| venus-os:remote_ve.bus_firmware_updates [2021-03-31 11:04] – [5. Error codes & trouble shooting] mvader | venus-os:remote_ve.bus_firmware_updates [2025-09-19 09:42] (current) – jpasop | ||
| Line 1: | Line 1: | ||
| ======= Remote VE.Bus firmware updates ======= | ======= Remote VE.Bus firmware updates ======= | ||
| - | This document is a draft version of the new Remote VE.Bus firmware update feature. Once officially released, this must be included into the main [[https:// | + | ===== 1. Introduction and limitations ===== |
| - | ===== 1. Firmware and hardware requirements ===== | + | ==== 1.1 Introduction |
| - | * Minimum installed VE.Bus | + | This feature allows remotely updating the firmware |
| - | * There must be no VE.Bus BMS installed. | + | |
| - | * GX Device minimum | + | |
| - | * In case of a CCGX, it must have serial number HQ1707 or newer. | + | |
| - | * In case of another GX Device, | + | |
| - | * Venus OS firmware must be 2.65 or later, | + | |
| - | * Two Way Communication must be enabled in the VRM menu of the GX device | + | |
| + | The inverter/ | ||
| - | In case either | + | This procedure includes migration of the settings. |
| There is no limitation on the type of system: single unit systems, parallel, split-phase, | There is no limitation on the type of system: single unit systems, parallel, split-phase, | ||
| - | In case a VE.Bus BMS installed, | + | It is not required to keep your Victron equipment updated to the latest firmware version. Stable systems should be left with their current firmware. Firmware updates should only be done when it is recommended to fix an issue you are experiencing, |
| + | ==== 1.2 Limitations and requirements ==== | ||
| + | * Minimum already installed VE.Bus firmware version must be 426 | ||
| + | * There must be no VE.Bus BMS connected to the VE.Bus network, and also no Digital Multi Control (DMC) panel. See section 2.2 for more information. | ||
| + | * In case of a Color Control GX (CCGX), | ||
| + | * In case of another GX Device, ie. a Cerbo, Venus GX, or otherwise, there is no minimum hardware version - they all meet the requirements. | ||
| + | * Venus OS firmware must be 2.65 or later. | ||
| + | * The '' | ||
| ===== 2. Preparations ===== | ===== 2. Preparations ===== | ||
| Line 25: | Line 30: | ||
| An AC-Coupled PV-Inverter is a PV Inverter connected to the AC out of the Victron Inverter. | An AC-Coupled PV-Inverter is a PV Inverter connected to the AC out of the Victron Inverter. | ||
| - | To make sure no overcharging occurs, disable AC-Coupled PV Inverters. For example by having someone local to the system disconnect its solar input, or if it has an on/off switch: switch it off. Alternatively, | + | To make sure no overcharging occurs, disable AC-Coupled PV Inverters. For example by having someone local to the system disconnect its solar input, or if it has an on/off switch: switch it off. Alternatively, |
| - | Why? After the firmware update, | + | The reason for having to do this is that the system will start-up while configured |
| ==== 2.2 Disconnect VE.Bus BMS and/or Digital Multi Control ==== | ==== 2.2 Disconnect VE.Bus BMS and/or Digital Multi Control ==== | ||
| - | It is not possible to update a VE.Bus inverter, or inverter/ | + | It is not possible to update a VE.Bus inverter, or inverter/ |
| + | This exception does not apply to a MultiPlus or Quattro with VE.Bus BMS V2. In such systems, a remote firmware update of the VE.Bus inverter or inverter/ | ||
| Error 734, “Cannot update with DMC or VE.Bus BMS connected” will be shown during the process when attempting to update such system. No settings or firmware is altered at the time, the system will remain operational. | Error 734, “Cannot update with DMC or VE.Bus BMS connected” will be shown during the process when attempting to update such system. No settings or firmware is altered at the time, the system will remain operational. | ||
| Line 48: | Line 54: | ||
| NOTE: we're currently still improving this use case. Once completed, the VRM Portal will keep trying to connect for a reasonable time compared to the number of devices that need updating. Which it will do in a manner where its clear for the user that there is no reason (yet) to worry. All this will be completed before official release. The FAQ entry will stay in case something does go wrong. | NOTE: we're currently still improving this use case. Once completed, the VRM Portal will keep trying to connect for a reasonable time compared to the number of devices that need updating. Which it will do in a manner where its clear for the user that there is no reason (yet) to worry. All this will be completed before official release. The FAQ entry will stay in case something does go wrong. | ||
| ==== 2.4 Be 100% sure that the GX Device is not powered by the inverter ==== | ==== 2.4 Be 100% sure that the GX Device is not powered by the inverter ==== | ||
| Line 55: | Line 62: | ||
| Careful: this is not automatically verified in any way. | Careful: this is not automatically verified in any way. | ||
| + | Testing this on site is easy: switch the inverter off. In case the GX Device remains powered: OK. If not, not OK. | ||
| ==== 2.5 Have the latest VEConfigure Tools ==== | ==== 2.5 Have the latest VEConfigure Tools ==== | ||
| Line 60: | Line 69: | ||
| The latest version available on our website includes the necessary features. If you start VEConfigure or VE.Bus System Configurator while connected to the internet, it will automatically check and update itself when necessary. | The latest version available on our website includes the necessary features. If you start VEConfigure or VE.Bus System Configurator while connected to the internet, it will automatically check and update itself when necessary. | ||
| - | Not having the latest | + | Not having the latest |
| - | ===== 3. Procedure ===== | + | ===== 3. Step by Step Procedure |
| The inverter/ | The inverter/ | ||
| - | Here is a video the demonstrates the process: | + | This video demonstrates the process: |
| {{vimeo> | {{vimeo> | ||
| - | __First stage__ | + | ==== 3.1 Checking installed version ==== |
| - | The first stage consists of the following steps: | + | |
| - | - Confirm Two Way Communication is enabled in the VRM menu of the GX device | + | In the VRM Portal, go to the Device List page, and click the Firmware update button at the bottom of the page. The system will now search for connected devices and once completed show the result: |
| - | - Open VRM -> Device list for the site you wish to update | + | |
| - | - Click the Firmware update button at the bottom of the device list of VRM | + | {{ :venus-os: |
| - | - Click the Update Firmware button on the VE.Bus device you wish to update | + | |
| - | - The new firmware file is then uploaded to the GX Device. | + | ==== 3.2 First stage - retrieving current configuration & doing the update ==== |
| + | Once the command is given to update | ||
| + | - The new firmware file is uploaded to the GX Device. | ||
| - The configuration is retrieved from the VE.Bus system. | - The configuration is retrieved from the VE.Bus system. | ||
| - | - The inverter is switched off and its firmware is updated. | + | - The inverter is switched off and its firmware is updated. |
| - | - After the firmware update is completed, the settings will be reset to defaults | + | - After the firmware update is completed, the inverter is switched on again. The settings will have been reset to their defaults. And, to prevent overcharging, |
| + | Now, the inverter is powered up, configured with default settings. In case the internet | ||
| + | At this point, the web browser shows below message. Note the downloaded settings template on the lower right: | ||
| + | ==== 3.3 Second stage - converting and restoring configuration ==== | ||
| + | Make sure you have the latest version of the [[https:// | ||
| + | The settings template will need to be converted. It should be a .RVMS file in your download folder (it is saved during the update procedure). Open it by double clicking. If the VE.Bus tools are correctly installed, it will then open in VE.Bus System Configurator, | ||
| + | Close VEConfigure (X on upper right of the window), which will automatically prompt saving that converted file: | ||
| - | At this moment the first stage is complete. | + | {{ : |
| - | __Second stage__ | + | Now upload |
| - | Now, you’ll need to open the file that was automatically downloaded for you from VRM in VE.Bus System Configurator by double clicking it. Immediately, the settings will be converted | + | |
| - | __Third stage__ | + | This step will restore the charge |
| - | On VRM, go to Device List -> Remote VEConfigure and there use the Upload feature to upload the settings. | + | |
| ===== 5. Error codes & trouble shooting ===== | ===== 5. Error codes & trouble shooting ===== | ||
| + | === Error 733 === | ||
| + | This error is generated by the updater logic on the GX device. It show the reason why a firmware update failed. The Error 733 message box will contain an error message with or without a code. | ||
| - | === mk2vsc-55 === | + | The most common reasons are: |
| + | ^ Message ^ Description ^ | ||
| + | | vbdup failed with exit code 54 | Failed to start Update. The file has an incompatible version number. \\ Please update your Venus OS version to the latest version | | ||
| + | | vbdup failed with exit code 111 | The bootblock is incompatible this version of the updater. | ||
| + | | vbdup failed with exit code 123 | One or more firmware file(s) supplied do not match the connected device models. | | ||
| + | | vbdup failed with exit code 129 | The supplied firmware is below the minimum allowed firmware version. \\ (Downgrade to this firmware version is rejected) | | ||
| + | === Error 1342 - Not updatable === | ||
| + | This errors shows in case either the minimum installed firmware is from before 426, or there is a CCGX installed which has too old hardware. | ||
| + | The already installed firmware version can be see here, the encircled number must be above 426. | ||
| + | How to check if the CCGX is new enough, see FAQ Q2. | ||
| + | === VEConfigure tools File corrupt error === | ||
| + | Most likely you are opening the file in the wrong way: double click the file to open it. | ||
| + | Or, the installed version is too old. See above for minimum required VEConfigure / VE.Bus System Configurator tools version. | ||
| + | === mk2vsc-45 - Uploaded file does not contain settings data for the connected unit === | ||
| + | Each inverter/ | ||
| + | Note that this error should never occur, error 47 or 48 will happen instead. | ||
| + | === mk2vsc-46 - Uploaded file does not match model and/or installed firmware version === | ||
| + | To remotely update a systems settings, the full seven digit number in the file must match the system, worded differently: | ||
| + | * its not possible to take settings from a 3kVA and then upload it to a 5kVA model. | ||
| + | * its not possible to store settings from a system having version 479. Then update that system to 481, and then restore the settings by uploading that earlier saved file. Instead, use the merge function, see elsewhere in this manual. | ||
| + | === mk2vsc-47 - More than one unknown unit detected === | ||
| + | This error applies to systems consisting if multiple units, ie. parallel-, split- or three-phase systems. | ||
| + | In case one unit of such a system must be replaced, that can be done. The steps involved are: | ||
| + | - Read the configuration of the whole system (or use an existing Remote VEConfigure file) | ||
| + | - Physically replace the failed unit | ||
| + | - Write the configuration. At this step the system will automatically detect that a previous device is missing, and it will discover a new device with an unknown serial number. It will assume that the new device is a replacement, | ||
| + | - (optionally) Read the new configuration file and store in your records. | ||
| + | Note that before starting above, make sure to update the new unit to the same version of VE.Bus firmware, which unfortunately can’t be done remotely. | ||
| + | Solution: go onsite and use VE.Bus Quick Configure or VE.Bus System Configurator to reconfigure the system. | ||
| + | === mk2vsc-48 - Updating a single unit with another unit's settings is not possible, even if they are of the same type === | ||
| + | There is a way: for the system that you want to configure, first do a Remote VEConfigure download, then open that file by double clicking it. Now in the menu of VEConfigure use Load settings option, and select the file of the system whose settings you want to copy. | ||
| + | === mk2vsc-55 | ||
| Error mk2vsc-55 can happen for two reasons. In case it happens while doing a remote firmware update, it typically | Error mk2vsc-55 can happen for two reasons. In case it happens while doing a remote firmware update, it typically | ||
| - | 1) After the firmware update, but still during stage 1, something went wrong. For example VRM lost connection to the site for too long because of bad internet. | + | 1) After the firmware update, but still during stage 1, something went wrong. For example VRM lost connection to the site for too long because of bad internet. |
| + | 2) The uploaded | ||
| - | 2) The uploaded file is for a different product type. The target number, for example 2659, does not match. | + | Note that from Venus OS v2.66 onwards, this error will not occur. Errors 45, 46, 47 and 48 have replaced it. |
| === mk2vsc-59 - file uploaded before merging in VE.Bus System Configurator === | === mk2vsc-59 - file uploaded before merging in VE.Bus System Configurator === | ||
| Line 113: | Line 201: | ||
| ===== 6. FAQ ===== | ===== 6. FAQ ===== | ||
| - | ==== Q1: What happens if the internet connection goes doen during the process? ==== | + | ==== Q1: What happens if the internet connection goes down during the process? ==== |
| - | The firmware update will complete without | + | That depends. If it goes down only for a while; and then recovers within a few minutes after the Inverters |
| - | What will go wrong is preparing | + | In case the internet |
| - | Steps to recover: | + | The firmware update will complete without |
| - | - In VRM -> Device List -> Remote VEConfigure, | + | |
| - | - Open that file by double clicking it. In case of a single unit it will open in VEConfigure. For systems consisting of multiple units, it will be opened | + | What **will** go wrong is the process |
| - | - Click File -> Load settings, and select | + | |
| - | - Now, the settings | + | To recover, see FAQ Q3. |
| - | - Close the file by exiting the application; | + | |
| - | - On VRM, go to Device List -> Remote VEConfigure and there use the Upload feature to upload the settings. | + | |
| + | In case you're wondering how this can work without internet: thats because first the current configuration is retrieve from the system, then the new firmware file is being uploaded to the system. And only once thats done and checked for file integrity, the actual firmware update starts. | ||
| ==== Q2: How to see if a CCGX hardware version matches the required minimal version ==== | ==== Q2: How to see if a CCGX hardware version matches the required minimal version ==== | ||
| Line 138: | Line 225: | ||
| It needs to say MK3. Above screenshot is from a CCGX which hardware is too old to perform remote VE.Bus firmware updates. | It needs to say MK3. Above screenshot is from a CCGX which hardware is too old to perform remote VE.Bus firmware updates. | ||
| + | ==== Q3: Merging files: how to recover the old settings when something went wrong ==== | ||
| + | - In VRM -> Device List -> Remote VEConfigure, | ||
| + | - Use the merge function in VE.Bus System Configurator: | ||
venus-os/remote_ve.bus_firmware_updates.1617188695.txt.gz · Last modified: by mvader
