victronconnect:beta
victronconnect:beta [2026-07-08 19:14] – mpalavecinovictronconnect:beta [2026-09-23 16:48] (current) – mpalavecino
Line 11: Line 11:
 (Currently available betas are on top. See further below for official releases.) (Currently available betas are on top. See further below for official releases.)
-==== v6.40beta10 ==== +==== v6.50beta8 ====
-** 2026-07-08 **+ 2026-09-18
 __Download links:__ __Download links:__
-  * iOS: Join TestFlight https://testflight.apple.com/join/cvufYMEh+  *iOS: Join TestFlight https://testflight.apple.com/join/cvufYMEh
   * Android via Google Play Store:   * Android via Google Play Store:
     * It is necessary to follow below steps     * It is necessary to follow below steps
     * [[https://groups.google.com/g/victronconnect-beta-testing|1. Join beta testing group on this link ]]     * [[https://groups.google.com/g/victronconnect-beta-testing|1. Join beta testing group on this link ]]
     * [[https://play.google.com/apps/testing/com.victronenergy.victronconnect|2. Join VictronConnect beta on Google Play Store ]]     * [[https://play.google.com/apps/testing/com.victronenergy.victronconnect|2. Join VictronConnect beta on Google Play Store ]]
-  * [[https://www.dropbox.com/scl/fi/2zsq6h19j783j66flmz5h/VictronConnectInstaller.exe?rlkey=kbjiupfpe693cssa0nu78jxtj&st=cuuebqyd&dl=1|Windows 10 and higher]] +  * [[https://www.dropbox.com/scl/fi/nkbi9h8konldjk6gluqhi/VictronConnectInstaller.exe?rlkey=glgi4drl8ey6ld79iyxsioblx&dl=1|Windows 10 and higher]]
-  * [[https://www.dropbox.com/scl/fi/o4ib5c7fdbkf7bglgtf9z/VictronConnect.dmg?rlkey=3vejf0w7x3pewc1f91kuvnrfg&st=7ouqnwlh&dl=1|macOS 11 (Big Sur) and higher]] +  * [[https://www.dropbox.com/scl/fi/w3ojxp9kel7ldhr7jkac5/VictronConnect.dmg?rlkey=48ejz6uwh1n6x2qu3xb2t071p&dl=1|macOS 11 (Big Sur) and higher]]
-  * [[https://www.dropbox.com/scl/fi/ztpzjhq9h2qs7b3f556zr/VictronConnect-x86_64.AppImage?rlkey=cggh9n7r9ftf2tgahk27bwvq7&st=w3wuiji1&dl=1|Linux AppImage]]+  * [[https://www.dropbox.com/scl/fi/sgohov71p3fczcakcqwnh/VictronConnect-x86_64.AppImage?rlkey=2mqtwb4sez2huspcr1e0csgu6&dl=1|Linux AppImage]]
 Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue.
Line 29: Line 29:
 __Changes__ __Changes__
-General +iOS:
-  * Improved dark mode +  * Add Apple CarPlay support. (Bluetooth)
-  * Other internal improvements+
-Superpack-NG +Android
-  * Improved descriptions for "Heater mode" settings+  * Improve Bluetooth device scanning
 +  * Notify when Bluetooth scanning cannot be initiated
-VeBus Inverters +GX Remote Console
-  * Added support for Multi units with a Q processor +* Significantly improve loading time
-  * Hidden "System frequency" when unavailable+
-VenusOS +EVCS
-  * Added support for configuring BLE sensors on Venus devices (requires new firmware not released yet)+  * Add new errors and warnings
 +  * Add local firmware updates via Ethernet (EVCS V2 only — requires a future firmware release)
 +  * Add Instant Readout support for remote connections
-Energy Meter +MultiHS
-  * Fixed handling of invalid energy values+  * Fix Grid Feed-In settings visibility
-==== v6.40beta9 ====
-** 2026-07-03 **
-__Changes__
-General + ==== v6.50beta7 ====
-  * Added support for .vcsf settings files created with older VictronConnect versions (minimum supported version: v6.30) + 2026-09-14
-Energy Meter +__Changes__
-  * Fixed energy value scaling+
 +EVCS
 +  * Add firmware v2.08
-==== v6.40beta8 ==== +OrionXS
-** 2026-06-30 **+  * Further improvements to the Emergency Charge feature (requires a future firmware release)
 +==== v6.50beta6 ====
 +** 2026-09-11 **
 General General
-  * Improved dark mode +  * Enable VRM data tabs on locally connected GX devices
-  * Improved online firmware library synchronization +  * List GlobalLink installations alongside GX remote installations (VRM tab)
-  * Fixed "Saved product passwords" section on General settings +  * Make it possible to create a VRM installation directly from VictronConnect
-  * Fixed temperature values in trend graphs when using Fahrenheit for certain devices+  * Add VRM account creation in the Remote tab and Settings
 +  * Add VRM login directly within VictronConnect
 +  * Speed up Remote Console loading after the first load
 +  * Various UI wording improvements as part of the continued VRM integration in VictronConnect
-SolarSense +OrionXS
-  * Added history data export to CSV +  * Further improvements to the Emergency Charge feature (requires a future firmware release)
-  * Added "Device not configured" alarm +
-  * Added warning dialog when the device is not configured+
-Android & iOS +MultiHS
-  * Moved input dialogs up when covered by the keyboard +  * Hide certain not yet supported settings
-  * Moved the close button down for embedded videos+
-Windows
-  * Fixed help links not opening correctly
-EVCS +==== v6.50beta5 ====
-  * Added EV Data support (requires new firmware not released yet)+** 2026-09-3 **
-  * Added save settings support for model VM-3P5A+
 +General
 +  * Improved overall performance
-==== v6.40beta7 ==== +OrionXS
-** 2026-06-18 **+  * Improved the Emergency Charge feature (requires a future firmware release)
 +==== v6.50beta4 ====
 +** 2026-08-31 **
-VE.Direct Inverter +General
-  * Fixed setting files and demos+  * Improved overall performance
 +  * Fixed a crash that could occur when loading saved settings files for certain products
 +  * Fixed incorrect timestamps when exporting CSV trend data in regions with negative UTC offsets
 Windows Windows
-  * Improve BLE connectivity+  * Fixed an issue where a VictronConnect process could remain running in the background under certain circumstances
 +EVCS
 +  * Added support for upcoming features that require a future firmware release
 Lynx Smart BMS Lynx Smart BMS
-  * Enable individual battery details on remote connections+  * Added more detailed information when charging or discharging is not allowed (Requires a future firmware release).
 +  * Added support for new alarms introduced in a future firmware release
 +MultiRS
 +  * Add firmware v1.32 for Multi RS Smart 48/6000
-==== v6.40beta6 ==== +
-** 2026-06-08 **+==== v6.50beta3 ====
 +** 2026-08-19 **
-Windows: +General
-  * Fixed issue where the app could freeze during PIN code entry+  * Added trends data export to CSV on products that support stored trends
 +  * Internal improvements
-Android:  +Android
-  * Added support for remote console in portrait mode +  * Improve battery usage for home screen widgets and alarm notifications.
- +  * Fix Android reporting VictronConnect as crashing in the background on some phones.
-MPPT Solar Chargers +
-  * Added PV short relay protection information to "Why is the charger off?"+
 +BMV/SmartShunt
 +  * Fix manual SOC setting when the reported SOC is undefined
-==== v6.40beta5 ==== +==== v6.50beta2 ====
-** 2026-06-04 **+** 2026-08-05 **
 General General
-  * Improved dark mode +  * Internal improvements
-  * Improved support for remote console in portrait mode +
-  * Better handle remote console expanded view in Windows and macOS +
-  * Fix issue with Venus security profile passwords not accepting special characters +
-  * Various fixes and improvements+
-MultiRS | InverterRS +Android
-  * Add "Ground relay" setting for InverterRS devices +  * Fixed a Bluetooth issue that could prevent the device list from being displayed under certain conditions
-  * Add "No restart after short" setting (VDE 2510-2 safety) +
-    * Requires a new firmware version not yet released +EVCS
-  * Add battery "Shared sensing" settings +  * Added password-less pairing with GX devices (requires Venus OS v3.80)
-    * Requires a new firmware version not yet released+  * Improved GX Communication settings
 MultiHS MultiHS
-  * Enable Relay settings+  * Added support for Instant Readout
-==== v6.40beta4 ==== +==== v6.50beta1 ====
-** 2026-05-29 **+** 2026-07-27 **
 General General
-  * Improved dark mode +  * Improved trend data time accuracy
-  * Improved content loading on GX device page +  * Added support for viewing stored trend data via MQTT from backup files
-  * Improved bottom safe area/insets handling on device pages +  * Reduced trend loading time after the initial connection
-  * Updated product icons for Inverter RS and Multi RS+
-SolarSense +Android
-  * Fixed incorrect starting date in history when limited data is available+  * Fixed a crash on devices with a 64-bit CPU running a 32-bit OS
-EnergyMeter VM-3P5A +Android & iOS
-  * Fixed CT current setting+  * Improved device list responsiveness
 +OrionXS
 +  * Added support for the Emergency Charge feature (requires a future firmware update that is not yet available)
-==== v6.40beta3 ==== +MultiHS
-** 2026-05-22 **+  * Added support for PV Tracker enabling settings
-__Changes__
-General +==== v6.43 (Released officially) ====
-  * Improve VRM page loading +** 2026-09-23 **
-  * Improve scaling for small-value trends in Advanced view +
-  * Fix demos not opening after searching by product name +
-  * Fix incorrectly drawn trend gaps when loading from files +
-  * Fix minor color issues in dark mode+
-==== v6.40beta2 ==== +__Download links:__
-** 2026-05-21 **+
 +  * iOS: [[https://itunes.apple.com/app/victronconnect/id943840744?mt=8|App Store]]
 +  * [[https://play.google.com/store/apps/details?id=com.victronenergy.victronconnect|Android]]
 +  * [[https://updates.victronenergy.com/feeds/VictronConnect/windows/w10/VictronConnectInstaller.exe|Windows 10 and higher]]
 +  * macOS [[https://itunes.apple.com/app/victronconnect/id1084677271?mt=12|11 (macOS Big Sur) and higher|App Store]]
 +  * [[https://updates.victronenergy.com/feeds/VictronConnect/linux/VictronConnect-x86_64_v6.42.AppImage|Linux AppImage]]
 +Firmware updates: For more details, check release notes on Victron Professional.
-General +OrionXS
-  * Add dark mode support +  - Added firmware v1.15
-  * Add support for new Smart Inverters +  - Added the new "Emergency Charge" feature
-  * Add search by product name in the Demo products page +
-  * Allow settings files from devices with newer firmware to be opened as demos +
-  * Improve page refresh in the VRM WebView +
-  * Fix crash when disconnecting from devices under certain conditions +
-  * Update to Qt 6.10 to meet app store requirements+
-Windows +
-  * Add Bluetooth connectivity support +==== v6.42 (Released officially) ====
-  * Add setting to enable automatic updates+** 2026-09-09 **
 +__Changes__
 +Lynx Smart BMS
 +- Added more detailed information when charging or discharging is not allowed (Requires a future firmware release).
 +- Added support for new alarms introduced in a future firmware release
 Android Android
-  * Improve handling of system bars to prevent content from being drawn underneath +- Fixed an issue where the device list could remain empty under certain conditions on some Android devices and versions.
-  * Improved back button/swipe behaviour+
-MultiHS +iOS
-  * Add "Solar charger enabled" setting +- Improved battery usage on recent versions of iOS
-  * Add "Energy meter miswired" alarm +
-  * Add "Solar safety switch open" off reason +
-  * Hide Battery Ripple Voltage value +
-  * Fix value shown after changing "General -> Mode" +
-  * Fix SoC visibility+
-MultiRS +
-  * Enable "Single phase" system selection for release versions+==== v6.41 (Released officially) ====
 +** 2026-08-25 **
 +__Changes__
 +General
 +  * Improve batch programming robustness
 +Android
 EVCS EVCS
-  * Support password-less pairing with GX + * Various improvements
-    * Requires a new EVCS firmware version (not yet released) +
-    * Requires a new Venus OS version on GX (not yet released)+BMV/SmartShunt
 +Lynx SmartBMS
 +  * Add support for new alarms to be introduced in a future firmware release
 +MPPT Solar Chargers:
 +  * Add firmware v1.75 for some models
-EnergyMeter
-  * Update gauge display to support negative values
-  * Improve energy data accuracy by properly scaling values
-==== v6.40beta1 ==== +==== v6.40 (Released officially) ====
-** 2026-04-22 **+** 2026-07-21 **
 General General
-  * Add initial support for new products +  * Added dark mode support and improved appearance throughout the app
-  * Improve trends robustness+  * Added support for new products and expanded device compatibility
 +  * Improved VRM page loading and synchronization
 +  * Improved trend graphs accuracy, scaling, and robustness
 +  * Improved remote console experience, including portrait mode support
 +  * Updated the built-in firmware library with the latest firmware files
 +  * Various fixes and internal improvements
-Sun Inverters +Windows
-  * Fix "Output voltage" setting+  * Added Bluetooth connectivity support
 +  * Added automatic update settings
 +Android & iOS
 +  * Improved handling of on-screen keyboards and system bars
 +  * Improved navigation and remote console usability
 +SolarSense
 +  * Added history export to CSV
-==== v6.34 (Released officially) ==== +Energy Meter
-** 2026-06-09 **+  * Improved energy data accuracy and value scaling
 +  * Added support for additional Energy Meter models and settings
-__Download links:__+VE.Bus Inverters
 +  * Added support for Multi units with a Q processor
-  * iOS: [[https://itunes.apple.com/app/victronconnect/id943840744?mt=8|App Store]] +MultiRS / InverterRS
-  * [[https://play.google.com/store/apps/details?id=com.victronenergy.victronconnect|Android]] +  * Added new settings
-  * [[http://updates.victronenergy.com/feeds/VictronConnect/windows/w10/VictronConnectInstaller.exe|Windows 10 and higher]] +
-  * macOS [[https://itunes.apple.com/app/victronconnect/id1084677271?mt=12|11 (macOS Big Sur) and higher|App Store]] +
-  * [[https://www.victronenergy.com/upload/software/VictronConnect-x86_64-v6.34.AppImage|Linux AppImage]]+
-Firmware updates: For more details, check release notes on Victron Professional.+MultiHS
 +==== v6.34 (Released officially) ====
 +** 2026-06-09 **
victronconnect/beta.1783530861.txt.gz · Last modified: by mpalavecino
