victronconnect:beta
victronconnect:beta [2025-09-04 14:22] mpalavecinovictronconnect:beta [2025-12-04 20:34] (current) jperez
Line 11: Line 11:
 (Currently available betas are on top. See further below for official releases.) (Currently available betas are on top. See further below for official releases.)
-==== v6.20beta16 ==== +==== v6.30beta4 ====
-** 2025-08-20 **+** 2025-12-04 **
 __Download links:__ __Download links:__
-  * iOS: [[https://testflight.apple.com/join/cvufYMEh|Join TestFlight]] +  * iOS: Join TestFlight https://testflight.apple.com/join/cvufYMEh
-  * [[https://www.dropbox.com/scl/fi/upxwhr80kijjzy3vul9we/VictronConnect-v6.20beta16-arm64_v8a.apk?rlkey=o99rezyy1yk3jkp3jez55um9s&st=0b26frlv&dl=1|Android ARM64]]* +  * Android via Google Play Store:
-  * [[https://www.dropbox.com/scl/fi/rrolhe5laapdwyxce1b3y/VictronConnect-v6.20beta16-x86_64.apk?rlkey=xg95f1a74pjvhnvubv089069k&st=7vfx1q6m&dl=1|Android x86_64]]* +    * It is necessary to follow below steps
-  * [[https://www.dropbox.com/scl/fi/g3xjbl1oa379aututyhs0/VictronConnectInstaller.exe?rlkey=8a3pjqfyyo6325soewet5m68x&st=fyrpljco&dl=1|Windows 10 and higher]] +    * [[https://groups.google.com/g/victronconnect-beta-testing|1Join beta testing group on this link ]]
-  * [[https://www.dropbox.com/scl/fi/mie5sil0cjm2cdv4gx4z5/VictronConnect.dmg?rlkey=isqhdrtx6a1ybya7v5hz9k1av&st=49n639n2&dl=1|macOS 11 (Big Sur) and higher]] +    * [[https://play.google.com/apps/testing/com.victronenergy.victronconnect|2. Join VictronConnect beta on Google Play Store ]]
-  * [[https://www.dropbox.com/scl/fi/fns2mbeve56xn9nw2o335/VictronConnect-x86_64.AppImage?rlkey=nryxu2pyo399ofret6gu64la9&st=s3hbht9p&dl=1|Linux AppImage]]+  * [[https://www.dropbox.com/scl/fi/ojzklna7mgqz4cmu7xd4e/VictronConnectInstaller.exe?rlkey=jbyxvgd6q5v5wkmd9iyrfc0z2&dl=1|Windows 10 and higher]]
 +  * [[https://www.dropbox.com/scl/fi/bcf4898qb4ofxsqzhehe9/VictronConnect.dmg?rlkey=m5yflk35wp0eabjhqjox98yn0&dl=1|macOS 11 (Big Sur) and higher]]
 +  * [[https://www.dropbox.com/scl/fi/uyjk0hsbpymcufm9j2vh6/VictronConnect-x86_64.AppImage?rlkey=4yvaan42eq49sb55ueflhwoqh&dl=1|Linux AppImage]]
 Notes: Notes:
Line 30: Line 32:
 __Changes__ __Changes__
-VRM Installations / GX on local network: +General
-  * New layout on mobile +  * Add support for upcoming new products
-    * GX details is shown at the top of the page for easy access to VRM and remote console +  Removes certain Min & Max values from Trends pages
-    "Remote console" button is added for VRM Installations +  Trends: minor improvements when data can'be fetched
-    "Remote console" UI can be selected -> Classic UI or New UI+  * Other minor improvements
 +  * New features for Android
-Inverter, Multi RS:
-  * Fix "Over voltage U> (10 min. running mean)" grid parameter visibility
-SolarSense +Android new features:
-  * Installation peak power is set in Wp instead of kWp to be more precise +  *  Android Auto App:
-  * Better description of the "Temperature compensation" parameter+    * See Instant Readout from your Victron products right on your vehicle Android Auto display.
 +  * Alarm Notifications via Bluetooth:
 +    * When any of your nearby (in-range) products triggers an alarm, you’ll receive a notification on your phone.
 +  * Home Screen Widgets:
 +    * Add your favorite products to your phone’s home screen for quick access to key information at a glance.
-Small and Smart BMS and VE.Bus and Smart Lynx BMS NG+SolarSense
-  * Added cell-id for min/max voltage/temp+  * Fix SolarSense firmware updating under certain circunstances
-Smart & Blue Smart Chargers
-  * Add firmware v3.65
-    * Add button lock feature to all chargers with a button
-    * Fix Blue Smart Charger IP65/IP67 rebulking based on voltage instead of current
-  * Applies to:
-    * Smart Charger IP43 120-240V models
-    * Impulse-II rev2 hardware models
-    * Blue Smart Chargers IP22, IP65 and IP67 models, produced after a hardware change made in production near the end of 2019. Chargers of the earlier generation can be updated to v3.25 and no further - VictronConnect App will then show a “this the latest version” note. Chargers of more recent hardware generations can be updated to v3.61. There are no plans to make firmware updates available for the earlier generation of chargers.
-General improvements
-  * Add copy action Serial Number on Product Info page
-  * Numeric setting inputs UX improvements
-  * Text inputs (on mobile) it's easier to set the cursor in a defined position
-  * Fix Instant Readout showing the same data for two products in certain cases
-  * Timing performance improvements
-Demos +==== v6.30beta3 ====
-* VE.Bus Inverters +** 2025-11-20 **
-  * Inform that settings requires MK3-USB +
-  * Fix settings button is not shown on demos +
-==== v6.20beta15 ==== +
-** 2025-07-18 ** +
-__Download links:__ +
-  * [[https://www.dropbox.com/scl/fi/5anhah7ugkle8f2mhjeec/VictronConnect-v6.20beta15-arm64_v8a.apk?rlkey=x33yefnw3cxezuzqyqrgeoueg&st=g9e476ow&dl=1|Android ARM64]]* +
-  * [[https://www.dropbox.com/scl/fi/kccwbk8xwt7x6v1gdvgae/VictronConnect-v6.20beta15-x86_64.apk?rlkey=nzxuiz3j1jsqwa1oqrwkid8mo&st=ipu6j0pe&dl=1|Android x86_64]]* +
-  * [[https://www.dropbox.com/scl/fi/2we7miqfpirg6253ts9oj/VictronConnectInstaller.exe?rlkey=4rf74a5w8b15mi8jvbz57373o&st=uvo41zk5&dl=1|Windows 10 and higher]] +
-  * [[https://www.dropbox.com/scl/fi/a7syrjtih6foyde8rklle/VictronConnect.dmg?rlkey=24my2f03bsxv6reuh6u4gb5h2&st=9b87eei1&dl=1|macOS 11 (Big Sur) and higher]] +
-  * [[https://www.dropbox.com/scl/fi/s6sjj41b4k078bbxzeo45/VictronConnect-x86_64.AppImage?rlkey=yo46c4o5j5c58lfokd5sj0mmv&st=6igrh7up&dl=1|Linux AppImage]]+
 Notes: Notes:
Line 86: Line 63:
-General performance improvements+Online Firmware Library
 +  Show firmware update release notes
-Lynx Shunt VE.Can +Stored trends
-  * Fix "reverse current" shown when it's not a supported feature+  * New view for the stored trends data, with the data presented in hours per day
 +  * Several performance improvements
-VRM Installations: +VRM
-  * Handling installations as "Favorites" +  * Make use of the system keychain for VRM login
-    * Installations are presented in two sections: "Favorites" and "Other installations" +
-    * Set/Unset as Favorites option is added+
-Inverter, Multi RS: +General
-  * Add "Self-consumption from battery" setting +  * SolarSense: Hide min and max battery voltages from Historical
-  * Disable the Ground relay when the Grid Code has the 'AC Neutral path externally joined' +  * OrionXS: add support for new Model
-  * Fixes on data reads when System phase is L2 or L3+  * InverterRS | MultiRS: Improves some System settings descriptions
 +  * EVCS: Improve the "Charging current" control usability
-EVCS +Fixes
-  * Add more detailed info when the product can't be reached via local network for firmware updates +  * Fix VRM login on iOS
-  * Add control on the password length+  * Fix issues with the remote products discovery
 +  * Fix BMW-600 not being shown through MQTT Connections
 +  * Fix EnergyMeter instant readout power values when "Split phase"
 +  * Android: Fix back button closes the app instead of navigating to previous page on some Android versions
-MPPT Solar Chargers:
-  * Add firmware v1.68
-    * Remove battery temperature compensation from load output voltage thresholds
-==== v6.20beta14 ==== +==== v6.30beta2 ====
-** 2025-07-08 **+** 2025-10-27 **
-  Various internal improvements.+Online Firmware Library
 +  New feature: VictronConnect includes the latest firmware and now auto-updates its library when internet is available. No internet is needed to update your devices.
-VictronConnect-remote: +==== v6.30beta1 ====
-  Improve connection and fetching times +** 2025-10-08 **
-  Fix an error that can make connection stuck at 40% and finally report an error while getting the products list +
-  Various robustness improvements +
-  Order products list by name+
-GX: +__Changes__
-  * Fix remote console button is not shown when GUI v2 is the default one+
-VE.Bus inverter/charger: +Energy Meter VM-3P75CT
-  * Add support for remote connection via VRM and local network. Monitoring only.+  * Add firmware v1.11
 +    * Increase robustness of CAN-bus handling to avoid brief passthrough mode occurrences in MultiRS systems
-SolarSense +EVCS
-  * Add data selection for historical values +  * Add firmware v2.05:
-  * Add total estimated energy yield in a period +    Minor stability and performance improvements
-  * Add graphics for historical values +
-  * Add instant readout on remote connections +
-  Fix instant readout total yield+
-Energy Meter+InverterRS & MultiRS
-  *  Add EV charger and Heatpump roles+  * Fix a bug that makes VictronConnect crash when load settings saved with VictronConnect 6.19 and older
-MPPT Solar Chargers: +Small & VEBus BMS
- Fix some models do not export TX/RX settings to settins files+  Updated history temperature description
-Inverter, Multi RS: +SolarSense
-  * Add firmware v 1.25 +  * Fix Total yield in the period on History page which caused that one of the days was summed twice
-    * For Inverter RS and Multi RS: +
-      * Add warning #76: shown when the inverter shuts down during operation due to insufficient inverters in the group. +
-      * Increase AC PV inverter stop frequency to 53.2Hz +
-    * For Multi RS working in 3 phase configurations and/or parallel configurations only: +
-      * Add settings synchronisation, VictronConnect shows which settings are synchronised if the feature is enabled. +
-      * Add 'Switch phases as group' configuration, allowing configurations like 1 phase in and 3 phase out. +
-      * Various improvements to make the 3-phase system behave as a single device. +
-    * Changes specific for Germany: +
-      * Add 3-phase support. +
-      * Divide maximum charge power 4.2kW by the number of units if the charge restriction is active (EnWg §14a).+
-EVCS +General
-  * Add firmware v2.03 +  * Fix numeric input validator showing wrong input when language/region is set to Finish/Swedish (and perhaps other)
-    * Reduced the voltage drop threshold for detecting a connected EV during the CP auto-calibration procedure +
-    * Fixed an issue with 2s delay before power off in disconnected state +
-    * Fixed an issue in the CP auto-calibration procedure that caused calibration to occur in a disconnected state +
-  * Fix color manual input selection for lightring settings+
-SmartCharger: +Qt Framework UpgradeWe transition from Qt 6.5 to Qt 6.8. This update brings improvements and advantages that enhance the user experience and set the stage for new features in the future.
-  * Add mode button lock option to IP43 models (requires new firmware not available yet)+
-==== v6.20beta13 ==== +==== v6.24 (Released officially) ====
-** 2025-06-11 **+** 2025-11-26 **
-  * iOS: Join TestFlight https://testflight.apple.com/join/cvufYMEh  +  * iOS: [[https://itunes.apple.com/app/victronconnect/id943840744?mt=8|App Store]]
-  * [[https://www.dropbox.com/scl/fi/gmopj9ts7jum4n1b2otwn/VictronConnect-v6.20beta13-arm64_v8a.apk?rlkey=rr45umna96e75mf5boiuxc1ts&dl=1|Android ARM64 ]]* +  * [[https://play.google.com/store/apps/details?id=com.victronenergy.victronconnect|Android]]
-  * [[https://www.dropbox.com/scl/fi/h7m5ymzhhjjjdjdv1c03a/VictronConnect-v6.20beta13-x86_64.apk?rlkey=0avyrytoe2vjl4rvqj1vke4ut&dl=1|Android x86_64]]* +  * [[http://updates.victronenergy.com/feeds/VictronConnect/windows/w10/VictronConnectInstaller.exe|Windows 10 and higher]]
-  * [[https://www.dropbox.com/scl/fi/0rmcduskhe7khn9653zl1/VictronConnectInstaller.exe?rlkey=lekzlxmrexljgzg1o6opn72jm&dl=1|Windows 10 and higher]] +  * macOS [[https://itunes.apple.com/app/victronconnect/id1084677271?mt=12|11 (macOS Big Sur) and higher|App Store]]
-  * [[https://www.dropbox.com/scl/fi/up3ak71ao72q35goxez4c/VictronConnect.dmg?rlkey=jw97dvv4u8lzmut3gaa6dwyrw&dl=1|macOS 11 (Big Sur) and higher]] +  * [[https://www.victronenergy.com/upload/software/VictronConnect-x86_64-v6.24.AppImage|Linux AppImage]]
-  * [[https://www.dropbox.com/scl/fi/1p324wqc6cuyj4rx6drll/VictronConnect-x86_64.AppImage?rlkey=xadz70i7qchmjm5c79ecqh7eb&dl=1|Linux AppImage]]+
 Notes: Notes:
Line 184: Line 141:
-  * Fix spin box switch dialog size +  * Fix back button behaviour on certain Android versions
-  * Save some space for the graphics of solar charger history data on full screen mode+  * Fix issues with the remote products discovery
-Multi RS+Orion XS 1400
-  * Add "System sync settings" icons/badge +  * Orion XS 1400: Add firmware v1.13
-  * Add "Switch phases as group" setting +
-  * Some fixes at "Ac input control" settings+
-SolarSense +SolarSense:
-  * Add Long History support & show historical maximums +  * SolarSense: Small fixes and improvements
-  * Fix Instant Readout+
-MultiHS +BMV-600S:
-  * Add settings save definition+  * Fix BMW-600S not being shown through MQTT Connections
-GlobalLink:
-  * Add support for rev2 hardware
-==== v6.20beta12 ==== +==== v6.23 (Released officially) ====
-** 2025-05-26 **+** 2025-10-20 **
 +__Download links:__
-__Changes__+  * iOS: [[https://itunes.apple.com/app/victronconnect/id943840744?mt=8|App Store]]
 +  * [[https://www.victronenergy.com/upload/software/VictronConnect-x86_64-v6.23.AppImage|Linux AppImage]]
-Orion Smart+Notes
-  * Fix startup issue on 48V output smart models+  * Android: If you can't open the downloaded file from the downloads list try using a file browser.
-SmallBMS NG: +Please report bugs and give feedback to these betas via the Disqus comments belowPlease note that comments are not public by default, and first go to moderation queue.
-  * Various improvements +
-VE.Bus BMS NG: +
-SuperPack NG: +
-  * Add initial support +
-SmartSolar: +
-  * Add Bluetooth firmware v2.53:  +
-    * Add VE.Smart Networking support for SmartSolar 250|60 & 250|70 +
-Phoenix & SUN inverter: +
-  * Add firmware v1.37: +
-    * Add missing high DC ripple voltage / high DC terminal temperature alarm and warning +
-  * Add support for new models +
-Smart Charger IP22, IP43 & IP65: +
-  * Add lock mode button option. This feature requires new firmware that will be released soon. +
-==== v6.20beta11 ==== +
-** 2025-04-25 **+
-  * Android: Fix custom names are not updated in the product list on some Android versions
-  * Fix Android navigation buttons don't work from the firmware update page in some situations
-SmartShunt & BMV-712: +  * Fix numeric input values are not correctly validated on certain locales
-  * Add firmware v4.19: +
-    * Added setting (76) to reverse the shunt direction (signedness of the Current will swap i.e. postive current becomes negative and vice versa). +
-    * Support battery capacity up to 32500 Ah (prior limit was set to 9999 Ah). +
-OrionXS: +
-  * Add firmware v1.11: +
-    * Internal improvements +
-  * Fix Orion XS 1400 Smart Alternator(24V) preset +
-Multi RS: +
-  * Add Czech grid code (not in firmware yet)  +
-Skilla-i: +
-  * Hide AC input current limit setting on models that do not properly support it+
 EVCS: EVCS:
-  * Add firmware v2.02: +  * Add firmware v2.05
-    * Added CP line auto-calibration procedure. Activated by default +
-    * Added retries for FW update over the web interface in case of error +
-    * Added more warning messages related to display FW update +
-    * Improvements for auto mode, related to start by low excess power and start by battery maximum SoC +
-    * Fixed issue with special characters in WiFi SSID +
-    * Fixed issue with display firmware storage +
-  * Improve firmware update mechanism +
-  * Fix connection issues on firmware v1.24 & v1.25 +
-  * Add new warnings and errors notifications +
-==== v6.20beta10 ==== +
-** 2025-04-12 ** +
-__Changes__ +
-  * Various improvements to reduce the chance of getting a crash report when closing VictronConnect +
-  * Fix an issue where VictronConnect could freeze for a while when opening a VRM deep link, if the app was not already running.+
 +Energy Meter:
-MPPT RS, Inverter RS+Lynx Shunt
-  * Add firmware v1.22: +  * Improve calibration routine
-    * Changes applying to all RS models: +
-      * Fix Paygo issue +
-      * Fix Paygo issue. +
-    * Changes applying to the Inverter RS and the Multi RS: +
-        * History does not log incoming AC power if there is no PV inverter detected. +
-    * Changes applying to Multi RS only: +
-      * Add grid codes: Germany single phase, South Africa and Spain Storage Systems without feed-in surplus. +
-      * Improve stability of 3 phase systems when connecting to the ac input.*  +
-  * Improvements on display settings menu +
-  * Add Solar charger On/Off control+
 Multi RS: Multi RS:
-  * Add new and improve existing off reasons +  * Fix settings saved with v6.19 or earlier could fail to load
-  * Improvemets on display settings menu +
-  * Add firmrmware v1.23: +
-    * Fix storing the grid code specific settings in non-volatile memory. +
-    * Note when upgrading from v1.22: please check the grid settings in VictronConnect, the Grid code reverts back to ‘None’.+
-Orion XS+VE.Bus Inverter/Chargers
-  * Fix generator shut-down detection can show wrong selected preset +  * Add new MultiPlus-II models
-  * Remember last selected values for trends +
-  * Fix connection via VE.Direct cable +
-  * Fix some settings are not available via remote connections+
-Smart Charger IP43:
-MPPT Solar Chargers: +==== v6.22 (Released officially) ====
-  * Add firmware v1.67 for some models: +** 2025-09-23 **
-    Internal improvements for SmartSolar 100/30 model. +
-    Improve startup robustness when a running on a synchronized charging network. +
-    Improve robustness of 100/50 startup under high solar potential.+
-smallBMS NG: +__Changes__
-  * Fix demo library icon +
-  * Add firmware v1.03 +
-    * Reduced power consumption+
 +GX:
 +  * Fix an issue where remote products are not displayed under certain conditions on Venus versions older than v3.50
 +  * Fix an issue where a blank page is displayed on Venus versions older than v3.50 when VRM two-way communication is disabled
-Energy Meter:  +VE.Bus Inverter/Chargers
-  * Add power factor live data +  * Update firmware library
-  * Add phase sequence live data +    Depending the model the latest firmware version is v556, v557 or v558
-  Add phase rotation alarm+
-EVCS: +VE.Bus Smart Dongle:
-  * Add description to various notifications, errors and warnings +  * Fix AC output instant readout
-  * Add Light Ring brightness limit settin (to be included in future firmware releases)  +
-==== v6.20beta9 ==== +
-** 2025-04-01 ** +
-__Changes__ +
-  * Update translations +
-  * Fix VE.Direct Smart Dongle icon is not displayed +
-  * Various internal improvements+
 Multi RS: Multi RS:
-  * Fix an issue that makes the solar trackers to do not show via Bluetooth on a second reconnection+  * Allow battery presets to set equalisation voltage to 0V
-==== v6.20beta8 ==== +==== v6.21 (Released officially) ====
-** 2025-03-25 **+** 2025-09-18 **
-VRM deep links: +VE.Bus Inverter/Chargers:
-Connect to remote products in VictronConnect directly from the VRM devices list by clicking the 'Open in VictronConnect' buttonCurrently, these buttons are only available at  +  * Fix detailed view is not loaded when connecting via MK3
-[[https://betavrm.victronenergy.com|VRM Beta (https://betavrm.victronenergy.com)]]+
-  * Actually fix an issue where, in some situations, VictronConnect incorrectly reports the installation as offline when the user tries to connect via deep links.+VE.Bus Smart Dongle:
 +  * Fix settings button is not visible
-Multi RS+EVCS
-  * Add option to configure Aux input 2 to imit the installation battery charge power to 4.2kW (German grid code only) +  * Add firmware v2.04:
-  Add new alarms: +    Added "Online Updates" feature for firmware
-    * Grid lost +    * Improvements to meet cybersecurity requirements
-    * Phase configurations +    * Improvements in Grid ON/OFF state detection
-    * Energy meter missing+    * Improvements in handling 'Start/Stop charging' based on backup battery SoC levels
 +    * Fixed an issue causing a 2-second delay before power-off in the charged state
 +    * Fixed incorrect Gateway address in Wi-Fi AP mode
 +==== v6.20 (Released officially) ====
 +2025-09-17
-MPPT RS, Inverter RS Solar & Multi RS: +**Changes**
-  Fix issue with MPPT tracker show/hide settings not working correctly when connected remotely+
-smallBMS NG: +General improvements
-  * Add firmware v1.02: +  * Various performance and stability improvements
-    Added product reset at (softswitch ON +  * Add copy action for Serial Number on Product Info page
-    Resolved issues with SoC & History update +  Numeric setting inputs UX improvements
-  * Add demo product+  * Text inputs (on mobile): easier to place the cursor in a defined position
 +  Fix Instant Readout showing the same data for two products in certain cases
 +  * Fix an issue that makes impossible to select a manual added firmware file in certain situations
-VE.Bus Inverter/chargers: +VRM Installations GX on local network:
-  * Add firmware v556: +
-    * Fixes instability issues (during PowerAssist/Charge/FeedIn) which became apparent with revision 555. +
-==== v6.20beta7 ==== +
-** 2024-03-12 ** +
-__Changes__ +
-VRM deep links: +
-Connect to remote products in VictronConnect directly from the VRM devices list by clicking the 'Open in VictronConnect' button. Currently, these buttons are only available at  +
-[[https://betavrm.victronenergy.com|VRM Beta (https://betavrm.victronenergy.com)]] +
-  * Fix an issue where, in some situations, VictronConnect incorrectly reports the installation as offline when the user tries to connect via deep links.+
 +  * New layout on mobile
 +    * GX details shown at the top for quick access to VRM and Remote Console
 +  * "Remote console" button added for VRM Installations
 +  * "Remote console" UI can be selected -> Classic UI or New UI
 +  * Add support for the recently added Favorites feature in VRM.
 +  * Improve connection and fetching times
 +  * Make VRM installations listing faster, solving an issue that can make VictronConnect to freeze for a while.
 +  * Fix an error that could make the connection stuck at 40% when loading the products list
 +  * Various robustness improvements
 +  * Order products list by name
 +  * VE.Bus inverter/charger: Add support for remote connection via VRM and local network. Monitoring only.
-   +Inverter, Multi RS:
-==== v6.20beta6 ==== +
-** 2025-03-11 **+
-__Changes__+  * Add "Self-consumption from battery" setting
 +  * Disable the Ground relay when the Grid Code has the 'AC Neutral path externally joined'
 +  * Fixes on data reads when System phase is L2 or L3
 +  * Fix PV Power on the Widget not being updated in remote connections
 +  * Add "System sync settings" support included in latest Multi RS firmware
 +  * Add "Switch phases as group" setting
 +  * Add firmware v1.26:
 +    * With solar only
 +      * Postpone partial shading scan if the tracker is limited by voltage or power as there is nothing to gain by scanning.
 +    * MultiRS only
 +      * Add grid code support for Austria
 +      * Remove the feed-in restriction of 5kW when using an external AC PV inverter
 +      * Self consumption from the battery can go to all system loads or only critical loads connected to the ac output if there is an energy meter
 +      * Only raise the grid lost alarm if the ac input type is set to grid
 +    * 3 phase configurations and/or parallel configurations only:
 +      * Fix inverter start-up issue, unit would not start charging if the grid returned when 'not allowed to discharge' or low-SoC was active.
 +    * Also include changes from v1.25
 +      * Add settings synchronisation; VictronConnect shows which settings are synchronised if the feature is enabled
 +      * Add 'Switch phases as group' configuration, allowing configurations like 1 phase in and 3 phase out
 +      * Various improvements to make the 3-phase system behave as a single device
 +      * Germany: divide maximum charge power 4.2kW by the number of units if the charge restriction is active (EnWG §14a)
-VE.Bus Inverter/Charger:
-  * Add firmware v555
-    * Improve system stability for Charge and PowerAssist in combination with certain gensets. On all tested gensets, the system now works stable without the need to enable the Weak AC Input setting. (This improvement is available when the selected gridcode is “None” or “Other”)
-    * Added support for the German 14a EnWG requirement. Battery charging of the system is limited to 4.2kW when the AUX2 input of the L1 phase master is “closed”.
-==== v6.20beta5 ==== +Energy Meter VM-3P75CT
-** 2025-02-25 **+
-__Changes__+  * Add firmware 1.10
 +    * Add power factor live data
 +    * Add phase sequence live data
 +    * Add phase rotation alarm
 +    * Add EV charger and Heatpump roles
 +MPPT Solar Chargers:
-Lynx Smat BMS NG: +  * Add firmware v1.68
-  * Add firmware v1.13 +    * Remove battery temperature compensation from load output voltage thresholds
-    * Various stability improvements, especially for systems with many Lithium-NG batteries. +  Fix some models do not export TX/RX settings to settings files
-    * Improved Lithium-NG battery firmware updates. +
-    Fixed invalid value in maximum cell temperature history (NG models only). +
-    * Fixed issue with Cumulative Ah counter. +
-    * Fixed issue where Lynx Distributors on the system side could incorrectly raise “blown fuse” warnings while the contactor was open. +
-    * Includes Lithium-NG battery firmware v1.01+
-Lynx Shunt VE.Can : +EVCS
-  * Add battery voltage calibration+
-Multi RS: +  * Add firmware v2.03
-  Include grid code settings when exporting & importing settings files +    Reduced the voltage drop threshold for detecting a connected EV during the CP auto-calibration procedure
-  Include grid code settings in demo products +    Fixed an issue with 2s delay before power off in disconnected state
-  * Add support for Austria & Spain grid codes (not in firmware yet)+    * Fixed an issue in the CP auto-calibration procedure that caused calibration to occur in a disconnected state
 +    * Add more detailed info when the product can't be reached via local network for firmware updates
 +    * Add control on the password length
 +    * Fix color manual input selection for lightring settings
-VE.Bus BMS NG: +Lynx Smart BMS NG:
-  * Various improvements+  * Added cell-id for min/max voltage/temp (Bluetooth only)
 +  * Add firmware 1.14
 +    * Improved State of Charge accuracy
 +    * Updated float voltage levels
 +    * Smoother transition to float stage (reduces discharge spikes in ESS systems that feed back into the grid)
 +    * New default Charged Voltage
 +    * NG: Synchronization between battery monitor and charge control added to avoid entering the float stage before battery monitor synchronization is complete
 +    * NG: Fixed the repeated absorption timer broken per v1.08
 +    * NG: The cell voltage threshold for not-allowed-to-charge contact has been reduced from 3.75V to 3.65V
 +    * NG: Added cell-ID information for minimum and maximum cell voltages and temperatures
 +    * NG: Added a data loop test to validate the communication interface with the batteries (no special handling in VictronConnect App or similar is required)
 +    * NG: Fixed issue with ATC and ATD not being retained when the BMS cable was disconnected
 +    * NG: Fix occasional issue where, especially systems with many batteries, would not start up and raise Error. #2, No battery found
 +    * Fixed alarm relay that was not activating for high temperature alarms
-MPPT Solar Chargers: +Smart & Blue Smart Chargers
-  * Add firmware v1.66 for Smart and BlueSolars 75/10 and 75/15 (from serial number HQ2231 and newer): +
-    * Fix issue with TX alternate pin feature where, when not selected as "normal communication", some extra unexpected pulses could be generated. +
-    * Fix issue with RX alternate pin feature where the functions wouldn't work according to the specs when the RX pin was left floating (not connected).+
-==== v6.20beta4 ==== +  * Add firmware v3.65
-** 2025-02-07 **+    Add button lock feature to all chargers with a button
 +    Fix Blue Smart Charger IP65/IP67 rebulking based on voltage instead of current
 +  Applies to:
 +    Smart Charger IP43 120–240V models
 +    * Impulse-II rev2 hardware models
 +    * Blue Smart Chargers IP22, IP65 and IP67 models, produced after a hardware change made in production near the end of 2019.
-__Changes__ +VE.Bus inverter/charger:
- +  * Fix Instant Readout AC out power does not show the sum of all the phases
-  * Fix loading cloud icon is shown intermitently after initial loading +
-  * Fixed an issue where VictronConnect could sometimes trigger macOS to ask for download new fonts +
-  * Android: Fixed a flickering issue after the splash screen. +
-  * Fixed an issue where the splash screen on Android and iOS could appear stretched when opening VictronConnect in landscape orientation +
-  * Fixed random crashes when a VM-3P75CT is available on the local network +
-  * Improve responsiveness of the product list when listing a large number of products +
-  * Fixed duplicate "My devices" entries appearing in the device list +
-  * Internal improvements to prevent false crash reports when closing VictronConnect +
-Lynx SmartBMS NG: +
-  * New settings: (requires a firmware update that has not been released yet) +
-    * Add 36V battery option +
-    * Add current measurement direction setting +
-    * Add "Indicator light" relay mode +
-Smart Chargers: +
-  * Add support for a new IP43 model+
 VE.Bus BMS NG: VE.Bus BMS NG:
-Smart Battery Sense: +  * Add support
-  * Add firmware v1.15: +
-    * Reduced power consumption compared to firmware v1.14+
-==== v6.20beta3 ==== +SolarSense
-** 2025-01-08 **+
-__Changes__+  * Installation peak power is set in Wp instead of kWp to be more precise
 +  * Better description of the "Temperature compensation" parameter
 +  * Add data selection for historical values
 +  * Add total estimated energy yield in a period
 +  * Add graphics for historical values
 +  * Add Long History support & show historical maximums
 +  * Add Instant Readout on remote connections
 +  * Fix Instant Readout total yield
 +  * Fix “Installation peak power” behaviour when set values over 655kWp
-Orion XS: +Demos
-  * Add firmware v1.08 +  * VE.Bus Inverters
-    * Fix issue introduced on v1.07 that could lead to the charger failing when the battery voltage is above the output voltage target. +    * Inform that settings requires MK3-USB
-Smart BatteryProtect: +
-  * Add firmware v2.12: +
-    * Released for 12/24V-100A and 12/24V-220A only +
-    * Fix an issue where a voltage drop to 9V causes misbehavior, displaying incorrect information on the screen and occasionally disabling the output instead of keeping it enabled during the warning. +
-==== v6.20beta2 ==== +
-** 2024-12-20 ** +
-__Changes__ +
-  * Add Czech, Korean and Vietnamese translations +
-  * Add support for various upcoming new products +
-  * Fix an issue where the Trends page does not save the selected trends under certain circumstances +
-Solar Chargers:  +
-  * Fix "Charger Enabled" setting toggle may not update its state after being disabled. +
-Multi RS: +
-  * Enable setting the grid code for the first time without requiring a password +
-  * Add "PV Inverter" ESS mode +
-  * Improve NS Log handling +
-  * Fix NS log displaying incorrect time in DST time zones +
-  * Make possible to hide unused MPPT trackers (requires beta firmware) +
-MPPT RS: +
-   * Add an option to hide unused MPPT trackers (requires beta firmware) +
-Orion XS: +
-  * Add firmware v1.07 +
-    * Remote H/L now also included as a condition to pause the charge algorithm as done with low input voltage. Charge algorithm is now paused for a maximum of 2h before triggering a new charge cycle, as already done for low input voltage. If charging resumes before the 2h timeout expires, the charge algorithm is resumed from the state it was previously. +
-  * Improve overall robustness of the hardware control and internal software to increase reliability even further. +
-  * Make the battery capacity setting non-editable since the value is received from the batteries +
-==== v6.20beta1 ==== +
-** 2024-11-23 ** +
-__Changes__ +
-** New Feature: Support for Deep Links ** +
-You can now open products in VictronConnect directly from VRM by clicking the "Open in VictronConnect" button. +
-  * This feature is not yet available in VRM but will be published soon. +
-  * Currently supported only on Windows, macOS, and Linux. Support for Android and iOS will be added in a future beta release. +
-Orion XS: +
-  * Add firmware v1.06 +
-    * Fix handling of newer serial numbers that could cause conflicts with VE.Smart networking +
-EVCS: +
-  * Fixed an issue where firmware update notifications continued to appear even after completing the update. +
-  * Notify users when the EVCS is not reachable on the network before attempting a firmware update from the settings menu+
 ==== v6.19 (Released officially) ==== ==== v6.19 (Released officially) ====
victronconnect/beta.1756988559.txt.gz · Last modified: by mpalavecino
