venus-os:mfd-raymarine
venus-os:mfd-raymarine [2023-04-13 13:57] – [7. NMEA 2000] mvader | venus-os:mfd-raymarine [2023-04-13 20:50] – [7. NMEA 2000] mvader | ||
Line 93: | Line 93: | ||
Fluid instancing details: | Fluid instancing details: | ||
- | * Raymarine i70: max number of tank levels is 5; fluid instance 0-4. | + | * Raymarine i70: max number of tank levels is 5; fluid instance 0-4 and type must be fuel. |
- | * Raymarine i70s: max number of tank levels is 5; fluid instance 0-4. | + | * Raymarine i70s: max number of tank levels is 5; fluid instance 0-4 and type must be fuel. |
* Axiom MFDs: per Lighthouse version 4.1.75, a maximum of 16 tanks can be connected; fluid instance 0-15. | * Axiom MFDs: per Lighthouse version 4.1.75, a maximum of 16 tanks can be connected; fluid instance 0-15. | ||
