venus-os:mfd-raymarine
venus-os:mfd-raymarine [2021-04-02 06:58] – [7. NMEA 2000] mvader | venus-os:mfd-raymarine [2021-04-30 20:44] – [7. NMEA 2000] pbu | ||
Line 79: | Line 79: | ||
* 127506 - DC Detailed Status (State-of-charge, | * 127506 - DC Detailed Status (State-of-charge, | ||
* 127508 - Battery Status (Battery Voltage, Battery Current) | * 127508 - Battery Status (Battery Voltage, Battery Current) | ||
+ | When the NMEA2000/ | ||
Below list of Victron related PGNs are not supported by the Raymarine, ie. in our tests we could not get such data to show on the MFD using NMEA2000 (use the Marine MFD App instead to see the same data!): | Below list of Victron related PGNs are not supported by the Raymarine, ie. in our tests we could not get such data to show on the MFD using NMEA2000 (use the Marine MFD App instead to see the same data!): | ||
* J1939 - AC data | * J1939 - AC data |
