victronconnect:beta
victronconnect:beta [2024-03-16 23:36] – [v6.00 (Released officially)] jperez | victronconnect:beta [2024-03-18 13:31] – [v6.03 (Released officially)] jperez | ||
Line 11: | Line 11: | ||
(Currently available betas are on top. See further below for official releases.) | (Currently available betas are on top. See further below for official releases.) | ||
- | + | ==== v6.03 (Released officially) ==== | |
- | ==== v6.02 (Released officially) ==== | + | ** 2023-03-18 ** |
- | ** 2023-03-16 ** | + | |
__Download links:__ | __Download links:__ | ||
- | * iOS: [[https:// | + | * iOS: [[https:// |
* macOS [[https:// | * macOS [[https:// | ||
* Android: If you can't open the downloaded file from the downloads list try using a file browser. | * Android: If you can't open the downloaded file from the downloads list try using a file browser. | ||
+ | __Changes__ | ||
+ | VE.Bus inverter/ | ||
+ | * Fix settings of individual units of a configured parallel of multi phase system can't be accessed | ||
+ | ==== v6.02 (Released officially) ==== | ||
+ | ** 2023-03-16 ** | ||
__Changes__ | __Changes__ | ||
Line 125: | Line 133: | ||
* Add all set of settings that are currently available via the web interface. | * Add all set of settings that are currently available via the web interface. | ||
- | BMV-712 & SmartShunt: | + | BMV-712, BMV-710h |
* Add firmware v4.16 update: | * Add firmware v4.16 update: | ||
* Fix: settings lock key& | * Fix: settings lock key& |
victronconnect/beta.txt · Last modified: 2024-05-01 21:41 by jperez
