victronconnect:beta
| victronconnect:beta [2026-02-27 09:28] – [v6.30 (Released officially)] jperez | victronconnect:beta [2026-06-18 20:03] (current) – mpalavecino | ||
| Line 10: | Line 10: | ||
| (Currently available betas are on top. See further below for official releases.) | (Currently available betas are on top. See further below for official releases.) | ||
| + | ==== v6.40beta7 ==== | ||
| + | ** 2026-06-18 ** | ||
| + | __Download links:__ | ||
| + | * iOS: Join TestFlight https:// | ||
| + | * Android via Google Play Store: | ||
| + | * It is necessary to follow below steps | ||
| + | * [[https:// | ||
| + | Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. | ||
| + | __Changes__ | ||
| + | VE.Direct Inverter | ||
| + | * Fixed setting files and demos | ||
| + | Windows | ||
| + | * Improve BLE connectivity | ||
| + | Lynx Smart BMS | ||
| + | * Enable individual battery details on remote connections | ||
| + | ==== v6.40beta6 ==== | ||
| + | ** 2026-06-08 ** | ||
| + | Windows: | ||
| + | * Fixed issue where the app could freeze during PIN code entry | ||
| + | Android: | ||
| + | * Added support for remote console in portrait mode | ||
| + | MPPT Solar Chargers | ||
| + | * Added PV short relay protection information to "Why is the charger off?" | ||
| + | ==== v6.40beta5 ==== | ||
| + | ** 2026-06-04 ** | ||
| + | General | ||
| + | * Improved dark mode | ||
| + | * Improve support for remote console in portrait mode | ||
| + | * Better handle remote console expanded view in Windows and macOS | ||
| + | * Fix issue with Venus security profile passwords not accepting special characters | ||
| + | * Various fixes and improvements | ||
| + | MultiRS | InverterRS | ||
| + | * Add " | ||
| + | * Add "No restart after short" setting (VDE 2510-2 safety) | ||
| + | * Requires a new firmware version not yet released | ||
| + | * Add battery " | ||
| + | MultiHS | ||
| + | * Enable Relay settings | ||
| + | ==== v6.40beta4 ==== | ||
| + | ** 2026-05-29 ** | ||
| + | General | ||
| + | * Improved content loading on GX device page | ||
| + | * Improved bottom safe area/insets handling on device pages | ||
| + | * Updated product icons for Inverter RS and Multi RS | ||
| + | SolarSense | ||
| + | * Fixed incorrect starting date in history when limited data is available | ||
| + | EnergyMeter VM-3P5A | ||
| + | * Fixed CT current setting | ||
| + | ==== v6.40beta3 ==== | ||
| + | ** 2026-05-22 ** | ||
| + | General | ||
| + | * Improve VRM page loading | ||
| + | * Improve scaling for small-value trends in Advanced view | ||
| + | * Fix demos not opening after searching by product name | ||
| + | * Fix incorrectly drawn trend gaps when loading from files | ||
| + | * Fix minor color issues in dark mode | ||
| + | ==== v6.40beta2 ==== | ||
| + | ** 2026-05-21 ** | ||
| + | General | ||
| + | * Add dark mode support | ||
| + | * Add support for new Smart Inverters | ||
| + | * Add search by product name in the Demo products page | ||
| + | * Allow settings files from devices with newer firmware to be opened as demos | ||
| + | * Improve page refresh in the VRM WebView | ||
| + | * Fix crash when disconnecting from devices under certain conditions | ||
| + | * Update to Qt 6.10 to meet app store requirements | ||
| + | Windows | ||
| + | * Add Bluetooth connectivity support | ||
| + | * Add setting to enable automatic updates | ||
| + | Android | ||
| + | * Improve handling of system bars to prevent content from being drawn underneath | ||
| + | * Improved back button/ | ||
| + | MultiHS | ||
| + | * Add "Solar charger enabled" | ||
| + | * Add " | ||
| + | * Add "Solar safety switch open" off reason | ||
| + | * Hide Battery Ripple Voltage value | ||
| + | * Fix value shown after changing " | ||
| + | * Fix SoC visibility | ||
| + | MultiRS | ||
| + | * Enable " | ||
| + | EVCS | ||
| + | * Support password-less pairing with GX | ||
| + | * Requires a new EVCS firmware version (not yet released) | ||
| + | * Requires a new Venus OS version on GX (not yet released) | ||
| + | EnergyMeter | ||
| + | * Update gauge display to support negative values | ||
| + | * Improve energy data accuracy by properly scaling values | ||
| + | ==== v6.40beta1 ==== | ||
| + | ** 2026-04-22 ** | ||
| + | General | ||
| + | * Add initial support for new products | ||
| + | * Improve trends robustness | ||
| + | Sun Inverters | ||
| + | * Fix " | ||
| + | ==== v6.34 (Released officially) ==== | ||
| + | ** 2026-06-09 ** | ||
| + | * iOS: [[https:// | ||
| + | * [[http:// | ||
| + | * macOS [[https:// | ||
| + | Firmware updates: For more details, check release notes on Victron Professional. | ||
| + | Solar Chargers: | ||
| + | * Add PV short relay protection information to "Why is the charger off?" | ||
| + | ==== v6.33 (Released officially) ==== | ||
| + | ** 2026-05-27 ** | ||
| + | * Make it possible to inspect a settings file created with a different product firmware version. | ||
| + | GX: | ||
| + | * Improve VRM content loading | ||
| + | Sun Inverter: | ||
| + | * Fix output voltage setting | ||
| + | ==== v6.32 (Released officially) ==== | ||
| + | * Fix trends can freeze at " | ||
| + | * Android auto: Improve stabilty of the products list | ||
| + | * Android widgets: Fix accuracy of the displayed last contact time | ||
| + | VE.Bus inverter/ | ||
| + | * Fix firmware update can fail reporting error 29 | ||
| + | ==== v6.31 (Released officially) ==== | ||
| + | ** 2026-03-23 ** | ||
| + | * Fix trends showing incorrect dates in certain conditions | ||
| + | * Fix live trends when connected via a VE.Direct Smart Dongle | ||
| + | * Improvements to firmware library synchronization | ||
| + | * Fix " | ||
| + | BMV-712: | ||
| + | * Fix some display settings not being exported to settings files | ||
| + | MultiRS: | ||
| + | * Export discharge current limit to settings files | ||
| + | * Add error 77: Settings sync disabled | ||
| + | SolarSense: | ||
| + | * Fix incorrect kWh scale on the history page | ||
| + | ==== v6.30.3 (Released officially) ==== | ||
| + | ** 2026-02-27 ** | ||
| + | This version is only available for Windows, macOS and Android. | ||
| + | Windows | ||
| + | * Fix VE.Bus firmware list do not show available update files. | ||
| ==== v6.30.2 (Released officially) ==== | ==== v6.30.2 (Released officially) ==== | ||
victronconnect/beta.1772180932.txt.gz · Last modified: by jperez
