venus-os:remote_ve.bus_firmware_updates [2021-04-19 15:24] – [3.2 First stage - retrieving current configuration & doing the update] mvader | venus-os:remote_ve.bus_firmware_updates [2021-05-04 02:38] – [3.3 Second stage - converting and restoring configuration] guystewart | ||
Line 66: | Line 66: | ||
The latest version available on our website includes the necessary features. If you start VEConfigure or VE.Bus System Configurator while connected to the internet, it will automatically check and update itself when necessary. | The latest version available on our website includes the necessary features. If you start VEConfigure or VE.Bus System Configurator while connected to the internet, it will automatically check and update itself when necessary. | ||
- | Not having the latest | + | Not having the latest |
- | ===== 3. Procedure ===== | + | ===== 3. Step by Step Procedure |
The inverter/ | The inverter/ | ||
Line 99: | Line 99: | ||
==== 3.3 Second stage - converting and restoring configuration ==== | ==== 3.3 Second stage - converting and restoring configuration ==== | ||
- | Convert the settings template by opening it in VE.Bus System Configurator. Do make sure you have the latest version installed. | + | Make sure you have the latest version |
- | Next, upload it to the system. Use the VRM Device List -> Remote VEConfigure menu. This step will also restore the charge | + | The settings template will need to be converted. It should be a .RVMS file in your download folder (it is saved during the update procedure). Open it by double clicking. If the VE.Bus tools are correctly installed, it will then open in VE.Bus System Configurator, |
+ | Save that converted file, then upload it to VRM. | ||
+ | This is done via the VRM Device List -> Remote VEConfigure menu -> ' | ||
+ | This step will restore the charge | ||
===== 5. Error codes & trouble shooting ===== | ===== 5. Error codes & trouble shooting ===== |
venus-os/remote_ve.bus_firmware_updates.txt · Last modified: 2023-10-04 11:03 by sloges
