venus-os:remote_ve.bus_firmware_updates [2024-11-15 10:37] – [1.2 Limitations and requirements] guy_stewartvenus-os:remote_ve.bus_firmware_updates [2025-09-19 11:42] (current) jpasop
Line 121: Line 121:
 ^ Message ^ Description ^  ^ Message ^ Description ^
 | vbdup failed with exit code 54  | Failed to start Update. The file has an incompatible version number. \\ Please update your Venus OS version to the latest version |  | vbdup failed with exit code 54  | Failed to start Update. The file has an incompatible version number. \\ Please update your Venus OS version to the latest version |
 +| vbdup failed with exit code 111 | The bootblock is incompatible this version of the updater.  \\ Please update your Venus OS version to the latest version |
 | vbdup failed with exit code 123 | One or more firmware file(s) supplied do not match the connected device models. | | vbdup failed with exit code 123 | One or more firmware file(s) supplied do not match the connected device models. |
- +| vbdup failed with exit code 129 | The supplied firmware is below the minimum allowed firmware version. \\ (Downgrade to this firmware version is rejected) |
venus-os/remote_ve.bus_firmware_updates.txt · Last modified: by jpasop
