victronconnect:beta
victronconnect:beta [2026-01-31 20:26] mpalavecinovictronconnect:beta [2026-06-18 20:03] (current) mpalavecino
Line 12: Line 12:
-==== v6.30beta7 ==== +==== v6.40beta7 ====
-** 2026-01-31 **+** 2026-06-18 **
 __Download links:__ __Download links:__
Line 22: Line 22:
     * [[https://groups.google.com/g/victronconnect-beta-testing|1. Join beta testing group on this link ]]     * [[https://groups.google.com/g/victronconnect-beta-testing|1. Join beta testing group on this link ]]
     * [[https://play.google.com/apps/testing/com.victronenergy.victronconnect|2. Join VictronConnect beta on Google Play Store ]]     * [[https://play.google.com/apps/testing/com.victronenergy.victronconnect|2. Join VictronConnect beta on Google Play Store ]]
-  * [[https://www.dropbox.com/scl/fi/8g5mza1cln6qb8qf21du2/VictronConnectInstaller.exe?rlkey=8cz13wjyxa14vuwg5a9wm9itf&st=nnez995z&dl=1|Windows 10 and higher]] +  * [[https://www.dropbox.com/scl/fi/qhha7ei3b0q635q5p99cs/VictronConnectInstaller.exe?rlkey=4zo6gaajhtgcrsl1n1dtya7gp&st=m3mifvpz&dl=1|Windows 10 and higher]]
-  * [[https://www.dropbox.com/scl/fi/stzk7phkgudd81sh9hbxp/VictronConnect.dmg?rlkey=e8t0v4ww1g53u12oh0u6n4n21&st=newi36yw&dl=1|macOS 11 (Big Sur) and higher]] +  * [[https://www.dropbox.com/scl/fi/xkslu5l1mip1fk668of1l/VictronConnect.dmg?rlkey=keh669l1ziy0m5zd42wrgsjl6&st=9wkcg3mj&dl=1|macOS 11 (Big Sur) and higher]]
-  * [[https://www.dropbox.com/scl/fi/q8p1sdzd1xm34ohp0naus/VictronConnect-x86_64.AppImage?rlkey=ytj5wh9wam5no6g5ar9haa3aa&st=2rkohp02&dl=1|Linux AppImage]]+  * [[https://www.dropbox.com/scl/fi/eg1q9kars4dy4yi0r8i7c/VictronConnect-x86_64.AppImage?rlkey=nnhodq6ijziu1v8r72gybseag&st=7relgwnq&dl=1|Linux AppImage]]
 Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue.
Line 30: Line 30:
 __Changes__ __Changes__
-Batch Programming +VE.Direct Inverter
-  * Fix iOS Vision OCR crash caused by invalid image lifetime+  * Fixed setting files and demos
-BMS-NG +Windows
-  * Add BLE-Networking support+  * Improve BLE connectivity
-RS products: +Lynx Smart BMS
-  * Add off reason 18 (by aux input) notification +  * Enable individual battery details on remote connections
-  * Add polarity selection for Aux Input settings (requires firmware over 1.27)+
-MultiRS / InverterRS
-  * Add Max discharge current limit (requires firmware over 1.27)
-Add Inverter RS firmware v1.27 +==== v6.40beta6 ====
-  Add option to select the polarity of the AUX inputs+** 2026-06-08 **
-Add MPPT RS firmware v1.27 +__Changes__
-  * Add option to select the polarity of the AUX inputs +
-  * Restore communication between the MPPT RS and the Multi RS/Inverter RS (broken in firmware v1.22)+
-Add Multi RS firmware v1.28 +Windows:
-  * Add option to select the polarity of the AUX inputs +  * Fixed issue where the app could freeze during PIN code entry
-  * Add feed-in control for DC coupled MPPT chargers for the GX +
-  * Fix issue in power response to voltage changes for certain grid codes, this was broken in v1.26 while removing the 5kW feed-in restriction for external AC PV inverters +
-  * Fix issue preventing some units to connect to the AC input +
-  * When combined with an Energy meter: Fix AC grid set-point in operation mode 'self consumption from battery only for critical loads'+
-More info about RS firmware 1.27 and 1.28 in the firmware changelog.+Android:
 +  * Added support for remote console in portrait mode
 +MPPT Solar Chargers
 +  * Added PV short relay protection information to "Why is the charger off?"
 +==== v6.40beta5 ====
 +** 2026-06-04 **
 +__Changes__
 General General
-  * Fix Role setting value displayed for Energy Meter over GX/Mqtt connections +  * Improved dark mode
-  * Fix firmware update available not being reported under certain conditions +  * Improve support for remote console in portrait mode
-  * Add "From/To battery" & "SoC min/max" daily values on the Solar Chargers trends+  * Better handle remote console expanded view in Windows and macOS
 +  * Fix issue with Venus security profile passwords not accepting special characters
 +  * Various fixes and improvements
-==== v6.30beta6 ==== +MultiRS | InverterRS
-** 2026-01-22 **+  * Add "Ground relay" setting for InverterRS devices
 +  * Add "No restart after short" setting (VDE 2510-2 safety)
 +    * Requires a new firmware version not yet released
 +  * Add battery "Shared sensing" settings
 +MultiHS
 +  * Enable Relay settings
 +==== v6.40beta4 ====
 +** 2026-05-29 **
 General General
-  * Fix crashes that could be reported when closing the app +  * Improved dark mode
-  * Improve handling of thousand separators in input fields +  * Improved content loading on GX device page
-  * Fix settings dialogs that could show extra spacing under certain conditions +  * Improved bottom safe area/insets handling on device pages
-  * Fix an issue where some Instant Readout values were not correctly scaled +  * Updated product icons for Inverter RS and Multi RS
-  * **Linux:** Fix app failing to start (introduced in v6.30 beta 5) +
-  * **Linux:** Improve handling of deep links +
-  * **Android:** Improve permission request handling when multiple VE.Direct / VE.Bus USB interfaces are connected+
-Batch Programming (New feature) +SolarSense
-  * Allow firmware updates and settings programming for multiple units of the same model in one operation +  * Fixed incorrect starting date in history when limited data is available
-  * Supported connection types per platform: +
-    * **VE.Direct:** Windows, macOS, Android +
-    * **Bluetooth:** Android, iOS+
-VRM Integration (New feature) +EnergyMeter VM-3P5A
-  * Show the VRM dashboard and overview graphs when connecting to an installation +  * Fixed CT current setting
-  * Open the Remote Console inside the app instead of in an external browser+
-Inverter RS / Multi RS
-  * Add proper minimum and maximum inverter limits in system settings
-  * Add support for new models
-Lynx Smart BMS +==== v6.40beta3 ====
-  Add firmware v1.15+** 2026-05-22 **
-MPPT +__Changes__
-  * Add firmware v1.73 for five models+
 +General
 +  * Improve VRM page loading
 +  * Improve scaling for small-value trends in Advanced view
 +  * Fix demos not opening after searching by product name
 +  * Fix incorrectly drawn trend gaps when loading from files
 +  * Fix minor color issues in dark mode
-==== v6.30beta5 ==== +==== v6.40beta2 ====
-** 2026-01-06 **+** 2026-05-21 **
 General General
-  * Save stored trends on settings file +  * Add dark mode support
-  * Restore stored trends when loading a setting file as demo +  * Add support for new Smart Inverters
-  * Performance improvement when starting the app +  * Add search by product name in the Demo products page
-  * Precision improvements in calculated trends +  * Allow settings files from devices with newer firmware to be opened as demos
-  * Other minor improvements+  * Improve page refresh in the VRM WebView
 +  * Fix crash when disconnecting from devices under certain conditions
 +  * Update to Qt 6.10 to meet app store requirements
-InverterRS/MultiRS +Windows
-  * Show the "Aux input" settings for all the models +  * Add Bluetooth connectivity support
-  * Fix "Aux input" in demos+  * Add setting to enable automatic updates
-MPPT RS +Android
-  * Add the "Aux input" settings+  * Improve handling of system bars to prevent content from being drawn underneath
 +  * Improved back button/swipe behaviour
-Orion XS +MultiHS
-  * Orion XS 1400 and 12V/12V-50A: Add firmware v1.13+  * Add "Solar charger enabled" setting
 +  * Add "Energy meter miswired" alarm
 +  * Add "Solar safety switch open" off reason
 +  * Hide Battery Ripple Voltage value
 +  * Fix value shown after changing "General -> Mode"
 +  * Fix SoC visibility
 +MultiRS
 +  * Enable "Single phase" system selection for release versions
 +EVCS
 +  * Support password-less pairing with GX
 +    * Requires a new EVCS firmware version (not yet released)
 +    * Requires a new Venus OS version on GX (not yet released)
 +EnergyMeter
 +  * Update gauge display to support negative values
 +  * Improve energy data accuracy by properly scaling values
-==== v6.30beta4 ==== +==== v6.40beta1 ====
-** 2025-12-04 **+** 2026-04-22 **
 General General
-  * Add support for upcoming new products +  * Add initial support for new products
-  * Removes certain Min & Max values from Trends pages +  * Improve trends robustness
-  * Trends: minor improvements when data can't be fetched +
-  * Other minor improvements +
-  * New features for Android+
 +Sun Inverters
 +  * Fix "Output voltage" setting
-Android new features:
-  *  Android Auto App:
-    * See Instant Readout from your Victron products right on your vehicle Android Auto display.
-  * Alarm Notifications via Bluetooth:
-    * When any of your nearby (in-range) products triggers an alarm, you’ll receive a notification on your phone.
-  * Home Screen Widgets:
-    * Add your favorite products to your phone’s home screen for quick access to key information at a glance.
-SolarSense:
-  * Fix SolarSense firmware updating under certain circunstances
 +==== v6.34 (Released officially) ====
 +** 2026-06-09 **
 +__Download links:__
-==== v6.30beta3 ===+  * iOS: [[https://itunes.apple.com/app/victronconnect/id943840744?mt=8|App Store]]
-** 2025-11-20 **+  * [[https://play.google.com/store/apps/details?id=com.victronenergy.victronconnect|Android]]
 +  [[http://updates.victronenergy.com/feeds/VictronConnect/windows/w10/VictronConnectInstaller.exe|Windows 10 and higher]]
 +  macOS [[https://itunes.apple.com/app/victronconnect/id1084677271?mt=12|11 (macOS Big Sur) and higher|App Store]]
 +  [[https://www.victronenergy.com/upload/software/VictronConnect-x86_64-v6.34.AppImage|Linux AppImage]]
-Notes: +Firmware updatesFor more details, check release notes on Victron Professional.
-  * Android: If you can't open the downloaded file from the downloads list try using a file browser.+
-Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue.+__Changes__
 +Solar Chargers:
 +  * Add PV short relay protection information to "Why is the charger off?"
 +==== v6.33 (Released officially) ====
 +** 2026-05-27 **
-Online Firmware Library +  Make it possible to inspect a settings file created with a different product firmware version.
-  Show firmware update release notes+
-Stored trends +GX:
-  * New view for the stored trends data, with the data presented in hours per day +  * Improve VRM content loading
-  * Several performance improvements+
-VRM +Sun Inverter:
-  * Make use of the system keychain for VRM login+  * Fix output voltage setting
-General
-  * SolarSense: Hide min and max battery voltages from Historical
-  * OrionXS: add support for new Model
-  * InverterRS | MultiRS: Improves some System settings descriptions
-  * EVCS: Improve the "Charging current" control usability
-Fixes +==== v6.32 (Released officially) ====
-  * Fix VRM login on iOS +
-  * Fix issues with the remote products discovery +
-  * Fix BMW-600 not being shown through MQTT Connections +
-  * Fix EnergyMeter instant readout power values when "Split phase" +
-  * Android: Fix back button closes the app instead of navigating to previous page on some Android versions+
 +  * Fix trends can freeze at "fetching" state in certain situations
 +  * Android auto: Improve stabilty of the products list
 +  * Android widgets: Fix accuracy of the displayed last contact time
 +VE.Bus inverter/charger:
 +  * Fix firmware update can fail reporting error 29
-==== v6.30beta2 ==== +==== v6.31 (Released officially) ====
-** 2025-10-27 **+** 2026-03-23 **
 +  * [[http://updates.victronenergy.com/feeds/VictronConnect/windows/w10/VictronConnectInstaller.exe|Windows 10 and higher]]
 +  * macOS [[https://itunes.apple.com/app/victronconnect/id1084677271?mt=12|11 (macOS Big Sur) and higher|App Store]]
 +  * [[https://www.victronenergy.com/upload/software/VictronConnect-x86_64-v6.31.AppImage|Linux AppImage]]
 +Firmware updates: For more details, check release notes on Victron Professional.
 +  * Fix trends showing incorrect dates in certain conditions
 +  * Fix live trends when connected via a VE.Direct Smart Dongle
 +  * Improvements to firmware library synchronization
 +  * Fix "Remove" option not always shown for user-added firmware
 +BMV-712:
 +  * Fix some display settings not being exported to settings files
 +MultiRS:
 +  * Export discharge current limit to settings files
 +  * Add error 77: Settings sync disabled
 +SolarSense:
 +  * Fix incorrect kWh scale on the history page
 +==== v6.30.3 (Released officially) ====
 +** 2026-02-27 **
 +This version is only available for Windows, macOS and Android.
-Online Firmware Library +Windows
-  * New feature: VictronConnect includes the latest firmware and now auto-updates its library when internet is available. No internet is needed to update your devices.+  * Fix VE.Bus firmware list do not show available update files.
 +==== v6.30.2 (Released officially) ====
 +** 2026-02-26 **
 +This version is only available for Windows.
-==== v6.30beta1 ==== +  * [[http://updates.victronenergy.com/feeds/VictronConnect/windows/w10/VictronConnectInstaller.exe|Windows 10 and higher]]
-** 2025-10-08 **+
 +Windows
 +  * Fix firmware updating to the latest version from the product info page.
 +==== v6.30.1 (Released officially) ====
 +** 2026-02-25 **
 +This version is only available for Android.
 +__Changes__
 +Android
 +  * Fix rendering issues on phones using PowerVR GPUs
 +  * Fix an issue that sometimes causes the app to hang on the splash screen
 +==== v6.30 (Released officially) ====
 +** 2026-02-23 **
 +  * [[https://www.victronenergy.com/upload/software/VictronConnect-x86_64-v6.30.AppImage|Linux AppImage]]
 +VRM Integration (New Feature)
 +  * View VRM dashboards and overview graphs directly within the app.
 +  * Remote Console now opens inside VictronConnect rather than an external browser.
 +Online Firmware Library (New Feature)
 +  * When available firmware update release notes are shown before and during the firmware update process.
 +  * VictronConnect now automatically syncs its internal library when internet is available. Firmware updates can still be carried out without an internet connection, just like before.
 +Batch Programming (New Feature)
 +  * Allows firmware updates and settings programming for multiple units of the same model in one operation.
 +  * Supported Platforms: VE.Direct (Windows, macOS, Android) and Bluetooth (Android, iOS).
 +Android Auto (New Feature)
 +  * View Instant Readout data from Victron products on your vehicle's display.
 +Android Widgets and alarm notifications (New Features)
 +  * Home Screen Widgets: Add your favorite products to your phone’s home screen for quick access to key information at a glance.
 +  * Alarm Notifications: Receive phone notifications for nearby products triggering alarms via Bluetooth.
 +  * Both the widgets and notifications features use Instant Readout and require you to be in Bluetooth range to get data updates.
 +Trends:
 +  * New enhanced view for stored trends.
 +  * Stored trends are now saved in the settings file and can be reviewed by loading the settings file.
 +  * Various improvements in calculated trends.
 +EV Charging Station
 +  * Self-Firmware Update: Added the ability for EVCS to check the internet for new firmware and trigger updates via VictronConnect.
 +  * Added firmware v2.05
 +  * Improved "Charging current" control usability.
 +  * GX Connection (LAN & VRM): New support for accessing and configuring EVCS through a GX device
 +    * Requires firmware v2.06 (soon to be released) and Venus OS v3.70.
 +RS products:
 +  * Add off reason 18 (by aux input) notification
 +  * Add polarity selection for Aux Input settings (requires firmware over 1.27)
 +  * (MultiRS / InverterRS) Add Max discharge current limit (requires firmware over 1.27)
 +  * Add Inverter RS firmware v1.27
 +  * Add MPPT RS firmware v1.27
 +  * Add Multi RS firmware v1.28
 +Solar Chargers
 +  * Add firmware v1.73 for five specific models.
 +Orion XS
 +  * Add firmware v1.13 (for 1400 and 12V/12V-50A models).
 +  * Add support for upcoming new models.
 +Lynx Smart BMS:
 +  * Add firmware v1.15
 Energy Meter VM-3P75CT Energy Meter VM-3P75CT
   * Add firmware v1.11   * Add firmware v1.11
-    * Increase robustness of CAN-bus handling to avoid brief passthrough mode occurrences in MultiRS systems
-EVCS  +VE.Bus Inverter/Chargers: A
-  * Add firmware v2.05: +  * Add firmware v558 for various models
-    * Minor stability and performance improvements+
-InverterRS & MultiRS+Linux
-  * Fix a bug that makes VictronConnect crash when load settings saved with VictronConnect 6.19 and older+  * Improved handling of deep links.
-Small & VEBus BMS +Other changes:
-  * Updated history temperature description+  * Improved handling of thousand separators in input fields. This solves issues on some reginonal configurations.
 +  * Qt Framework Upgrade: This update brings numerous improvements and advantages that enhance your user experience and set the stage for new features in the future.
-SolarSense +Minimum OS version requirements:
-  * Fix Total yield in the period on History page which caused that one of the days was summed twice +  * Android:
- +    * Android 9 or higher: (previously Android 8)
-General +  * iOS:
-  * Fix numeric input validator showing wrong input when language/region is set to Finish/Swedish (and perhaps other)+    * iOS 16 or higher (previously iOS 14)
 +  * Microsoft Windows:
 +    * Windows 10 or higher. (same as previous version)
 +  * macOS:
 +    * macOS Monterey (12) or newer (previously macOS Big Sure (11))
-Qt Framework Upgrade: We transition from Qt 6.5 to Qt 6.8. This update brings improvements and advantages that enhance the user experience and set the stage for new features in the future.
 ==== v6.24 (Released officially) ==== ==== v6.24 (Released officially) ====
victronconnect/beta.1769887588.txt.gz · Last modified: by mpalavecino
