venus-os:mfd-raymarine
venus-os:mfd-raymarine [2021-04-01 08:50] – [7. NMEA 2000] mvader | venus-os:mfd-raymarine [2021-04-02 06:58] – [7. NMEA 2000] mvader | ||
- | This document explains how to connect to Raymarine MFDs using an Ethernet connection. | + | This document explains how to connect to Raymarine MFDs using an Ethernet connection. |
The integration technology used is called [[http:// | The integration technology used is called [[http:// | ||
Line 60: | Line 61: | ||
{{youtube> | {{youtube> | ||
+ | After connecting the Ethernet cable the GX device receives an IP number (10.x.x.x) from the Axiom DHCP. | ||
+ | If you start the Victron App on the Axiom and it shows " | ||
===== 7. NMEA 2000 ===== | ===== 7. NMEA 2000 ===== | ||
- | The MFD can also be connected to the Victron system using NMEA 2000, see the [[ve.can: | + | A Raymarine |
- | In order to properly display | + | This chapter explains |
+ | If there are more than 1 (for example) SmartShunt in the NMEA2000 network then you change the Data instances of the Victron | ||
To setup the data sources on the Raymarine, go to //Settings > Network > Sources > Advanced...// | To setup the data sources on the Raymarine, go to //Settings > Network > Sources > Advanced...// | ||
+ | If you have more than 1 battery be sure to adjust the settings of the Axiom to the correct amount of battery(banks). | ||
The following Victron related PGNs are supported: | The following Victron related PGNs are supported: |
