venus-os:remote_ve.bus_firmware_updates [2023-06-15 15:00] – Add Error 733 desciption jpasop | venus-os:remote_ve.bus_firmware_updates [2023-10-04 11:03] (current) – Add exception for Multi/Quattro with VE.Bus BMS V2 sloges | ||
Line 37: | Line 37: | ||
==== 2.2 Disconnect VE.Bus BMS and/or Digital Multi Control ==== | ==== 2.2 Disconnect VE.Bus BMS and/or Digital Multi Control ==== | ||
- | It is not possible to update a VE.Bus inverter, or inverter/ | + | It is not possible to update a VE.Bus inverter, or inverter/ |
+ | This exception does not apply to a MultiPlus or Quattro with VE.Bus BMS V2. In such systems, a remote firmware update of the VE.Bus inverter or inverter/ | ||
Error 734, “Cannot update with DMC or VE.Bus BMS connected” will be shown during the process when attempting to update such system. No settings or firmware is altered at the time, the system will remain operational. | Error 734, “Cannot update with DMC or VE.Bus BMS connected” will be shown during the process when attempting to update such system. No settings or firmware is altered at the time, the system will remain operational. | ||
Line 119: | Line 120: | ||
The most common reasons are: | The most common reasons are: | ||
^ Message ^ Description ^ | ^ Message ^ Description ^ | ||
- | | vbdup failed with exit code 54 | Failed to start Update. The file has an incompatible version number. \\ Please | + | | vbdup failed with exit code 54 | Failed to start Update. The file has an incompatible version number. \\ Please update |
| vbdup failed with exit code 123 | One or more firmware file(s) supplied do not match the connected device models. | | | vbdup failed with exit code 123 | One or more firmware file(s) supplied do not match the connected device models. | | ||
venus-os/remote_ve.bus_firmware_updates.1686834033.txt.gz · Last modified: 2023-06-15 15:00 by jpasop
