venus-os:mfd-raymarine
venus-os:mfd-raymarine [2020-06-22 09:22] – [3. Wiring] mbosma | venus-os:mfd-raymarine [2020-06-25 17:34] – mbosma | ||
Line 58: | Line 58: | ||
{{youtube> | {{youtube> | ||
+ | The MFD can also be connected to the GX device using NMEA 2000, see [[https:// | ||
+ | In order to properly display the NMEA 2000 data from Victron equipment, you need to change the data instances of the PGNs that are sent out. See [[https:// | ||
+ | To setup the data sources on the MFD, go to //Settings > Network > Sources > Advanced...// | ||
+ | * 127508 - Battery Status |
