venus-os:mfd-raymarine
venus-os:mfd-raymarine [2021-03-15 23:51] – [7. NMEA 2000] mvader | venus-os:mfd-raymarine [2023-04-13 20:50] – [7. NMEA 2000] mvader | ||
- | This document explains how to connect to Raymarine MFDs using an Ethernet connection. | + | This document explains how to connect to Raymarine MFDs using an Ethernet connection. |
The integration technology used is called [[http:// | The integration technology used is called [[http:// | ||
Line 30: | Line 31: | ||
To connect the [[https:// | To connect the [[https:// | ||
- | :!: Connecting a Axiom MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. | + | :!: Connecting a Axiom MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server |
- | :!: It is not possible to use a [[https:// | + | :!: It is not possible to use a [[https:// |
+ | **Note: As of Raymarine LightHouse v3.15, there is an option to toggle DHCP. Disabling this option does not mean that the Axiom MFD will work with third party network routers. See [[https:// | ||
On the Victron GX Device, go to //Settings → Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | On the Victron GX Device, go to //Settings → Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | ||
- | Next, go to //Settings | + | |
+ | Next, go to Menu -> Settings | ||
Line 60: | Line 64: | ||
{{youtube> | {{youtube> | ||
+ | After connecting the Ethernet cable the GX device receives an IP number from the Axiom DHCP. | ||
+ | If you start the Victron App on the Axiom and it shows " | ||
===== 7. NMEA 2000 ===== | ===== 7. NMEA 2000 ===== | ||
- | The MFD can also be connected to the Victron system using NMEA 2000, see the [[ve.can: | + | Besides connecting over ethernet, a Raymarine |
- | In order to properly display | + | This chapter explains |
+ | === 7.1. Generic and supported PGNs === | ||
To setup the data sources on the Raymarine, go to //Settings > Network > Sources > Advanced...// | To setup the data sources on the Raymarine, go to //Settings > Network > Sources > Advanced...// | ||
- | The following Victron related PGNs are supported: | + | If you have more than 1 battery be sure to adjust the settings of the Axiom to the correct amount of battery(banks). |
+ | The following Victron related PGNs are supported | ||
* 127505 - Fluid level (tank levels) | * 127505 - Fluid level (tank levels) | ||
* 127506 - DC Detailed Status (State-of-charge, | * 127506 - DC Detailed Status (State-of-charge, | ||
+ | * 127507 - Charger status | ||
* 127508 - Battery Status (Battery Voltage, Battery Current) | * 127508 - Battery Status (Battery Voltage, Battery Current) | ||
+ | * 127509 - Inverter status | ||
- | These Victron related PGNs are not supported by the Raymarine, ie. in our tests we could not get such data to show on the MFD using NMEA2000 (use the Marine MFD App instead!): | + | This PGN is not supported by Raymarine: |
* J1939 - AC data | * J1939 - AC data | ||
+ | When the NMEA2000/ | ||
+ | === 7.2. Instancing requirements when using Raymarine === | ||
+ | Fluid instancing details: | ||
+ | * Raymarine i70: max number of tank levels is 5; fluid instance 0-4 and type must be fuel. | ||
+ | * Raymarine i70s: max number of tank levels is 5; fluid instance 0-4 and type must be fuel. | ||
+ | * Axiom MFDs: per Lighthouse version 4.1.75, a maximum of 16 tanks can be connected; fluid instance 0-15. | ||
+ | ==== LightHouse 4.1.75 and newer versions ==== | ||
+ | As of LightHouse version 4.1.75, the battery instances no longer need to be unique. This means that you can leave the battery instance to its default value, which is typically set to 0. The batteries are automatically detected by the Axiom display. | ||
+ | ==== LightHouse 4.1.74 and prior versions ==== | ||
+ | If there are more than 1 (for example) SmartShunts in the NMEA2000 network, or a Solar Charger and a SmartShunt, or any other device that transmits the same type of PGNs, then the Data instances of those PGNs need to changed to make each data instance unique. | ||
+ | Typically this concerns the Battery instance, used in the Battery Status and DC Detailed PGNs. | ||
+ | See here for how to do that: [[https:// |
