victronconnect:beta
| victronconnect:beta [2025-09-12 17:31] – mpalavecino | victronconnect:beta [2026-02-09 19:06] (current) – mpalavecino | ||
| Line 11: | Line 11: | ||
| (Currently available betas are on top. See further below for official releases.) | (Currently available betas are on top. See further below for official releases.) | ||
| - | ==== v6.20beta18 | + | ==== v6.30beta8 |
| - | ** 2025-09-12 ** | + | ** 2026-02-09 ** |
| __Download links:__ | __Download links:__ | ||
| - | * iOS: [[https:// | + | * iOS: Join TestFlight |
| - | * [[https://www.dropbox.com/scl/fi/ | + | |
| - | * [[https://www.dropbox.com/scl/fi/d3v4ryqpnsz78ym9fp30g/ | + | * It is necessary to follow below steps |
| - | * [[https:// | + | |
| - | * [[https:// | + | * [[https://play.google.com/apps/testing/com.victronenergy.victronconnect|2. Join VictronConnect beta on Google Play Store ]] |
| - | * [[https:// | + | * [[https:// |
| - | + | * [[https:// | |
| - | Notes: | + | * [[https:// |
| - | * Android: If you can't open the downloaded file from the downloads list try using a file browser. | + | |
| Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. | Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. | ||
| Line 30: | Line 29: | ||
| __Changes__ | __Changes__ | ||
| - | VRM Installations | + | Batch Programming |
| - | * Fix an issue that can make VictronConnect freeze for users with ~1000 or more VRM installations | + | * Fix filtering by Product ID on VE.Direct connections |
| - | VE.Bus | + | |
| - | * Fix Instant Readout AC out power does not show the sum of all the phases | + | |
| - | Energy Meter VM-3P75CT | + | |
| - | * Fix gauge maximum value | + | |
| - | InverterRS / MultiRS: | + | Online Firmware Library |
| - | * Fix Ac Output 1 data is not shown when the system phase is L1 | + | * iOS: Fix issues with Online Firmware Library when VictronConnect |
| + | * Fix lastest firmware aren' | ||
| General | General | ||
| - | * Fix an issue that makes impossible | + | * Fix crashes on older Android versions |
| + | * Stored trends are no longer tried to be fetched over remote connections | ||
| + | * Internal improvements | ||
| + | EVCS | ||
| + | * GX/Mqtt connection (new feature - requires new firmware not released yet and Venus OS v3.70) | ||
| + | * EVCS can be accessed and configured through a GX (Mqtt connection) | ||
| + | * Mqtt connection with the GX needs to be set | ||
| + | * Self Firmware Update (new feature - requires firmware not released yet) | ||
| + | * The EVCS checks on Internet for new firmware | ||
| + | * The update can be trigged from VictronConnect | ||
| + | * Previous update method is still available | ||
| - | ==== v6.20beta17 | + | VE.Bus Inverter/ |
| - | ** 2025-09-04 ** | + | * Add firmware v558 for models |
| + | * 2684 - MultiPlus-II 48/ | ||
| + | * 2688 - MultiPlus-CL 48/ | ||
| + | * 2711 - MultiPlus-II 24/ | ||
| + | * 2713 - MultiPlus 24/ | ||
| + | ==== v6.30beta7 | ||
| + | ** 2026-01-31 ** | ||
| - | * UI Improvements, | + | * Fix iOS Vision OCR crash caused by invalid image lifetime |
| - | General | + | BMS-NG |
| - | * Add limit controls on some settings | + | * Add BLE-Networking support (requires a new firmware, not available yet) |
| - | * Fix firmware | + | |
| - | * Fix some VE.Direct Inverter names | + | |
| - | * Other general improvements | + | |
| - | SolarSense: | + | RS products: |
| - | * Fix " | + | * Add off reason 18 (by aux input) notification |
| + | * Add polarity selection for Aux Input settings (requires firmware | ||
| - | InverterRS | + | MultiRS / InverterRS |
| - | * Add firmware 1.26 | + | * Add Max discharge current limit (requires |
| - | * With solar only | + | |
| - | * Postpone partial shading scan if the tracker is limited by voltage or power as there is nothing to gain by scanning. | + | |
| - | * MultiRS only | + | |
| - | * Add grid code support for Austria | + | |
| - | * Remove the feed-in restriction of 5kW when using an external AC PV inverter | + | |
| - | * Self consumption from the battery can go to all system loads or only critical loads connected to the ac output if there is an energy meter | + | |
| - | * Only raise the grid lost alarm if the ac input type is set to grid | + | |
| - | * To 3 phase configurations and/or parallel configurations only: | + | |
| - | * Fix inverter start-up issue, unit would not start charging if the grid returned when 'not allowed to discharge' | + | |
| - | * Add support for new model Inverter RS Smart 48V/6000VA (Rev2) | + | |
| - | * Add support for new model Multi RS without Solar | + | |
| - | * Fix PV Power on the Widget not being updated in remote connections | + | |
| - | Lynx Smart BMS & BMS NG: | + | Add Inverter RS firmware v1.27 |
| - | * Add firmware | + | * Add option |
| - | * Improved State of Charge accuracy | + | |
| - | * Updated float voltage levels | + | |
| - | * Smoother transition to float stage (reduces discharge spikes in ESS systems that feed back into the grid) | + | |
| - | * New default Charged Voltage | + | |
| - | * NG: Synchronization between battery monitor and charge control added to avoid entering the float stage before battery monitor synchronization is complete | + | |
| - | * NG: Fixed the repeated absorption timer broken per v1.08 | + | |
| - | * NG: The cell voltage threshold for not-allowed-to-charge contact has been reduced from 3.75V to 3.65V | + | |
| - | * NG: Added cell-ID information for minimum and maximum cell voltages and temperatures | + | |
| - | * NG: Added a data loop test to validate | + | |
| - | * NG: Fixed issue with ATC and ATD not being retained when the BMS cable was disconnected | + | |
| - | * NG: Fix occasional issue where, especially systems with many batteries, would not start up and raise Error. #2, No battery found | + | |
| - | * Fixed alarm relay that was not activating for high temperature alarms | + | |
| - | * Removed minimum and maximum battery temperature data from the history page of the Lynx Smart BMS 500/1000, as this information is not available from the Smart Lithium batteries interface | + | |
| - | Energy Meter VM-3P75CT | + | Add MPPT RS firmware |
| - | * Fix issue where, when connected | + | * Restore communication between the MPPT RS and the Multi RS/Inverter RS (broken |
| + | Add Multi RS firmware v1.28 | ||
| + | * Add option to select the polarity of the AUX inputs | ||
| + | * Add feed-in control for DC coupled MPPT chargers for the GX | ||
| + | * Fix issue in power response to voltage changes for certain grid codes, this was broken in v1.26 while removing the 5kW feed-in restriction for external AC PV inverters | ||
| + | * Fix issue preventing some units to connect to the AC input | ||
| + | * When combined with an Energy meter: Fix AC grid set-point in operation mode 'self consumption from battery only for critical loads' | ||
| - | ==== v6.20beta16 | + | More info about RS firmware 1.27 and 1.28 in the firmware changelog. |
| - | ** 2025-08-20 ** | + | |
| + | General | ||
| + | * Fix Role setting value displayed for Energy Meter over GX/Mqtt connections | ||
| + | * Fix firmware update available not being reported under certain conditions | ||
| + | * Add " | ||
| + | ==== v6.30beta6 | ||
| + | ** 2026-01-22 ** | ||
| - | VRM Installations / GX on local network: | + | General |
| - | * New layout on mobile | + | * Fix crashes that could be reported when closing the app |
| - | * GX details is shown at the top of the page for easy access | + | * Improve handling |
| - | * " | + | * Fix settings dialogs that could show extra spacing under certain conditions |
| - | * " | + | * Fix an issue where some Instant Readout values were not correctly scaled |
| + | * **Linux:** Fix app failing | ||
| + | * **Linux:** Improve handling of deep links | ||
| + | * **Android: | ||
| - | Inverter, Multi RS: | + | Batch Programming (New feature) |
| - | * Fix "Over voltage U> (10 min. running mean)" grid parameter visibility | + | * Allow firmware updates and settings programming for multiple units of the same model in one operation |
| + | * Supported connection types per platform: | ||
| + | * **VE.Direct:** Windows, macOS, Android | ||
| + | * **Bluetooth: | ||
| - | SolarSense | + | VRM Integration (New feature) |
| - | * Installation peak power is set in Wp instead of kWp to be more precise | + | * Show the VRM dashboard and overview graphs when connecting |
| - | * Better description of the " | + | * Open the Remote Console inside the app instead of in an external browser |
| - | Smart Lynx BMS NG: | + | Inverter RS / Multi RS |
| - | * Added cell-id | + | * Add proper minimum and maximum inverter limits in system settings |
| + | * Add support | ||
| - | Smart & Blue Smart Chargers | + | Lynx Smart BMS |
| - | * Add firmware | + | * Add firmware |
| - | * Add button lock feature to all chargers with a button | + | |
| - | * Fix Blue Smart Charger IP65/IP67 rebulking based on voltage instead of current | + | |
| - | * Applies to: | + | |
| - | * Smart Charger IP43 120-240V models | + | |
| - | * Impulse-II rev2 hardware models | + | |
| - | * Blue Smart Chargers IP22, IP65 and IP67 models, produced after a hardware change made in production near the end of 2019. Chargers of the earlier generation can be updated to v3.25 and no further - VictronConnect App will then show a “this the latest version” note. Chargers of more recent hardware generations can be updated to v3.61. There are no plans to make firmware updates available for the earlier generation of chargers. | + | |
| - | General improvements | + | MPPT |
| - | * Add copy action Serial Number on Product Info page | + | * Add firmware v1.73 for five models |
| - | * Numeric setting inputs UX improvements | + | |
| - | * Text inputs (on mobile) it's easier to set the cursor in a defined position | + | |
| - | * Fix Instant Readout showing the same data for two products in certain cases | + | |
| - | * Timing performance improvements | + | |
| - | Demos | ||
| - | * VE.Bus Inverters | ||
| - | * Inform that settings requires MK3-USB | ||
| - | * Fix settings button is not shown on demos | ||
| - | ==== v6.20beta15 | + | ==== v6.30beta5 |
| - | ** 2025-07-18 ** | + | ** 2026-01-06 ** |
| - | * General | + | General |
| + | * Save stored trends on settings file | ||
| + | * Restore stored trends when loading a setting file as demo | ||
| + | * Performance improvement when starting the app | ||
| + | * Precision improvements in calculated trends | ||
| + | * Other minor improvements | ||
| - | Lynx Shunt VE.Can | + | InverterRS/ |
| - | * Fix "reverse current" | + | * Show the "Aux input" settings for all the models |
| + | * Fix "Aux input" | ||
| - | VRM Installations: | + | MPPT RS |
| - | * Handling installations as "Favorites" | + | * Add the "Aux input" |
| - | * Installations are presented in two sections: " | + | |
| - | * Set/Unset as Favorites option is added | + | |
| - | Inverter, Multi RS: | + | Orion XS |
| - | * Add " | + | * Orion XS 1400 and 12V/ |
| - | * Disable the Ground relay when the Grid Code has the 'AC Neutral path externally joined' | + | |
| - | * Fixes on data reads when System phase is L2 or L3 | + | |
| - | EVCS | ||
| - | * Add more detailed info when the product can't be reached via local network for firmware updates | ||
| - | * Add control on the password length | ||
| - | MPPT Solar Chargers: | + | ==== v6.30beta4 |
| - | * Add firmware v1.68 | + | ** 2025-12-04 ** |
| - | * Remove battery temperature compensation from load output voltage thresholds | + | |
| - | ==== v6.20beta14 | + | |
| - | ** 2025-07-08 ** | + | |
| - | | + | General |
| + | * Removes certain Min & Max values from Trends pages | ||
| + | * Trends: minor improvements | ||
| + | * New features for Android | ||
| - | VictronConnect-remote: | ||
| - | * Improve connection and fetching times | ||
| - | * Fix an error that can make connection stuck at 40% and finally report an error while getting the products list | ||
| - | * Various robustness improvements | ||
| - | * Order products list by name | ||
| - | GX: | + | Android new features: |
| - | * Fix remote console button is not shown when GUI v2 is the default one | + | * |
| + | * See Instant Readout from your Victron products right on your vehicle Android Auto display. | ||
| + | * Alarm Notifications via Bluetooth: | ||
| + | * When any of your nearby (in-range) products triggers an alarm, you’ll receive a notification on your phone. | ||
| + | * Home Screen Widgets: | ||
| + | * Add your favorite products to your phone’s home screen for quick access to key information at a glance. | ||
| - | VE.Bus inverter/ | + | SolarSense: |
| - | * Add support for remote connection via VRM and local network. Monitoring only. | + | * Fix SolarSense firmware updating under certain circunstances |
| - | SolarSense | ||
| - | * Add data selection for historical values | ||
| - | * Add total estimated energy yield in a period | ||
| - | * Add graphics for historical values | ||
| - | * Add instant readout on remote connections | ||
| - | * Fix instant readout total yield | ||
| - | Energy Meter: | ||
| - | * Add EV charger and Heatpump roles | ||
| - | MPPT Solar Chargers: | + | ==== v6.30beta3 |
| - | * Fix some models do not export TX/RX settings to settins files | + | ** 2025-11-20 ** |
| - | Inverter, Multi RS: | + | |
| - | * Add firmware v 1.25 | + | |
| - | * For Inverter RS and Multi RS: | + | |
| - | * Add warning #76: shown when the inverter shuts down during operation due to insufficient inverters in the group. | + | |
| - | * Increase AC PV inverter stop frequency to 53.2Hz | + | |
| - | * For Multi RS working in 3 phase configurations and/or parallel configurations only: | + | |
| - | * Add settings synchronisation, | + | |
| - | * Add ' | + | |
| - | * Various improvements to make the 3-phase system behave as a single device. | + | |
| - | * Changes specific for Germany: | + | |
| - | * Add 3-phase support. | + | |
| - | * Divide maximum charge power 4.2kW by the number of units if the charge restriction is active (EnWg §14a). | + | |
| - | EVCS | + | |
| - | * Add firmware v2.03 | + | |
| - | * Reduced the voltage drop threshold for detecting a connected EV during the CP auto-calibration procedure | + | |
| - | * Fixed an issue with 2s delay before power off in disconnected state | + | |
| - | * Fixed an issue in the CP auto-calibration procedure that caused calibration to occur in a disconnected state | + | |
| - | * Fix color manual input selection for lightring settings | + | |
| - | SmartCharger: | + | |
| - | * Add mode button lock option to IP43 models (requires new firmware not available yet) | + | |
| - | ==== v6.20beta13 | + | |
| - | ** 2025-06-11 ** | + | |
| - | __Download links:__ | + | |
| - | * iOS: Join TestFlight https:// | + | |
| Notes: | Notes: | ||
| Line 244: | Line 190: | ||
| - | * Fix spin box switch dialog size | + | Online Firmware Library |
| - | * Save some space for the graphics of solar charger history data on full screen mode | + | * Show firmware update release notes |
| - | Multi RS: | + | Stored trends |
| - | * Add " | + | * New view for the stored trends data, with the data presented in hours per day |
| - | * Add " | + | * Several performance improvements |
| - | * Some fixes at "Ac input control" | + | |
| - | SolarSense | + | VRM |
| - | * Add Long History support & show historical maximums | + | * Make use of the system keychain for VRM login |
| - | * Fix Instant Readout | + | |
| - | MultiHS | + | General |
| - | * Add settings | + | * SolarSense: Hide min and max battery voltages from Historical |
| + | * OrionXS: add support for new Model | ||
| + | * InverterRS | MultiRS: Improves some System | ||
| + | * EVCS: Improve the " | ||
| - | GlobalLink: | + | Fixes |
| - | * Add support for rev2 hardware | + | * Fix VRM login on iOS |
| + | * Fix issues with the remote products discovery | ||
| + | * Fix BMW-600 not being shown through MQTT Connections | ||
| + | * Fix EnergyMeter instant readout power values when "Split phase" | ||
| + | * Android: Fix back button closes the app instead of navigating to previous page on some Android versions | ||
| - | ==== v6.20beta12 ==== | ||
| - | ** 2025-05-26 ** | ||
| - | __Changes__ | + | ==== v6.30beta2 |
| - | + | ** 2025-10-27 ** | |
| - | Orion Smart: | + | |
| - | * Fix startup issue on 48V output smart models | + | |
| - | SmallBMS NG: | + | |
| - | * Various improvements | + | |
| - | VE.Bus BMS NG: | + | |
| - | SuperPack NG: | + | |
| - | * Add initial support | + | |
| - | SmartSolar: | + | |
| - | * Add Bluetooth firmware v2.53: | + | |
| - | * Add VE.Smart Networking support for SmartSolar 250|60 & 250|70 | + | |
| - | Phoenix & SUN inverter: | + | |
| - | * Add firmware v1.37: | + | |
| - | * Add missing high DC ripple voltage / high DC terminal temperature alarm and warning | + | |
| - | * Add support for new models | + | |
| - | Smart Charger IP22, IP43 & IP65: | + | |
| - | * Add lock mode button option. This feature requires a new firmware that will be released soon. | + | |
| - | ==== v6.20beta11 | + | |
| - | ** 2025-04-25 ** | + | |
| - | * Android: Fix custom names are not updated in the product list on some Android versions | ||
| - | * Fix Android navigation buttons don't work from the firmware update page in some situations | ||
| - | SmartShunt & BMV-712: | + | Online Firmware Library |
| - | * Add firmware v4.19: | + | * New feature: VictronConnect includes |
| - | * Added setting (76) to reverse | + | |
| - | * Support battery capacity up to 32500 Ah (prior limit was set to 9999 Ah). | + | |
| - | OrionXS: | + | |
| - | * Add firmware v1.11: | + | |
| - | * Internal improvements | + | |
| - | * Fix Orion XS 1400 Smart Alternator(24V) preset | + | |
| - | Multi RS: | + | ==== v6.30beta1 |
| - | * Add Czech grid code (not in firmware yet) | + | ** 2025-10-08 ** |
| - | Skilla-i: | + | |
| - | * Hide AC input current limit setting on models that do not properly support it | + | |
| - | EVCS: | + | |
| - | * Add firmware v2.02: | + | |
| - | * Added CP line auto-calibration procedure. Activated by default | + | |
| - | * Added retries for FW update over the web interface in case of error | + | |
| - | * Added more warning messages related to display FW update | + | |
| - | * Improvements for auto mode, related to start by low excess power and start by battery maximum SoC | + | |
| - | * Fixed issue with special characters in WiFi SSID | + | |
| - | * Fixed issue with display firmware storage | + | |
| - | * Improve firmware update mechanism | + | |
| - | * Fix connection issues on firmware v1.24 & v1.25 | + | |
| - | * Add new warnings and errors notifications | + | |
| - | ==== v6.20beta10 | + | |
| - | ** 2025-04-12 ** | + | |
| - | * Various improvements to reduce the chance of getting a crash report when closing VictronConnect | ||
| - | * Fix an issue where VictronConnect could freeze for a while when opening a VRM deep link, if the app was not already running. | ||
| + | Energy Meter VM-3P75CT | ||
| + | * Add firmware v1.11 | ||
| + | * Increase robustness of CAN-bus handling to avoid brief passthrough mode occurrences in MultiRS systems | ||
| - | MPPT RS, Inverter RS: | + | EVCS |
| - | * Changes applying to all RS models: | + | * Minor stability |
| - | * Fix Paygo issue | + | |
| - | * Changes applying to all RS models: | + | |
| - | * Fix Paygo issue. | + | |
| - | * Changes applying to the Inverter RS and the Multi RS: | + | |
| - | * History does not log incoming AC power if there is no PV inverter detected. | + | |
| - | * Changes applying to Multi RS only: | + | |
| - | * Add grid codes: Germany single phase, South Africa and Spain Storage Systems without feed-in surplus. | + | |
| - | * Improve stability of 3 phase systems when connecting to the ac input.* | + | |
| - | * Improvements on display settings menu | + | |
| - | * Add Solar charger On/Off control | + | |
| - | Multi RS: | + | InverterRS & MultiRS: |
| - | | + | * Fix a bug that makes VictronConnect crash when load settings |
| - | * Improvemets on display settings menu | + | |
| - | * Add firmrmware v1.23: | + | |
| - | * Note when upgrading from v1.22: please check the grid settings | + | |
| - | Orion XS: | + | Small & VEBus BMS |
| - | * Fix generator shut-down detection can show wrong selected preset | + | * Updated history temperature description |
| - | * Remember last selected values for trends | + | |
| - | * Fix connection via VE.Direct cable | + | |
| - | * Fix some settings are not available via remote connections | + | |
| - | Smart Charger IP43: | + | SolarSense |
| - | * Fix connection via VE.Direct cable | + | * Fix Total yield in the period on History page which caused that one of the days was summed twice |
| - | MPPT Solar Chargers: | + | General |
| - | * Add firmware v1.67 for some models: | + | * Fix numeric input validator showing wrong input when language/region is set to Finish/Swedish (and perhaps other) |
| - | * Internal improvements for SmartSolar 100/30 model. | + | |
| - | * Improve startup robustness when a running on a synchronized charging network. | + | |
| - | * Improve robustness of 100/50 startup under high solar potential. | + | |
| - | smallBMS NG: | + | Qt Framework Upgrade: We transition from Qt 6.5 to Qt 6.8. This update brings improvements and advantages that enhance the user experience and set the stage for new features in the future. |
| - | * Fix demo library icon | + | |
| - | * Add firmware v1.03 | + | |
| - | * Reduced power consumption | + | |
| + | ==== v6.24 (Released officially) ==== | ||
| + | ** 2025-11-26 ** | ||
| - | Energy Meter: | + | __Download links:__ |
| - | * Add power factor live data | + | |
| - | * Add phase sequence live data | + | |
| - | * Add phase rotation alarm | + | |
| - | EVCS: | + | * iOS: [[https:// |
| - | * Add description to various notifications, | + | * [[https:// |
| - | * Add Light Ring brightness limit settin | + | * [[http:// |
| + | * macOS [[https:// | ||
| + | * [[https:// | ||
| - | ==== v6.20beta9 ==== | + | Notes: |
| - | ** 2025-04-01 ** | + | * Android: If you can't open the downloaded file from the downloads list try using a file browser. |
| + | Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. | ||
| - | * Update translations | + | * Fix back button behaviour on certain Android versions |
| - | * Fix VE.Direct Smart Dongle icon is not displayed | + | * Fix issues with the remote products discovery |
| - | * Various internal improvements | + | |
| - | Multi RS: | + | Orion XS 1400: |
| - | * Fix an issue that makes the solar trackers to do not show via Bluetooth on a second reconnection | + | * Orion XS 1400: Add firmware v1.13 |
| - | ==== v6.20beta8 ==== | + | SolarSense: |
| - | ** 2025-03-25 ** | + | * SolarSense: Small fixes and improvements |
| - | __Changes__ | + | BMV-600S: |
| + | * Fix BMW-600S not being shown through MQTT Connections | ||
| - | VRM deep links: | ||
| - | Connect to remote products in VictronConnect directly from the VRM devices list by clicking the 'Open in VictronConnect' | ||
| - | [[https:// | ||
| - | * Actually fix an issue where, in some situations, VictronConnect incorrectly reports the installation as offline when the user tries to connect via deep links. | + | ==== v6.23 (Released officially) ==== |
| + | ** 2025-10-20 ** | ||
| - | Multi RS: | + | __Download links:__ |
| - | * Add option to configure Aux input 2 to imit the installation battery charge power to 4.2kW (German grid code only) | + | |
| - | * Add new alarms: | + | |
| - | * Grid lost | + | |
| - | * Phase configurations | + | |
| - | * Energy meter missing | + | |
| - | MPPT RS, Inverter RS Solar & Multi RS: | + | * iOS: [[https:// |
| - | * Fix issue with MPPT tracker show/hide settings not working correctly when connected remotely | + | * [[https:// |
| + | * [[http:// | ||
| - | smallBMS NG: | + | Notes: |
| - | * Add firmware v1.02: | + | * Android: If you can't open the downloaded file from the downloads list try using a file browser. |
| - | * Added product reset at (soft) switch ON | + | |
| - | * Resolved issues with SoC & History update | + | |
| - | * Add demo product | + | |
| - | VE.Bus Inverter/ | + | Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. |
| - | * Add firmware v556: | + | |
| - | * Fixes instability issues (during PowerAssist/ | + | |
| + | __Changes__ | ||
| - | ==== v6.20beta7 ==== | + | |
| - | ** 2024-03-12 ** | + | |
| - | __Changes__ | + | EVCS: |
| + | * Add firmware v2.05 | ||
| - | VRM deep links: | + | Energy Meter: |
| - | Connect to remote products in VictronConnect directly from the VRM devices list by clicking the 'Open in VictronConnect' | + | Lynx Shunt: |
| - | [[https:// | + | * Improve calibration routine |
| - | | + | Multi RS: |
| - | | + | VE.Bus Inverter/ |
| - | | + | * Add new MultiPlus-II models |
| - | ==== v6.20beta6 ==== | + | |
| - | ** 2025-03-11 ** | + | |
| - | __Changes__ | ||
| - | VE.Bus Inverter/ | + | ==== v6.22 (Released officially) |
| - | * Add firmware v555 | + | ** 2025-09-23 ** |
| - | * Improve system stability for Charge and PowerAssist in combination with certain gensets. On all tested gensets, the system now works stable without the need to enable the Weak AC Input setting. (This improvement is available when the selected gridcode is “None” or “Other”) | + | |
| - | * Added support for the German 14a EnWG requirement. Battery charging of the system is limited to 4.2kW when the AUX2 input of the L1 phase master is “closed”. | + | |
| - | ==== v6.20beta5 | + | |
| - | ** 2025-02-25 ** | + | |
| + | GX: | ||
| + | * Fix an issue where remote products are not displayed under certain conditions on Venus versions older than v3.50 | ||
| + | * Fix an issue where a blank page is displayed on Venus versions older than v3.50 when VRM two-way communication is disabled | ||
| - | Lynx Smat BMS NG: | + | VE.Bus Inverter/ |
| - | * Add firmware | + | * Update |
| - | * Various stability improvements, | + | * Depending |
| - | * Improved Lithium-NG battery firmware updates. | + | |
| - | * Fixed invalid value in maximum cell temperature history (NG models only). | + | |
| - | * Fixed issue with Cumulative Ah counter. | + | |
| - | * Fixed issue where Lynx Distributors on the system side could incorrectly raise “blown fuse” warnings while the contactor was open. | + | |
| - | * Includes Lithium-NG battery | + | |
| - | Lynx Shunt VE.Can : | + | VE.Bus Smart Dongle: |
| - | * Add battery voltage calibration | + | * Fix AC output instant readout |
| Multi RS: | Multi RS: | ||
| - | * Include grid code settings when exporting & importing settings files | + | * Allow battery presets |
| - | * Include grid code settings in demo products | + | |
| - | * Add support for Austria & Spain grid codes (not in firmware yet) | + | |
| - | MPPT Solar Chargers: | + | |
| - | * Add firmware v1.66 for Smart and BlueSolars 75/10 and 75/15 (from serial number HQ2231 and newer): | + | |
| - | * Fix issue with TX alternate pin feature where, when not selected as " | + | |
| - | * Fix issue with RX alternate pin feature where the functions wouldn' | + | |
| - | ==== v6.20beta4 | + | ==== v6.21 (Released officially) |
| - | ** 2025-02-07 ** | + | ** 2025-09-18 ** |
| - | * Fix loading cloud icon is shown intermitently after initial loading | + | VE.Bus Inverter/ |
| - | * Fixed an issue where VictronConnect could sometimes trigger macOS to ask for download new fonts | + | * Fix detailed view is not loaded |
| - | * Android: Fixed a flickering issue after the splash screen. | + | |
| - | * Fixed an issue where the splash screen on Android and iOS could appear stretched when opening VictronConnect in landscape orientation | + | |
| - | * Fixed random crashes when a VM-3P75CT | + | |
| - | * Improve responsiveness of the product list when listing a large number of products | + | |
| - | * Fixed duplicate "My devices" | + | |
| - | * Internal improvements to prevent false crash reports | + | |
| - | Lynx SmartBMS NG: | + | VE.Bus Smart Dongle: |
| - | * New settings: (requires a firmware update that has not been released yet) | + | * Fix settings |
| - | * Add 36V battery option | + | |
| - | * Add current measurement direction setting | + | |
| - | * Add " | + | |
| - | Smart Chargers: | + | |
| - | * Add support for a new IP43 model | + | |
| - | VE.Bus BMS NG: | + | EVCS: |
| - | * Add initial support | + | * Add firmware v2.04: |
| + | * Added " | ||
| + | * Improvements to meet cybersecurity requirements | ||
| + | * Improvements in Grid ON/OFF state detection | ||
| + | * Improvements in handling ' | ||
| + | * Fixed an issue causing a 2-second delay before power-off in the charged state | ||
| + | * Fixed incorrect Gateway address in Wi-Fi AP mode | ||
| + | ==== v6.20 (Released officially) ==== | ||
| + | 2025-09-17 | ||
| - | Smart Battery Sense: | + | **Changes** |
| - | ==== v6.20beta3 ==== | + | General improvements |
| - | ** 2025-01-08 | + | * Various performance and stability improvements |
| + | * Text inputs (on mobile): easier to place the cursor in a defined position | ||
| + | * Fix Instant Readout showing the same data for two products in certain cases | ||
| - | __Changes__ | + | VRM Installations / GX on local network: |
| - | Orion XS: | + | * New layout on mobile |
| - | * Add firmware v1.08 | + | * GX details shown at the top for quick access to VRM and Remote Console |
| - | * Fix issue introduced on v1.07 that could lead to the charger failing | + | * " |
| + | * Add support for the recently added Favorites feature in VRM. | ||
| + | * Improve connection and fetching times | ||
| + | * Make VRM installations listing faster, solving an issue that can make VictronConnect to freeze for a while. | ||
| + | * Fix an error that could make the connection stuck at 40% when loading | ||
| + | * Various robustness improvements | ||
| + | * Order products list by name | ||
| + | * VE.Bus inverter/ | ||
| + | Inverter, Multi RS: | ||
| - | Smart BatteryProtect: | + | * Add " |
| - | * Add firmware | + | * Disable the Ground relay when the Grid Code has the 'AC Neutral path externally joined' |
| - | * Released | + | * Fixes on data reads when System phase is L2 or L3 |
| - | * Fix an issue where a voltage drop to 9V causes misbehavior, displaying incorrect information on the screen and occasionally disabling | + | * Fix PV Power on the Widget not being updated in remote connections |
| + | * Add " | ||
| + | * Add " | ||
| + | * Add firmware v1.26: | ||
| + | * With solar only | ||
| + | * Postpone partial shading scan if the tracker is limited by voltage or power as there is nothing to gain by scanning. | ||
| + | * MultiRS only | ||
| + | * Add grid code support | ||
| + | * Remove the feed-in restriction of 5kW when using an external AC PV inverter | ||
| + | * Self consumption from the battery can go to all system loads or only critical loads connected to the ac output if there is an energy meter | ||
| + | * Only raise the grid lost alarm if the ac input type is set to grid | ||
| + | * 3 phase configurations | ||
| + | * Fix inverter start-up | ||
| + | * Also include changes from v1.25 | ||
| + | * Add settings synchronisation; | ||
| + | * Add ' | ||
| + | * Various improvements to make the 3-phase system behave as a single device | ||
| + | * Germany: divide maximum charge power 4.2kW by the number of units if the charge restriction is active (EnWG §14a) | ||
| - | ==== v6.20beta2 ==== | ||
| - | ** 2024-12-20 ** | ||
| - | __Changes__ | + | Energy Meter VM-3P75CT |
| - | * Add Czech, Korean and Vietnamese translations | + | * Add firmware 1.10 |
| - | * Add support for various upcoming new products | + | * Add power factor live data |
| - | * Fix an issue where the Trends page does not save the selected trends under certain circumstances | + | * Add phase sequence live data |
| + | * Add phase rotation alarm | ||
| + | * Add EV charger and Heatpump roles | ||
| + | * Various improvements | ||
| - | Solar Chargers: | + | MPPT Solar Chargers: |
| - | * Fix " | + | |
| - | Multi RS: | + | |
| - | * Enable setting the grid code for the first time without requiring a password | + | * Remove battery temperature compensation from load output voltage thresholds |
| - | | + | * Fix some models do not export TX/RX settings |
| - | * Improve NS Log handling | + | |
| - | * Fix NS log displaying incorrect time in DST time zones | + | |
| - | * Make possible | + | |
| - | MPPT RS: | + | EVCS |
| - | * Add an option to hide unused MPPT trackers (requires beta firmware) | + | |
| - | Orion XS: | + | |
| - | | + | * Reduced |
| - | * Remote H/L now also included as a condition to pause the charge algorithm as done with low input voltage. Charge algorithm is now paused | + | * Fixed an issue with 2s delay before |
| - | * Improve overall robustness of the hardware | + | * Fixed an issue in the CP auto-calibration procedure that caused calibration to occur in a disconnected |
| + | * Add more detailed info when the product can't be reached via local network for firmware updates | ||
| + | * Add control | ||
| + | * Fix color manual input selection for lightring settings | ||
| - | Lynx SmartBMS | + | Lynx Smart BMS & NG: |
| - | * Make the battery | + | * Added cell-id for min/max voltage/ |
| + | * Add firmware 1.14 | ||
| + | * Improved State of Charge accuracy | ||
| + | * Updated float voltage levels | ||
| + | * Smoother transition to float stage (reduces discharge spikes in ESS systems that feed back into the grid) | ||
| + | * New default Charged Voltage | ||
| + | * NG: Synchronization between | ||
| + | * NG: Fixed the repeated absorption timer broken per v1.08 | ||
| + | * NG: The cell voltage threshold for not-allowed-to-charge contact has been reduced | ||
| + | * NG: Added cell-ID information for minimum and maximum cell voltages and temperatures | ||
| + | * NG: Added a data loop test to validate the communication interface with the batteries | ||
| + | * NG: Fixed issue with ATC and ATD not being retained when the BMS cable was disconnected | ||
| + | * NG: Fix occasional issue where, especially systems with many batteries, would not start up and raise Error. #2, No battery found | ||
| + | * Fixed alarm relay that was not activating for high temperature alarms | ||
| + | Smart & Blue Smart Chargers | ||
| - | ==== v6.20beta1 ==== | + | * Add firmware v3.65 |
| - | ** 2024-11-23 | + | * Add button lock feature to all chargers with a button |
| + | * Impulse-II rev2 hardware models | ||
| + | * Blue Smart Chargers IP22, IP65 and IP67 models, produced after a hardware change made in production near the end of 2019. | ||
| - | __Changes__ | + | VE.Bus inverter/ |
| + | * Fix Instant Readout AC out power does not show the sum of all the phases | ||
| + | VE.Bus BMS NG: | ||
| - | ** New Feature: Support for Deep Links ** | + | |
| - | You can now open products in VictronConnect directly from VRM by clicking the "Open in VictronConnect" | + | SolarSense |
| - | * This feature is not yet available in VRM but will be published soon. | + | |
| - | * Currently supported only on Windows, macOS, and Linux. Support for Android and iOS will be added in a future beta release. | + | |
| - | Orion XS: | + | * Installation peak power is set in Wp instead of kWp to be more precise |
| - | * Add firmware v1.06 | + | * Better description of the " |
| - | * Fix handling of newer serial numbers that could cause conflicts with VE.Smart networking | + | * Add data selection for historical values |
| + | * Add total estimated energy yield in a period | ||
| + | * Add graphics for historical values | ||
| + | * Add Long History support & show historical maximums | ||
| + | * Add Instant Readout on remote connections | ||
| + | * Fix “Installation peak power” behaviour when set values over 655kWp | ||
| - | EVCS: | + | Demos |
| - | * Fixed an issue where firmware update notifications continued to appear even after completing the update. | + | * VE.Bus Inverters |
| - | * Notify users when the EVCS is not reachable on the network before attempting a firmware update from the settings | + | * Inform that settings |
| ==== v6.19 (Released officially) ==== | ==== v6.19 (Released officially) ==== | ||
victronconnect/beta.1757691071.txt.gz · Last modified: by mpalavecino
