venus-os:mfd-raymarine
venus-os:mfd-raymarine [2023-04-13 13:57] – [7. NMEA 2000] mvader | venus-os:mfd-raymarine [2023-06-22 19:32] (current) – Removed and linked to corresponding GX manual chapter sloges | ||
====== Raymarine MFD Integration ====== | ====== Raymarine MFD Integration ====== | ||
- | ===== 1. Introduction ===== | + | https:// |
- | This document explains how to connect to Raymarine MFDs using an Ethernet connection. Also, the last chapter explains the Raymarine specifics when connecting on NMEA2000. | + | |
- | The integration technology used is called [[http:// | + | |
- | Note that there is an alternative method to connect, which is NMEA2000. See the [[https://www.victronenergy.com/ | + | |
- | The MFD integration is compatible with the Axiom, Axiom Pro and Axiom XL MFDs running on LightHouse 3. The eS & gS Series multifunction displays which have been upgraded to LightHouse 3 are **not** compatible. | + | |
- | Raymarine MFDs need at least LightHouse v3.11 for compatibility, | + | |
- | From Victron side, all GX devices (Cerbo GX, CCGX, Venus GX, and so forth) can be used and are compatible. For details on detailed product compatibility with regarding to inverter/ | + | |
- | The MFD needs to be connected to the [[https:// | + | |
- | The RayNet adapters can be purchased from Raymarine: | + | |
- | * A62360 | + | |
- | * A80151 - RayNet (F) to RJ45 (M) - 3m | + | |
- | * A80159 - RayNet (F) to RJ45 (M) - 10m | + | |
- | * A80247 - RayNet (F) to RJ45 (F) Adapter | + | |
- | * A80513 - RayNet male to RJ45 adaptor cable | + | |
- | To connect the [[https:// | + | |
- | :!: Connecting a Axiom MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server in the Axiom MFD. | + | |
- | :!: It is not possible to use a [[https:// | + | |
- | **Note: As of Raymarine LightHouse v3.15, there is an option to toggle DHCP. Disabling this option does not mean that the Axiom MFD will work with third party network routers. See [[https:// | + | |
- | On the Victron GX Device, go to //Settings → Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | + | |
- | {{:venus-os:venus-html5-mqtt.png? | + | |
- | Next, go to Menu -> Settings -> System Setup -> Battery Measurements. And there set up what batteries you want to see on the MFD; and by what name. | + | |
- | No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | + | |
- | ===== 5. Configuring Multiple Battery Measurements ===== | + | |
- | This video explains how to setup multiple battery measurements, | + | |
- | {{youtube> | + | |
- | ===== 6. Step by Step ===== | + | |
- | After connecting the Ethernet cable the GX device receives an IP number from the Axiom DHCP. | + | |
- | If you start the Victron App on the Axiom and it shows " | + | |
- | ===== 7. NMEA 2000 ===== | + | |
- | Besides connecting over ethernet, a Raymarine MFD can also be connected to the Victron system using NMEA 2000. If you’re new to NMEA2000 & Victron, start with reading the [[ve.can: | + | |
- | This chapter explains the specifics of NMEA2000 when connecting Victron to a Raymarine MFD. | + | |
- | === 7.1. Generic and supported PGNs === | + | |
- | To setup the data sources on the Raymarine, go to //Settings > Network > Sources > Advanced...// | + | |
- | If you have more than 1 battery be sure to adjust the settings of the Axiom to the correct amount of battery(banks). | + | |
- | The following Victron related PGNs are supported by Raymarine: | + | |
- | * 127505 - Fluid level (tank levels) | + | |
- | * 127506 - DC Detailed Status (State-of-charge, | + | |
- | * 127507 - Charger status | + | |
- | * 127508 - Battery Status (Battery Voltage, Battery Current) | + | |
- | * 127509 - Inverter status | + | |
- | This PGN is not supported by Raymarine: | + | |
- | * J1939 - AC data | + | |
- | When the NMEA2000/ | + | |
- | === 7.2. Instancing requirements when using Raymarine === | + | |
- | Fluid instancing details: | + | |
- | * Raymarine i70: max number of tank levels is 5; fluid instance 0-4. | + | |
- | * Raymarine i70s: max number of tank levels is 5; fluid instance 0-4. | + | |
- | * Axiom MFDs: per Lighthouse version 4.1.75, a maximum of 16 tanks can be connected; fluid instance 0-15. | + | |
- | ==== LightHouse 4.1.75 and newer versions ==== | + | |
- | As of LightHouse version 4.1.75, the battery instances no longer need to be unique. This means that you can leave the battery instance to its default value, which is typically set to 0. The batteries are automatically detected by the Axiom display. | + | |
- | ==== LightHouse 4.1.74 and prior versions ==== | + | |
- | If there are more than 1 (for example) SmartShunts in the NMEA2000 network, or a Solar Charger and a SmartShunt, or any other device that transmits the same type of PGNs, then the Data instances of those PGNs need to changed to make each data instance unique. | + | |
- | Typically this concerns the Battery instance, used in the Battery Status and DC Detailed PGNs. | + | |
- | See here for how to do that: [[https:// | + |
