victronconnect:beta
victronconnect:beta [2024-04-15 16:58] – [v6.01 (Released officially)] jperez | victronconnect:beta [2024-04-23 16:40] – [v6.10beta1] jperez | ||
Line 11: | Line 11: | ||
(Currently available betas are on top. See further below for official releases.) | (Currently available betas are on top. See further below for official releases.) | ||
- | ==== v6.10beta1 | + | ==== v6.10beta2 |
- | ** 2024-04-10 ** | + | ** 2024-04-23 ** |
__Download links:__ | __Download links:__ | ||
* iOS: Join TestFlight https:// | * iOS: Join TestFlight https:// | ||
Line 25: | Line 25: | ||
Notes: | Notes: | ||
* Android: If you can't open the downloaded file from the downloads list try using a file browser. | * Android: If you can't open the downloaded file from the downloads list try using a file browser. | ||
+ | * Settings Lock: When using the settings lock function, use a password that you can easily remember. Recovering a locked product from a forgotten password requires a VE.Direct USB cable or a PUK code for Bluetooth-connected products. | ||
Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. | Please report bugs and give feedback to these betas via the Disqus comments below. Please note that comments are not public by default, and first go to a moderation queue. | ||
+ | __Changes__ | ||
+ | * Fix minimum Android version required by the Google Play Store to install the app. | ||
+ | * Fix QR Qucick Connect on iOS. | ||
+ | * Add PIN code dialog when connecting to a product through QR Qucick Connect. | ||
+ | EVCS: | ||
+ | * Add firmware updating support | ||
+ | MPPT chargers: | ||
+ | * Fix settings export/ | ||
+ | ==== v6.10beta1 ==== | ||
+ | ** 2024-04-10 ** | ||
__Changes__ | __Changes__ |
victronconnect/beta.txt · Last modified: 2024-05-01 21:41 by jperez
