venus-os:mfd-raymarine
venus-os:mfd-raymarine [2021-05-16 21:51] – [3. Wiring] mvader | venus-os:mfd-raymarine [2023-06-22 19:32] (current) – Removed and linked to corresponding GX manual chapter sloges | ||
====== Raymarine MFD Integration ====== | ====== Raymarine MFD Integration ====== | ||
- | ===== 1. Introduction ===== | + | https:// |
- | This document explains how to connect to Raymarine MFDs using an Ethernet connection. Also, the last chapter explains the Raymarine specifics when connecting on NMEA2000. | + | |
- | The integration technology used is called [[http:// | + | |
- | Note that there is an alternative method to connect, which is NMEA2000. See the [[https://www.victronenergy.com/live/ | + | |
- | The MFD integration is compatible with the Axiom, Axiom Pro and Axiom XL MFDs running on LightHouse 3. The eS & gS Series multifunction displays which have been upgraded to LightHouse 3 are **not** compatible. | + | |
- | Raymarine MFDs need at least LightHouse v3.11 for compatibility, | + | |
- | From Victron side, all GX devices (Cerbo GX, CCGX, Venus GX, and so forth) can be used and are compatible. For details on detailed product compatibility with regarding to inverter/ | + | |
- | The MFD needs to be connected to the [[https:// | + | |
- | The RayNet adapters can be purchased from Raymarine: | + | |
- | * A62360 | + | |
- | * A80151 - RayNet (F) to RJ45 (M) - 3m | + | |
- | * A80159 - RayNet (F) to RJ45 (M) - 10m | + | |
- | * A80247 - RayNet (F) to RJ45 (F) Adapter | + | |
- | * A80513 - RayNet male to RJ45 adaptor cable | + | |
- | To connect the [[https:// | + | |
- | :!: Connecting a Axiom MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server in the Axiom MFD. | + | |
- | :!: It is not possible to use a [[https:// | + | |
- | On the Victron GX Device, go to //Settings → Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | + | |
- | Next, go to //Settings → System Setup → Scroll to the bottom → Marine MFD App configuration// | + | |
- | {{:venus-os:venus-html5-batteries2.png? | + | |
- | No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | + | |
- | ===== 5. Configuring Multiple Battery Measurements ===== | + | |
- | This video explains how to setup multiple battery measurements, | + | |
- | {{youtube> | + | |
- | ===== 6. Step by Step ===== | + | |
- | {{:venus-os: | + | |
- | After connecting the Ethernet cable the GX device receives an IP number (10.x.x.x) from the Axiom DHCP. | + | |
- | If you start the Victron App on the Axiom and it shows " | + | |
- | ===== 7. NMEA 2000 ===== | + | |
- | A Raymarine MFD can also be connected to the Victron system using NMEA 2000. If you’re new to NMEA2000 & Victron, start with reading the [[ve.can: | + | |
- | This chapter explains the specifics of NMEA2000 when connecting Victron to a Raymarine MFD. | + | |
- | If there are more than 1 (for example) SmartShunt in the NMEA2000 network then you change the Data instances of the Victron PGNs to make the 2nd device can be seen too. See here for how to do that: [[https:// | + | |
- | To setup the data sources on the Raymarine, go to //Settings > Network > Sources > Advanced...// | + | |
- | If you have more than 1 battery be sure to adjust the settings of the Axiom to the correct amount of battery(banks). | + | |
- | The following Victron related PGNs are supported: | + | |
- | * 127505 - Fluid level (tank levels) | + | |
- | * 127506 - DC Detailed Status (State-of-charge, | + | |
- | * 127508 - Battery Status (Battery Voltage, Battery Current) | + | |
- | When the NMEA2000/ | + | |
- | Below list of Victron related PGNs are not supported by the Raymarine, ie. in our tests we could not get such data to show on the MFD using NMEA2000 (use the Marine MFD App instead to see the same data!): | + | |
- | * J1939 - AC data | + |
