venus-os:mfd-raymarine
venus-os:mfd-raymarine [2020-06-27 08:07] – [1. Introduction] mvader | venus-os:mfd-raymarine [2023-06-22 19:32] (current) – Removed and linked to corresponding GX manual chapter sloges | ||
====== Raymarine MFD Integration ====== | ====== Raymarine MFD Integration ====== | ||
- | ===== 1. Introduction ===== | + | https:// |
- | This document explains how to connect to Raymarine MFDs using an Ethernet connection. | + | |
- | The integration technology used is called [[http:// | + | |
- | Note that there is an alternative method to connect, which is NMEA2000. See the [[https://www.victronenergy.com/live/ | + | |
- | The MFD integration is compatible with the Axiom, Axiom Pro and Axiom XL MFDs running on LightHouse 3. The eS & gS Series multifunction displays which have been upgraded to LightHouse 3 are **not** compatible. | + | |
- | Raymarine MFDs need at least LightHouse v3.11 for compatibility, | + | |
- | The MFD needs to be connected to the [[https:// | + | |
- | The RayNet adapters can be purchased from Raymarine: | + | |
- | * A62360 | + | |
- | * A80151 - RayNet (F) to RJ45 (M) - 3m | + | |
- | * A80159 - RayNet (F) to RJ45 (M) - 10m | + | |
- | * A80247 - RayNet (F) to RJ45 (F) Adapter | + | |
- | * A80513 - RayNet male to RJ45 adaptor cable | + | |
- | To connect the [[https:// | + | |
- | :!: Connecting a Axiom MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server. | + | |
- | :!: It is not possible to use a [[https:// | + | |
- | On the Victron GX Device, go to //Settings → Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | + | |
- | Next, go to //Settings → System Setup → Scroll to the bottom → Marine MFD App configuration// | + | |
- | No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | + | |
- | ===== 5. Configuring Multiple Battery Measurements ===== | + | |
- | This video explains how to setup multiple battery measurements, | + | |
- | {{youtube> | + | |
- | ===== 6. Step by Step ===== | + | |
- | ===== 7. NMEA 2000 ===== | + | |
- | The MFD can also be connected to the GX device using NMEA 2000, see [[https:// | + | |
- | In order to properly display the NMEA 2000 data from Victron equipment, you need to change the data instances of the PGNs that are sent out. See here for how to do that: [[https:// | + | |
- | To setup the data sources on the Raymarine, go to //Settings > Network > Sources > Advanced...// | + | |
- | The following Victron related PGNs are supported: | + | |
- | * 127505 | + | |
- | * 127506 | + | |
- | * 127508 - Battery Status (Battery Voltage, Battery Current) | + | |
- | These Victron related PGNs are not supported by the Raymarine, ie. in our tests we could not get such data to show on the MFD using NMEA2000 (use the Marine MFD App instead!): | + | |
- | * J1939 - AC data | + |
