be automatically requested.
v3.2 (Released officially)
2017-08-14
Changes:
* Always show “Restore factory defaults” button when supported. Button is not shown when VictronConnect doesn not support settings files for the product.
* Enable manual firmware updates for Bluetooth products.
* Show “Stay close to the device” when updating bluetooth connected devices
Windows & Mac:
BMV:
Settings files:
Add support for the new SmartSolar 75/10, 75/15, 100/15, 100/20, 100/30, 100/50, 150/35 & 150/100.
Demos:
Add SmartSolar 75/10, 75/15, 100/15, 100/20, 100/30, 100/50, 150/35 & 150/100 to the demo library
Fix low current mode toggled when opening app from background. If the app is connected to the charger, the charger is in low current mode and the app is sent to background and then opened again the low current mode toggles to normal mode.
Show the proper firmware error messages when the update fails
Improve firmware update error message including a link to Victron Live troubleshooting.
Include firmware v3.0 update.
v3.1 (Released officially)
2017-08-01
Changes:
Add settings files feature. This enables saving the product settings to a file and then load it later in the same or another product. Besides this, a setting file can be also opened as a demo and use it for diagnosis as it contains a snapshot of the product at the moment the file was saved including history records.
Add demo products feature. A demo product can be used to:
Learn and show the options available for different products.
Create a specific setup, save that and send it to a customer so they can put it in their device.
Besides loading products from the standard library, it is also possible to load it from a saved file.
Use this to review settings made to your installations, make changes and then send them to whoever is at the site so they can apply them.
Allow filtering of the device list
Change menu items width to page width
Feedback when a setting is correctly stored in the device
Fix “Unsupported firmware version” error when opening BlueSolar & SmartSolar demos
Fix “Show PIN code” option on PIN code change page
Fix “Show PUK code” option on PIN code reset page
Windows & Mac:
BlueSolar & SmartSolar MPPT chargers:
Fix automatic equalisation interval setting is disabled when “Use default charge settings” is selected
Add an option to disable the charger.
Include firmware v1.27 update
Add StreetLight night and day detection delay setting
Add inverted load on/off mode for Rx port function
Remove automatic battery voltage detection option:
Automatic battery voltage detection is only done once @ power-up. If the battery voltage is present (>7V) the detected battery voltage is stored and further automatic detection is disabled. If the battery voltage is absent (<7V) the unit operates as a 12V model, automatic detection remains active (@ next power-up).
Add manual equalization for some models. Excluded models:
BlueSolar 75/50
BlueSolar 75/15
BlueSolar 100/15
BlueSolar 100/30
BlueSolar 100/50
BlueSolar 75/10
Blue Smart Charger IP22:
SmartLithium:
Android:
Windows & Mac:
v3.0 (Released officially)
2017-07-05
Download links:
Changes:
SmartLithium batteries:
v2.9 (Released officially)
v2.8 (Released officially)
2017-05-16
Changes:
Windows & Mac
Phoenix Inverters:
v2.7 (Released officially)
2017-04-25
Changes:
v2.6 (Released officially)
2017-04-20
Changes:
v2.5 (Released officially)
2017-04-18
Changes:
Android:
General:
v2.4.2 (Android only, Released officially)
v2.4.1 (Android only, Released officially)
v2.4 (Released officially)
2017-03-24
Changes:
VE.Direct Bluetooth Smart dongle:
SmartSolar MPPT:
Show the correct icon when updating bluetooth firmware
Fix battery voltage can't be set to 48V on some models
New Bluetooth firmware update v2.10
SmartLitihum batteries:
Phoenix Inverter:
Peak Power Pack:
v2.3 (Released officially)
2017-01-20
Changes:
General:
Phoenix Inverter:
v2.2.2 (Released officially, Android only)
v2.2 (Released officially)
2016-12-02
Changes:
General:
Add custom names for Bluetooth products, can be set on the product info page
Add support for future products
Show hardware version(if available) on the product info page
Android:
Improve compatibility with Android 6 devices
Keep firmware update running in background when a phone call is received during a firmware update.
Improve compatible devices filtering on Google Play Store specially with some Android 6 devices. This improvement involves the use of the new Android 6 permission system which makes necessary to request access to device location services to be able to scan nearby bluetooth low energy devices. You must allow VictronConnect to access to the location services when requested if you want to find bluetooth products.
BMV:
Phoenix Inverter:
Blue Smart Charger IP67:
v2.1(Released officially)
2016-10-31
Changes:
General:
Android:
BlueSolar MPPT:
Fix a bug on streetlight settings page that made lights don't switch off till sunrise when PWM is disabled and “At sunset, switch lights on for a fixed time” is selected.
Add constraints to the day/night detection voltages to make sure that night detection voltage is never below the minimum detectable voltage
v2.0 (Released officially)
2016-08-30
Changes:
General:
Add reset PIN code by entering a PUK code. This option is accessible by doing a long press on the desired product on the discovery page, right click on desktop. This feature is only available on some products.
CCGX log to xlsx: Include units in column
Android:
New VE.Direct Smart bluetooth dongle firmware version 2.09 (fixes issues with Galaxy S5 and probably many other phones)
Improve updating and connecting for Android 6
Fixed BlueSolar MPPT 30 day history records are not displayed on Android 4.3
BlueSolar MPPT:
New v1.19 firmware update included as a mandatory update.
Add a switch to enable/disable equalisation, no need to set equalization values to 0 anymore.
Fixed a bug that made the streetlight functionality stop working after toggling the on/off switch. The problem was that the “Switch lights on at sunset” event is disabled when streetlight functionality is set to off but it is not enabled again till the “At sunset” setting is modified by the user. This fix also detects if the issue is present on the configuration and automatically fixes it when opening the streetlight settings page.
Blue Smart Charger IP65:
Improved page layout on desktop platforms
New v2.03 firmware included:
Reduce connection problems, esp. in combination with Android 6
Fixes issues with Galaxy S5 and probably some other phones
Added identification: LEDs blink for 2 seconds when connecting
Add support for future Blue Smart Charger models
v1.9 (Released officially)
2016-07-20
Changes:
General:
Phoenix Inverter:
BlueSolar MPPT:
BMV:
v1.8 (Released officially)
2016-07-04
Changes:
Phoenix Inverter:
v1.7 (Released officially)
2016-06-29
Changes:
General:
New functionality: Convert CCGX log files to .xlsx Excel sheet (only Windows & Mac
OS X)
New functionality: Export 30-day BlueSolar MPPT history as CSV
New functionality: “Create service report” option generates a diagnostics report for sending it to Victron Energy service in case of any issue.
Improve dialogs, now all the dialogs are better centred on the screen
Android: Shorten connecting time during updating
Fix an issue that makes necessary to scan several times before Peak Power Pack is shown on the devices list when using VE.Direct USB interface(issue introduced in VictronConnect v1.6)
Fix issue that makes one of the Accept/Cancel buttons sometimes doesn't appear on iOS dialogs
Remove some unused icons, now the install size is sightly smaller on iOS
BlueSolar MPPT:
Send local time to the MPPT when accessing to the streetlight settings and when switching on streetlight function. This makes the streetlight timer works more accurately prior to the synchronisation with the solar activity.
Streetlight: Don't hide sunrise options when “Switch on till sunrise” is selected
Load settings: Add boundaries for high and low voltage levels
Battery settings: Make possible to set equalisation voltage to 0V
Phoenix Inverter:
Peak Power Pack:
*Tested phones
The following phones are tested and working but the update should also fix compatibility with many other Android 6 phones.
[1] There still one issue that randomly makes the connection fail, to make it work again disable/enable bluetooth.
[2] To make it easier we recommend to use another phone to update the dongle firmware but is also possible to use the Samsung phone to do it, then some extra steps are necessary:
Remove the dongle from the paired devices list on the phone bluetooth settings
Close VictronConnect
Disconnect the dongle from the VE.Direct port and connect again while pressing the clear PIN code button to start the dongle in boot loader mode. Blue and red LED's will blink alternatively.
Open VictronConnect and click on the dongle item and start the update process
After entering in boot loader mode you have 30 seconds to connect to the dongle before it goes back to the normal mode. Start the process from step 1 if something fails.
After the dongle is updated you might have to disable and then enable bluetooth again.
v1.6 (Released officially)
2016-06-10
General:
BlueSolar MPPT:
Fix “Use default charge settings” item behaviour when switching the rotary switch while battery settings page is displayed.(Only affects to MPPT with rotary switch and fw v1.17)
Include BlueSolar MPPT firmware v1.17 as mandatory update
v1.5 (Released officially)
v1.4 (Released officially)
2016-04-27
iOS:
New firmwares included on this version:
v1.3 & 1.3.1(iOS) (Released officially)
2016-03-31
New feature: Firmware updates. Firmware updates are included inside VictronConnect, when connecting to a product with a new firmware available the update page will pop up.
Included firmwares on this version:
VE.Direct Bluetooth Smart dongle fw: v2.05 (mandatory*)
BlueSolar MPPT VE.Direct fw: v1.16 (mandatory*)
Phoenix inverter 250 and 375 VA fw: v1.01 (mandatory* and fixes bug in changing low battery settings)
Phones/Tablets
Android
BlueSolar MPPT
Added total yield (system and resettable) to the history page.
Remove white space displayed on history records for MPPT without load output
BatterySettings: Only supported voltages are displayed.
Fix an issue that sends the voltage values automatically when entering to the battery
BMV
Phoenix inverter
Fix wrong product name displayed
iOS: Fix product info page doesn't open
Change power bar color to red when the nominal power is passed
Display a warning box notifying that the “Store settings” button should be pressed to make the changes permanent
Known issues:
* Products with firmware updates marked as mandatory should be updated to continue using VictronConnect
v1.2 (Released officially)
2016-03-03
New platforms: Windows and Mac
OS X versions are now available.
Add action bar to iOS keyboard with a minus (-) button and a “Done” button
Fix “Clear history” button on MPPT and BMV
Use different name in each step during the bluetooth dongle firmware update. (VE.Direct BLE dongle (legacy) and VE.Direct BLE dongle 2 (legacy))
Show Bluetooth/VE.Direct icon depending on the connection type.(Android and MacOS)
BMV
Fix an issue that returns a wrong value by setting to zero the alarm/relay temperature settings
Fix typo in temperature warning message shown on the live data page
Improve max/min values handling on alarms/relay settings pages
BlueSolar MPPT
Show description of the selected load mode algorithm
Fix “Clear history” button: it was partially hidden on the history page
Auto scale yield and consumption unit on the history page from kWh to Wh
Allow negative values for midnight-point shift on streetlight settings
Add load current to the live data page
Fix information box that warns the user that 30 day history is only available since firmware v1.16.
Known issues:
v1.1.5 (Released officially)
2016-02-02
Fix BlueSolar MPPT streetlight settings. In versions v1.1.0 up to and including v1.1.4 it seemed like the streetlight settings were stored correctly, but they were not.
VE.Direct BLE dongle renamed to VE.Direct Bluetooth Smart dongle
Known issues:
v1.1.4 (Released officially)
2016-01-28
Add support for VE.Direct BLE dongles.
Always go back to device main page on disconnection
Fix consumption scale for BlueSolar MPPT history records
Improve dialog style under iOS
Improve appearance on small screens (<4“)
Correct TextField font
Disable settings button while connecting
Fix PWM information box in the streetlight settings page
General small bug fixes and improvements
Add new MPPT SmartSolar products
Improve Blue Smart Charger page on small screens
Update settings values immediately when restoring to defaults
Fix ”-0Ah“ values for the BMV “Consumed Ah”.
