venus-os:remote_ve.bus_firmware_updates [2021-04-20 09:53] – [2.5 Have the latest VEConfigure Tools] iburger | venus-os:remote_ve.bus_firmware_updates [2023-06-23 09:33] – jpasop | ||
Line 12: | Line 12: | ||
There is no limitation on the type of system: single unit systems, parallel, split-phase, | There is no limitation on the type of system: single unit systems, parallel, split-phase, | ||
+ | It is not required to keep your Victron equipment updated to the latest firmware version. Stable systems should be left with their current firmware. Firmware updates should only be done when it is recommended to fix an issue you are experiencing, | ||
==== 1.2 Limitations and requirements ==== | ==== 1.2 Limitations and requirements ==== | ||
Line 67: | Line 69: | ||
Not having the latest version of VEConfigure Tools installed will result in an error when opening the file. | Not having the latest version of VEConfigure Tools installed will result in an error when opening the file. | ||
- | ===== 3. Procedure ===== | + | |
+ | ===== 3. Step by Step Procedure | ||
The inverter/ | The inverter/ | ||
Line 98: | Line 101: | ||
==== 3.3 Second stage - converting and restoring configuration ==== | ==== 3.3 Second stage - converting and restoring configuration ==== | ||
- | Convert the settings template by opening it in VE.Bus System Configurator. Do make sure you have the latest version installed. | + | Make sure you have the latest version |
- | Next, upload | + | The settings template will need to be converted. It should be a .RVMS file in your download folder (it is saved during the update procedure). Open it by double clicking. If the VE.Bus tools are correctly installed, it will then open in VE.Bus System Configurator, |
+ | Close VEConfigure (X on upper right of the window), which will automatically prompt saving that converted file: | ||
+ | Now upload the converted file. On the VRM Portal, go to the Device List -> Remote VEConfigure menu -> ' | ||
+ | This step will restore the charge | ||
===== 5. Error codes & trouble shooting ===== | ===== 5. Error codes & trouble shooting ===== | ||
+ | === Error 733 === | ||
+ | This error is generated by the updater logic on the GX device. It show the reason why a firmware update failed. The Error 733 message box will contain an error message with or without a code. | ||
+ | The most common reasons are: | ||
+ | ^ Message ^ Description ^ | ||
+ | | vbdup failed with exit code 54 | Failed to start Update. The file has an incompatible version number. \\ Please update your Venus OS version to the latest version | | ||
+ | | vbdup failed with exit code 123 | One or more firmware file(s) supplied do not match the connected device models. | | ||
=== Error 1342 - Not updatable === | === Error 1342 - Not updatable === |
venus-os/remote_ve.bus_firmware_updates.txt · Last modified: 2023-10-04 11:03 by sloges
