venus-os:mfd-raymarine
venus-os:mfd-raymarine [2021-12-09 19:21] – [7. NMEA 2000] mvader | venus-os:mfd-raymarine [2023-03-01 16:42] – [6. Step by Step] mbosma | ||
Line 34: | Line 34: | ||
:!: It is not possible to use a [[https:// | :!: It is not possible to use a [[https:// | ||
+ | **Note: As of Raymarine LightHouse v3.15, there is an option to toggle DHCP. Disabling this option does not mean that the Axiom MFD will work with third party network routers. See [[https:// | ||
On the Victron GX Device, go to //Settings → Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | On the Victron GX Device, go to //Settings → Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | ||
Line 62: | Line 64: | ||
{{youtube> | {{youtube> | ||
- | After connecting the Ethernet cable the GX device receives an IP number | + | After connecting the Ethernet cable the GX device receives an IP number from the Axiom DHCP. |
If you start the Victron App on the Axiom and it shows " | If you start the Victron App on the Axiom and it shows " | ||
===== 7. NMEA 2000 ===== | ===== 7. NMEA 2000 ===== |
