victronconnect:beta
victronconnect:beta [2026-03-23 11:58] – [v6.30.3 (Released officially)] jperezvictronconnect:beta [2026-06-18 20:03] (current) mpalavecino
Line 10: Line 10:
 (Currently available betas are on top. See further below for official releases.) (Currently available betas are on top. See further below for official releases.)
 +==== v6.40beta7 ====
 +** 2026-06-18 **
 +__Download links:__
 +  * iOS: Join TestFlight https://testflight.apple.com/join/cvufYMEh
 +  * Android via Google Play Store:
 +    * It is necessary to follow below steps
 +    * [[https://groups.google.com/g/victronconnect-beta-testing|1. Join beta testing group on this link ]]
 +    * [[https://play.google.com/apps/testing/com.victronenergy.victronconnect|2. Join VictronConnect beta on Google Play Store ]]
 +  * [[https://www.dropbox.com/scl/fi/qhha7ei3b0q635q5p99cs/VictronConnectInstaller.exe?rlkey=4zo6gaajhtgcrsl1n1dtya7gp&st=m3mifvpz&dl=1|Windows 10 and higher]]
 +  * [[https://www.dropbox.com/scl/fi/xkslu5l1mip1fk668of1l/VictronConnect.dmg?rlkey=keh669l1ziy0m5zd42wrgsjl6&st=9wkcg3mj&dl=1|macOS 11 (Big Sur) and higher]]
 +  * [[https://www.dropbox.com/scl/fi/eg1q9kars4dy4yi0r8i7c/VictronConnect-x86_64.AppImage?rlkey=nnhodq6ijziu1v8r72gybseag&st=7relgwnq&dl=1|Linux AppImage]]
 +Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue.
 +__Changes__
 +VE.Direct Inverter
 +  * Fixed setting files and demos
 +Windows
 +  * Improve BLE connectivity
 +Lynx Smart BMS
 +  * Enable individual battery details on remote connections
 +==== v6.40beta6 ====
 +** 2026-06-08 **
 +__Changes__
 +Windows:
 +  * Fixed issue where the app could freeze during PIN code entry
 +Android:
 +  * Added support for remote console in portrait mode
 +MPPT Solar Chargers
 +  * Added PV short relay protection information to "Why is the charger off?"
 +==== v6.40beta5 ====
 +** 2026-06-04 **
 +__Changes__
 +General
 +  * Improved dark mode
 +  * Improve support for remote console in portrait mode
 +  * Better handle remote console expanded view in Windows and macOS
 +  * Fix issue with Venus security profile passwords not accepting special characters
 +  * Various fixes and improvements
 +MultiRS | InverterRS
 +  * Add "Ground relay" setting for InverterRS devices
 +  * Add "No restart after short" setting (VDE 2510-2 safety)
 +    * Requires a new firmware version not yet released
 +  * Add battery "Shared sensing" settings
 +MultiHS
 +  * Enable Relay settings
 +==== v6.40beta4 ====
 +** 2026-05-29 **
 +__Changes__
 +General
 +  * Improved content loading on GX device page
 +  * Improved bottom safe area/insets handling on device pages
 +  * Updated product icons for Inverter RS and Multi RS
 +SolarSense
 +  * Fixed incorrect starting date in history when limited data is available
 +EnergyMeter VM-3P5A
 +  * Fixed CT current setting
 +==== v6.40beta3 ====
 +** 2026-05-22 **
 +__Changes__
 +General
 +  * Improve VRM page loading
 +  * Improve scaling for small-value trends in Advanced view
 +  * Fix demos not opening after searching by product name
 +  * Fix incorrectly drawn trend gaps when loading from files
 +  * Fix minor color issues in dark mode
 +==== v6.40beta2 ====
 +** 2026-05-21 **
 +__Changes__
 +General
 +  * Add dark mode support
 +  * Add support for new Smart Inverters
 +  * Add search by product name in the Demo products page
 +  * Allow settings files from devices with newer firmware to be opened as demos
 +  * Improve page refresh in the VRM WebView
 +  * Fix crash when disconnecting from devices under certain conditions
 +  * Update to Qt 6.10 to meet app store requirements
 +Windows
 +  * Add Bluetooth connectivity support
 +  * Add setting to enable automatic updates
 +Android
 +  * Improve handling of system bars to prevent content from being drawn underneath
 +  * Improved back button/swipe behaviour
 +MultiHS
 +  * Add "Solar charger enabled" setting
 +  * Add "Energy meter miswired" alarm
 +  * Add "Solar safety switch open" off reason
 +  * Hide Battery Ripple Voltage value
 +  * Fix value shown after changing "General -> Mode"
 +  * Fix SoC visibility
 +MultiRS
 +  * Enable "Single phase" system selection for release versions
 +EVCS
 +  * Support password-less pairing with GX
 +    * Requires a new EVCS firmware version (not yet released)
 +    * Requires a new Venus OS version on GX (not yet released)
 +EnergyMeter
 +  * Update gauge display to support negative values
 +  * Improve energy data accuracy by properly scaling values
 +==== v6.40beta1 ====
 +** 2026-04-22 **
 +__Changes__
 +General
 +  * Add initial support for new products
 +  * Improve trends robustness
 +Sun Inverters
 +  * Fix "Output voltage" setting
 +==== v6.34 (Released officially) ====
 +** 2026-06-09 **
 +  * iOS: [[https://itunes.apple.com/app/victronconnect/id943840744?mt=8|App Store]]
 +  * [[https://play.google.com/store/apps/details?id=com.victronenergy.victronconnect|Android]]
 +  * [[http://updates.victronenergy.com/feeds/VictronConnect/windows/w10/VictronConnectInstaller.exe|Windows 10 and higher]]
 +  * macOS [[https://itunes.apple.com/app/victronconnect/id1084677271?mt=12|11 (macOS Big Sur) and higher|App Store]]
 +  * [[https://www.victronenergy.com/upload/software/VictronConnect-x86_64-v6.34.AppImage|Linux AppImage]]
 +Firmware updates: For more details, check release notes on Victron Professional.
 +__Changes__
 +Solar Chargers:
 +  * Add PV short relay protection information to "Why is the charger off?"
 +==== v6.33 (Released officially) ====
 +** 2026-05-27 **
 +__Changes__
 +  * Make it possible to inspect a settings file created with a different product firmware version.
 +GX:
 +  * Improve VRM content loading
 +Sun Inverter:
 +  * Fix output voltage setting
 +==== v6.32 (Released officially) ====
 +  * Fix trends can freeze at "fetching" state in certain situations
 +  * Android auto: Improve stabilty of the products list
 +  * Android widgets: Fix accuracy of the displayed last contact time
 +VE.Bus inverter/charger:
 +  * Fix firmware update can fail reporting error 29
 ==== v6.31 (Released officially) ==== ==== v6.31 (Released officially) ====
victronconnect/beta.1774263503.txt.gz · Last modified: by jperez
